Barco V.
Trigger 12v
Barco V.
Pavel V.
Very good streamer
Roland S.
AUDIO-GD R-7HE 2021 MK2 Balanced DAC R2R FPGA I2S HDMI Amanero 32bit 384kHz DSD Accusilicon Audio-GD is developing its HE range, composed of its most top-of-the-range products. They benefit from the longest design and testing period since the brand's inception. This...
Finally sound to love
un-artificial, believable, strong and like real. I confirm Herb Reichert’s review at Stereophile. Many years of search without arriving for me. All this oversampling filters or dsd conversion which I studied: interesting but not satisfying in the end, since it never sounded really real. Now with this chinese monster dac baby, I always come back to NOS after playing with different oversampling settings (Hqplayer). And so it will stay. This dac must be have been developed by someone who loves to listen. Many, many thanks to this person(s)!
Still, the r7he mk2 needed some help to shine. In my case I added a singxer su-6 as a ddc, connected by I2S. Better now, but still it was not the sound I wanted. A sound-killing dryness was there. The singxer has a poor switching power supply and the claim is that for its super-capacitor it does not need a proper linear power supply. Simply wrong, at least in my case for this dac. Exchanging the standard PSU of the ddc by a linear PSU was the missing last piece in the puzzle. I guess, if you go with the ddc from audio-gd you get a direct goal. Et voila: my search ended, music is playing to happy ears :-)
Jani B.
energijaj@gmail.com
plug for the main starting point from the wall, top quality and power with a nice sound
Dominique V.
Contrepointes Aluminium
J'ai acheté ces contrepointes car c'était l'élément manquant pour mes pieds d'enceintes. Sur les photos elles sembles jolies, mais une fois installées c'est nickel. Elles finissent et embellissent parfaitement mon ensemble pieds / enceintes DYNAUDIO. Concernant le son, même si s'il est déjà très bon, je pense qu'il y aura encore une amélioration. De plus j'ai commandé des câbles Dynavox, que j'attends car rupture de stock, et là ce sera le TOP.
Merci à Audiophonics de proposer des produits de qualité à des prix adaptés à toutes les bourses.
BENOIT D.
Fait l'affaire !
Fonctionne parfaitement, le son est bon. Parfait pour le pour le prix.
P.S. à l'attention d'audiophonics : l'alimentation que vous préconisez sur votre site n'est pas adaptée au récepteur car ce dernier possède une entrée en USB C alors que l'alim. est encore avec l'usb première génération. Donc l'alimentation que j'ai reçue ne me sert à rien, dommage.
Miroslav T.
XH 2.54mm Female to Bare wires Cable 3 Poles 1 Connectors Gray 30cm 24AWG (Unit) This good quality shielded cable has a 2.54mm 3 pole XH connector and 3 bare wires (red, white, black). It will allow you to carry out simpler assemblies on your PCBs also...
nice product
I am very satid+sfied with this one
Fabien F.
Petit mais costaud (et propre)
Monté dans une enceinte close 2 voies de 10l, qui fait aussi sub. Il monte dans les medium et avec un filtre à 2k + Tweeter, on a un son de basses/sub très propre et pas de "boooom" baveux. mais... nécessite une équalisation forte avec DSP (moi j'ai un module Arylic) qui boost les fréquences en dessous de 80 Hz, + mode Deep Bass, vu que le rendement chute rapidement dans une enceinte close, contrairement à un bass reflex.
Il faut donc pas mal de puissance pour bien ressentir les basses si vous voulez un encombrement minimum. Mais n'achetez pas un ampli de 200 W (la puissance du HP annoncée par Dayton): j'atteins le xMax avec un ampli de 80 W. Le HP peut aussi être monté avec 2 radiateurs passifs de la même gamme Epique.
Hugo Á.
SOVTEK 6H30PI / 6H30 / 6N30 / 6N30P Twin Triode Tube (Unit) This Russian-made, audiophile-quality 6H30PI power tube from Sovtek (sometimes also called 6H30, 6N30 or 6N30P), often used in pre-amplifiers, gives...
Good Quality
There are New, 2022, original valves by Sovtek. They replaced used ones, from 2004. They sound good. Recommend.
DIMITRIOS T.
XDUOO XD05 BASIC Portable Headphone Amplifier DAC ES90108K2M XMOS 32bit 384kHz DSD256 xDuoo presents with its XD-05 Basic a small, affordable yet extremely powerful portable headphone and DAC amplifier. Indeed, low price doesn't always rhyme with economy of means...
powerful entry-level amp and good dac
It sounds clean and detailed. There is enough power to drive any headphone even on low gain. The dac seems fine and works well when connected to an external amp (this is not a pre-amp so no volume control for the line-out, volume control is only for the headphone-out.) there very little channel imbalance on extremely low volume (you will never listen to that low even with iems) The pachage has all the accesories you would need except from an aux cable (only needed to connect to external amp) there is even a very handy resusable adhesive to use if you want to "glue" this device to your phone or DAP. Battery lasts about 7 hours depending on use so pretty good. There is no hiss or noise even on very sensitive iems although the volume is too much to pair it with such iems, better suited for harder to drive stuff, unless you lower the volume from the phone-computer-dap. Generally Very satisfied with the purchase.
franck l.
Très bon lecteur, comparé au blu.... dernière génération que je possède également, et relié au même amplificateur avec dac, le son est équivalent voir un poil supérieur. Le chromcast est très pratique, ce qui fait aussi la différence avec blueso....affichage des pochettes des titres diffusés des radios. Livraison impeccable, merci à audiophonics
antoine L.
ELECTRO HARMONIX GOLD 12AU7
je reviens sur mon avis du 06/12/2022, c'est vrai j'avais préféré le tube Psvane, qui apportait plus de matière, en réécoutant le ELECTRO HARMONIE GOLD, ce tube apporte plus de finesse comme des micros informations supplémentaires, lors de ma comparaison le tube ELECTRO HARMONIE n'etait pas rodé, donc la comparaison n'etait pas équitable, pour le moment ce tube n'est pas disponible, je vais donc attendre un peu et en recommander un autre, merci à Audiophonics pour leur sérieux,
Davor M.
After the long break-in period I can only say that cables are
amazing. I have 5 time more expensive cables but this is pure music. Recommended.
Raffaele V.
DAC R2R vs DS
Preso più per curiosità che per necessità, ora è il mio rigerimento. ho trovato un R1 usato su Subito (sempre Audiophonics) e confermo che è un ottimo marchio (Audio-GD) e un ottimo sistema. Appena possibile mi compro il R11 MKII.
André G.
Copper / Silver Wiring Cable 4mm² PTFE Sleeve Ø3.6mm Black This 3.6mm diameter cable has a single 4mm² conductor made of Silver plated OFC Copper. This provides excellent signal conductivity while providing the conductor with high...
Câble hp cuivre argent
J utilise ce câble pour alimenter un hp grave avec succès. Bonne tenue des basses
Raffaele V.
TUNG-SOL 12AU7 / ECC82 Tubes (Matched Pair) The Tung-Sol 12AU7, manufactured in Russia, ensures very low noise. It has been designed to mimic the performance of American NOS 6189 tubes. This one proposes an open...
COPPIA SELEZIONATA ECC82
Splendida coppia selezinata, motata su un TotemPole, sono risultate praticamente perfette.
MONACOR MDM-2 Speaker Damping Polyester 130g 63x33x3.5cm (Set x2) This environmentally friendly damping material for thermal and sound insulation is made of 100% Polyester fibres. It is therefore ideal as a sound absorber to be installed...
Complément amorti synthétique, obstruction des évents.
Je l'utilise en complément d'amortissant interne d'enceintes tout en bas, bourrage du bas de l'enceinte, me permet de boucher les évents en laissant le passage de l'air grâce à son faible amorti.
Pour les parois internes, je mets la plaque en feutre Jantzen amortissant de 1mx1m bien plus absorbante et hautement qualitative.
Tapisser les parois internes des enceintes.
Génial comme amortissant interne d'enceintes, j'ai découpé cette plaque épaisse de 1 mètre sur 1 mètre, collé les morceaux avec un pot de colle gel néoprène sur les parois internes.
L'amorti est très supérieur aux matières synthétiques, c'est propre (pas de particules) et en plus c'est tout doux.
Bravo à Audiophonics de proposer un tel matériau !!
Pour remplacer mon Sommercable Orbit 240 mkII 2x4mm2.
Remplace mon Sommercable Orbit 240 mkII en 2x4mm2 déjà excellent pour passer en bi-câblage ou en 2x8mm2.
Ce câble est agréablement très souple bien plus flexible que l'Orbit, facile à dénuder, diamètre extérieur identique à l'Orbit 4mm2 donc pas si gros (rond quand l'Orbit est plat).
Ecoute toujours chaleureuse, pas de dureté, c'est transparent, le rodage améliorera encore le son.
Au prix proposé au mètre, c'est une affaire exceptionnelle, j'ai testé de très nombreux câbles ésotériques pour m'arrêter sur Sommercable (en modulation le câble Sommercable Epilogue arrive en tête aussi).
Merci à Audiophonics pour la qualité de l'envoi !! (emballage et transport).
Yordan K.
The cable is of very good quality. I give 4 stars only for the delay in delivery.
Bruce P.
AUDIOPHONICS Network Patch RJ45 Ethernet Cable High-End Cat 7 10m Hand assembled in our workshops and made from the best components on the market, this RJ45 cable provides you with the best possible interconnection quality at this price.
Audiphonics Network Patch RJ45 Ethernet Cables High-End Cat 7, 10 metre and One metre
Beautifully made and of excellent quality and performance. Comes in a nice "velvet" bag. Marked improvement to my streaming setup. Superfast shipping to Australia. Highly recommended upgrade.
Alain R.
J'ai utilisé cette pince sur une trentaine de contacts XH.
Ils ont tous été parfaitement sertis sur un fil multibrins de 0,24mm² et isol
Sorin A.
Didn't expect to make a difference.
Bought it to replace the stock DC cable of the Pro-Ject Accu Box S2 which powers my EAT Glo Petit phono preamp. The only reason was to replace an ugly cheap looking cable, never expected to actually make a difference sound-wise.
Christophe A.
Produit solide qui pèse son poids. Gain dans la puissance du son par rapport au produit que j’avais avant et qu’il remplace. Écartement prises cinch non au standard amplificateur. Nécessite une rallonge rca pour brancher le récepteur Bluetooth advanced à acoustic wtx 500 mais rien de grave. Bref parfait pour donner une seconde jeunesse à mon vieil ampli nad.
Denis S.
En remplacement
Très étonné par ces câbles, pour le prix, ils n'ont rien à envier à mes stratus 7.... 3 fois plus cher... Ils sont même plus énergique et clair, moins pataud... Un petit hic, mais à corriger avec barrette la phase et a l'envers... Pour petit budget, c'est à recommander.
Pascal B.
Fait le job !
Acheté pour alimenter une centrale Focal CC1008 Be, il se balade avec présence et impact !
Il ne chauffe pas en étant totalement silencieux, juste un très très léger petit souffle en collant l'oreille au tweeter Be donc rien à signaler.
A noter que le trigger fonctionne très bien derrière mon Marantz AV8805 sans aucun bruit, ni ploc à l'allumage.
Pascal B.
Solide & performant !
Un beau boitier tout métal, une sélection de source souple et totalement silencieuse, pour l'instant tout est parfait !
Il ne faut pas se tromper à la commande sur les entrées/sorties, le boitier étant stable et relativement lourd, il ne bouge pas même avec 6 câbles XLR connectés.
Christophe M.
avis number 2
Alors je n'enlève rien à l'avis précédent mais le souci est que parfois il faut tout réinstaller. On se lève, on veut écouter de la musique et rien ne fonctionne, les WiiM ne sont plus détectés. Ca prend du temps, c'est anxiogène, désagréable. Mais quand ça fonctionne, le produit est très bien. Est ce parce que j'en ai deux??
Mickael P.
Pour Drop + Hifiman HE4XX
Mousse fournie d'origine sur le casque Drop + Hifiman HE4XX. Parfait pour remise à neuf du casque avec pièce officielle.
Joris J.
Great value, but bit harsh on top
Spacious soundstage, transparent, good bass BUT a bit harsh/digital sounding on the top end. That spoiled the listening experience to me, so I am still looking for a better DAC.
Warning: despite info on datasheet : NO remote control included!
fernando B.
XDUOO TA-30 DAC Tube Headphone Amplifier ES9038Q2M XMOS XU208 Bluetooth 5.0 32bit 768kHz DSD512 The xDuoo TA-30 is a high-performance tube and DAC headphone amplifier combo, offering rich and detailed sound reproduction. Its headphone output amplified by a pair of power...
todo perfecto
Sonido ce calidad
fernando B.
Todo perfecto envio rapido
Envio muy rapido
Pedro P.
Excellents amplis utilisés dans un système actif
Ces amplis sont une base solide pour qui veut sortir des systèmes passifs (où ils excellent aussi d'ailleurs). Cela fait des années que je bricole sur mes MG 1.7i avec des résultats à chaque fois meilleurs. Meilleurs filtres passif et triamplification, PLLXO et finalement filtrage numérique, PEQ et autres amplis. Je viens d'améliorer tout cela avec l'aide de ces amplis et d'in excellent DSP, à écouter sur Youtube: https://www.youtube.com/watch?v=_CknxQ42AFw
Rien de tappe à l'oeil, je laisse cela aux influenceurs, ce n'est qu'un simple partage et les commentaires ne sont pas censurés, bons comme mauvais :D
Manuel S.
Noisefree wonder amplifier
If you search an amplifier which generates no noise, even when pressing your ear against a horn tweeter of a Triangle Australe Titan tweeter, you will find it here.
I looked for the Sparkos edition as I only use a Marantz AV Receiver as pre amp. So the Sparkos would be the best choice in the pre buffer section.
The shipment of the amplifier was turbo fast to Germany. Unfortunately, the first amp had a problem with the right channel. But no problem with audiophonics after sales support. They sent me a retoure label, checked the amp, confirmed the failure and sent me a new one after checking it.
Again a turbo fast delivery and now everything is fine.
The crystal clear and simulateously dynamical sound of this amp is wonderful. I compared it to the ICE Power Modules in XTZ amps: No comparison. Absolute big difference!
There is so much more "life" in this Purifi amp. I think this will be the last amp for years now and I hope it will last a long time.
Before I had a Musical Fidelity m6 500i 30kg monster and it did not sound as good. It had a white noise permanently (not to loud but with horn tweeters,you got to hear it in 2m distance) . Furthermore it drew 120W of expensive current. This Purifi based beauty only takes 20W.
Additionally it does not get warm and does not convert your listening room in a hot and dry desert.
I just can recommend Audiophonics as not only the products are perfect. Also the support really is top!
Franck M.
puissant uniquement si bien alimenté!
si on lui met 600watts de reserve en amont on peut faire une mini teuf avec 2 pauvres hps de 10cm de diamètre! sinon avec une alimentation pas ouf en 3ampères ca s'arrrete à l'oeil à 2x5watts!
Eric K.
Ampli phono FOSI
parfait. Fonctionne très bien.Merci
Perfection
Je fais peu de CR cause peu de temps mais ce 3001 de Néotech est a mes oreilles et mon système proche de la perfection.
N'attendez pas qu'il règle un problème car il est simplement ou plutôt parfaitement neutre et transparent.
Il lui faudra quelques heures de rodage (cablos-sceptiques s'abstenir) mais au bout quelle récompense, il est carrément addictif.
J'ai tout dis il y a peut être mieux mais dans cette gamme de prix ce sera difficile, il est monté en xlr avec les excellents EIZZ vendu ici aussi et le résultat est simplement fantastique.
Guy L.
JANTZEN AUDIO Bass Reflex Port Tube 102mm Ø25mm This Jantzen Audio Bass Reflex speaker vent has an internal diameter of 25mm. It will be perfect for any small speaker. In the shape of a pavilion, its flared opening prevents...
Très bien, fait le travail
Intégré dans enceinte bluetooth .https://youtu.be/xEGvq1JDTl8
Guy L.
Très content de ces hauts parleurs que j'ai intégré dans un enceinte bluetooth.
didier g.
TOPPING L50 Balanced Headphone Amplifier NFCA Black The Topping L50 is a desktop headphone amplifier with an architecture optimized for incredible sound performance. It features a new generation NFCA circuit, based on the one...
Bon appareil
Testé en Jack TRS, pas en RCA, bon appareil bien fini.
Le sélecteur de gain est appréciable, je suppose pour les écouteurs IEM, par exemple. Si je garde le gain le plus élevé pour des casques à rendement faible ou moyen et impédance moyenne ou élevée, par contre même avec des casques à impédance de 32 ohms ou à rendement moyen ou élevée, je préfère rester sur cette position même si le potentiomètre n'est utilisé qu'au début de sa course: la restitution est plus incarnée: en position de gain 0dB, la clarté est excellente mais je trouve un aspect montant et désincarné gênant.
Gestion de la commande par Audiophonics: sans souci
didier g.
comparé un à un ancien petit DAC 24 bits, 192 kHz, la clarté est appréciable. Appréciable aussi le fait de pouvoir jouer sur le filtre de sortie, qui me semble (c'est subjectif) avoir une influence subtile mais audible sur la douceur de restitution ou au contraire une restitution définie mais un peu désincarnée. Testé en Jack TRS, pas en RCA. Télécommande pratique.
Gestion de la commande par Audiophonics: aucun souci.
rob m.
Incredible
My system is a BlueSound Node through a Audiolab 8300A and Kef LS50 Meta. The Mogami opened up the system, it's unbelievable what this cable can do, Highly recommended
Michel P.
Multiprise de bonne facture pour le prix, mais un peu légère qualitativement : ne pas s'attendre à une amélioration remarquable.
Normal : structure en plastique, absence de blindage, schulko très moyennes, ma prise DIV (bois - carbone - blindée - schulko et câblage de qualité en étoile) à été à la hauteur de mes attentes. Mais bien que réalisée par mes soins est beaucoup plus chère.
Michel P.
Excellent rapport qualité prix, beaucoup de définition et un très bon équilibre tonal. Personnellement, pour un prix équivalent je préfère les Viborg : même qualités mais "en mieux" peut être la différence de placage.
Michel P.
Assez bien
Le connecteur est indéniablement de bonne qualité, mais à une tendance à comprimer un peu la dynamique et la définition : "trop sage". Utilisé sur un ampli audio résultat moyen, mais très bon sur un AVR de moyenne gamme de qualité (lisse peut être les défauts de ces appareils en audio).
Michel P.
Excellent câble avec des connecteurs de haut de gamme et une conception irréprochable, comparaison avec d'autre produits : on ne paye pas la marque mais le résultat absolu.
Michel P.
Excellente
Remarquable en qualité audio (neutralité et définition), toutefois assez longue et lourde : attention requise si le dégagement derrière l'appareil est insuffisant ou si l'embase recevant le connecteur est peu profonde (celui-ci aura tendance à glisser vers le bas).
Michel P.
superbe cable
Excellent câble hautement blindé, d'autre part sa structure mono brin permet de s'affranchir des problèmes récurant en audio (sans être un spécialiste) : stabilité et intégrité globale de la transmission du courant. Toutefois très rigide difficilement pliable, utilisé pour réaliser une multiprise 8 ports, à nécessité une hauteur interne de celle-ci de 10 cm, pour s'affranchir de la courbure maximale possible.
Michel P.
excellente prise en audio
qualité audio indéniable : équilibre tonal et définition sans artifice. mais un peu fragile : serrage de l'embase dur le support avec précaution au risque de fendre celle-ci, les visses des plots sont à six pans creux : insérer l'outil de serrage avec attention (droit et profondément, sans faillir lors de la connexion) au risque de détruire la visse, toutefois en respectant cette attention le serrage sera puissant et sur.
Philippe V.
TOPPING EX5 Headphone Amplifier DAC 2x ES9038Q2M Bluetooth 5.0 LDAC 32bit 768kHz DSD512 MQA Silver Topping offers with its EX5 an extremely powerful DAC and headphone amplifier combo. Its conversion stage is indeed based on two ES908Q2M DAC chips and allows the reading of...
Excellent Dac
Passe quasi parfaitement le test de lecture de l'album Myopia d'Agnès Obel que tant de Dacs massacre. L'ampli n'est pas en reste et fait un très bon travail. Enchanté de mon achat chez Audiophonics
Ethernet RJ45 Cable Cat 8.1 40Gbps Shielded Gold Plated 10m This RJ45 Ethernet cable takes advantage of the recent Cat 8.1 standard, offering a bandwidth of up to 40Gbps. The cable itself has a high quality design with a double shielding...
Excellent, mais attention lors des angles de murs
L'excellent triple blindage fait que c'est assez rigide, vous ne ferez pas d'angles droits avec ce câble ! Sur dix mètres, il y aura des virages, il faudra faire des doucines. C'est hélas obligatoire avec cette norme hyper rapide.
Ethernet RJ45 Cable Cat 8.1 40Gbps Shielded Gold Plated 0.5m This RJ45 Ethernet cable takes advantage of the recent Cat 8.1 standard, offering a bandwidth of up to 40Gbps. The cable itself has a high quality design with a double shielding...
Très bonne qualité mais assez rigide
La qualité est là, mais l'excellent triple blindage oblige à une certaine rigidité, lors de son installation
