Want to enjoy optimal headphone listening at home? Our range of sedentary headphone amplifiers is made for you. A wide selection of headphone amplifiers for both sensitive headphones and high-impedance models.
The HiFiMAN Mini Shangri-La amplifier has been specially designed to drive electrostatic headphones. Its amplification stage uses two MOSFET transistors (metal-oxide-semiconductor field-effect transistor) in a symmetrical design. Its independent high-voltage power supply stage is equipped with an independent power supply regulator, guaranteeing perfectly...
With the Prelude, HIFIMAN presents a balanced Class A headphone amplifier based on MOSFET transistors to deliver natural sound reproduction and 10W of power at 32Ω.
With its Serenade WiFi, HIFIMAN unveils a versatile R2R DAC that also acts as a preamplifier, headphone amplifier and streamer, thanks to an RJ45 LAN port and WiFi functionality. The device was developed by HIFIMAN in collaboration with GoldenWave. It features R2R Hymalaya Pro conversion technology, as well as an XMOS XU316 USB interface and Class A...
The Holo Audio Bliss Level 1 is a discrete, high-end pure Class A headphone amplifier, offering incredible sound quality thanks to a design based on an optimized and careful architecture, using only high-end electronic components. It also allows to develop an important power of 12W under 32Ω, making it able to accompany any headphone of the market...
With its NEO iDSD 2, iFI Audio unveils an upgraded version of the NEO iDSD, fulfilling the functions of DAC / Preamplifier / Headphone Amplifier. The NEO iDSD 2 is one of the first DACs to integrate Bluetooth aptX Lossless technology. Versatile and high-performance, the NEO iDSD 2 can be used in a variety of ways: DAC/headphone amplifier, pure DAC coupled...
The iFi Audio Pro iDSD Signature is the new flagship DAC from iFi Audio, a true technology powerhouse with incredible performance. It builds on the strengths of the award-winning Pro iDSD, while offering improvements for even higher performance. The extremely versatile Pro iDSD Signature combines the functions of a DAC and preamplifier, network player and...
The iFi Audio Uno is a compact DAC and headphone amplifier that easily and efficiently enhances the sound quality of a standard digital source such as a smartphone, tablet or computer. Uno simply connects to your source device via its USB-C input and requires no additional power supply. Add headphones, powered speakers or an amplifier and passive speakers...
As the successor to the ZEN Can 2, IfI Audio's ZEN Can 3 benefits from an improved look and a number of additional features. This Class A headphone amplifier features a purely analog design, with no DSP for a more natural sound, and extended equalization parameters.
With the ZEN V3, Ifi Audio presents a new version of its successful ZEN series. The brand's ambition is still to offer a digital/analog converter offering exceptional performance at the lowest possible price. This V3 version builds on the success of its predecessor, while integrating a Burr-Brown DAC chip capable of supporting a 768 kHz sampling rate.
The J.C Acoustics UDP-5 is a DAC and headphones amplifier based on audiophile components. It features two ES9039Q2M DAC chip and an XU216 interface for support of high-resolution sampling rates up to PCM 32bit 768kHz and DSD512. It also boasts a balanced Class AB headphone amplifier circuit with four TPA6120A2 chips for output power of up to 7500mW under...
The J.C Acoustics UDP-6PRO is a DAC headphones amplifier based on audiophile components. It features an ES9039SPRO DAC chip and an XU216 XMOS USB interface for support of high-resolution sampling rates up to PCM 32bit 768kHz and DSD512. It also boasts a balanced Class AB headphone amplifier circuit with four TPA6120A2 chips for output power of up to...
With the Keces S3 you get an all-in-one device, covering the functions of DAC, preamplifier and headphone amplifier. Carefully designed with high-end components, it provides a high quality sound reproduction that is as rich and precise as it is dynamic.
LAiV's Harmony HP2A is a preamplifier and headphone amplifier meticulously designed for discerning audiophiles who demand uncompromising sound quality.
The Little Dot LD-S2 is a tube amplifier and headphone amplifier, using NOS (New Old Stock) 17BF11 tubes. It is capable of delivering 2x5W RMS power, providing the warm, round sound reproduction characteristic of this type of amplification. The unit features a terminal output for speakers and a headphone output in 6.35mm jack format.
The Little Dot MKII is a small tube headphone amplifier and preamplifier, offering musical, round and smooth sound reproduction. It features two 1J1 input tubes and two 6N6 output tubes.
The Little Dot MKIII SE, the successor to the MKIII, is a tube headphone amplifier that offers excellent audio performance with a signature specific to tube devices, namely a warm but extremely detailed sound. This version adds balanced input and output connections as well as a discrete Class A output stage.
The Little Dot MKIII is a very nice tube headphone amplifier, offering excellent audio performance. It is topped by two GE5654 tubes (United States GE) for its input circuit and two 6H6 tubes (Russia) for its output circuit.
The Little Dot Zero is a desktop DAC and headphone amplifier combo, whose amplification stage is powered by a pair of 1T4 tubes. These allow it to reveal a sound that is both warm and fine, highlighting a great musicality.
Loxjie offers its D30, a particularly powerful and affordable DAC and headphone amplifier combo, in a V2 version now equipped with an ESS ES9068AS digital/analog conversion chip. This, in association with an optimized general architecture, allows to reach a rich and precise sound restitution. It also offers full connectivity for easy integration into the...
With its D60 DAC / headphone amplifier, Loxjie offers a modern, high-performance device, carefully designed and equipped with audiophile components. It incorporates an ES9039MSPRO DAC chip with MQA decoder, as well as an XMOS XU-316 USB interface, enabling it to support sampling rates up to PCM 32bit 768kHz, DSD512 and MQA-CD. Versatile, it features...
The Luxsin X9 DAC headphone amplifier was developed by Eversolo and benefits from the brand's expertise. It incorporates top-quality components, enabling it to achieve a very high level of performance.
The successor to the Mini-I Pro 3, the Mini-I Pro 4 is a versatile, compact device offering the functions of DAC, headphone amplifier and, the latest addition to the Mini-I series, network player. Matrix has upgraded the DAC chip in the Mini-I Pro 4 to an ES9039Q2M. On the network player side, this device supports numerous broadcast protocols and...
Headphone amplifier with balanced architecture in pure class A. Drives Hhadphones from 15 to 600 Ohm with impressive signal / noise ratio of up to 131dB on its balanced output.
The Original Audio OPA-Q2.1SE is a headphone amplifier and DAC. It delivers great performance thanks to its careful design. Its various functions and its numerous inputs and outputs make it a very good all-rounder.
The Original Audio OPA-Q3.1 is a balanced Class A DAC and headphone amplifier combo. Its digital to analog conversion stage uses an ESS ES9038Q2M DAC chip known for its ability to provide accurate and transparent playback and to support high sampling rates, up to PCM 32bit 768kHz, DSD512 and DoP256. The tube headphone amplifier stage allows to develop a...
Questyle's CMA 18 MASTER DAC/headphone amplifier is a high-performance device featuring top-of-the-range components. It incorporates an ES9039PRO DAC chip and an XMOS XU-316 USB interface, enabling it to support sampling rates up to PCM 32bit 768kHz and native DSD up to DSD512.
The RT-5000 from Roseselsa is a DAC and amplifier for headphones using a pair of SABRE ES9038Pro chips and JRC MUSES01 transistors for digital/analogue conversion up to PCM 32bit 384kHz and DSD256 and an output power of 1600mW at 32Ω. These top-of-the-range components ensure quality sound reproduction that's both warm and soft, all housed in a...
Sabaj's A20d DAC and headphone amplifier returns in an improved version for 2023. It now uses two AK4499 EX + AK 4131 EQ DAC chips and an XMOS XU316 USB interface supporting 32bit 768kHZ PCM and DSD512. Featuring top-of-the-range components, it includes an MQA decoder, three AOP1612s and a TI TPA6120A2 amplifier chip. Its comprehensive connectivity means...
With its EH1, Shanling unveils a compact, high-performance desktop DAC with a modern design. It embeds a Cirrus Logic CS43198 DAC chip, enabling it to support high-resolution sampling rates up to PCM 32bit 768kHz and native DSD up to DSD512. Headphone amplification relies on two SGM8262-2 OPAs and gain control for output power of up to 2x1015mW into 32...
