The SMSL AS400 is an extremely versatile integrated amplifier. It offers numerous advantages, such as a phono input, an HDMI ARC input, a preamplified output for active subwoofers, and two headphone outputs. It also features an audiophile chipset allowing it to support sampling rates up to PCM 32-bit 768kHz and DSD256 while delivering up to 2x 165W of...
The SA6 MK2 are in-ear earphones featuring a total of six balanced armature drivers combined with a crossover system that combines physical and electronic solutions for a sound that is both smooth and detailed. Their aesthetics, a combination of wood, gold particles and resin, give each piece a unique design for a look that is both understated and...
The USB DD HIFI TC19CC is a USB cable with a high-end audiophile design. It features DATA conductors made of 4N monocrystalline pure silver and load conductors made of silver-plated OFC 5N copper, all implemented in a parallel structure with 4 flat conductors.
The USB DD HIFI TC19BC is a USB cable with a high-end audiophile design. It features DATA conductors made of 4N monocrystalline pure silver and load conductors made of silver-plated OFC 5N copper, all implemented in a parallel structure with 4 flat conductors.
The USB DD HIFI TC19BA is a USB cable with a high-end audiophile design. It features DATA conductors made of 4N monocrystalline pure silver and load conductors made of silver-plated OFC 5N copper, all implemented in a parallel structure with 4 flat conductors.
The UcPure Pro from Ian Canada is part of the third generation of supercapacitor power supplies designed by the brand. It makes use of the huge 3000F or higher capacitance ultracapacitor pack to achieve an ultimate power supply performance. Because it is a pure passive power supply, there will be neither feedback nor active components involved when...
The UcPure Pro from IAN Canada is part of the third generation of supercapacitor power supplies designed by the brand. It makes use of the huge 3000F or higher capacitance ultracapacitor pack to achieve an ultimate power supply performance. Because it is a pure passive power supply, there will be neither feedback nor active components involved when...
The Syitren R400 is a small battery-powered CD player that combines retro design with modern features. It is equipped with an M93BG6 playback head and an SC6137D decoding chip. In terms of functions, the R400 offers a choice of playback modes: loop, single loop, or random. In addition, in terms of connectivity, it features a classic 3.5mm jack output for...
The Syitren N100 is a compact wireless speaker with a minimalist retro design. It is equipped with two small speakers and is capable of delivering 2x5W of power. Its top panel features an ON/OFF button, a play/pause button, and a volume button. Audio input is via the N100's 3.5mm jack connector or the built-in Bluetooth 5.0 receiver, allowing you to...
PSVANE's EL34-Z power tube offers a soft, warm sound, full and natural, with good balance and no background noise. PSVANE offers us a tube with a more pronounced analog texture than conventional tubes, with voices more prominent than usual and an overall sound evocative of vinyl.
The Ian Canada UcConditioner Pro 2025 3.3V is a supercapacitor signal conditioning module operating with a 3.3V power supply. It will significantly improve the quality of your power supply by reducing both internal ESR and noise levels, while optimising stability and maximum current delivery.
The Ian Canada UcConditioner Pro 2025 5V is a supercapacitor signal conditioning module operating with a 5V power supply. It will significantly improve the quality of your power supply by reducing both internal ESR and noise levels, while optimising stability and maximum current delivery.
Aune's N7 is a powerful, discreet, fully balanced Class A headphone amplifier-preamplifier. It's based on a combination of JFET transistors for headphone amplification, an independent Class A preamplifier function and R2R volume control for optimal audio signal processing. The use of JFET transistors delivers a warm, smooth sound that will delight tube...
The Aune Evo N5 is a network player based on an architecture that favors signal processing using audiophile components. It features an ES9039Q2M DAC chip, an NXP Cortex-M7 processor, an Intel FPGA and a Qualcomm QCC5125 Bluetooth chip, as well as FIFO technology and a dual PLL internal clock for optimized jitter management.
This socket and circuit breaker tester allows you to test your installation safely. Among other things, this product can detect a lack of earth, phase reversal, or a lack of phase or neutral. This small tester can save lives and prevent fires, and should be included in every electrician's toolbox.
With its VIMI I, Silkline unveils a discrete integrated amplifier ideal for small to medium-sized rooms, being able to deliver 2x50W of power at 4Ω. This Class AB amplifier delivers a warm, delicate sound, and features a design incorporating Japanese Toshiba 2SC5198 and 2SA1941 transistors. Efficient and relatively compact, the VIMI I will fit...
The Dayton Audio DAX66 is a 12-channel Class D multiroom amplifier. It offers considerable output power for a wide range of spaces, with 12x 50W under 4 ohm and up to 100W under 8 ohm in bridged mono mode.
These high-quality aeco ASP-1935G spade plugs, sold in packs of 4, benefit from a rigorous design using top-of-the-range materials. The contacts, waved for better connection, are made of 99.9% pure copper with 10µ gold plating, ensuring both excellent conductivity and perfect resistance to oxidation.
These high-quality aeco ASP-1935R spade plugs, sold in packs of 4, benefit from a rigorous design using top-of-the-range materials. The contacts, waved for better connection, are made of 99.9% pure copper with rhodium plating, ensuring both excellent conductivity and perfect resistance to oxidation.
These high-quality aeco ASP-1935S spade plugs, sold in packs of 4, benefit from a rigorous design using top-of-the-range materials. The contacts, waved for better connection, are made of 99.9% pure copper with silver 120µ plating, ensuring both excellent conductivity and perfect resistance to oxidation.
These very high-quality aeco ASP-1956 spade plugs, sold in packs of 4, benefit from a rigorous design using top-of-the-range materials. The contacts, waved for better connection, are made of 99.99% pure silver, ensuring perfect conductivity.
This CCHD XO 9C adapter module from Ian Canada, precision-engineered and manufactured to the highest standards, features custom-made gold-plated SMT pins that are robust and durable, perfectly matched to XO sockets, with pre-mounted power cleaning capacitors and a fully assembled PCB ready for use, making integration simple and clean.
This SMT XO 22C adapter module from Ian Canada, precision-engineered and manufactured to the highest standards, features custom-made gold-plated SMT pins that are robust and durable, perfectly matched to XO sockets, with pre-mounted power cleaning capacitors and a fully assembled PCB ready for use, making integration simple and clean. This adapter is...
This Pangea Premier XL Balanced XLR to XLR modulation cable is exceptionally well made. It is composed of Cardas Grade One copper strands with PE tube insulation and Al Mylar aluminium foil shielding, silver-plated braided copper and carbon-filled PE tube. The triple-layer shielding provides this cable with effective protection against RFI noise and EMI...
The Aiyima T20 is a simple yet elegant balanced preamplifier. It features two ECC83 tubes combined with LME49720 and OPA1612 chips to deliver the warm, smooth sound typical of tube amplification. For further convenience, the T20 includes a 12V trigger input and output, allowing for seamless integration into your audio system.
The Meze Audio 105 Silva is a high-performance open-back circum-aural headphone. Tuned with a perfect balance of musicality and refinement, the 105 Silva delivers clear, rich and engaging sound effortlessly. Transients are fast and articulate, bringing out complex details with natural ease. Highs extend gracefully, soft but revealing, while bass remains...
This T3-CB11 cable from Tago Studio for headphones has a 3.5 mm jack connector on one end and two 3.5 mm jack connectors on the other. This cable is designed to replace the cable supplied with the brand's T3-01 headphones.
The STA-HI END from EarAcoustic are in-ear earphones based on two dynamic drivers to offer excellent performance at an affordable price. The combination of a 6mm polymer composite driver responsible for the upper part of the frequency spectrum and a 10mm beryllium driver assigned to the lower parts ensures detailed sound reproduction and neutral timbre,...
The Mundorf AMT25CM1.1-R tweeter has been developed for integration into 2-way bookshelf or 3-way column speakers. It combines strong vertical directivity with wide horizontal dispersion, making it ideal for rooms with reverberant ceilings and floors. It is also the tweeter in the AMT range with the lowest crossover frequency. The AMT25CM1.1-R delivers...
