SHANLING SE100 SMALL IEM Ear Tips
The Shanling SE100 are silicone ear tips designed to optimise acoustic coupling between the IEM and the ear canal, relying on a specific internal architecture integrating a metal insert to improve sound wave transmission. This design combines soft silicone with a rigid internal structure, maintaining stable geometry while ensuring precise morphological adaptation, resulting in more consistent reproduction across the full frequency spectrum.
Reference : 22109
10,00 €tax incl.
8,33 € tax excl.
Shipping date: 25-11-2026.
Shanling SE100 SMALL IEM Ear Tips Ø11mm (Pair)
SHANLING SE100 : Front view
Shanling SE100: Invisible Internal Structure
The integration of a so-called invisible support structure rigidifies the central zone without disrupting wave propagation, preventing internal deformations responsible for distortion and loss of directivity. This approach is further extended by an optimised phase cone geometry, allowing sound waves to travel through the ear tip more linearly, improving soundstage precision while maintaining a uniform frequency response.
SHANLING SE100 : Sound wave path illustration
SHANLING SE100 : Aluminium structure
Shanling SE100: Aluminium Insert
The aluminium insert, combined with a short horn internal geometry, acts directly on the control of parasitic resonances, limiting the harmonic distortion typically induced by soft materials alone. Drawing on principles used in loudspeaker acoustics, this design improves micro-detail intelligibility while stabilising signal behaviour, resulting in cleaner and more structured reproduction.
Shanling SE100: Wearing Comfort
Beyond acoustic performance, the silicone used exhibits controlled flexibility that allows the ear tip to conform precisely to the shape of the ear canal, reducing pressure points while ensuring stable long-term retention. This adaptation limits fatigue during extended listening sessions while maintaining consistent sealing — a necessary condition for preserving low-frequency response and tonal balance.
Shanling SE100: Impact on Sound Reproduction
This combination of rigid internal structure and soft external interface optimises the frequency response of the IEM, reducing variations induced by standard ear tips and improving overall signal coherence. For the user, this translates into more accurate reproduction, with better register separation and enhanced perception of nuance, whether in mobile or more analytical listening contexts.
Technical caracteristics
Product typeIEM ear tips
MaterialsSilicone
Aluminum
Compatible IEM nozzle diameter4.9-6.5mm
External diameterØ11mm
ColorClear
PackageSold as a pair
SHANLING SE100 SMALL IEM Ear Tips Ø11mm (Pair)
The Shanling SE100 are silicone ear tips designed to optimise acoustic coupling between the IEM and the ear canal, relying on a specific internal...
