FOSI AUDIO MD3 MAGDAC Portable Magnetic DAC Headphone Amplifier Silver
The Fosi Audio MD3 MagDac is a compact portable magnetic DAC based on the use of an ESS ES9039Q2M DAC chip and no fewer than 4 ES9603Q headphone amplifier chips in a balanced configuration. Compatible with USB Audio Class UAC 2.0 and UAC 1.0, it supports up to PCM 32bit 384kHz as well as native DSD256 in UAC 2.0 mode, and up to PCM 16bit 48kHz in UAC 1.0.
Reference : 21773
159,00 €tax incl.
132,50 € tax excl.
Shipping date: 25-11-2026.
Fosi Audio MD3 MagDac Portable Magnetic DAC Headphone Amplifier ES9039Q2M 32bit 384kHz DSD256 Silver
Photo of the Fosi Audio MD3 MagDac
The Fosi Audio MD3 MagDac is a compact portable magnetic DAC based on the use of an ESS ES9039Q2M DAC chip and no fewer than 4 ES9603Q headphone amplifier chips in a balanced configuration. Compatible with USB Audio Class UAC 2.0 and UAC 1.0, it supports up to PCM 32bit 384kHz as well as native DSD256 in UAC 2.0 mode, and up to PCM 16bit 48kHz in UAC 1.0. It features two headphone outputs, a 3.5mm single-ended jack and a 4.4mm balanced jack, with an output power of ≥ 2x80mW under 32Ω in 3.5mm and ≥ 2x180mW under 32Ω in 4.4mm. Its stated performance includes a frequency response of 20Hz to 48kHz (±0.2dB), a signal-to-noise ratio of up to 116dB, a dynamic range of up to 116dB, THD+N of ≤0.00075% in 3.5mm and ≤0.00084% in 4.4mm, as well as a noise floor below 1.7µV in single-ended mode and 2.7µV in balanced mode. It is compatible with headphones and earphones from 16 to 300Ω. Its dual USB-C connectivity allows audio, image/data transfer, firmware updates, and smartphone charging during use.
Highlights of the Fosi Audio MD3 MagDac
Fosi Audio MD3 MagDac: Circular Display
Equipped with a 1.28" circular display, the Fosi Audio MD3 MagDac features fun animated images and emojis. It is also possible to customize the screen display with your own photos.
Fosi Audio MD3 MagDac: Magnetic Attachment
Sixteen high-strength N52 magnets keep the MD3 firmly attached to your phone. This avoids the need for straps and reduces clutter. An aluminum alloy insulating plate separates the PCB from the magnets, preventing any risk of magnetic interference affecting sound quality.
Overview of the Fosi Audio MD3 MagDac
1LCD Screen
2Vista Button
3Volume +
4Volume -
5Menu/Confirm
6USB-C Input (Audio Decoding/Image Transfer/Charging)
7USB-C Input (Audio Decoding/Image Transfer/Firmware Update)
83.5mm Jack Headphone Output
94.4mm Jack Headphone Output
Product typePortable DAC
DAC chipESS Sabre ES9039Q2M
Amplifier chips4x ESS ES9603Q
Inputs1x USB-C (Audio Decoding/Image Transfer/Charging)
1x USB-C (Audio Decoding/Image Transfer/Firmware Update)
Outputs1x 3.5mm single-ended Jack
1x 4.4mm balanced Jack
Compatible USB protocolUAC 1.0
UAC 2.0
Supported sample ratesUAC 1.0 : PCM 16bit 48kHz
UAC 2.0 : PCM 32bit 384kHz, DSD256
Max. output power3.5mm Jack: ≥ 2x 80mW under 32Ω
4.4mm Balanced Jack: ≥ 2x 180mW under 32Ω
Frequency response20Hz-48kHz (±0.2 dB)
SNR3.5mm Jack: ≥ 115dB
4.4mm Balanced Jack: ≥ 115dB
Dynamic range3.5mm Jack: ≥ 115dB
THD+N3.5mm Jack: ≤ 0.00075%
4.4mm Balanced Jack: ≤ 0.00084%
Noise floor3.5mm Jack: < 1.7μV
4.4mm Balanced Jack: < 2.7μV
Headphone impedance16-300Ω
Volume control100 steps
Weight50g (±2g)
Dimensions70 x 45 x 12mm
ColorSilver
Package1x Fosi Audio MD3 MagDac
OutputJack 3.5mm
OutputJack 4.4mm
DAC / ADC ChipES9039Q2M
Max sampling rateDSD256
Max sampling rate384kHz
ColorSilver
FOSI AUDIO MD3 MAGDAC Portable Magnetic DAC Headphone Amplifier ES9039Q2M 32bit 384kHz DSD256 Silver
The Fosi Audio MD3 MagDac is a compact portable magnetic DAC based on the use of an ESS...
