Paul R.
Shanling EC3
6CA7
EL34PH
Customers reviews - There are 19681 reviews.
Imrich R.
Excellent cable, very neutral with excellent dynamics, which gradually improves as the cable burns down.
So far, I've gone through a few major speaker brands, but this one is really the ultimate for me. After Nordost cabling, this Canare is a great choice.
I can only recommend.
Apml: Egg Shell Classic 15.1
CD payer: Mcintosh MVP-871
Bluesound Node 2i
Dac Adi2fs
Speaker: Fisher octavia ambiente - Limited edition
Arthur S.
Volume drop
Experienced a volume drop, may not be as universally compatible as one would expect. But very low distortion amp if it is compatible in target product.
Jonathan D.
Le Meilleur même a ce prix
Relié entre ma prise murale FURUTECH FT-SWS NCF (R) et ma barette LH Audio 8 embases chêne avec comme connecteur les VF503S et VE503S de chez Viborg j'ai encore gagné en clartés et timbres par rapport a mes habituelle câbles de chez YARBO, le SP-1100PW Câble secteur Triple Blindage OCC qui eux vont de ma barette a mes éléments HI-FI, tous mes câbles sont en longueurs de 2 mètres. Merci Audiophonics.
Jonathan D.
NEUTRIK NADITBNC-MX Impedance Transformer XLR AES/EBU 110 Ohm Male / BNC 75 Ohm Female This digital adapter consists of a 75Ω female BNC connector and a 110Ω male XLR. It allows long cables to be installed via a low attenuation coaxial line, while...
Pratique
Fonctionne très bien, m'a permis de relié ma source Cocktail Audio X14 depuis la sortie coaxial RCA vers mon DAC Audiolab M-DAC+ sur son entrée AES sans aucune perte ni changement de qualité, merci Audiophonics.
Does what the marketing says
Hi had used a variety of power conditioners and the most recent expensive one squashed the dynamics and made the sound glary and harsh.
For once, the marketing is to be believed with this product. It really smoothes out the sound without any loss of detail while letting more detail through.
I have it in use less than 24hrs and already its proving its worth. A reallly terrific investment.
Danitza P.
Excellent préampli
Audiophile depuis plus de quinze ans, et client depuis de nombreuses années, n'ayant jamais été déçus par le professionnalisme des gens de chez Audiophonics, une fois encore cela c'est avéré exact.
Contexte: après avoir envoyé un mail à M. Aubert lui expliquant que suite à la mise en réparation de mon ampli intégré habituel (Cambridge Audio), j'ai mis en service un petit (mais puissant) ampli de classe D (SURE A2100 Explorer), afin d'alimenter mon système à base d'enceintes larges bandes (Fostex), d'un caisson JBL, d'une platine Marantz et d'un lecteur numérique FIIO, le tout orchestré par un Mini DSP 2X4 HD. L'écoute du classe D par rapport à mon ancien ampli s'avérait très neutre et plaisante avec une belle qualité des timbres, mais à mon gout manquait d'un poil de dynamisme.
L'achat d'un préampli pour vitaminer tout ça, me paraissait indispensable (c'est souvent ce qui ressort avec les amplis classe D, ou l'ajout d'un préampli apporte une réelle plus-value à l'écoute).
C'est donc en ayant suivi ses conseils que j'ai acheté ce préampli j'ai donc reçu l'appareil de "format moyen" (ni tout à fait compact, ni au format habituel des appareil hifi). Ce dernier s'avère excellent dès les première notes (Classe A oblige), transparent, très dynamique, facile à utiliser. ça a radicalement changé mon système. De très bon, il est passé à excellent. La qualité de fabrication n'est pas en reste: boitier, boutons… et mention + à la connectique très qualitative. Seule la LED rouge en façade est un peu dérangeante, elle éclaire trop… (c'est malheureusement souvent le cas avec les appareils d'aujourd'hui).
Pour le prix, vous pouvez y aller les yeux fermer, vous ne le regretterez pas, je pense même qu'il rivalise sans soucis avec des appareils beaucoup plus chers.
Merci et bravo à toute l'équipe d'Audiophonics.
Jonas Å.
Instant upgrade!
I bought two and put the first one between my PC and a buss-powered 4-port USB 3.0 hub. The second one is plugged into the hub right before an iFi idefender. The iDefender then connects to a USB 2.0 hub that has been modified with grounding, extra shielding and power filtering. This hub then connects to a usb to coax decoder.
Each iSilencer added resulted in instant improvement! Sound became softer, more pleasant. Very happy with purchase!
I also tried putting them in empty USB jacks next to the cables but this didn't work as well. Seems to work best in series.
Nikolaus N.
Zauberkästchen für mein Digione
Ich habe dieses Netzteil bestellt, da mein bisheriges keine CE Kennung hatte. Deshalb habe ich es ohne Erwartungen gekauft. Es sollte einfach nur ein Austausch sein.
Aber nach den ersten Takten der Musik war mir klar, dass das Teil viel mehr kann. Die Musik löst sich über den gesamten Frequenzbereich mit viel mehr Details von den Lautsprechern. Was für ein glaublicher zugewinn! Kann ich nur empfehlen!
Lautsprecher: ELAC Navis arf
DAC: SMSL M400
Transport: ALLO Digione
Supra Cable
Florent L.
YARBO SP-1100 PW
Une autre planète pas la peine d'aller plus loin wow WOW c'est quoi ce câble YARBO IL Y A QUOI dans le câble rapport qualité une tuerie monté avec les Viborg je suis bouche B je recommande à 10000000%.
Un peu long à monter mais le résultat est là.
YARBO J'y suis j'y reste un point c'est TOUT je vais commander d'autres c'est sur WOW WOW!! merci encore Audiophonics
Martin S.
Fast delivery. Really good product for a very good price
Marcel M.
Remote Control for FX-Audio D802E / D2160 This FX-Audio remote control is the same as the one supplied with the FDA amplifiers D802E and D2160, so it will be perfectly suitable as a replacement for a defective model for...
Pas compatible avec le D2160 MK2
Attention, cette télécommande est celle de l'ancien FX-AUDIO D2160 MK1.
La Télécommande du FX-AUDIO D2160 MK2, actuellement commercialisé n'est pas la même. Les boutons sont différents et certaines fonctions ne sont pas accessibles avec la version du MK1.
Florent L.
YARBO SP 8000PW
Acheté sur les conseils d'audiophonics pour alimenter ma barrette en cours de rodage patience....très beau produit top qualité YARBO...j'ai été surpris par la souplesse vu le diamètre du câble. J'ai commandé aussi le SP 1100PW OCC en vue d'une comparaison monte sur des fiches VIBORG pour les deux câbles le plus effet.
Merci encore Audiophonics
Pas mal
produit bien fini comme le reste des produits viablue, et fait le boulot.
J'ai hésité avec les furutech, qui ont l'air supérieures mais pas le même prix.
Bon rendu sonore
C'est l'essentiel, je les préfère du coup aux neutrick nf2cb2 qui sont plus douce mais plus ternes, en association avec le stratos.
C'est naturel aéré, et pas fatigant.Les fiches sont plutôt réussies esthétiquement.
rendu naturel, sans agressivité, associé aux fiches viablue t6s.Celles-ci paraissent plus définies que les rca neutrick nf2cb2 montées sur le stratos aussi.
Krzysztof S.
I'm dissapointed. No volume control on volumio (version 2.x and 3.x). Huge problems with installing the power button. In Volumio 3.x, I was unable to get the button to work. Only the downgrade to 2.x helped. It gives 2 stars instead of 0 only because the sound quality generated by this DAC is very good.
Hi,
This DAC doesnt have an hardware built in volume control but you can always use the embedded to volumio software volume control.
This feature has been removed we are not responsible of that ...
Hermann B.
AMANERO COMBO384SE Digital interface USB 384kHz / SPDIF WM8804 to I2S / DSD Combo384SE version also incorporating a bidirectional S / PDIF WM8804 interface which can function as input or as output according to the needs of your project.
Excellent customer support
my request was resolved very quickly
Hermann B.
excellent customer support
customer service is fast and excellent
Poor clamp
I sent this back as the cable clamp did not grip a 12mm cable. Poorly designed.
Great connector
Build and finish is excellent. The cable clamping is very cable friendly, unlike Furutech and others that splay heavy gauge cables and I use 10AWG cables.
As plugs go, they impart great air and spaciousness to the sound.
Terrific cable
An excellent cable for the price. Have it paired with Furutech copper/rhodium plugs and sound is smooth, detailed and open.
Excellent cable
I paired this cable with Ramm silver/rhodium RCA plugs. Really gorgeous textured sound and not at all bright.
Tomas H.
Easy to work with
Nice quality-cable!
Straight forward and clean, straight sound - but IMHO not as musical as my Belden 8402 who plays a warmer sound with a bit more low´s and depth.
Remi B.
Jack haut de gamme
Produit de qualité contacts fermes et paraissent sûrs. Utilisé sur sortie de lecteurs cd, et oui, et dac externe les diffences sont clairement audibles entre appareils. Reste à savoir si le prix fait vraiment une différence avec les autres modèles sur le site à prix très inférieur ?
Cristian E.
MOGAMI W2524
Est parfait pour cable secteur. La qualité est au rdv!
Cristian E.
MOGAMI NEGLEX W2534
cable de calite! je recommand sans hesitation!
Venčeslav D.
AUNE X8 DAC FPGA Altera Max II 32bit 768kHz DSD512 XMOS Silver The Aune X8 is a high-performance DAC, compatible with high-resolution files up to 32bit PCM 768kHz and DSD512. The conversion is done using an Altera Max II FPGA chip,...
Venceslav
I solved the problem with the installation with the usb plug, it was tested on you tube, and at the moment via spotify, great sound, I am pleasantly surprised, great device :)
Bien meilleur que les cables de marque à ce tarif
J'utile ce cable depuis maintenant plus d'un an:relief de l'image stéreo (sur de bon enregistrement on est vraiment immergé par la musique),les timbres semblent réaliste,bref trés bon.
J'ai put comparer à du QED de même gamme tarifaire;atomisé littéralement,ou est passé le relief de l'imamage stéreo,c'est trop clair et limite agressif...si vous avez un budget serré à essayer absolument.
Excellent Dac a condition de soigner le cablage
Je poste cet avis,ayant eut l'opportunité d'en acquérir un d'occasion quasi neuf,le produit n'étant pas disponible pour le moment.
Utilistaion pc portable,foobar asio:les cales secteur et usb doivent obligatoirement être remplacés par des modèles plus qualitatifs(compter environ 100 euros)
Dans ce cas,trés belle image stéréo,sonorité trés detaillée mais pas agressive;si vous aimez un son plutôt rond et chaud,passez votre chemin.
Pour ma part,associé a un ampli Rega IO et des enceintes Q Acoustics Concept20;du pur bonheur sur du jazz/blues acoustique,c'est extremement vivant et enjoué.
Multiprise de bonne qualité mais le montage du câble secteur n'est pas évident...j'ai bien mis 2 heures pour
monter cette satanée Multiprise !!
Un petit tutoriel serait le bienvenue
Bon cable
Bon câble a prix correct.
Fiche banane de qualité
Fiche banane de qualité, cependant le blocage sur mon ampli est presque insuffisant.
Cette fiche peut ne pas fonctionner avec toutes les fiches femelles.
C'est dommage, car la fiche est de bonne facture.
EXCELLENT UPGRADE
En remplacement de deux NE5532 sur ampli classe D, le résultat est impressionnant. Image stéréo véritablement tridimensionnelle, excellente transparence. Définition à l'avenant sans brillance dans l'aigu ni excès dans le grave. un AOP à retenir absolument.
Dimitar C.
Firstly I purchase another product mean chassis, but didn't receive the courier lost the goods. But thanks to the Audiophonics support everything finish with happy end, Thanks Audiophonics for your attention, accuracy and fast response.
Anyway they send to me this unit and I am very happy with it, according to the design it is fabulous, beauty and precise, now I am in the way to complete my mono power amplifier.
Thanks again Audiophonics!
Dimitar C.
Good quality, but need to inform that the fuse is not include.
For this price it is a shame for Furutech!
Yoann L.
Câble assez neutre dans le haut du spectre. Grave ferme sans manque d’information. Un câble qui donnerais des sueurs froides à bien plus chère …
Tester sur ampli et dac goldmund , streamer auralic femto ,et enceintes pylon diamond 30.
Mário Z.
A true killer amplifier
Amazing amplifier! Better than Sugden A21 SE and 14 times cheaper!!!
Ribamar A.
VIABLUE X-60 Silver Power Cable
Câble d'excellente qualité. Le son est devenu plus propre, cristallin. Je ne m'attendais pas à une amélioration aussi significative. Cela prouve une fois de plus qu'il n'est pas nécessaire de dépenser une fortune pour réaliser de réels gains de performances. Pour moi ça valait l'investissement.
Philippe A.
AUDIO-GD PRECISION 3 2020 EDITION Balanced Class A Amplifier ACSS 2x 70W 8 Ohm Audio-GD is upgrading its Audio-GD Precision 3 by offering this 2020 edition. It is based on the previous model, but with a modified circuitry and adjusted sound performance to...
bon appareil, utilisé dans le cadre d'une tri amplification active pour les médiums, j'ai gagné en clarté et en précision dans cette partie du spectre. son assez doux, pas agressif.
Philippe A.
commandé lundi soir reçu jeudi matin. pas encore utilisé mais produit apparemment de qualité.
Laurent W.
TOPPING P50 Regulated Linear Power Supply Ultra Low Noise 2x 5V 1A + 15V 1A Black This regular linear power supply Topping P50 offers excellent performance and allows a HiFi system to be powered properly and thus promotes the sound reproduction quality of the...
Excellent produit. M'a permis d'alimenter un 'vieux' dac nuprime udsd grâce au câble audiophonics usba mâle vers 2x USB femelle et en même temps y connecter un iphone ou un dap qui ne pouvaient alimenter le dac. J'ai l'impression que le son du DAC s'en trouve amélioré.
Robin L.
Marche très bien !
Renvoyé pour un problème de soudure, celui qui m'est revenu fonctionne à merveille depuis 6 mois avec le petit hp sub TANG BANG sur le même site, et une vieille paire d'enceinte de chaine hifi du commerce grand public.
Vraiment pratique, mode 2.1 ou sub uniquement. Différents réglages, bonnes connectiques etc... parfait pour une petite installation pas chère, fait maison rapidement, et avec des basses bien présentes !
Robin L.
Parfait, super puissant pour une petite pièce d'atelier
Vraiment excellent, j'en ai fait un sub basse reflexe, c'est très puissant pour une petite pièce de 10m², au dessus ça devient vite limité je pense, en extérieur c'est très faible aussi si on veux vraiment pousser le volume, mais suffisant pour une ambiance qui casse pas les oreilles
Robin L.
Très pratique
Très facile à installer grâce au filetage, suffit de percer, poser, visser et ça bouge pas. (Et souder de l'autre côté...)
Robin L.
Très content
Ravis par ce petit ampli, très efficace pour le prix. Aigues un peu fortes, je les baisse de 3 ou 4 dB dans le réglage, mais ça dépend des enceintes aussi (j'ai des klipsh).
Attention à la sortie sub, elle m'a semblé assez puissante pour une sortie non amplifiée par rapport à une sortie line d'ampli classique, donc monter très doucement le potard du caisson de basse amplifié !
Autre détail pas terrible c'est qu'il est tellement léger que suivant la disposition, tout les câbles à l'arrière peuvent soulever l'ampli vers l'arrière, ce qui le rend un peu ridicule...
Gabriel L.
Un must
Pas l'habitude de donner mon avis, mais c'est vraiment bluffant ce petit préampli au prix ridicule comparé à la HIFI des grandes marques. Après avoir dépensé des milliers d'euros je me suis tourné vers des produits moins ésotériques et c'est gagné à 100%. il faut vraiment remplacer rapidement les tubes d'origines par les GE 5654, le son n'est plus le même. Pour info je fonctionne avec un lecteur maison sous Daphile, un dac Dopping D70, le superbe ampli AUDIOPHONICS MPA-S125NC (extra avec le tube 03) et des enceintes Higland Audio Aingel 3205, dans une pièce de + de 40 m2 c'est juste incroyable.
David G.
FX-AUDIO D01 DAC Headphone Amplifier Bluetooth 5.0 ES9038Q2M TPA6120A2 XMOS CSR8675 32bit 768kHz DSD512 Featuring an excellent 32-bit ES9038Q2M digital-to-analog conversion chip, the DAC FX-Audio D01 offers excellent audio performance with a wide dynamic range, low distortion, and...
Nickel.
Bt reconnu immédiatement, pas besoin de pilote pour l'entrée usb sur pc windows 10.
Seul bémol, le volume un peu faible, je dois positionner le potard au delà de 60 %. Il faut un ampli avec de la pêche derrière.
David G.
Fiches pas tip top
Les fiches de ces câbles forcent beaucoup sur les entrées de mon technics su8044. Problème que je ne rencontre pas avec des câbles génériques. J'ai branché ces dynavox sur des appareils plus récents et ça passe.
Claudio c.
FIIO FD1 In-Ear Monitor IEM Beryllium Plated Dynamic Drivers With the FD1, Fiio offers high-quality in-ear headphones at a reduced price. They benefit from a careful design to offer a rich and immersive sound reproduction, as well as an...
Incroyable écouteur
Pour le prix c'est vraiment incroyable, ergonomie au top , le son très dynamique vraiment imbattable pour son prix. Il va droit au but , donner du plaisir à l"écoute.
Florent L.
Wow Viborg
hello, le TOP!
