DAYTON AUDIO EPIQUE E150MR-8 Speaker Driver Midrange / Full Range
The Dayton Audio Epique E150MR-8 is a wideband midrange speaker of 139.75mm (5.5 inches) designed to cover a frequency range from 70Hz to 7kHz. It operates at an impedance of 8Ω and reaches a sensitivity of 89.6dB, with a power handling of 60W RMS, allowing integration into systems requiring a consistent output level across a wide portion of the midrange spectrum.
Reference : 22157
89,00 €tax incl.
74,17 € tax excl.
Dayton Audio Epique E150MR-8 Speaker Driver Midrange / Full Range Carbon Fiber 60W 8 Ohm 89dB 70-7000Hz Ø15.2cm
Thumbnail of the Dayton Audio Epique E150MR-8
The Dayton Audio Epique E150MR-8 is a wideband midrange speaker of 152.4mm (6 inches) designed to cover a frequency range from 70Hz to 7kHz. It operates at an impedance of 8Ω and reaches a sensitivity of 89.6dB, with a power handling of 60W RMS, allowing integration into systems requiring a consistent output level across a wide portion of the midrange spectrum.
Designed for multi-way speakers as well as extended configurations, it uses a carbon fiber cone combined with a profiled surround to maintain consistent behavior across its operating range. The motor incorporates an aluminum ring and a copper cap, acting on inductance and operational stability, while the aluminum phase plug contributes to high-frequency management. The assembly is mounted on a cast aluminum frame, ensuring structural rigidity, with a ventilation system contributing to heat dissipation during extended use.
Specifications and Dimensions of the Dayton Audio Epique E150MR-8
Technical specifications
Product typeSpeaker
Speaker typeWideband midrange
Nominal diameterØ152.4mm (6")
Power handlingRMS: 60W
Max: 120W
Impedance8Ω
Frequency response70Hz-7kHz
Sensitivity89.6dB 2.83V/1m
Voice coil diameter31.75mm
Thiele-Small Parameters
Resonant frequency (Fs)74Hz
DC resistance (Re)6.5Ω
Voice coil inductance (Le)0.1mH @ 1kHz
Mechanical Q factor (Qms)4.23
Electrical Q factor (Qes)0.67
Total Q factor (Qts)0.58
Equivalent compliance volume (Vas)8.0L
Mechanical compliance (Cms)0.56mm/N
BL product6.12 T·m
Moving mass (Mms)8.3g
Maximum linear excursion (Xmax)2.7mm
Cone area (Sd)100.3cm²
Displacement volume (Vd)27.1cm³
Materials
Cone materialCarbon fiber
Surround materialRubber
Voice coil former materialTitanium
Phase plugAluminum
Frame materialCast aluminum
Mounting information
Overall outer diameter152.4mm
Cutout diameter125.48mm
Depth74.422mm
Number of mounting holes4
Weight4.5kg
Packaging1x Dayton Audio Epique E150MR-8
Speaker Power (W RMS)60.0
Speaker TypeMidrange
Speaker TypeFull range
Impedance (Ω)8
Loudspeaker diameter (mm)152.0
Diaphragm typeCarbon fiber
Efficiency / Sensitivity (dB)89.0
Max Linear Excursion (Xmax) (mm)2.7
Lowest frequency (Hz)70
Highest frequency (Hz)7000
DAYTON AUDIO EPIQUE E150MR-8 Speaker Driver Midrange / Full Range Carbon Fiber 60W 8 Ohm 89dB 70-7000Hz Ø15.2cm
The Dayton Audio Epique E150MR-8 is a wideband midrange speaker of 139.75mm (5.5 inches) designed to cover a frequency range from 70Hz to 7kHz. It...
