By buying this product you get 63 loyalty points
-20,00 € Viewed products
DAC E50 ES9068AS + Balanced Amplifier PA5 + Jack 6.35mm Cables TCT1
This Topping pack composed of an E50 DAC, a PA5 amplifier and TCT1 connection cables allows you to enjoy a complete and coherent set, capable of a high quality sound reproduction at an affordable price.
Topping offers with its E50 a compact and very powerful DAC, using proven audio components widely recognized by audiophiles. This one is indeed based on an ESS ES9068AS digital/analog conversion chip, as well as an XMOS XU216 USB interface, allowing it to read high resolution files but also to decode MQA files. It also benefits from a balanced output on TRS connectors.
View the product pageTopping's PA5 is a compact yet powerful and high performance balanced amplifier. It incorporates an optimized new generation Class D amplifier circuit capable of delivering 2x125W of power at 4Ω, with high efficiency. This new circuit offers a precise, neutral and rich sound reproduction, with a totally inaudible background noise. The symmetrical design of the PA5 also allows it to limit its noise level considerably and to cancel ground loops.
View the product pageThe TCT1 cables from Topping are high quality 6.35mm jack cables. They integrate 6N copper and 6N silver plated copper conductors ensuring a perfect signal transmission. Each conductor has a section of 0.533mm² (19AWG). The contacts of the connectors are gold plated in order to maintain an excellent conductivity while ensuring a great resistance to oxidation. Each cable is covered with a beautiful and robust black and red braided nylon sheath. They will allow you to connect the E50 and the PA5 together.
View the product page| Specifications | |
| Product type | DAC + Amplifier + Jack 6.35mm cables |
| Pack content | 1x Topping E50 1x Topping PA5 1x Topping TCT1 |
| Topping E50 Specifications | |
| Product type | DAC |
| DAC Chip | ESS ES9068AS |
| Supported sampling rates | USB : PCM up to 32bit 768kHz, Native DSD up to DSD512, DSD DoP up to DSD256, MQA Optical, Coaxial : PCM up to 24bit 192kHz, DSD DoP up to DSD64, MQA |
| Inputs | 1x USB-B 1x Optical Toslink 1x Coaxial |
| Outputs | 1x Single-ended stereo RCA 1x Balanced TRS Jack 6.35mm |
| THD+N @ A-Weighting | Single-ended : < 0.0001% @ 1kHz Balanced : < 0.00009% @ 1kHz |
| THD+N @ No-Weighting 90kBw | Single-ended : < 0.0003% @ 20Hz-20kHz Balanced : < 0.0003% @ 20Hz-20kHz |
| SNR @ A-Weighting | Single-ended : 124dB @ 1kHz Balanced : 126dB @ 1kHz |
| Dynamic range @ A-Weighting | Single-ended : 124dB @ 1kHz Balanced : 126dB @ 1kHz |
| Frequency response | Single-ended : 20Hz-40kHz (±0.3dB) Balanced : 20Hz-40kHz (±0.3dB) |
| Output level | Single-ended : 2Vrms @ 0dBFS Balanced : 4Vrms @ 0dBFS |
| Noise @ A-Weighting | Single-ended : < 1.3µVrms Balanced : < 2.3µVrms |
| Crosstalk | Single-ended : -130dB @ 1kHz Balanced : -139dB @ 1kHz |
| Output impedance | Single-ended : 20Ω Balanced : 100Ω |
| Supply voltage | 5VDC |
| Dimensions | 129 x 155 x 41mm |
| Color | Black |
| Package | 1x Topping E50 1x Remote control 1x USB-A to Jack DC power cable 1x USB-A to USB-B cable |
| Topping PA5 Specifications | |
| Product type | Amplifier |
| Inputs | 2x Balanced stereo Jack TRS |
| Output | Speaker terminals (BTL output) |
| Output power | 2x140W @ 4Ω, THD+N < 10% 2x125W @ 4Ω, THD+N < 1% 2x85W @ 8Ω, THD+N < 10% 2x65W @ 8Ω, THD+N < 1% |
| Display | LED |
| THD+N @ A-Weighting, 1kHz | < 0.0005% @ 4Ω 5W < 0.0004% @ 8Ω 5W |
| THD+N @ No-Weighting 20kBw | < 0.0015% @ 4Ω 5W < 0.0006% @ 8Ω 5W |
| SNR @ A-Weighting | 124dB |
| Dynamic range @ A-Weighting | 124dB |
| Frequency response | 20Hz-40kHz (±0.3dB) |
| Output level | 65Vpp @ RL=4Ω 68Vpp @ RL=8Ω |
| Noise @ A-Weighting | < 16µVrms |
| Crosstalk | -106dB |
| Input sensitivity | 2.6Vrms |
| Gain | 19.1dB |
| Channel balance | 0.1dB |
| Output impedance | < 0.01Ω |
| Supply voltage | 38VDC 4A |
| Standby consumption | < 0.1W |
| Dimensions | 166 x 129 x 41mm |
| Color | Black |
| Package | 1x Topping PA5 1x Power supply |
| Topping TCT1 Specifications | |
| Product type | Jack 6.35mm TRS cables |
| Connectors | Male Jack 6.35mm TRS |
| Length | 25cm |
| Cable external diameter | Ø8mm |
| Conductors material | Copper Silver plating copper |
| Conductors section | 0.533mm² (19AWG) |
| Connectors contacts plating | Gold |
| External sheath | Braided nylon |
| Color | Black and red |
| Quantity | Sold in pairs (1 cable with red markings, 1 cable with white markings) |
