Tolerance (%)
0 % - 20 %
Capacitor capacitance (µF)
Capacitor format
Capacitor type
Inductance (mh)
Power (W)
0 - 250
Rated voltage (V)
Input voltage (V)
V
V
Output voltage (V)
Output current (A)
0 A - 5 A
Rated current (A)
Resistance (Ohm)
Section (mm²)
0 mm - 1 mm
Contacts number
4 - 9
Channel
Max panel thickness
mm
mm
Color
Electronic components
Stephane G.
Incroyable !!
Je possède depuis une vingtaine d’années du Naim Audio (NAC 282 / HICAP / NAP 250.2) couplé à des ATC SCM 50 Passives.
Très...
Attention fragile
La conception est fragile et le conditionnement très sommaire : certaines des vis sont coincées dans la banane.
Egalement,...
Yves F.
Marvelous DAC
Ma configuration : Denon PMA 3000NE, streamer dmp a6 master edition gen 2 + dac holo cyan 2 (connection en USB : câble Black...
  • Capacitors
    Capacitors
  • Selfs & Coils
    Selfs & Coils
  • Resistors
    Resistors
  • Potentiometers
    Potentiometers
  • Selectors
    Selectors
  • OPA Adapters
    OPA Adapters
  • Universal circuit boards
  • Relays
    Relays
  • Fuse and Circuit breaker
  • OPA
    OPA
  • Transistors
    Transistors
  • Speaker L-control
    Speaker L-control
  • Voltage Regulator
    Voltage Regulator
  • Clocks
    Clocks
  • Light Bulbs and LED
    Light Bulbs and LED
  • Tubes and lamps
    Tubes and lamps
  • Audio Transformer
    Audio Transformer
  • 3,50 € 2,92 €Ex.
    In Stock
  • Ref : 12712
    In Stock
    This stereo potentiometer is already mounted and soldered on the card. The connectivityis installed as well.
    2,50 € 2,08 €Ex.
    In Stock
  • Ref : 18077
    In Stock
    Psvane 12AT7-S tubes offer high plate current and low noise. They are therefore particularly recommended for use with a preamplifier or phono stage.
    99,00 € 82,50 €Ex.
    In Stock
  • Ref : 14787
    In Stock
    Psvane 12AU7-S tubes offer high plate current and low noise. They are therefore particularly recommended for use on a preamplifier or phono stage. This model has the same features as its predecessor, the 12AU7-TII, but with internal structural improvements for even better performance.
    89,00 € 74,17 €Ex.
    In Stock
  • Ref : 6717
    In Stock
    The PSVane 12AX7-S / ECC83 is a high-end S-Art preamp/amp tube with very good performance and musicality. It can be used as a DIY design or as a replacement for a defective 12AX7 or ECC83 tube.
    99,00 € 82,50 €Ex.
    In Stock
  • Ref : 16009
    In Stock
    199,00 € 165,83 €Ex.
    In Stock
  • Ref : 17015
    In Stock
    The PSVane 211-TII tube is a high quality direct heated thorium-tungsten triode that can be used in class A, B and C. The MKII series tubes use a PTFE base, ensuring high stability and very good insulation. The amber colored oxidized aluminum collar surrounding the PTFE base prevents corrosion and fingerprints while giving the tube a prestigious design.
    289,00 € 240,83 €Ex.
    In Stock
  • Ref : 19104
    In Stock
    PSVANE's 274B-Z rectifier offers a soft, warm sound, full and natural, with good balance and no background noise. PSVANE offers us a tube with a more pronounced analog texture than that of classic tubes, with voices more prominent than usual and an overall sound evocative of vinyl's own texture.
    129,00 € 107,50 €Ex.
    In Stock
  • Ref : 19108
    PSVANE's 2A3-Z power tube offers a warm sound, full and natural, with good balance and no background noise. PSVANE offers us a tube with a more pronounced analog texture than that of conventional tubes, with voices more prominent than usual and an overall sound evocative of vinyl's own texture.
    159,00 € 132,50 €Ex.
    In Stock
  • Ref : 19109
    PSVANE's 300B-Z power tube offers a warm sound, full and natural, with good balance and no background noise. PSVANE offers us a tube with a more pronounced analog texture than that of conventional tubes, with voices more prominent than usual and an overall sound evocative of vinyl's own texture.
    209,00 € 174,17 €Ex.
    In Stock
  • Ref : 15457
    In Stock
    The 5881 tube is the electrical equivalent of the 6L6 and 6L6G tubes, except that the dissipation plate and screen values are increased by about 20%. The design of this tube also provides better shock and vibration resistance.
    29,90 € 24,92 €Ex.
    In Stock
  • Ref : 16522
    The PSVane 6CA7-TII MARK II is a high quality pentode tube that offers excellent sound performance for a rich and musical reproduction. This model will be able to replace advantageously a tube EL34.
    399,00 € 332,50 €Ex.
    In Stock
  • Ref : 21012
    PSVane 845-T-MII/2 tubes are high-quality triode power tubes that can be used in class A, B and C. The MKII range of tubes uses a PTFE base, ensuring high stability and excellent insulation. The amber-coloured anodised aluminium collar surrounding the PTFE base prevents corrosion and fingerprints while giving this tube a prestigious design. The tube also...
    279,00 € 232,50 €Ex.
    In Stock
  • Ref : 17149
    In Stock
    The Acme Series high power tubes offer an exceptional design to provide high quality sound. This series takes advantage of a composite metal shield pole structure, skillfully combining graphite and wire mesh, promoting a warm and transparent sound reproduction.
    949,00 € 790,83 €Ex.
    In Stock
  • Ref : 21210
    In Stock
    Psvane ACME 2A3 tubes are high-end triode power tubes offering exceptional audio performance with a typically analogue sound. This version of the 2A3 tubes features gold plating on the control grid for maximum dissipation and undergoes meticulous burn-in by Psvane.
    649,00 € 540,83 €Ex.
    In Stock
  • Ref : 21209
    In Stock
    Psvane ACME 300B tubes are high-end triode power tubes offering exceptional audio performance with a timeless analogue sound. This version of the 300B tubes features gold plating on the control grid for maximum heat dissipation and undergoes meticulous burn-in by Psvane.
    1 089,00 € 907,50 €Ex.
    In Stock
  • Ref : 16499
    In Stock
    999,00 € 832,50 €Ex.
    In Stock
  • Ref : 19010
    In Stock
    PSVANE Art KT150 is a high-end tetrode power tube with 70W plate dissipation. It is the most powerful tube in the 6550/KT88/KT90/KT120 family, developed to improve heat dissipation and ensure optimal sound performance. It is extremely reliable and guarantees a long life.
    479,00 € 399,17 €Ex.
    In Stock
  • Ref : 19012
    899,00 € 749,17 €Ex.
    In Stock
  • Ref : 17294
    In Stock
    The PSvane CV181-TII is a high quality dual triode tube used in voltage amplifier circuits. It can replace the 6N8P and 6SN7GT tubes, and offers excellent performance.
    249,00 € 207,50 €Ex.
    In Stock
  • Ref : 16798
    In Stock
    499,00 € 415,83 €Ex.
    In Stock
  • Ref : 19098
    In Stock
    PSVANE's CV181-Z power tube offers a warm sound, full and natural, with good balance and no background noise. PSVANE offers us a tube with a more pronounced analog texture than conventional tubes, with voices more prominent than usual and an overall sound evocative of vinyl.
    In Stock
  • Ref : 18086
    In Stock
    The PSVane ECC81 is a high-performance preamplifier/amplifier tube. These tubes are part of the brand's classic standard range, and provide excellent musicality. PSVane ECC81 tubes are 9-pin double triode tubes (Noval).
    39,90 € 33,25 €Ex.
    In Stock
  • Ref : 18085
    In Stock
    The PSVane ECC82 is a high-performance preamplifier/amplifier tube. These tubes are part of the brand's classic standard range, and provide excellent musicality. PSVane ECC82 tubes are 9-pin double triode tubes (Noval).
    39,90 € 33,25 €Ex.
    In Stock
  • Ref : 18081
    In Stock
    The PSVane ECC83 / 12AX7 is a preamplification / amplification tube that offers excellent performance and belongs to the Classic Series range of the brand. It can be used both for DIY projects or as a replacement for a faulty 12AX7 or ECC83 tube.
    30,90 € 25,75 €Ex.
    In Stock
  • Ref : 18323
    In Stock
    PSVane's EL34-PH tube is a replica of the well known Philips EL34, widely used in many tube amplifiers. The EL34-PH is characterized by a soft and musical sound signature. It is also capable of withstanding high voltages, up to 800V, to provide high power output.
    659,00 € 549,17 €Ex.
    In Stock
  • Ref : 14716
    In Stock
    379,00 € 315,83 €Ex.
    In Stock
  • Ref : 19094
    PSVANE's EL34-Z power tube offers a soft, warm sound, full and natural, with good balance and no background noise. PSVANE offers us a tube with a more pronounced analog texture than conventional tubes, with voices more prominent than usual and an overall sound evocative of vinyl.
    89,00 € 74,17 €Ex.
    In Stock
  • Ref : 21029
    In Stock
    189,00 € 157,50 €Ex.
    In Stock
  • Ref : 18087
    The PSVane EL84 is a high-performance preamplifier/amplifier tube. These tubes are part of the brand's classic standard range, and provide excellent musicality. PSVane EL84 tubes are 9-pin pentode tubes (Noval).
    32,90 € 27,42 €Ex.
    In Stock
  • Ref : 15691
    In Stock
    These EL84-S PSVane pentode tubes are improved versions of the EL84. They use longer plates, better materials and gold plated contacts, resulting in excellent sound performance. They are delivered matched.
    89,00 € 74,17 €Ex.
    In Stock
  • Ref : 15799
    In Stock
    These EL84-S PSVane pentode tubes are improved versions of the EL84. They use longer plates, better materials and gold plated contacts, resulting in excellent sound performance. They are delivered matched by four tubes..
    In Stock
  • Ref : 19382
    In Stock
    PSVane KT150-J tubes are high-performance tubes mainly used for Hi-Fi amplification. They offer clear, detailed sound reproduction while maintaining pronounced dynamics.
    539,00 € 449,17 €Ex.
    In Stock
  • Ref : 19285
    In Stock
    PSVane KT150-PT tubes are high-performance tubes mainly used for Hi-Fi amplification. They offer clear, detailed sound reproduction while maintaining pronounced dynamics.
    269,00 € 224,17 €Ex.
    In Stock
  • Ref : 18288
    In Stock
    These PSVANE KT66GC tubes are power tetrodes from the PSVANE "Legend" series. They are ideal for DIY HiFi design, or as replacements for similar models such as the EL34, 6L6 or, KT77 or the original KT66 from GEC. Their baseplate has 7 pins. They are sold factory-paired in pairs.
    349,00 € 290,83 €Ex.
    In Stock
  • Ref : 18292
    In Stock
    These PSVANE KT66GE tubes are power tetrodes from the PSVANE "Legend" series. They are ideal for DIY HiFi design, or as replacements for similar models such as the EL34, 6L6 or, KT77 or the original KT66 from GEC. Their baseplate has 7 pins. They are sold factory-paired in pairs.
    In Stock
  • Ref : 16347
    In Stock
    These high-end PSVane T-Series Mark II matched tubes offer exceptional performance. These tubes have a superb design quality and will easily find their place in your audio designs. The inside of the tubes is covered with a carbon layer for better heat dissipation and more stable performance.
    449,00 € 374,17 €Ex.
    In Stock
  • 229,00 € 190,83 €Ex.
    In Stock
  • Ref : 19099
    In Stock
    PSVANE's KT88-Z power tube offers a soft, warm sound, full and natural, with good balance and no background noise. PSVANE offers us a tube with a more pronounced analog texture than conventional tubes, with voices more prominent than usual and an overall sound evocative of vinyl.
    In Stock
