Marcus L.
Michael M.
Worth every penny!
mathieu l.
SangYoon Y.
Am I the first one?
I received it 3 days after I ordered it in Korea. Hypex's reputation made me nod.
Compared to previous amplifiers, the stage mood has expanded and the instrument's sense of hitting and separation at mid-low notes has definitely improved.
From high to low range, It plays a textured yet clear sound.
I like the housing material of the amplifier and the heat is a little lukewarm.
Even this is the impression of a situation where I don't connect an external DAC and connect with the line-out of the PC! From now on, all I have to do is choose DAC in a happy mood.
I pay tribute to a Member who said NC252MP was a fantastic combination with 'Davis olympia one master'. It's just the way it is.
Tomas H.
Buy with confidence!!
The best Speaker Cable I´ve built so far!
I´ve paired it up with Viborg VB402R connectors with very nice result!
I´ve f.ex. recently built one "RAMM AUDIO AMADEUS 5 MK2" that´s about three times as expensive/meter. Burned the RAMM in with NordOst-equipment, but still it is NOT as musical as my old MOGAMI.
the Mogami is far mor lively and presents music more "real" and with more energy.
It´s just a fantastic cable that I absolutely and with confidence can recommend for all you DIY´rs out there!!
Just remember to order big enough connectors, since this is a large snake.
PATRICK D.
Fonctionne parfaitement avec Sigma Studio. Une étoile en moins car il faut connecter la carte de programmation à l'ordinateur puis connecter le DSP à la carte de programmation pour voir apparaitre le bon driver dans le gestionnaire de périphérique.
PATRICK D.
Impressionnant
J'ai acheté ce DSP pour tester son potentiel en égalisation par convolution avec utilisation de fichiers issus de REPHASE afin d'envisager son utilisation en tandem ou en remplacement des mes DCX2496. Ne connaissant pas ce type de matériel, la prise en main m'a demandé un peu de persévérance mais le résultat est à la hauteur. Les possibilités de programmation sont impressionnantes et l’AUTO-EQ fait pratiquement jeu égal avec celui de ROOM EQ WIZARD.
Dans un premier temps j'utilise le DSP en écoute comparative avec EQUALIZER APO sur ordinateur avec carte son ZOOM UAC2, ampli SMSL SA-98E et enceintes DAVIS EVA.
En partant de l'égalisation d'une même mesure effectuée avec REW, les premières écoutes sont très encourageantes. La seule limitation de ce DSP est le nombre de TAPS utilisable. Sur une égalisation paramétrique cela ne pose pas de problème mais par convolution cela nécessite d'utiliser un module par voie.
Les difficultés que j'ai rencontrées sont:
- Il n'existe pas de manuel d'aide
- La syntaxe des lignes d'entête des fichiers à importer dans l'AUTO-EQ
- La position des switchs en phase de programmation et d'utilisation du DSP
- L'utilisation du driver USB dû au fait qu'il faut connecter la carte de programmation à l'ordinateur puis connecter le DSP à la carte de programmation. Je n'ai pas testé si la position des switchs a une influence sur ce point.
Il est à noter qu'il faut éviter d'utiliser un port USB de l'ordinateur pour alimenter le DSP sous peine de rencontrer des bruits parasites non négligeables.
PATRICK D.
RAS
La prise USB n'est pas située comme sur la photo
PATRICK D.
RAS produit conforme
Câble est assez rigide
Dario G.
Beau et produit sérieux.
Dario G.
Très très bien
Marque et produit sérieux ! Rapport qualité prix sans commentaire !
Absolument recommandé.
thierry V.
Après branchement des sources, streameur en optique et ordi en USB (problème de pilote en cours), et liaison RCA sur ampli, net amélioration du rendu des écoutes sur streameur. Son propre, détaillé, sans fioritures. Peut-être un petit manque de flamboyance, mais à ce prix on l'excuse largement ! Sortie casque impeccable également. Pour la lecture via USB, j'attends de résoudre le souci du driver, qui vient de mon ordi et non du Dac. Satisfait des performances et de sa praticité.
Kenneth m.
Super ddc
It makes me use my fanless PC and big screen all the time now. Clearly surpasses the sound from my ifi zen stream, by several steps. This is in the spirit of Alan Blumlein, who invented e.g. stereo, with the screen in mind. The only downside is max 24bit 192 kHz, so it can only handle 99.98% of all media.
Remember a USB-B Adapter Cable for DC 5.5 / 2.1mm Female Power Supply, also bought here, and some good clean 5v, not the 5v pc noise power;)
Jan S.
AUNE XC1 Master Clock OCXO 10MHz Black The Aune XC1 is an external master clock, using a high quality OCXO and featuring four isolated outputs, capable of operating simultaneously. Its ability to provide an extremely...
Nice first Buy.
It was a gamble. Buy a more expensive clock or a cheaper? Didn't now what to expect. My first external clock. XC1 deliver! Using it with Gustard R26. The overall sound is calmer and quiter background.
Miroslava L.
NEOTECH SOCT-18 Wiring cable Copper UP-OCC PTFE 0.8mm² Neotech has long been the leader in cable production using UP-OCC "single crystal" copper developed by Professor Ohno of the Chiba Institute of Technology in Japan.
Maximum satisfaction
Miroslava L.
IAN CANADA TRANSPORTPI MKII Low Jitter Digital Audio Interface Transmitter The Ian Canada TransportPi MKII module is a low jitter digital audio interface compatible with the Raspberry Pi. It has been specifically designed in pure synchronous mode to...
Pierrick R.
1MII LAVAUDIO DS220 Bluetooth 5.1 Receiver QCC5125 DAC ES9018K2M aptX Adaptive LDAC This small, practical and compact 1Mii Lavaudio DS220 Bluetooth 5.1 receiver brings wireless connectivity to your HiFi system. Its high-quality design is based on the...
Étonné
Pour completer mon precedent avis, le Ds220 fait aussi bien en Flac avec des sources HighRes audio (96khz/ 24 bits) que mon Dac Smsl su-1 connecté à un pc sans compression aucune. Incroyable !
Miroslava L.
Paulius S.
FP-S022N
Expensive but very good.
Paulius S.
SCHURTER IEC socket for soldering boxes This SCHURTER IEC subbase is ideal for integration into a housing during DIY installation.
IEC socket
Very good for the price.
Paulius S.
Standart Z
Just like promised, sounds detailed fast smooth.
Jean-François A.
Condensateur très musical
Ce condensateur va encore plus loin que les excellents Nichicon ou Kendeil (et même les CO39).Un rendu moins sombre, tout semble "relevé" mais sans aucune outrance. Mais surtout beaucoup de vie et de rythme sur tout la bande audio. En fait on ne se pose plus de question car il n'y a aucun revers de dureté du son. Un investissement, car il sont onéreux mais ça en vaut la "chandelle". Merci Audiophonics pour l'approvisionnement de ces condensateurs.
Sorin P.
Superb quality
This thing is the real deal. I made a power strip with it to have my dedicated power line from the wall. I used a Panasonic no-cable power strip and a Legrand plug. I was using a Bachmann power strip before. Improvements across the board, but especially the bass is phenomenal. Even if it's a bit stiff, copper is not a hard metal and you can easily shape the cable and it will stay in place without issues. Highly recommended!
Didier a.
4 Channel RCA Input Selector Module This module will allow you to integrate a four-channel source selection system into a DIY project. It consists of three separate components: the switch module, the inputs and...
Il ne faut qu'ajouter un transfo pour faire fonctionner ce module qui est classique (sélection par relais 5VDC). Le module RCA doit être remplacé par des fiches RCA individuelles pour un usage plus "audiophile". La méthode de sélection par un bouton poussoir et un affichage de la source sélectionnée par LED est pratique. Par contre il faut dessouder le bouton poussoir pour pouvoir le placer en face avant ce qui n'est pas bien pensé...
Didier a.
Emballage un p
Pour ce type de produit haut de gamme, je m'attendais à le voir fourni dans une boite et avec un guide d'utilisation et de branchement. J'ai donc été déçu de le voir emballé dans une enveloppe à bulles entourée d'une feuille de carton et sans aucun document d'accompagnement (heureusement il y a de la documentation sur le site). Donc emballage robuste mais pas très "classe" pour ce produit "Hi-Tech". Sinon, le produit à l'air de qualité.
LINDY CROMO LINE Gold Plated Male USB-A / Male USB-B 2.0 Cable 2m The Cromo series is the most powerful USB cables manufactured by Lindy. This one relies on a well thought out design and oriented towards a technical reality, to meet a need for...
Câble classique, bon rapport qualité/prix.
Câble classique, le construction à l'air solide.
L'habillage des prises en plastique chromé fait un peu cheap je trouve mais la connectique elle même est de bonne qualité.
Il fait son boulot pour relier mon PC à un reclocker USB.
A ce prix il n'y a rien à dire.
Livraison Audiophonics parfaite, comme toujours.
Pierre P.
Streamer Qobuz
J’ai acheté le Wiim pro+ pour Streamer Qobuz en hires et le résultat est satisfaisant.je passe par un dac externe oppo ha1que je possède depuis quelques années et le résultat est super avec les fichiers en hires. Pour un prix raisonnable, mon système hifi est remis au goût du jour.
Le Streamer a l’air de qualité, fonctionne très bien et le service Audiophonic est super a recommander sans hésiter
Pierre
Didier a.
Interrupteur à ne pas souder
J'ai eu le malheur de souder les fils sur les cosses. J'ai dû les dessouder pour un ajustage et tout à fondu (cosses et contacts sont sortis du boitier qui avait fondu...). donc si vous voulez utiliser cet interrupteur, utiliser des cosses à sertir pour le cablage.
Câble sérieusement construit.
Avoir du cuivre OCC et OCC plaqué argent à ce prix c'est une aubaine.
Musicalement: je l'utilise après un reclocker Wyred4Sound Recovery et j'ai un gain sensible en détail et définition, surtout sur les aigus.
Il fait bien son boulot.
Livraison Audiophonics au top, comme d'hab.
Didier a.
Boitier solide
Ce boitier est d'une conception robuste. Il manque toutefois une notice de construction pour en faciliter l'assemblage. De plus, j'ai dû ajuster les trous de fixation de la face avant (en limant les trous existants), ceux existants n'étant pas bien situés (1 à 2 mm de décalage). Dommage car c'est un bon produit.
Vivien V.
INCROYABLE
Mettons de côté la question de la puissance brute, c est une claque monumentale ! Même à fort volume ce petit FDA pilote des grosses Dynaudio sans problème. La restitution est ultra détaillée, précise une neutralité quasi irréprochable. Un vrai pousse au crime, l’envie de monter le volume est omniprésente car l’écoute est vraiment très agréable et ce même à fort volume. L’image stéréo est vraiment convaincante, englobante mais je dois avouer que cette enthousiasme n’est rien face à une source full numérique. Streamez de la musique en 192 KHz depuis Qobuz via l’entrée optique et là on passe dans une tout autre dimension. Un peu de négatif tout de même… l’écran est nul, la navigation dans les options de l’ampli est de fait pas évidente... mais bon à ce prix ce serait dommage de s’en priver. Je pose ça là mais j’ai eu l’occasion de posséder des appareils bien plus onéreux et pourtant bien moins performants.
Frederic S.
Tout respire la qualité dans ce câble. La rigueur de fabrication saute aux yeux et est présente dans chaque détail, comme cette fine couche de téflon qui enrobe délicatement les beaux brins de cuivre d'un éclat chatoyant :) Ou ces fils en vrai coton ( ça se fait rare ). C'est aussi un plaisir de le travailler, joli couple avec les ELECAUDIO RC90-REDC, soyeux et riche aux oreilles, le tout pour un prix dérisoire, il détrône chez moi le NEOTECH NEMOI-3220.
simon p.
RAS
correspond à la description
simon p.
description erronée
le diamètre de la partie dorée (vissable) est d'environ 7.5 mm et la partie grise 10mm (alors qu'il est décrit comme "de diamètre 5mm")
Damien M.
des aiguilles pour le show !
faciles à intégrer dans un boitier , si ce n'est le diamètre de 34mm qui n'a pas de pendant dans le standard scies à cloche. il faut jouer de la lime après avoir percé au diamètre inférieur. Attention aussi lors du pointage et du perçage des trous de fixations , perceuse colonne oblige , car l'espace restant entre le trou de vis et celui d'encastrement de l'appareil est bien mince. A part cela , leur côté vintage est bien sympathique avec leur cadran au chaud éclairage ou aiguilles s'invitent souvent en duo pour faire le show !
Damien M.
Juge de paix entre " pros" et antiskating"
je l'ai associé aux vumètres ronds de la même marque et l'ai raccordé occasionnellement en juge de paix sur la sortie de préampli phono pour la lecture d'un disque test (ou un disque mono à défaut). Cela m'a permis après différentes valeurs d'antiskating , et le constat d'un bon équilibre immuable des canaux droite gauche , de douter de la pertinence de ce système dont son équipées nos platines. (Joseph Grado conseillait d'ailleurs de le laisser à 0).
petite remarque remontée également par d'autres clients: les connecteurs câblés de façon symétrique sur une nappe que l'on doit couper à mie-longueur , impose d'avoir des couleurs inversées au niveau du câblage des vumètres.
jean michel G.
Belle surprise
Le son est détendu et bien contrôlé avec une séparation légèrement prononcée des voix et des instruments. Écoute en finesse.
Bien meilleur que les NE5532.
Je pense acquérir une paire de Opa2604ap pour comparer
exceptionnel !
Je possédai un câble ramm audio masse flottante qui m'apportait pleine satisfaction . Par curiosité je procède au remplacement par celui-ci et quelle claque! La scène sonore est épanouie avec un naturel confondant , la distinction des instruments et leur timbres est évidente avec une homogénéité parfaite . Son grand atout : IL TRANSMET L'EMOTION ! QUEL NATUREL! Imbattable à ce prix . Aucun reproche possible . Si vous n'étiez pas satisfait par ce câble le problème vient de votre système hifi .
Gilbert S.
RAMM AUDIO ZEUS SI 15 Power Cable Schuko C15 OCC Copper Triple Shielding 1.5m Ramm Audio offers with the Zeus SI 15 a high quality audiophile power cable. It features an exceptional design with high purity OCC copper conductors for maximum conductivity....
Une semaine avec ce câble et je suis déjà conquis. Essayé sur le lecteur réseau et sur l'ampli et whaou quelle surprise, tout est là : dynamique, timbre, scène sonore... Je suis étonné que ce câble ne soit pas plus connu et qu'aucun avis ne soit posté. Il est composé de l'amadeus 5 mk2 avec du cuivre OCC qui lui n'a que des avis positifs. Pour ceux qui recherchent un câble au rapport qualité prix imbattable, vous pouvez y aller les yeux fermés. Musicalement
Bartus G.
its do the job
as in the title its do the job, easy soldering
Bartus G.
IAN CANADA MONITORPI OLED Screen and Signal Analyzer Board for Raspberry Pi The Ian Canada MonitorPi is an OLED display that works for all types of audio applications with Raspberry Pi. Installation is very simple using the module's GPIO port....
plus 100HP
Ye, in my streamer its only plus 100HP :) informative, if you use for debug.
Bartus G.
IAN CANADA SHIELDPI PRO Multifunction Board EMI Shielding / Power Supply Filter for Raspberry Pi Ian Canada's ShieldPi Pro MKII is not only a universal EMI shielding module for Raspberry Pi, but also a high performance power supply filter, ON/OFF control button and GPIO...
Makeing calm in the music
Makes the music more fluid
Bartus G.
Perfect for a PI streamer
No question, perfect for a Pi streamer with a good PSU
Bartus G.
Amazing streamer for the money
Amazing device, I use it with Accusilicon clocks (45 and 49). Super soundstage, calm, fantastic!
Jerome R.
CEN.GRAND DSDAC 1.0 SUPERCLOCK DAC FPGA XMOS XU208 Femtosecond Clock 32bit 384KHz DSD512 Black Created by CEN.GRAND, the DSDAC 1.0 SUPERCLOCK  is a DAC based on DSD technology. It is different from most DACs on the market, in fact the DSDAC 1.0 can increase the...
Un son sans défaut
Excellent DAC pour le prix. Comparé à mon MSB Diamond, il apporte une plus belle scène et des voix plus naturelles. Rien n'est agressif sans manquer de dynamisme ou de détail. Il n'y a peut être que dans les basses où ça tape un peu moins fort que MSB. Un DAC qui mérite d'être connu...et qui commence à l'être chez nos voisins anglosaxons.
Rui R.
Very good quality plug!
Raffaele V.
AUDIO-GD DA7 corretto
Not simple but not complicated either. You need to pay attention to the wiring and power supplies and I highly recommend the original ones.
One day of work, triple checking everything, It pretty much worked first time. The sound is basically excellent, but can be improved with some adjustments that I will install in the future. Non semplice ma neanche complicato. Bisogna porre attenzione ai cablaggi e alle alimentazioni che consiglio vivamente le sue originali.
Un giorno di lavoro, ricontrollando tutto tre volte, Ha praticamente funzionato al primo colpo. Il suono, di base ottimo, ma migliorabile con alcuni accorgimenti che intallerò in futuro.
ETI NEXUS Silver Plated Tellurium Copper Female 3 Poles XLR Connector Ø8.5mm (Pair) Nexus ETI XLR connectors offer a very good design quality, integrating copper machined contacts with a small quantity of Tellurium. In addition, there is a silver plating of the...
Cela sent la qualite
Tout est a vis !
Ne pas forcer les vis sur les 3 partie
Pour le reste cela vaut le prix
Jean-Charles O.
Bon produit, prix très correct.
Utilisé avec un casque Sennheiser HD660S. Ca fonctionne tres bien en symétrique et en asymétrique.
Sur smartphone j'ai eu besoin de mettre un player spécifique car le driver system d'Android ne fonctionne pas mais bon j'utilise e/os sur un Fairphone. De toute facon je pense que l'utilisation d'un player dédié est conseillé. Sinon de pas aussi hésiter à installer l'application de Tanchjim pour vérifier les settings du DAC et/ou les changer.
Claude R.
Excellent pour écouter sa chaine Hifi au casque Bluetooth
Acheté dans le but d'écouter une chaine hifi non équipée pour le sans-fil (Rega Apollo & Brio R) sur un casque Grado GW100x, le FiiO BTA30 PRO s'est montré étonnamment performant.
Bien sur le Bluetooth n'est pas à proprement parler un mode "Hifi" mais le son qu'il transmet est vraiment bon et n'engendre pas de frustration.
Par ailleurs le FiiO BTA30 PRO fonctionne très bien aussi pour écouter Qobuz ou Tidal sur la chaine à partir d'un smartphone.
L'installation et l'utilisation m'ont demandé un peu de patience pour m'y retrouver mais le résultat en vaut la peine.
Je le recommande chaudement car il est d'un excellent rapport qualité/prix.
Laurent z.
Grande Musicalité
Après avoir contacté le service clients Audiophonics afin de « déblayer le terrain » avant achat, j’ai décidé d’acquérir cette belle machine et je ne regrette rien. J’ai déjà un Gustard X26 PRO basé sur des puces Sabre. Je ne dirais pas qu’un est meilleur que l’autre, mais ne correspondent pas aux mêmes types de système. Sur mon ampli à tubes ou tout autres amplis a tendance douce, le X26 pro apporte un surcroît de définition, d’attaque. En revanche l’A26 a une coté plus neutre, plus de matière et d’espace. Il n’est surtout ni moue ni anémique, bien au contraire, mais le mariage avec mon gros transistor très vif est bien meilleur. Histoire de goût et de mariage. Il me rappelle beaucoup un dac très haut de gamme que j’ai possédé dans les années 90 ( Métronome Technologie). Vraiment très Musicale dans le sens premier du terme. Aucune partie du spectre n’est mis en avant. Tout est très bien dosé . En 2 mots : ça chante. Encore merci à audiophonics pour sa disponibilité, réactivité et ses bons conseils
Lotfi B.
Ce n'est pas du noir
Pointes de bonne qualité pour le prix, par contre ce n'est pas du noir et rien a voir avec la photo, c'est même pas anthracite et encore, je vais devoir les repeindre pour pouvoir les intégrer a mon projet.
Stéphane R.
Utilisé pour streamer Qobuz et Tidal en high res vers un DAC externe, le Wiim pro me donne entière satisfaction, facile à configurer et à utiliser grâce à l’appli Wiim. Plus la possibilité d’utiliser directement l’appli Tidal en Tidal Connect ou Spotify connect.
Excellent rapport qualité prix pour mon utilisation avec un DAC externe! Ravi de l’achat
