DAYTON AUDIO BR-1 Kit DIY Bookshelf Speaker 2 Way
This Dayton Audio BR-1 kit allows you to build your own Hi-Fi bookshelf speakers. They are based around a DC160-8 bass driver and a DC28FL-8 silk dome tweeter. Once assembled, the bookshelf speakers can deliver a maximum power of 100W under 8Ω with a frequency response of 43Hz to 18kHz.
Reference : 21205
299,00 €tax incl.
249,17 € tax excl.
Shipping date: 24-11-2026.
Dayton Audio BR-1 Kit DIY Bookshelf Speaker 2 Way 100W 85dB 4 Ohms 43Hz-18kHz (Pair)
Dayton Audio BR-1 : Front view of kit contents
This Dayton Audio BR-1 kit allows you to build your own Hi-Fi bookshelf speakers. They are based around a DC160-8 bass driver and a DC28FL-8 silk dome tweeter. Once assembled, the bookshelf speakers admit a maximum power of 100W under 8Ω with a frequency response of 43Hz to 18kHz.
This kit comes with an assembly manual and, although simple to assemble, it requires basic soldering skills, particularly for the crossover section.
Please note: This kit does not include the cabinet.
This kit includes:
  • 2 Dayton Audio DC160-8 woofers
  • 2 DC28F-8 tweeter speaker
  • 2 BR-1XO crossover filters
  • 2 Non-polarised capacitors 47 µF-100 V
  • 2 DFFC-0.10 bypass capacitors 0.10 µF 400 V
  • 2 Non-inductive resistors DNR-8.0 8Ω 10 W
  • 2 DMPC-3.0 polypropylene capacitors 3.0 µF 250 V
  • 2 Air core coils 0.4 mH 20 AWG
  • 1.8m of 16 AWG speaker cable
  • 24 Female Blade Connectors
  • 2 Absorbent foam pads
  • Screws
Product typeKit for bookshelf speakers
Power rating100W max
Sensitivity85dB
Frequency response43Hz-18kHz
Impedance8Ω
Conditionnement2x Dayton Audio DC160-8 woofers
2x DC28F-8 tweeter speakers
2x BR-1XO crossover filters
2x Non-polarised capacitors 47 µF-100 V
2x DFFC-0.10 bypass capacitors 0.10 µF 400 V
2x Non-inductive resistors DNR-8.0 8Ω 10 W
2x DMPC-3.0 polypropylene capacitors 3.0 µF 250 V
2x Air core coils 0.4 mH 20 AWG
24x Female Blade Connectors
2x Absorbent foam pads
Screws
Assembly guide
DAYTON AUDIO BR-1 Kit DIY Bookshelf Speakers 2 Way 100W 85dB 4 Ohm 43Hz-18kHz (Pair)
This Dayton Audio BR-1 kit allows you to build your own Hi-Fi bookshelf speakers. They are based around a DC160-8 bass driver and a DC28FL-8 silk...
