Dominique R.
Hautement recommandé
Dominique R.
Marc J.
Customers reviews - There are 20173 reviews.
Thomas M.
it wrorks very well
Absolutely no problems with win 10, asio driver and connections.
Martin B.
Good improvement for a Musical Fidelity MX DAC
I had ordered your Linear power supply 5V 2A for powering a Musical Fidelity MX DAC (power consumption 5.18 V 0.89 A).
(It had been recommended in HiFi magazines to replace the MF "Wall Wart" switching power supply by a quality linear power supply, because it would improve the sound).
Before ordering , I checked this statement (using a linear laboratory power supply) and (to my surprise) indeed the depth, width, separation of instruments in the soundstage improved remarkably (of course using a good HiRes recording e.g. Katie Mulua No 8 acoustic recording (96/24 WAV) from www.HiRes Audio.com.
I checked the Musical Fidelity Wall Wart Switching Power supply and it indeed appeared to have a lot of noise extending from the KHz regime all into the Mhz regime ( I used a 100 Mhz BW Tektronix 465B scope to investigate this ).
NB The lab supply had only noise (1 mV pp) , in the regime of higher than 20 MHz.
In view of the encouraging results with the lab Power Supply I ordered yourAudiophonics Linear Low Noise 5V 2A power supply with equally good results.
(significant increase of breath and width of soundstage and separation of voice and instruments).
Checking by oscilloscope revealed a noise free DC below cut off of 20 MHz and only one small sine noise (1 mV PP) at approx 35 MHz .
Most likely this will be damped in the DAC itself, anyhow.
All in all , a recommendation, of an item in which initially I did not believe in!
BTW one cautionary remark:
The Musical Fidelity MX DAC is critical with over -and under voltage (inbuilt power protection).
I had to increase the 5V DC voltage of the Audiophonics slightly with the trimmer potentiometer at the back ( to 5.19V).
Reason:
Initially the MF MX DAC did not work at all with the power supply (only power LED lit, but otherwise dead).
Increasing the voltage (1/4 turn ) solved this and kicked the DAC into life.
Anne b.
condensateur mundorf 10000uf 63v
montage condensateur mundorf 10.000uf 63v sur ampli tuner kenwood vraiment bien ca change le son le rodage n est pas encore fait tres satisfait du produit tout simplement
PATRICK D.
Cable de bonne facture, la qualité est au rendez-vous.
PATRICK D.
Signal faible
Je déconseille ce produit qui fonctionne mais avec une énorme perte de niveau qui le rend inutilisable pour une utilisation de qualité. Test effectué sur plusieurs appareils. L'achat d'un autre convertisseur a réglé le problème.
Peter P.
Peter P.
High Quality product
Claude V.
AUDIOPHONICS BT60W PRO HiFi USB DAC Amplifier Infineon MA12070 Bluetooth 2x55W 4 Ohm Audiophonics offers you a revised version of the compact but no less excellent BT60W amplifier with its PRO version. On the menu of improvements: an increase in power and sound...
Je l'utilise depuis plus de 2 ans avec des enceintes DAVIS EVA ayant comme source un PC relié en USB et je suis toujours étonné de la qualité sonore de l'ensemble pour un petit budget
Antonio C.
Excellence
Qoui dire: en quelques jours seulement ce DAC est en train de prendre le dessus sur mes autres appareils. Le lecteur de CD Prima Luna passe par là, le préamplificateur Conrad Johnson n'est que rarement utilisé. Je branche le RME DAC directement sur l'amplificateur de puissance (un CJ Première 140 à tubes) qui alimente mes haut parleurs passifs (des vieux Sonus Faber Guarneri). J'ai pu faire quelques ajustements pour une écoute agréable pour mes oreilles. Je le connecte aussi à mon téléphone Android et à un iPad et je vais bientôt compléter la chaîne avec un streamer WiiM qui sera connecté via coaxial ou optique (pour ne pas utiliser le DAC interne du streamer). Un changement important pour mon écoute a été la capacité de reproduire bien la musique même a des niveaux sonores plus bas: la musique reste audible sans devenir un bruit de fond comme c'était le cas auparavant. Il y a encore pas mal de paramètres à découvrir et essayer. Entre temps, c'est une belle réussite, bravo!
GERARD V.
media sun
Excellent câble pour un prix correct.
Meme approche de son plus que satisfaisant sur mon système.
À recommander dans cette gamme Cuivre/Argent.
Merci audiophonics, envoi parfait comme d'habitude.
Nikolaos R.
Very good build quality. It works very accurately and has a great antique finish! It added value to my build.
Laurent B.
Après le Raspdac mini, j'ai choisi l' Evo-sabre pour le câblage de mes HP Genelec (Symétriques) .
Un régal de précision, image stéréo bien définie.
J'ai rajouté un radiateur (Geekworm Raspberry Pi 4 Embedded Heatsink with Fan) pour le raspberry (sans le ventilateur) il s'adapte sans problème .
Patrik L.
The cable is missing a separate conductor between RCA sleeve and XLR pin 3 to avoid ground hum.
Patrik L.
Note that XLR pin 3 is connected to the RCA sleeve and not left open.
Jean-Claude P.
soundcare version sans filetage
Je suis très content de mon achat. Avec ma platine Atoll cd50 cela marche à merveille. Le son est précis sans être froid comme parfois avec le cd, avec un côte feutré et on peut même dire moelleux (cela provient peut-être aussi de mon ampli). En tout les cas le résultat est très supérieur qu'avec des pieds beaucoup plus chers que j'ai eu l'occasion d'essayer auparavant. Merci Audiophonics pour le prix imbattable et pour la livraison parfaite.
Joris J.
Surprisingly powerfull
The build in amplifier of my old Monitor Audio Radius 360 subwoofer died. In stead I connected the driver unit directly to this little amplifier. (so I used the sub as a passive subwoofer). Powered by a 6 ampere 24V SMPS:
Surprise: bass sounded deeper, less boomy/muddled and more powerfull than with the original build in amplifier of the subwoofer!
Thanks to audiphonics.
pascal P.
Adapter Impedance Transformer SPDIF Coaxial 75Ω to AES/EBU 110Ω This adapter and impedance transformer will allow you to convert a 75Ω SPDIF coaxial signal into a 110Ω AES/EBU signal and thus to connect devices with these...
Utile ?
J'ai acheté ce transfo pour connecter la sortie 75 ohms de mon MiniDSP SHD à l'entrée 110 ohms de mon Behringer DCX 2496. C'est moins bon qu'avec un simple cordon coaxial vers AES/EBU. Pourquoi ? Je ne sais pas si le transfo est en cause ou si mon DCX est un "faux 110 ohms" et du coup sature.
Part ailleurs l'appareil semble bien construit et sérieux. Cependant, mauvaise surprise quand j'ai vu qu'il fallait lui adjoindre une alimentation 5 V ce qui est mal pratique et ajoute des frais.
N'utilisez pas de cordons coax vers AES. cela existe bien mais ne correspond à aucune norme et ne respecte pas l'impédance nécessaire.
Ce produit est actif et dispose d'une batterie interne, il est en effet nécessaire de le recharger.
Florent D.
Je recommande fortement
Parfait pour la transmission numérique.
Remplace un cable bas de gamme (entre lecteur et DAC), avec ce cable Audiophonics
tout est en place, les basses sont enfin là, la restitution est transparente, medium bien placé.
Tous ces pulses et bits arrivent maintenant 'dans le bon ordre':75ohms de bout en bout c'est ce qu'il faut.
Le prix du câble est justifié, moins cher que d'autres marques réputées, justifié au vu du résultat et de la qualité de construction.
Merci Audiophonics
Christian R.
Des améliorations très audibles
J'ai acquis cette alimentation pour mon streamer Node 2i tweaké par une carte polonaise. Par rapport à l'alimentation fournie avec la carte, l'amélioration apportée par l'Allo Shanti est immédiate, et encore plus audible après un rodage de quelques heures. Des micro-informations sont plus nettes, l'ensemble du son est plus doux. C'est la meilleure alimentation que j'aie acquise chez Audiophonics jusqu'à présent.
Rinze B.
Power Supply
Very good power supply for the price. I thnk you can buy better ones but not for this price. It is a very good combination with my music server. I am very pleased with it and would recommend this.
Rinze B.
ATAUDIO SQ-7 Angled Power Connector Schuko Gold Plated Ø19mm ATAudio's SQ-7 angled Schuko power connector features superb build quality and will allow you to design high-end power supply cables that perform and look great. Its transparent...
Good quality for the money
This connector is strongly build and has even an angle positioning integrated. I am very pleased with this connector. I would recommend this also to others
Hervé T.
Active SPDIF Optical Toslink Switch 3 to 1 This SPDIF switch has three inputs and one output in Toslink optical format. It allows you to multiply the number of sources for the same output, and to easily select the active...
Switch qualitatif
Bon matériel, conforme à la description, fonctionne bien, aspect qualitatif, tout métal. Bon rapport qualité/prix
Hervé T.
SMSL SU-9n DAC ES9038Pro USB XMOS Bluetooth 5.0 32bit 768kHz DSD512 Little brother of the SMSL SU-9, the SU-9n is a modified version, with all the characteristics of its model, but this time without the support of MQA files, of the Bluetooth UAT...
DAC très performant
Très bon DAC. Utilisé avec un bloc de puissance Audiophonics HPA S400 ET, le couple s'entend à merveille. Le couple surpasse un ampli intégré de renom que j'avais de la même gamme de prix et ça s'entend!
Bon rapport qualité/prix.
Hervé T.
Super Ampli
Très bon matériel, à la fois puissant et précis. Son clair et détaillé, graves percutants et vifs. Utilisé en gain moyen en XLR. Écoute addictive!
Joel G.
Feels and looks good
The product looks solid and well built. Since it’s arrival has been used for a new position of my amp and speakers and that involved new (longer and different brand of) speaker cables so the whole sound in the room is currently different. I can’t therefore say if my equipment sound better with this power distributor, but I like the built
Pascal P.
Super rapport qualité prix.
Je viens de relier en ampli classe A/B 90 watts et une paire d'enceintes Q-Acoustics 3020 éloignés de 10 mètres. J'ai donc utilisé 2X10 mètres de ce câble et ça marche très bien pour le prix. Je l'ai conseillé à un ami audiophile qui en a utilisé pour brancher des voix du théâtre. Il est satisfait aussi. Rien à dire, ce câble est plus que correct.
Johan v.
Good stuff
Not much to say about it it damps metal sheet very well so it will work on you Thorens TD1..sub chassis as damping material just have a look at the 160S innards and see what the factory did for ideas.
Large un-damped metal CD player parts are also a good candidate just be careful not to block the laser unit in any way.
Johan v.
The beauty and the tuff one
This is are very stiff cable but making a interconnect with it is certainly worth it.
The conductors are double insulated so after the first layer there is a ptfe layer so be aware of that.
The outer sleeve is also made of two layers of witch one can be peeled of if you are careful not to cut too deep this makes smaller cable entrance diameter RCA plugs possible to fit.
Compared to a expensive silver cable it loses some fine nuances but gains in solidity and warmth it is not a"warm" cable but very neutral and resolving.
Milan D.
FX-AUDIO TUBE-06 MKII Tube Preamplifier 2x 6N3 DAC ES9018K2M CM6642 Subwoofer 24bit 192kHz Silver The FX-Audio TUBE-06 MKII is an affordable and efficient tube preamplifier. Its preamplifier stage is based on the use of a pair of 6N3 tubes. It is associated with a...
Livraison rapide.
Johan v.
Exellent
My favourite RCA plugs very well made nicely packaged like jewellery!
Good sound no artificial colouration that I can hear.
Johan v.
Good quality item
Chosen for the small mass of this connector and yes the amount of metal in the signal path makes a audible difference.
Used by many manufacturers of equipment even very expensive ones not necessary this brand but this model.
Johan v.
Good quality item
Johan v.
Replaced a Pr.Ject phono cable
This cable replaced the cheapest Pr.Ject din to RCA cable with good results, more extension on both frequency ends and more detail.
If you have one of these Pr.Ject cables on your record player replace it if you want to hear what your cartridge is capable of, so recommended.
Merci Beaucoup Audiophonics for having all these goodies is house and so quickly delivered!
Maximiliano L.
Good
Very useful and convenient.
Maximiliano L.
Good
Nice looking knob
Jam M.
bon taraud pour les métaux tendres
Un seul taraud pour remplacer les traditionels triples tarauds, cela permet de gagner du temps. Mais attention à bien démarrer le taraudage afin qu'il soit perpendiculaire à la pièce.
Jam M.
Super précision et maintien des NE5532 et autres
Permet d'éviter de souder les circuits directement sur le circuit imprimé.
Jam M.
Insulation Spacer Transistor Components TO-220 / TOP-3 (Unit) This isolation spacer has dimensions that allow it to be adapted to certain electronic components, in particular transistors in TO-220 or TOP-3 packages. It will allow you to...
Conforme
Permet de fixer des TDA7294 sur un dissipateur.
Jam M.
Précis et propre
Elle me permet de réaliser des trous dans l'alliage d'aluminium.
Jam M.
Bien pratique
Elle me permet de réaliser des trous dans l'alliage d'aluminium. Travail précis.
M'ayant envoyé une cloche de 22 mm, Audiophonics m'a expédié rapidement une cloche de 18 mm dès que j'ai signalé l'erreur.
1877PHONO FUSION PURE RCA MKII Modulation Cable PC-OCC RCA-RCA (Pair) 1.5m The Fusion cable series is the perfect integration with pure silver strands and Japanese monobrin PC-OCC copper. Designed with rigour and great precision, this Fusion series has...
Tres bon cable
Belle construction.
Cable pas trop lourd et assez flexible qui ne fatiguera pas vos connecteurs.
Tres equilibre.
Belle extension avec des details fouilles mais pas mis en avant.
Dynamique mais capable de plenitude.
Image construite et assez precise.
Tres bon rapport qualite prix
gilles A.
IBASSO AMP14 Korg Nutube Amplifier Module for DX320 / DX300 DAP Blue This iBasso AMP14 amplifier module is specifically designed to accompany the brand's DX320 and DX300 DAPs. Each module is hand tested and calibrated at the factory to provide...
ampli au son trés équilibré et la douceur du "tube"
cet ampli NUTUBE a un rendu sonore superbe ! complémentaire aux amp 12 (plus technique) et amp13(son plus analogique avec une légère mise en avant des basses). beaucoup moins de parasites avec le wifi activé que l'amp13
Erwin S.
Initially good, but sensitive and now broken
RCA inlet looks like a high quality, but the plug itself is made out of a thin folded sheet. When pushing an RCA plug in it under an angle, first the plastic insert breaks and then also the ring ruptures open. Had to take them out again, completely broken. So it is very important to push the RCA plug completely straight into the RCA inlet.
MANSOUR S.
This DAC module is a giant killer
Installed one of these R2R DACs today, coupled with Linear PSU and I2S direct from Raspberry PI 4.
After 4-5 hours playing, it is actually comparable with Denafrips Pontus 2, only diff is as thread starter mentions Pontus 2 is cleaner, probably because of all that power filtering. In the future I will add more capacitance to the PSU and see if that makes a different. Else it is a bargain. Make your own and pay 10 times less.
This replaced a Denafrips Ares 2 and no regrets.
More air, details, natural tone and off course no Delta Sigma harsness.
Quick delivery and quick response on tech questions from Audiophonics. Cheers
Thierry S.
Très bon rapport qualité-prix
Pour faire cours: très détaillé et très aéré, mais attention dans certaines configurations on peut être très proche du clinique.
Thierry S.
ARYLIC S50 PRO+ Network audio player DAC ES9023 ADC WiFi AirPlay Bluetooth 5.0 aptX HD Arylic proposes with its S50 Pro+ a connected stereo preamplifier, having the particularity to take advantage of a complete connectivity with WiFi and Bluetooth 5.0 reception....
La taille mais pas le son d'un gadget
Tout fonctionne correctement.
Le dlna ne pose aucun soucis et est télécommandable par toutes les applications que j'ai essayé.
Le wifi, je ne l'utilise pas, juste pour les maj, là un peu compliqué par contre.
La sortie analogique n'est pas ridicule.
Mais quel dommage que la sortie numérique soit limitée à du 16 / 44.1!!!
Pour du Bitperfect haute résolution regardez du coté des WIIM, Olio ou Octavio
Thierry S.
Tout d'un (très) haut de gamme
Je ne vais pas contredire les avis précédents, tout y est.
Reproduction tendance neutre ( pas typée)
En fonction des enregistrements: grande transparence, image large et profonde, excellente macro et micro dynamique, grande fidélité des timbres, etc.
Par contre, ne pardonnera rien.
L'appareil chauffe et les aérations sont dessous, donc n'hésitez pas à rajouter des pieds plus hauts et ne rien poser dessus.
Sensible au cordon et à la phase secteur.
Thierry S.
Très Très bon rapport qualité-prix
Apporte beaucoup de détourage, caractéristique de l'OCC et une très bonne profondeur.
Si votre casque est un peu décharné, par contre, passez votre chemin.
Peu microphonique, mais vous pouvez lui rajouter une gaine textile sans trop la tendre.
Les fils ne sont pas repérés, vous aurez besoin d'un multimètre et d'un fer qui chauffe beaucoup.
Thierry S.
Female Balanced Jack 4.4mm Connector Gold Plated Ø8mm This female Jack 4.4mm connector of good quality benefits from gold plated contacts, ensuring a good transmission quality and an excellent resistance to oxidation. It accepts...
Les pinoches seraient deux fois plus grandes la soudure en serait grandement facilitée.
Thierry S.
Fonctionne Parfaitement
La prise Toslink a juste un peu trop de jeu.
