WONDOM ADP-XAI AA-AA11432 Audio Distribution Panel Combo XLR / Jack 6.35mm TRS Inputs
The Wondom ADP-XAI (AA-AA11432) is an analog audio distribution panel designed to ensure the interface between XLR and 6.35mm TRS jack connectors to terminal block wiring. It allows routing analog audio signals to RJ128 terminals, thus facilitating the integration of equipment not featuring XLR connectors while maintaining a direct signal correspondence.
Reference : 22092
14,91 €tax incl.
12,42 € tax excl.
Wondom ADP-XAI (AA-AA11432) Audio Distribution Panel Combo XLR / Jack 6.35mm TRS Inputs
xxx
The Wondom ADP-XAI (AA-AA11432) is an analog audio distribution panel designed to ensure the interface between XLR and 6.35mm TRS jack connectors to terminal block wiring. It allows routing analog audio signals to RJ128 terminals, thus facilitating the integration of equipment not featuring XLR or Jack 6.35mm connectors while maintaining a direct signal correspondence.
It integrates 3-pin XLR connectors and stereo 6.35mm TRS jack on the front panel, allowing to connect different analog audio sources on the same panel. Each input is directly connected to a RJ128 screw terminal, which allows to retrieve the signal in wired form to integrate it into an existing system. The connection preserves the three conductors of the audio signal, corresponding to hot, cold and ground links, thus ensuring connection continuity compatible with differential audio inputs.
The panel is based on a 4mm thick aluminum front panel, allowing direct mounting on different supports while maintaining alignment and stability of the connectors. Its compact format of 69.85x44.45mm and its M3 screw mounting facilitate its integration into technical panels, chassis or custom interfaces.
Technical specifications
Inputs3-pin female XLR
6.35mm TRS stereo female jack
OutputsRJ128 connectors
MaterialAluminum
Dimensions69.85 x 44.45 x 4mm
Weight64.7g
Packaging1x Wondom ADP-XAI
4x M3 x 8mm screws (fine thread 0.5mm)
4x M3 x 12mm screws (coarse thread 1.2mm)
1x Rubber strip 20 x 250 x 2mm
The Wondom ADP-XAI (AA-AA11432) is an analog audio distribution panel designed to ensure the interface between XLR and 6.35mm TRS jack connectors...
