IFI AUDIO LAN IPURIFIER PRO Network Isolator
The iFi Audio LAN iPurifier Pro optical galvanic isolator lets you optimize the LAN Ethernet connection of your audio equipment. Galvanic isolation technology converts the incoming network signal via RJ45 into an optical signal, removing any noise present in the original signal while improving jitter before converting it back to output on a second RJ45 port.
4.5 / 5
Reference : 19423
299,00 €tax incl.
249,17 € tax excl.
Shipping date: 16-06-2026.
IFI Audio LAN iPurifier Pro Galvanic Optical RJ45 Ethernet Network Isolator
IFI Audio LAN iPurifier Pro picture
The iFi Audio LAN iPurifier Pro optical galvanic isolator lets you optimize the LAN Ethernet connection of your audio equipment. Galvanic isolation technology converts the incoming network signal via RJ45 into an optical signal, removing any noise present in the original signal while improving jitter before converting it back to output on a second RJ45 port. The two RJ45 Ethernet ports are based on the IEEE 802.3x standard, with speeds of up to 1000/100/10Mbps (10/100/1000Base-T). LEDs keep you informed of the device's operating status. Power is supplied via a USB-C port (5V - 1A). A USB power adapter with cable and RJ45 network cable complete the package.
IFI Audio LAN iPurifier Pro connections and LED indicators
Product typeNetwork isolator
Interface2x RJ45
Ethernet standardIEEE 802.3x
Supported speeds1000/100/10Mbps (10/100/1000Base-T)
Power supplyUSB-C 5V 1A DC
Dimensions99 x 92.8 x 24.2mm
Net weight241g
ColorGray
Package1x IFI Audio LAN iPurifier Pro
1x RJ45 cable
1x Power adapter with USB-A to USB-C cable
Length (m)N/A
ShieldingNC
Section (mm²)N/A
ConnectorRJ45
Conductors material (Cable)N/A
Conductors Plating (Cable)NC
8 reviews
One step further!
The IPURIFIER PRO works well. Better separation, details and image. Not a huge step, but enough to recognize it and like it.
More effective than the IFI LAN ISILENCER.
This review has been posted for IFI AUDIO LAN IPURIFIER PRO Galvanic Optical RJ45 Ethernet Network Isolator
SAV Audiophonics au top
Suite à la réception d’un exemplaire du purifier en panne, grâce au Sav d’Audiophonics je recevrai à peine 8 jours plus tard un exemplaire testé. Installé entre la box et le streamer, dés les premières secondes le son est transfiguré et cela se renforce au fil des heures.
Tout est mieux plus musical.
Adepte du vinyle et nouveau dans la musique dématérialisee j’en étais arrivé à mettre le streamer de côté ( pourtant assez haut de gamme). Grâce au ifi purifier pro la matière et la scène sonore sont crédibles.
Indispensable !
Panne
Arrivé en panne ( pas de découplage optique)retour à audiophonic très réactif, en attente de réception d’un autre exemplaire. Sav audiophonic au top mais réserve sur la fiabilité de l’appareil.
bel upgrade
Isole parfaitement l'appareil de la source, et ainsi supprime totalement les interférences des appareils reliés à la Box? notamment ceux qui sont alimentés par des alimentations à découpage, très polluantes.
Easy to install - works well
The iFi Audio LAN iPurifier Pro optical galvanic isolator lets you optimize the LAN Ethernet connection of your audio equipment. Galvanic isolation...
