JANTZEN AUDIO AMBER Z-CAP 001-7256 Capacitor
Jantzen Audio's Amber Z-Cap capacitors are made from pure copper foil of the highest quality. They have been specially designed for the tweeter section of crossover filters for passive HiFi loudspeakers. They are also ideal for use in the midrange. Amber Z-Caps are designed to deliver a more neutral sound reproduction, with an excellent balance between midrange and treble.
By buying this product you get 37 loyalty points
Reference : 22168
379,00 €tax incl.
315,83 € tax excl.
Jantzen Amber Z-Cap 001-7256 Pure Copper Foil Capacitor Axial 200V 10µF
Jantzen Audio Amber Z-Cap
Jantzen Audio
Key features:
  • Highly reactive capacitor.
  • Ultra-fine dielectric insulation to eliminate memory effect in the capacitor.
  • Extremely low ESR, ESL, inductance and dielectric absorption.
  • High-quality pure copper foil wound on high-precision machines.
  • Capacitor center reinforced with small steel balls for even greater stability and shape.
  • Very low distortion.
  • Specifically designed for the tweeter and midrange sections of passive loudspeaker crossovers.
  • Can also be used as a coupling capacitor for transistor amplifiers.
Due to the Amber Z-Cap's max voltage of 200V DC, a certain amount of caution is required when using it with tubes or power amplifiers. For upgrading coupling capacitors in power amplifiers, we recommend the Superior Z-Cap or Silver Z-Cap ranges.
Capacitor typeNon-polarized pure copper film capacitor
DielectricPolypropylene film
FormatAxial
Rated voltage200VDC
160VAC
Capacitance10µF
Capacitance tolerance+/-5%
Dissipation factorExtremely low
Dielectric absorption factor< 0.5% @ 20°C
Dielectric thickness5µm
ESRExtremely low
Self inductance0nH
Insulation resistance> 100 000 MOhm @ 20°C
Temperature range-55°C / +85°C
Metal layer thickness0.3µm
Conductivity of the metal layer1.2Ω/cm²
DimensionsØ63 x 70mm
ColorBrown
Tolerance (%)5
Capacitor capacitance (µF)10
Rated voltage (V)200.0
Rated voltage (V)160.0
Capacitor typeFilm capacitor
Capacitor formatAxial
JANTZEN AUDIO AMBER Z-CAP 001-7256 Pure Copper Foil Capacitor Axial 200V 10µF
Jantzen Audio's Amber Z-Cap capacitors are made from pure copper foil of the highest quality. They have been specially designed for the...
