DAYTON AUDIO CE30P-4 Full Range Speaker Driver
The Dayton Audio CE30P-4 is a miniature full-range speaker designed for compact applications requiring quality sound reproduction despite limited available space.
Reference : 22309
6,70 €tax incl.
5,58 € tax excl.
DAYTON AUDIO CE30P-4 Miniature Full-Range Speaker 2W 4 Ohm 81dB 280Hz-14kHz Ø2.54cm
The Dayton Audio CE30P-4 is a miniature full-range speaker designed for compact applications requiring quality sound reproduction despite limited available space. With a diameter of only 1-1/4" (Ø31.75 mm) and a diaphragm area of 4.1cm², it features a paper cone, a rubber surround, and a powerful dual neodymium magnet motor system providing excellent efficiency in an extremely compact format. Compatible with a 4Ω load, it supports a continuous power handling of 2W RMS (4W max) and offers a sensitivity of 81dB (2.83V/1m) as well as a frequency response ranging from 280Hz to 14kHz. Its circular injection-molded plastic frame is specifically designed for press-fit or adhesive mounting, making it easy to integrate into numerous electronic and multimedia projects. Thanks to its low 14.5mm depth, 13mm voice coil, 336Hz resonant frequency, and maximum linear excursion of 0.3mm, the CE30P-4 is an ideal solution for compact multimedia speakers, portable player docking stations, televisions, soundbars, and other embedded audio devices requiring a high-performance and economical miniature speaker.
DAYTON AUDIO CE30P-4: An ultra-compact format for easy integration
With an external diameter of only 31.75mm, a recommended cutout diameter of 30.2mm, and a depth of 14.5mm, the CE30P-4 easily fits into the most confined spaces. Its robust injection-molded plastic frame allows quick press-fit or adhesive mounting, providing great flexibility for designers and integrators.
DAYTON AUDIO CE30P-4: Dual neodymium motor and paper cone
The Dayton Audio CE30P-4 combines a lightweight paper cone with a rubber surround and a high-energy dual neodymium magnet structure. This design ensures dynamic and detailed sound reproduction while maintaining excellent cone control despite the transducer's particularly compact dimensions.
DAYTON AUDIO CE30P-4: Ideal for compact audio projects
Designed for embedded applications and consumer electronic devices, the CE30P-4 is perfectly suited for multimedia speakers, televisions, compact soundbars, portable audio systems, and other projects requiring a miniature full-range speaker. Its 4Ω impedance, extended frequency response up to 14kHz, and low power consumption make it a versatile and economical solution.
Technical specifications
Product typeMiniature full-range speaker
Nominal diameterØ2.54cm (1")
PowerRMS: 2W
Max: 4W
Impedance4Ω
Frequency response280Hz - 14000Hz
Sensitivity81dB 2.83V/1m
Voice coil diameterØ12.954mm (0.51")
Thiele-Small Parameters
Resonant frequency (Fs)336Hz
DC resistance (Re)3.4Ω
Voice coil inductance (Le)0.19mH
Mechanical quality factor (Qms)3.62
Electromagnetic quality factor (Qes)1.03
Total quality factor (Qts)0.8
Equivalent air volume of the moving mass compliance (Vas)0.00028ft³
Mechanical compliance of the suspension (Cms)0.34mm/N
Force factor (BL)2.16T·m
Maximum linear excursion (Xmax)0.3mm
Diaphragm surface area (Sd)4.1cm²
Materials
Cone materialCoated paper
Surround materialRubber
Magnet materialNeodymium
Mounting information
Overall external diameterØ31.75mm (1.25")
Cutout diameterØ30.2mm (1.19")
DepthØ14.5mm (0.57")
Recommended enclosure volume
Sealed enclosure0.0135L (0.000478ft³)
F3 Sealed enclosure372.2Hz
Bass reflex enclosure0.0306L (0.00108ft³)
F3 Bass reflex enclosure179Hz
Speaker Power (W RMS)4.0
Speaker TypeFull range
Impedance (Ω)4
Loudspeaker diameter (mm)25.4
Diaphragm typePaper
Efficiency / Sensitivity (dB)81.0
Max Linear Excursion (Xmax) (mm)0.3
Lowest frequency (Hz)280
Highest frequency (Hz)14000
DAYTON AUDIO CE30P-4 Miniature Full Range Speaker Driver 2W 4 Ohms 81dB 280Hz–14kHz Ø2.54cm
The Dayton Audio CE30P-4 is a miniature full-range speaker designed for compact applications requiring quality sound reproduction despite limited...
