WONDOM AA-AS32992 WPA2X20 IP67 Waterproof Amplifier Bluetooth 2x20W
The WONDOM AA-AS32992 WPA2X20 is a compact stereo amplifier designed for outdoor, automotive, marine, and industrial applications requiring excellent resistance to harsh environments. Certified IP67, it is resistant to dust, weather conditions, and temporary immersion up to 1 meter deep for 30 minutes. Based on a 2x20W stereo amplification architecture, it supports both Bluetooth audio sources and analog 3.5mm AUX inputs, providing great flexibility of use.
Reference : 22272
34,90 €tax incl.
29,08 € tax excl.
Shipping date: 25-11-2026.
WONDOM AA-AS32992 WPA2X20 IP67 Waterproof Bluetooth Amplifier 2x20W
The WONDOM AA-AS32992 WPA2X20 is a compact stereo amplifier designed for outdoor, automotive, marine, and industrial applications requiring excellent resistance to harsh environments. Certified IP67, it is resistant to dust, weather conditions, and temporary immersion up to 1 meter deep for 30 minutes. Based on a 2x20W stereo amplification architecture, it supports both Bluetooth audio sources and analog 3.5mm AUX inputs, providing great flexibility of use. Its power supply accepts an extremely wide voltage range from 10V to 80V DC, allowing integration into vehicles, boats, agricultural equipment, and off-grid installations. Its fully aluminum enclosure ensures excellent heat dissipation while providing high resistance to vibrations and mechanical stress. The WPA2X20 also features Bluetooth disconnect and quick shutdown controls, secure Plug & Play connectors, and integrated protection against overheating, overcurrent, short circuits, and reverse polarity. Supplied with a waterproof connection cable and heat-shrink identification sleeves, it provides a reliable and easy-to-deploy audio solution for the most demanding environments.
WONDOM AA-AS32992 WPA2X20: IP67 Certification for Outdoor Use
Thanks to its fully waterproof and dustproof IP67-certified design, the WPA2X20 can be used confidently in humid environments or areas exposed to harsh weather conditions. It withstands rain, water splashes, dust, mud, and temporary immersion up to 1 meter deep for 30 minutes. This ruggedness makes it ideal for boats, off-road vehicles, outdoor installations, terraces, and embedded audio systems.
WONDOM AA-AS32992 WPA2X20: Wide 10V to 80V DC Power Supply Compatibility
The WPA2X20 stands out with its extremely wide power supply range from 10V to 80V DC. This compatibility allows it to operate directly from numerous power sources commonly used in cars, trucks, boats, agricultural vehicles, and autonomous systems without requiring a dedicated voltage converter.
WONDOM AA-AS32992 WPA2X20: Bluetooth Connectivity and 3.5mm AUX Input
To suit every application, the amplifier offers dual audio connectivity with wireless Bluetooth input and a 3.5mm AUX input. Users can choose between a stable wired connection or convenient wireless streaming depending on the application. The quick Bluetooth disconnect and power-off functions also simplify the daily management of connected devices while helping to reduce power consumption.
WONDOM AA-AS32992 WPA2X20 Overview
1Bluetooth LED
2Power LED
3Bluetooth Antenna
4Power Supply / Line Input / Speaker Output / Control Port (Mini-fit 2x6 CKT)
Technical Specifications
Product TypeWaterproof amplifier
Waterproof RatingIP67
Input1x Analog input via Mini-fit 2x6 port
Bluetooth
Output1x Stereo speaker output via Mini-fit 2x6 port
Bluetooth VersionBluetooth 5.0
Output Power2x 20W
Gain21.7dB (1kHz, 4Ω, Test signal=775mVrms, Line in L&R Channel)
Input Sensitivity775mVrms (1kHz, 4Ω, Test signal=775mVrms, Power out=2x20W, Line in L&R Channel)
Noise Level38 μVrms (1kHz, 4Ω, Test signal=0 mVrms, Line in L&R Channel, A-weighted)
35 μVrms (Bluetooth Input, L&R Channel, A-weighted)
THD0.07% (1kHz, 4Ω, Power out=2x1W, Line in L&R Channel, A-weighted)
SNR108dB (1kHz, 4Ω, Test signal=775mVrms, Line in L&R Channel, A-weighted)
Channel Separation-64dB (1kHz, 4Ω, Test signal=775mVrms, Line in L&R Channel)
Frequency Response±1dB (Test signal=775mVrms, 20Hz - 20kHz, 4Ω)
Power Supply10-80V DC (Typ.: 24V DC)
Idle Current0.11A / 0.13A / 0.14A (Power supply= 24V, without input signal)
Idle Power Consumption2.64W / 3.12W / 3.36W (Power supply= 24V, without input signal)
Operating Temperature-20/65°C
Storage Temperature-10/55°C
Dimensions110 x 48 x 40mm
Weight340g ±10g
Package Contents1x WONDOM WPA2X20
1x Mini-Fit 2x6 CKT Cable
12x Blue Waterproof Sleeves
12x Red Waterproof Sleeves
12x Printed Waterproof Sleeves
InputMini-fit
OutputMini-fit
Channel2 (Stereo)
Amplifier chipN/A
Power (W)20.0
The WONDOM AA-AS32992 WPA2X20 is a compact stereo amplifier designed for outdoor, automotive, marine, and industrial applications requiring...
