ALSOZONE PAM256 Power Amplifier
New
The Alsozone PAM256 is a six-channel power amplifier designed to power a 5.1 home cinema system. It delivers up to 260 W per channel and relies on TPA3255 chips, which integrate MOSFETs in their output stage. The PBTL architecture increases the available current, while the PFFB technology helps control distortion and stabilize the amplification behavior.
By buying this product you get 79 loyalty points
Reference : 22590
799,00 €tax incl.
665,83 € tax excl.
ALSOZONE PAM256 6-Channel Power Amplifier TPA3255 6x 260W 4 Ohm
Alsozone PAM256 : Front view
The ALSOZONE PAM256 is a six-channel power amplifier designed to power a 5.1 home cinema system. It delivers up to 260W per channel and relies on TPA3255 chips, which integrate MOSFETs in their output stage. The PBTL architecture increases the available current, while the PFFB technology helps control distortion and stabilize the amplification behavior.
Each channel features two independently adjustable gain levels, in order to adapt the amplifier to the sources and speakers of the installation. This multichannel design centralizes the amplification of the different channels and allows their level to be adjusted according to the home cinema configuration.
ALSOZONE PAM256: 6x260W Amplification
The ALSOZONE PAM256 is a multichannel power amplifier designed for 5.1 home cinema installations. Part of the PAMX series, it delivers 260W per channel and can reach a peak power of 450W per channel at 2Ω. Its amplification relies on TPA3255 chips, which integrate the MOSFETs of their output stage, combined with a PBTL architecture and PFFB feedback in order to increase the available current while controlling distortion.
Alsozone PAM256 : TPA3255
Alsozone PAM256 : PFFB
ALSOZONE PAM256: Audiophile Architecture
In PBTL mode, two half-bridges operate in parallel on each channel, which increases the available current and reduces the output resistance of the power stage integrated into the TPA3255 chips. The PFFB technology complements this architecture by contributing to the stability of the amplification with different loads. The GaN switching power supply is designed to deliver high power in a compact format; the TDK, ELNA and Rubycon capacitors, as well as the flat-wire inductors, contribute to the stability of the power supply and to the operation of the whole unit.
ALSOZONE PAM256: Settings and System Integration
Each channel features two gain levels, which allows the amplification to be adapted individually to the characteristics of the sources and speakers. The trigger input and output allow coordinated power-on with other compatible devices, while the Auto On/Off function activates the amplifier when an audio signal is detected and turns it off after 20 minutes without signal. A front-panel control retains priority for operation independent of the automatic trigger.
Alsozone PAM256 : Back view
ALSOZONE PAM256 Overview
Alsozone PAM256 : Diagram
1Power button
2Power indicator (red)
3Clip indicator (green)
4Trigger input and output
5Trigger/Auto mode selector
6Input selector
7RCA input
8XLR/6.35mm TRS Jack input
9Gain selector
10Speaker output
11IEC mains power connector 100-240V
12Power switch
Technical specifications
Product typePower amplifier
Number of channels6
Inputs6x RCA
6x Combo XLR/6.35mm Jack
Outputs6x Output on speaker terminal
Amplification chipTPA3255
Amplification typeClass D
Output power6x 450W @ 2Ω, THD+N = 1%
6x 260W @ 4Ω, THD+N = 1%
6x 150W @ 8Ω, THD+N = 1%
6x 320W @ 4Ω, THD+N = 10%
6x 200W @ 8Ω, THD+N = 10%
THD+NUnbalanced input: 0.0007% @ 4Ω/ 0.0006 @ 8Ω
Balanced input: 0.0006% @ 4Ω / 0.0005 @ 8Ω
SNRUnbalanced input: 121dB
Balanced input: 124dB
Dynamic rangeUnbalanced input: 121dB
Frequency response20Hz-30kHz
NoiseUnbalanced input: <20µVrms
Balanced input: <15µVrms
CrosstalkUnbalanced input: -100dB
Balanced input: -110dB
GainUnbalanced input: 23/29dB
Balanced input: 17/23dB
Input sensitivityUnbalanced input: 2/1Vrms
Balanced input: 4/2Vrms
Recommended speaker impedance2Ω-16Ω
Supply voltage100-240V AC 50/60Hz
Dimensions265 x 460 x 90mm
Package1x ALSOZONE PAM256
6x Banana Plug
1x AC power cable
InputXLR
InputJack 6.35mm
OutputSpeaker terminal
Channel6
Amplifier chipTPA3255
Power (W)260.0
ALSOZONE PAM256 Power Amplifier 6 Channel TPA3255 6x 260W 4 Ohm
The Alsozone PAM256 is a six-channel power amplifier designed to power a 5.1 home cinema system. It delivers up to 260 W per channel and relies on...
