Jean-Claude F.
Très bon câble HP
Jean-Claude F.
Yvain C.
J’ai hâte de la...
Rene R.
Rroels
Nous sommes deux a avoir testé cet AOP, sur deux dac similaires de chez audiophonics et d autres fabricants utilisant le même AOP
Musical ,mais produit trop audiophile, manque d ouverture,les ambiances de salles,les instruments son bien reproduits mais avec une certaine retenue, manque de lisibilité dans les extrêmes,manque de naturel,décevant..........
Le LME 49720 HA, est plus exubérant ( peut être trop......), mais beaucoup plus réaliste sur les timbres et la restitution des différents lieux d enregistrement , plus vivant, plus rapide
A méditer!!!!!!!
Michalis B.
Great switch
Things are simple!
Works exactly as you read here.
Press once ON, press again OFF and vice versa!
Means, press once OFF, press again ON
The LED lights more beatiful than you see on pictures here! Looks like "very" high end your build!
Michalis B.
Nice quality connectors
Not much words to say!
If your needs is something nice, cheap, stable on screwing, you have a good reason to buy these connectors!
Thank you audiophonics for your products!
Philip H.
Amazing everything
The RASPDAC MINI arrived quickly, at reasonable cost and well packed.
Assembly was simple and the instructions were detailed. With the exception of a battery for the remote and a USB charger (and the Pi and micro SD) everything was included.
moOde is a better option than Volumio, especially if you want Spotify support. I didn't try the other two options. I downloaded and burned the images onto a mini SD card in minutes.
The RASPDAC MINI itself looks REALLY GOOD. I like the minimal interface and the tiny screen looks pefect through the smoked perspex.
And, finally, the sound is crisp and clear, even from relatively low-quality internet radio. Using a decent Spotify stream gives a gorgeous bright sound that really makes the most of my system.
Thank you, AUDIOPHONICS!
Victor M.
a great little brick
maybe not exactly my sound signature, but this little piece of equipment is beautufully built and does sound and work wonderfully. It is definitely a keeper! Audiophonics=great customer service!
Pierre P.
LKS USB-100 Digtial Interface AMANERO USB to SPDIF I2S LVDS HDMI 32bit 384khz DSD512 This USB interface to HDMI I2S LVDS and I2S RJ45 offers excellent sound performance thanks to a high level of electronic design quality. The LKS USB-100 is ideal on a high-end...
Interface très efficace
Elle nettoie bien la pollution présente dans la sortie USB de la carte mère. Ainsi l'entrée usb du dac gagne beaucoup en qualité ( silence, aération, beauté des timbres...). L'entrée usb se trouve au niveau de l'I2S.
Transfigure un dac comme le Topping D70.
Pierre P.
Dual Linear Power Supply Module LT3042 5V 1A This linear power supply module with two outputs is based on an LT3042 and a pair of high-performance A1930 transistors from Toshiba. It benefits from the PSRR architecture...
Excellent module
Je l'ai utilisé en rentrant en continu (après les diodes).
Alimentation très silencieuse qui fait bien son job.
Didier V.
Service rapide et parfait. Prix très raisonnable. Envoi rapide et bien sécurisé. Déjà recommandé aux passionnés!
Jean-Jacques J.
RQP imprésionnant !!!
à moins de 400€ en longueur de 3.5 mètres c'est difficile de trouver mieux, le registre le plus surprenant étant les basses enfin plutôt la tenue de celles-ci, la scéne sonore globale est beaucoup plus ouverte aussi par rapport à des Cardas bi-cablés ou des WhyNot FLASH (début de gamme chez WhyNot)...Les terminaisons bananes que j'ai sur ces cables ne ressemblent pas par contre à celle que l'on peut voir sur les photos de votre site est-ce normal ou pas (perso c'est pas génant pour moi dans le sens ou ceux que j'ai reçu m'ont limite l'air plus qualitatif que ceux sur vos photos) ?
Francisco Jose P.
Qualité d'image nette
Achetez ce câble avec les connecteurs Furutech FI-8.1 NCF et FI-E50 NCF (R) pour connecter un téléviseur Samsung 4K.
J'ai opté pour cet OCC car à mon avis il est plus vierge dans la transmission de l'énergie électrique par rapport à un U-OFC du même prix.
Dès que j'ai allumé l'écran, j'ai été surpris par la clarté accrue de l'écran, avec quelques images de référence, j'ai pu apprécier ce que faisait cet ensemble:
L'aspect d'écran sale a disparu presque complètement. Appréciez les nuances de couleurs dégradées que je ne connaissais pas, les couleurs sont vibrantes, saturées et à un niveau authentiquement différent et très similaire à la vie réelle, certains semblent regarder une fenêtre et non un écran comme avant d'installer ce câble et son jeu de connecteurs. Les ombres et les images dans l'obscurité sont apparues pour laisser place à un fond noir qui a donné lieu à plus d'informations et de détails. Dans les images en mouvement et dans la transition, par exemple, des onglets d'ouverture et de fermeture dans Windows, la réponse en millisecondes montre qu'elle a été raccourcie pour donner des images plus douces et plus précises dans son mouvement. Le son est un autre grand effet évidemment affecté, pouvant augmenter plus de points de volume que la quantité normale que j'utilisais, avec un son avec beaucoup de corps et de détails, et une scène sonore accrue dans toutes les directions à la fois en largeur, hauteur, profondeur en avant et en arrière, Tous très bien contrôlés. Tout cela au cours de la première semaine de tournage, par expérience, je sais que ces Furutech OCC gagnent en qualité avec le temps.
Franck P.
Excelent Produit
Excellent produit, simple d'utilisation mais n'est pas compatible avec tous type d'appareil ( Xbox mini 4k de Bouygues Télécom)
Jerry L.
Good, but has a dominating character
Sounds warm and smooth. Easy listening. However, its inherent warmness is quite dominating and will even mask up the characteristics of some sources. Same observation in a few different systems. Having that said, it is still reasonably good if warm and sweet is your preference.
Kinn R.
stephane j.
SUBERBE COULEURE ,NAVETTE LED BLEU
Livraison ; ULTRA RAPIDE !!
Service après vente : AU TOP & a l’écoute de votre demande !
En bref : UN RAPPORT QUALITÉ PRIX : IMPECCABLE ,pour des navettes de qualité ; QUI DURENT DANS LE TEMPS ! Merci
Kristijan K.
Just brilliant
With Voskhod 6J1P-EV or even better GE JAN5654W tubes instead of the original Chinese 6J1, this little thing simply increased the level of my system. Something completely new and fresh. Nice and warm tube sound. And believe me, my system already sounded very good. And the asked price is a joke. I also changed both the opamps with OPA627 behind the tone controls and with OPA1622 on the output stage for further sound coloration. I don't believe there are or could be many things that will give you more value for money.
patrice f.
avis sur rca ramm 30891 gt
associé à un nemoi 3220, excellent rendu audio !
prévoir une clé 6 pans mâle de 1.3 pour le serrage point chaud
fabrication qui inspire confiance
obligation " d'éplucher " au cutter le nemoi, car le diamètre
intérieur n'est que de 9.5 environ en ôtant le manchon plastique.
très satisfait du résultat global.
patrice f.
avis sur cable nemoi 3220
bien mieux que le câble écossais qu'il remplace.
entièrement d'accord avec Yannick M (28 04 2018) auquel j'ajoute:
câble vif ; je redécouvre mes cd, ce neotech me permet d'entendre
des sons inaudibles auparavant ! un régal !
patrice f.
soudure mundorf argent or
très satisfait de ce fil de soudure, bonne adhérence
utilisé avec fer 60w
Terriblement efficaces
J'avais ces absorbeurs dans un tiroir car achetés pour mon ampli à tube trop lourd..
Hier soir, j'ai eu l'idée de les glisser sous le Dac Audio-Gd R8.
Quand j'ai remis le son, je n'en croyais pas mes oreilles, tout était plus aéré, limpide, les basses plus nettes.
Il faut dire que le Dac est à 50cm d'une enceinte, et n'étant pas prix nobel de physique, je suppose que le courant qui traverse le matériaux des composants qui microvibrent c'est pas top.
Regret de n'y avoir pas pensé avant.
Pas de problème d'installation de la barrette, ni de fonctionnement de chacune des prises.
Je recherchais une multiprise simple, non filtrée.
Couplée à la prise secteur murale avec un Pangea ac9se mkII. Sur les appareils j'ai tout en Pangea secteur, dont les diamètres varient selon le type de maillon.
L'amélioration du rendu audio par rapport à mon ancienne multiprise en plastique est réelle: plus de matière partout, surtout les basses ont pris du corps et de l'énergie, dans le médium aigu la dynamique est meilleure dans le sens où c'est plus délié, le seuil de durcissement est relevé.
Bon rapport qualité prix pour moi, je ne voulais pas mettre une fortune dans ce genre de matériel.
Axel T.
M'a apporté le petit quelque chose qui manquait pour savourer pleinement le son de mes intras sur smartphone.
La construction en aluminium donne une impression de qualité à l’œil et au toucher.
Bart L.
Excellent value for money
Nice cable, sounds great. Very well made, fast delvery to the Netherlands.
Excellent tube
C'est ces tubes que l'excellente marque Line Magnetic monte d'origine sur ses amplis et notamment le LM-211A.
Mais ils sont sérigraphiés " Line Magntic ".
Ces tube sont du niveau du TUNG-SOL dont j'ai déjà fait l'éloge.
Christophe P.
Mini ampli casque nomade ultra compact qui tient dans le creux de la main. Design simple et qui inspire confiance. Associé à un lecteur mp3 Sony NW-A45 Hi-RES et un casque Fostex T-50RP MK3, il tient parfaitement son rôle. Son limpide -rien à redire- et il permet d'étayer le volume avec un casque gourmand. L'autonomie de la batterie est également très, très bonne. Je recommande.
bon rapport qualité prix
interface moderne, tactile et soignée : agréable et bien pensée.
Facile à utiliser, rapide pour se deplacer dans la bibliotheque
Possibilité de naviguer par dossier et sous-dossier.
Scan de la bibliotheque un peu long, mais pas plus que mon smarphone.
traduction française bonne, bons paramètres.
Volume ingénieux.
égaliseur manuel pas facile à régler et grosse baisse de sensibilité quand on l'active.
high or low gain output disponible
superbe écran, réglages luminosité, veille, theme de couleur, veille avec pochette.
Pas trouvé de négatif dans ce lecteur.
Melvin L.
excellent mais mérite d’être corrigé
j'ai essayé le produit : il reçoit tous les parasites environnants (rayonnement) et le bourdonnement caractéristique était toujours + ou - présent. (il suffit de le placer pas loin d'un transformateur d'alimentation en 50 Hz et la c'est la catastrophe.)
ce que j'ai fait :
1) au niveau du câble, il faut séparer les deux tresses de masse en interne de chaque coté afin d'éviter complètement les boucles de masse...il faut procéder au coupage puis grattage de la piste du PCB interne (a deux endroits) et venir ressouder directement les fils des prises RCA sur les bornes des transformateurs BF.
2) il faut tirer une tresse de masse reliée a une des prises de votre choix (une prise de préférence ou la terre y est raccordée)...la souder en interne direct sur le PCB....scotcher toute l’électronique en laissant dépasser cette tresse...faire une a deux couches de feuille d'aluminium sur cette électronique interne et faire prendre avec en sandwich la tresse. (blindage électromagnétique)
ce blindage permet d'éviter de recevoir le rayonnement induit par un transformateur d'alimentation ou des câbles secteurs (ramassage du 50 Hz)...grâce a ces deux grosse modifications, mon installation est parfaitement silencieuse dans un environnement très chahuté (rack d'amplificateurs multiples).
pour résumer : bon produit mais cela demande a être amélioré d'origine.
Bruno P.
Excellente
Déjà elle sonnait très bien mais avec un changement de composants interne, elle est complétement réveillée gain de détails, dynamisme.
Voici les composants:
-Fil de câblage multibrins Cuivre Plaqué Argent Isolé PTFE 1.23mm² Rouge
-Fil de câblage multibrins Cuivre Plaqué Argent Isolé PTFE 1.23mm² Noir
-JANTZEN AUDIO SUPERIOR Z-CAP Condensateur 800V 6.8µF
-MUNDORF MRESIST SUPREME MRES20-2.7 Résistance 20W 2.7 Ohm
Excellente maintenant
Jacques S.
Alimentation à décuopage pour FDA alientek D8
Alimentation SMPS 24 V montée dans un boiter aluminium, câblée avec fils Néotch multibrins 1,3
mm2+ connecteur Elecaudio DC et pour le secteur un câble MIT en direct modifié avec une prise Viborg VE 501cuivre pur + inter aviation, L'alimentation sert à alimenter un FDA Alientek D8 .
Le gain en restitution est très supérieur à à l'alimentation d'origine , avec un parfait silence de fonctionnement (message parfaitement propre et non pollué) : Augmentation de la transparence avec encore plus de détails , meilleur séparation des pupitres ( beaucoup d'air circule entre les instruments),temps de monté accru au niveau du FDA qui génère de très bonnes attaques ainsi que de belles extinctions de notes sont au rendez-vous, le tout accompagné d'une justesse des timbres avec fluidité et dynamique. Alimentation vivement recommandée pour tout FDA et n'ayant rien à envier à une alimentation linéaire plus coûteuse et gourmande en énergie.
Une bonne alimentation sublime l'alientek D8 déjà excellent en mode flat.
Encore merci à Audiophonics pour les produits proposés et le service de qualité.
Cordialement et musicalement Jacques.
Jean-Luc G.
Un ampli ? Quel ampli ?
Tout a été dit ici. En fait, c’est comme si mes enceintes étaient reliées direct à la source musicale, comme s’il n’y avait pas d’ampli : le AD18 n’existe pas, et le gros son analogique sort du tuyau. Je n’ai même pas cherché dans les réglages programmés. Appréciable aussi à faible volume.
À éviter pour un audiofile qui veut entendre son ampli, il n’y a rien à entendre ici, à part de petits clics quand on change de source avec la télécommande. Pas de distorsion à vol30/60, je n’ai pas encore eu besoin de pousser plus loin. La puissance n’est pas scénique, juste domestique.
Devant il est mignon, mais derrière c’est un sac de fils à commencer par l’alim qui est plus grosse que le AD18. Plein de possibilités à brancher derrière un petit boîtier. On peut isoler entre elles les grosses fiches banane avec un tour d’adhésif.
Au prix où sont ces petits FDA, ça vaut vraiment le coup d’essayer. Faites couler doucement la musique dans le tuyau, le AD18 distribue le débit en toute transparence. C’est l’avantage paradoxal du full digital : il livre tels quels les sons électro mais il laisse passer le vrai son analogique d’origine.
FURUTECH Alpha-S14 Speaker Cable µ-OCC Copper Alpha Treatment 2x2mm² Ø8.9mm This FURUTECH Alpha S14 speaker cable in multi-strand OCC copper with Alpha treatment (anti-magnetic, cryogenic) is an elegant solution. Here's a simple, effective loudspeaker...
Superbe câble
A la fois souple et très bien isolé, ce multibrin est parfait pour ma configuration YBA / Monitor Audio Silver. Je recommande vivement.
Nicolas T.
Parfait pour moi
Facile à insérer dans tous les connecteurs, bonne résistance et contact à priori impeccable, sans risque d'arracher les bornes à l'extraction. C'est ma première commande de ces fiches bananes, mais pas la dernière
Nicolas T.
Etonnant!
Acheté pour alimenter des grosses colonnes Atohm, le résultat est bluffant. Bien entendu, nous sommes pas encore au niveau des meilleurs, mais à ce prix, c'est tout à fait incroyable. Je ne regrette pas.
Kristijan K.
TOPPING A50 Headphone Amplifier Balanced Silver The Topping A50 is an efficient and affordable sedentary headphone amplifier. Its careful design makes it an ideal ally for any audiophile wishing to enjoy a rich and clear...
Versatile headphone amp
I am using this connected to the Topping D50s DAC. It drives my AKG K712 and Sennheiser HD headphones. It can drive them both at the same time which I especially like because now both my wife and I can listen to the music at the same time :-) or I can switch the headphones for different genres. And it sounds fair enough good. Clean, no hissing or buzzing, not warm sounding, not cold sounding, the bass is good, feels like it has a tons of power, around 10-11 O'clock on high gain sounds like you are at some live concert. I also like the way it controls it's line out so when you turn it on it disconnects the line out (to my amp+speakers). The relays operate quietly and quickly. The volume knob is smooth. The device feels robust and really nice built. Tried also some other opamps but eventually returned to the original LM49720. So here is a first con: there is simply no place for some custom built opamps on adapters, only for regular size DIP8 chips. Keep this in mind if you want to give a go to some opamp rolling. The only real big thing I could image that would make this device just perfect would probably be a remote control as the volume is already digitized. But, well, for the price, it already has many qualities and features. And perhaps the biggest and serious con is a power button that serves as a power button on long press and as a gain switch on short press. So the one has to be extra careful when operate this button and listening at low gain because a short click will switch the output power to high gain.
Kristijan K.
Great little DAC with a big sound
This is actually my second standalone DAC. Purchased the Topping D70 a month ago for my main system. But since it initially sounded somewhat slow and weak on the bass, I had to make some further system enhancements to fix it (added a tube preamp). I wanted another DAC for my second system for headphones, so decided to try something from the opposite camp (ESS). Well, honestly, this little DAC is a gem. It sounds bright, clean, detailed, the bass hits you, slams like a thunder, it is faster and rocks in many ways. Definitely not warm or velvet sounding like the D70, but it sounds so differently good. And when I changed the socketed opamp (LME49720NA) for the AD797BRZ, the sound just exploded in every direction in every positive sense. Technically speaking it also works great. Completely silent when changing tracks of different frequencies, works on a ten euro cell phone charger without a trace of hissing or buzzing, supports the Bluetooth that works flawlessly, can turn off its display completely (the D70 has only a dimmer), feels nicely and robustly made, has small footprint and doesn't occupy much space, can control the volume on DSD tracks, comes with a remote control and costs 249 euros. Well, as I already mentioned, It sounds different in comparison to the D70, but I can't say which one actually sounds better or which one I like more. They both sound great. Perhaps you can't cover everything with a single DAC. To sum up my impressions, the D50s is a fantastic device.
Kristijan K.
Vocal enhancer
Tried this within the Topping D50s DAC instead of the LM49720NA and it sounded like, well, unplugged :-). Seriously. Vocals forward, everything else a mile behind. Weird. But vocals sounded like a million bucks. Honestly, in 20 years I've never heard better vocals from my speakers. So I put it into my FX-Audio Tube-03 preamp on the output stage connected between the Topping D70 DAC and Fase Performance amp and that combination sounds incredibly good. Brilliant opamp.
Kristijan K.
Warm and dark sounding opamp
For many years I was using a pair of these as a buffer in my HT Omega Claro Halo XT soundcard in combination with a pair of AD797 on the I/V stage. Currently I am using it in the FX-Audio Tube-03 tube preamp in combination with the OPA1622 on the output. Also tried it with some other components. The common experience with this opamp is that it makes sound warm and dark. The sound has nice depth. It also produces/adds full meaty bass. Now, if you prefer bright and/or analytical sound with tons of details and bright vocals, then maybe this opamp will not suits you. Overall this is a very musical, warm and nice sounding opamp, especially for jazz and light ambient music.
Joël P.
vraiment top
j'ai acheté ce kit en ayant un peu peur n'ayant jamais assemblé ce type de matériel d'une part et d'autre part je n'étais pas sûr que la qualité d'écoute soit au rendez-vous .Et bien je suis totalement rassuré, non seulement c'est trés facile à monter mais en plus le résultat est probant.
Je me sers de ce kit pour alimenter un Auris Euterpe/Casque Focal Clear en analogique, le résultat est supérieur à l'écoute à la combinaison Macbook/Audirvana/Dac de L'Euterpe aussi bien sur la dynamique que sur la véracité des timbres , je suis vraiment très content .
Il parait que l'on peut encore améliorer ce kit en utilisant une alimentation soignée...Hélas mes compétentes dans le domaine sont trop faibles pour opérer un choix...Je vais contacter les spécialistes d'Audiophonics.
Stephan R.
Bonne qualité .Attention aux dimensions de la découpe pour le filtre.Il faut légèrement agrandir pour rentrer un filtre SCHAFFNER FN9222.
Jean-Francois C.
Super!
Achetées pour remplacer la totalité des ampoules (7) sur mon Ampli-tuner MARANTZ 2265. Magnifique résultat, il faut juste faire attention à bien positionner les leds en face avant (pour ma part, j'ai fait avec des pinces brucelles). Bravo et merci à Audiophonics pour le rapport qualité prix et les délais de livraison!!!
F.J. d.
Execellent product, absolutely satisfied!
Always a guess when you order a casing. This one is very satisfactory! All components fit perfectly. The case was assembled without any effort.
One tip: Add exact drawings, having all dimensions makes it easier to add or adapt stuff. The end result will be even more perfect ;) I , for example, need to modify the top 'lid' to fit 3 transformers and two large KT120 tubes. Replacing the top lid with another plate is easiest but I need accurate dimension to get a good result without the inaccuracy of measuring it myself.
Elsa A.
Prise NCF extra
Je l'ai montée en prise murale et sur 2 barrettes multiprises, gain sur beaucoup de paramètres d'où le relief amélioré.
pour l'adaptation en prise murale: j'ai adapté un modèle à 4€ à cache circulaire car mes murs en béton ont des encastrements de profondeur limitée : (
je ne sais pas si la prise murale Furutech à 3 fois le prix de celle-ci est meilleure, mais je suis Ok avec mon adaptation.
Gianni D.
Ottimo Prodotto
Il Prodotto è ottimo! La componentistica è di livello alto, il suono è molto neutro. A me ha soddisfatto appieno!
Rolando C.
cable para tocadisco
Compre este cable para recablear mi Linn Axis y funciona muy bien, el trato de esta casa es muy cordial y fiables. Los envios son muy rapidos. Altamente recomendados. un saludo
priam l.
module de protection HP
Bonsoir, je viens de recevoir le module mais je ne trouve pas d'explication pour relier les fils surtout pour l'alimentation 12V DC merci pour votre aide
Jean-Marc F.
Magic Ampli ;)
Avec ce petit amplificateur au son insoupçonné, je redécouvre mes enceintes Radius Audio Monitor et ce , beaucoup mieux qu'avec mon ancien DENON PMA-710 AE moins dynamique...Étonnant ! Et par dessus le marché, il est d 'un excellent rapport/qualité prix ,à acheter sans hésitation ! J'ajouterais aussi, l'impeccable service d'Audiophonics,merci à l'équipe. ( NB;écoute sans subwoofer)
Yves T.
Parfaitement adapté à mon ampli AUDIOPHONICS TPA-SW25F Amplificateur 2.1. La prise n'est pas identique à celle de la photo mais comme la rallonge est livrée avec …..
Yves T.
Efficace et pas cher
J'ai acheté cet ampli pour remplacer celui de mon ensemble home-cinéma 2.1 Focal dont j'aimais le son mais dont l'alimentation était morte. Les ampli 2.1 ne sont pas légion sur le marché….il y avait celui-là et je ne regrette pas mon achat. Il est tout petit, discret, assez puissant et de construction robuste; je pense qu'il est meilleur que celui d'origine. Quelques bémols, une diode trop vive et qui ne s'éteint pas (ou change de couleur) et des sérigraphies peu visibles. Mais de grandes qualités en regard de son prix et de la rareté de ce genre de produit.
Dominique C.
Est-ce aussi "supreme sound" que son nom le laisse l'entendre ?
Testé sur couple Hifiman 4xx + Xduoo XD-05 Plus en remplacement de l'AOP d'origine. N'en déplaise à certains mais personnellement je n'ai constaté aucune amélioration notable sur l'ensemble du spectre sonore, d'ou le 3 étoiles. A l'instar de l'AOP d'origine qui a une rendu exceptionnel, avec cette ouverture et une précision remarquable qui doit être propre à l’AOP d’orgine, le Burson lui ajoute un voile et vient dénaturer (boucher) l'écoute, la rendant moins précise, moins exceptionnelle. Pas top du coup ! Ceci dit, avec le Burson on remarque effectivement des changements assez importants sur certains instruments, notamment la grosse caisse ou la caisse claire, les rendant plus percutants, plus énergique, les cordes sont également transformées de la même manière. Est-ce en bien ou en mal je suis incapable de le dire, mais c'est sûr que ça "claque" un peu plus avec le Burson et tous les "effets" ajoutés à la musique sont un peu plus "marqués". Cependant, j'ai remis l'AOP d'origine car après quelques heures d'écoutes je me suis rendu compte que "quelque chose" manquait et cela s’est immédiatement manifesté par une disparition du voile, redonnant toute sa splendeur à l'écoute de mon Hifiman avec ce Xduoo. Quelle précision ! Quelle ouverture ! Comment s’en passer ? Hop retour dans sa boite le Burson, dommage. Pour conclure Je ne peux donc pas affirmer que ce changement d'AOP soit bénéfique à tout le monde en ajoutant vraiment quelque chose à la qualité finale du rendu.
Thierry B.
Une petite merveille
Première commande sur Audiophonics, réception parfaite en 3 jours, rien à dire. On est d'abord surpris par le look minimaliste et le gabarit de l'engin. Après les branchements sur enceintes Triangle Elara LN 01 et une connection sans problême sur bluetooth, on se lance et là...quelle claque!!
Sons précis, pas de distorsion même en poussant le volume, des basses nettes et pas baveuses. J'ai testé ensuite en USB et en optique avec chromecast audio, rien que du très bon, les différences entre les entrées sont peu palpables.
Toutes les personnes qui passent et découvrent cet ampli sont agréablement surprises par la qualité d'un si petit ampli. Au point que mon beau-fils va en commander un...
L'essayer c'est l'adopter!
Jean Luc m.
MUNDORF 2.8G Insulated Female Blade Terminal Gold Plated 2.8mm 0.5-1.5mm² Red (x10) These female blade connectors allow a simple and fast connection/disconnection while ensuring excellent contact. The contacts of these connectors are gold...
Très bien ,mais...
Très bon contact,correspond à mes attentes mais il faut savoir que pour le sertissage(avec pince appropriée)il faut enlever l'isolant et que par la suite celui ci ne se replace pas
bien du fait de la déformation au niveau du sertissage.
Coté résultat j'ai l'impression d'une meilleur transparence
ainsi qu'une présence accrue.
Les graves sont renforcés et les aigus plus fins.
Je précise que l'opération a consisté au changement des cosses d'origine de raccordement des HP sur les enceintes.
