LUDIC ORPHEUS INTERLINK RCA Interconnect Cable 1.5m (Pair)
The Ludic Orpheus Interlink is an RCA interconnect cable designed to transmit audio signals between your source and your amplifier with low impedance and good immunity to interference. It features an OCC copper construction combined with double shielding, preserving signal integrity whilst minimising interference in the home environment. Designed for integration into hi-fi systems, it combines conductivity, protection and connection stability to ensure a reliable link between the various components of the audio chain.
Reference : 21626
105,00 €tax incl.
87,50 € tax excl.
Ludic Orpheus Interlink RCA Interconnect Cable OCC Copper 1.5m (Pair)
Ludic Orpheus Interlink : Front view
Ludic Orpheus Interlink: OCC copper cable
The Ludic Orpheus features two OCC copper conductors with a cross-sectional area of 0.2407mm², ensuring low resistance whilst providing stable signal transmission along the entire length of the cable. The signal is protected by double shielding combining an aluminium foil layer with a tinned copper braid, effectively reducing EMI/RFI interference whilst maintaining good installation flexibility. The assembly is finished with an attractive braided cotton sheath, bringing the total cable diameter to 6mm.
Ludic Orpheus Interlink : Separator
cross section Ludic Orpheus Interlink : RCA connector
Ludic Orpheus Interlink: Gold-plated copper connectors
RCA connectors feature 24-carat gold-plated copper contacts, ensuring stable conductivity whilst minimising oxidation and corrosion over time. Their nickel-plated brass bodies enhance their mechanical strength.
Product typeInterconnect Cable
ConnectorsMale RCA
Length1.5m
Number of conductors2
Conductive materialOCC copper
Conductors cross section0.2407mm²
Outer diameter6.0mm ±0.15mm
Outer sheath materialCotton
Contact materialCopper
Contact plating24-carat gold
Body materialNickel-plated brass
PackageSold by pair
Length (m)1.5
ShieldingYes
Section (mm²)0.24
ConnectorRCA
LUDIC ORPHEUS INTERLINK RCA Interconnect Cable OCC Copper 1.5m (Pair)
The Ludic Orpheus Interlink is an RCA interconnect cable designed to transmit audio signals between your source and your amplifier with low...
