AMPAPA Balanced Interconnect Cable 6.35mm Jack TRS Male Shielded OFC Copper 1m (Pair)
The Ampapa 6.35mm TRS jack interconnect cable is a HiFi balanced audio cable designed to ensure perfectly stable, clean, and interference-free signal transmission. It is suitable for audiophiles, studio users, and content creators looking to get the most out of their audio equipment.
Reference : 21668
32,91 €tax incl.
27,42 € tax excl.
Shipping date: 24-11-2026.
Ampapa Balanced Interconnect Cable 6.35mm TRS Jack Male Shielded OFC Copper 0.5m (Pair)
Photo of the AMPAPA Balanced Interconnect Cable
It uses 6N (99.9999%) OFC copper conductors, ensuring excellent conductivity and faithful audio signal reproduction, with a high level of detail and extended dynamics. The 6.35mm TRS male jack connectors feature 24K gold plating to reduce contact resistance and ensure stable transmission over time.
The cable also incorporates a high-performance multi-layer shielding, including a tinned copper braid, effectively limiting EMI and RFI interference as well as unwanted noise. Its internal structure is optimized with vibration-absorbing materials to reduce handling noise.
Its robust design is based on a core made of multiple copper strands and an outer PVC jacket with nylon braiding, providing flexibility, twist resistance, and durability, withstanding more than 15,000 bending cycles.
In terms of connectivity, this model features a 6.35mm TRS male to 6.35mm TRS male connection, perfectly suited for balanced connections on DACs, amplifiers, audio interfaces, mixers, preamplifiers, or active speakers.
Key features of the AMPAPA balanced interconnect cable
Technical Specifications
Product TypeBalanced interconnect cable
Connectors6.35mm TRS Jack
Conductor Material6N OFC Copper
Connector Contact Plating24K Gold
Outer JacketPVC and braided Nylon
Length0.5m
PackagingSold as a pair
Length (m)0.5
ShieldingYes
Section (mm²)N/A
ConnectorJack 6.35mm
AMPAPA Balanced Interconnect Cable 6.35mm Jack TRS Male Shielded OFC Copper 0.5m (Pair)
The Ampapa 6.35mm TRS jack interconnect cable is a HiFi balanced audio cable designed to ensure perfectly stable, clean, and interference-free...
