DAYTON AUDIO EPIQUE E150MR-4 Speaker Driver Midrange / Full Range
The Dayton Audio Epique E150MR-4 is a 152.4mm (6 inches) wideband midrange speaker designed to cover a frequency range from 70Hz to 7kHz. It operates at an impedance of 4Ω and reaches a sensitivity of 92.6dB, with a power handling of 60W RMS, allowing a higher output level at equivalent voltage while maintaining extended coverage of the midrange register.
Reference : 22162
89,00 €tax incl.
74,17 € tax excl.
Dayton Audio Epique E150MR-4 Speaker Driver Midrange / Full Range Carbon Fiber 60W 4 Ohm 92.6dB 70-7000Hz 15.2cm
Thumbnail of the Dayton Audio Epique E150MR-4
Designed for multi-way speakers as well as extended configurations, it relies on a carbon fiber cone whose rigidity limits deformation, while the geometry of the cone and surround contributes to a smooth transition across the usable band. This approach extends to the motor, which integrates an aluminum shorting ring combined with a copper cap, allowing reduction of inductance and flux variations, while the aluminum phase plug promotes dispersion in the upper spectrum. The assembly is supported by a cast aluminum frame, ensuring mechanical rigidity while facilitating heat dissipation during prolonged operation.
Graphs and dimensions of the Dayton Audio Epique E150MR-4
Technical specifications
Product typeSpeaker
Speaker typeFull range / Midrange
Nominal diameterØ152.4mm (6")
Power handlingRMS: 60W
Max: 120W
Impedance4Ω
Frequency response70Hz-7kHz
Sensitivity92.59dB 2.83V/1m
Voice coil diameter31.75mm
Thiele-Small Parameters
Resonant frequency (Fs)75.23Hz
DC resistance (Re)3.638Ω
Voice coil inductance (Le)0.075mH @ 1kHz
Mechanical Q factor (Qms)3.619
Electrical Q factor (Qes)0.606
Total Q factor (Qts)0.519
Equivalent compliance volume (Vas)7.4L
BL product4.94T·m
Moving mass (Mms)8.61g
Maximum linear excursion (Xmax)3.25mm
Cone surface area (Sd)100.3cm²
Displacement volume (Vd)28.3cm³
Materials
Cone materialCarbon fiber
Voice coil former materialTitanium
Phase plugAluminum
Frame materialCast aluminum
Mounting information
Overall outer diameter152.4mm
Cutout diameter125.48mm
Depth74.422mm
Number of mounting holes4
Weight3.85kg
Packaging1x Dayton Audio Epique E150MR-4
Speaker Power (W RMS)60.0
Speaker TypeFull range
Speaker TypeMidrange
Impedance (Ω)4
Loudspeaker diameter (mm)152.0
Diaphragm typeCarbon fiber
Efficiency / Sensitivity (dB)92.0
Max Linear Excursion (Xmax) (mm)3.2
Lowest frequency (Hz)70
Highest frequency (Hz)7000
DAYTON AUDIO EPIQUE E150MR-4 Speaker Driver Midrange / Full Range Carbon Fiber 60W 4 Ohm 92.6dB 70-7000Hz 15.2cm
The Dayton Audio Epique E150MR-4 is a 152.4mm (6 inches) wideband midrange speaker designed to cover a frequency range from 70Hz to 7kHz. It...
