Tolerance (%)
1 % - 20 %
Capacitor capacitance (µF)
Capacitor format
Capacitor type
Rated voltage (V)
Capacitors
rodrigue Y.
Connecteur RCA
Franck M.
Franck M.
excellentissime
Capacitors
  • Polarized capacitors
  • Non-polarized capacitors
  • Capacitors accessories
