Robert g.
Pascal H.
Szilard M.
Very-very good quality, my DIY amplifier is happy now and the fading of the LED ring with an Arduino program is a cool extra in standby mode. :)
Szilard M.
Toroidal Transformer 60VA 5V 12A This high quality toroidal transformer delivers a power of 60VA 5V 12A and will be an ideal choice especially for the realization of your DIY projects requiring these voltages.
A quality transformer
.. but due to voltage drop it cannot feed the Raspberry Pi4 with my stabilizer module, I had to use a DC-DC step-up converter after rectification/stabilization. With that, everything is fine now. When looking for a Raspberry/DAC based transformer, choose a higher voltage one. Apart of this, quality is really top notch, the transformer is absolutely silent, quality work.
Szilard M.
TOPPING D30 PRO Balanced DAC 4x CS43198 32bit 384kHz DSD256 Silver Powerful and compact balanced DAC, the digital-to-analog conversion stage of the Topping D30 Pro is based on no less than four Cirrus Logic CS43198 chips. These enable it to...
A matter of taste
Great DAC, measures excellent and sounds very refined. From my experience it fits systems rather with relaxed highs because this kind of Cirrus-based DAC has it's own clarity. Mid region, mid tones and vocals aren't that emphasized like with an AKM DAC, bass is well-controlled. Top quality overall and the simultaneous use of XLR and RCA outs make this an amazing "preamp" too (in PRE-mode) for e.g. a 2.1/2.2 system (where you feed your sub/subs from the RCA outs while main system is fed from XLR). All-in-all, a neutral, precise sound without much emotion. It just doesn't has its own sound. Some people like this, some not. A matter of taste. For us it lifted a bit on the highs which came very handy so we give it 5 stars.
Szilard M.
Cleanness and transparent sound with power
This is the first time I ordered this Hypex module based amplifier of Audiophonics and I don't regret it. It arrived into to a luxurious home's audiophile system and the owner (a friend of mine) was blown away by the quality and cleanness of sound. Excellent product, thank you Hypex, thank you Audiophonics.
Szilard M.
Beautiful sound
Szilard M.
Great quality
Excellent button of great quality, I can only recommend.
Exelent steamer
Brancher avec alimentation Ifi élite 12v 4a et usb neotech neu argent sur interface digital di20 audio gd qui est branché via hdmi (pangy premier cardans pl argent 0,5m) sur dac r2r r28 audio gd. Et ami cayn st200. Superbe image superbe audio du grave profond à l aigus montant et lumineux. Ont sens la puissance la dynamique et la spacialite avec transparence naturel et ultra musical. Par apport à mon lecteur cd. Sais vivant et jubilatoire. Bon si il faut chipoter un chouilla l infra grave manque très peut d assise. Mais pour le prix d un cable secteur moyen de gamme. Le RQP et exceptionnel. A consommer sans aucune modération. Merci à audiophonics de proposer de vrais bijoux tj à pris contenu et réaliste.
Rémy D.
LINDY Ethernet RJ45 Cable Cat 8.1 S/FTP LSZH Gold Plated 1m The RJ45 Ethernet cable takes advantage of the latest Cat 8.1 standard to support bandwidth up to 2000MHz. The cable has an S/FTP structure, where the twisted pairs are shielded...
Gain en qualité et vitesse
Après avoir remplacé mes câbles cat 5e par ces câbles, j'ai gagné sur mon réseau interne presque 10Mbps grâce à la propreté du signal. Le câble est plus gros que du câble ordinaire, il est aussi plus rigide mais les connecteur rj45 sont de bonne qualité et ne bouge plus une fois enfichés. Je recommande (j'ai mis entre boitier fibre et ma box puis de ma box vers du cpl...)
Rémy D.
PANGEA PREMIER SE Ethernet Cable RJ45 Cat7 Silver Plated Cardas Copper Triple Shielding 1.5m If you have high-end audio devices connected in a network, then it is essential to use quality Ethernet cables to allow your devices to deliver their full potential. With its...
Aération et silence
Dès la pose du câble, le son m'est apparu bien plus calme (moins de perturbation) se traduisant par de meilleurs silences, son moins agressif. Un très bon câble pour l'audio
markus s.
Perfect Bass
Very good bass, better than the TCS31. For me on the amplifier with Electra speakers. But the treble is too resolved and slightly harsh. Whether with gold or rhodium. With good recordings it's ok, with bad ones too many details, somehow slightly metallic. It now has 60 hours on it.
Grégory O.
Carte ok
Tout fonctionne correctement. Le schéma fourni en description par audiophonics est appréciable. Livraison toujours Ok après plusieurs commandes.
Prise coudée de très bonne qualité, avec une FI48or sur un SP1100 ça marche très bien sur un R7.
Magnifique
Câble de grande qualité monté sur des Furutech FI48R. C'est très propre, net, fin, et plus rapide oui.
Testées avec un Yarbo Sp1100 les FI48R apportent de la propreté, mais ce FP-P55N va plus loin et amène une exécution immédiate de la musique. C'est très impressionnant.
Diametre
J’apporte une petite précision sur le diamètre extérieur de ce câble
Il fait 6.5 mm et non 4.6 mm
Essayé avec une chute avec des prises rca rean en modulation c’est absolument bluffant et Il tient la comparaison avec des câbles à 3/400 €.
Je viens de le monter avec des rca Elec Tellurium, une gaine cuivre, soudure mundorff 10% et gaine de finition. Soit 40€ le tout en 1 mètre.
Seconde claque, qui renvoie le ultra haut de gamme très cher au rang d’imposteur.
Essayez par vous même, c’est une révélation.
Damien N.
Très complet, de bonne qualité et performant
Ce tout petit ampli fait bien ce qu'on attend de lui. En l'occurrence il remplace ma vieille chaîne compacte qui sonorisait mon PC. La finition est bonne, jusqu'à présent je n'ai pas eu de mauvaises surprises et je l'utilise principalement avec les entrées bluetooth et optiques.
J'apprécie les réglages disponibles pour ajuster les graves et les aigus, et c'est ce qui me l'avait fait choisir face à un Elipson Music Center BT équivalent. Alors ça ne donnera pas autant de contrôle que l'égaliseur à bandes de ma vieille Sony mais ça suffit largement.
Elsa A.
Bruit de fond
Bonne idée d'une alim non symétrique, mais le bruit de fond augmente dès qu'elle augmente mème au delà de 5V (tests avec une alim faible bruit : ça ne change rien)
Jean Michel P.
Excellente fiche banane
Excellente fabrication et rendu sonore parfait : son consistant et raffiné . insertion très franche. Utilisée en mode vissage avec du câble HP de section de 1,5 mm2 que j'ai replié à l'extrémité .
La meilleure parmi les nombreuses que j'ai testées .
Merci à Audiophonics de proposer ce modèle de qualité
Trés bien pour un smartphone
Je rechercherchais un petit dac pour connecter à mon smartphone Samsung,afin de lire ma musique stockée sur une micro sd(que du lossless ou supérieur),suite à un essais peut concluant avec un FX Audio dac X6.
C'est très très bon, même en utilisation sur un système classique ampli rega et enceintes monitor audio.
L'appli permet de sélectionner plusieurs filtres passe-bas (c'est subtil mais il me semble que ça modifie l'impression d'effet 3D )
En tout cas,quand je pense à mes début en hifi il y a plus de 20 ans avec des dacs séparé et mes centaines de CD et ce que maintenant on peut faire avec ce minuscule appareil à 100 euros et de la musique stockée sur une minuscule carte mémoire,c'est vraiment bluffant.
Valentin R.
Good heatsink with predrilled holes
But one of them may be not enough for TT5200 amp, I tested it with 24V power supply and it gets really hot, so bought the second one.
Valentin R.
MEAN WELL RS-100-24 Switching Power Supply SMPS 100W 24V 4.5A This switching power supply from Mean Well offers a power of 108W, a voltage of 24V DC and a current of 4.5A. With a universal connection system, it will fit easily into a...
used it for TT5200 amp.
Valentin R.
Unexpectedly good experience
Assembled a small amplifier, used MEAN WELL RS-100-24 power supply, for this power supply one Heat Sink Radiator Black Anodized 176x60x33mm (that has already holes for the transistors) is not enough, final version will have two of them in ECO Case EP1001825 180x250x100. Can only recommend it.
Massimo L.
Buon prodotto
Per il prezzo che costa, è un buon connettore XLR.
Massimo L.
Interconnect Cable Female XLR - Male XLR 1m CANARE L-2E5AT White This XLR cable, although sold at an affordable price, offers a very good quality design. Its Canare cable integrates two copper conductors and a drain to efficiently transmit...
Sezione del cavo ridotta.
Si tratta di un cavo economico, funziona senza nessun problema ma il cavo è di sezione davvero piccola.
Massimo L.
Buon prodotto
Massimo L.
ECCELLENTE ! !
Ordinato domenica, spedito il lunedì e ricevuto giovedì. Imballaggio semplice ma molto efficace: complimenti AudioPhonics!
Dunque io cercavo da tempo una schedina per portare le uscite di un filtro passa basso attivo per subwoofer, da sbilanciate a bilanciate. però avevo due problemi : lo spazio limitato a disposizione, e l'alimentazione del filtro 15 Vcc non duali. Quasi tutti i circuiti RCA/XLR necessitano di alimentazione duale. Io avevo a disposizione invece 15 Volt CC molto ben filtrati, e non avevo nessuna intenzione di aggiungere una alimentazione dedicata, e non avendo lo spazio avrei dovuto aggiungere uno "scatolotto".
Lo spazio libero all'interno del filtro passa basso era di 50-55 /60-65 mm. Questa piccola PCB soddisfa entrambe le mie necessità. Quindi verificato questo, ho ordinato. La scheda si presenta bene, buone le saldature, e SOPRATUTTO DOTATA DI CAVETTI SCHERMATI con relativi connettori. La scheda è sicuramente di costruzione Cinese, ma ripeto di buona qualità Le aree di massa sulla scheda sono più che abbondanti. Nessun circuito integrato è zoccolato, essendo tutti in versione SMD.-SOC, e neppure servirebbe. L'alimentazione in CC della scheda va dai 5Volt ai 24 Volt, io la utilizzo a 15V e funziona benissimo. Non capivo come potessero lavorare due DRV134 senza alimentazione duale. Molto semplicemente il circuito funziona con un LM7805 sul ramo positivo, mentre il ramo negativo viene generato da un LM2662M: semplice e geniale: in sostanza il circuito lavora con +/-5V, ottenuti riducendo i 15 Vcc del filtro passa basso attivo. La scheda penso che abbia una uscita di 2rms per ramo. Proprio quello che mi serviva per pilotare un finale BTL in classe D ! Il circuito ha anche un piccolissimo diodo LED rosso che indica la presenza della alimentazione. La circuitazione di presenta molto "standard" quasi presa da una application note della Texas Inst. La misura della PCB è esattamente quella indicata : 50x50mm e l'ho montata senza nessuna difficoltà nel medesimo case del filtro passa passo. Funziona davvero molto bene, nessun ronzio nessun disturbo. Ancora complimenti a AudioPhonics che riesce a "trovare" questi prodotti!
Branislav K.
ERATO M7 Tube Preamplifier 12AX7 / 6N4 Balanced XLR The Erato M7 is a high-end tube preamplifier with an intelligent and meticulous design, allowing it to deliver exceptional audio performance. It integrates high-quality...
Salut Daniel,
il est possible de vous contacter pour me donner de meilleurs avis sur cet appareil. Je serais intéressé par lui, mais il est impossible de le trouver sur Internet.
Merci Brano K.
Luis V.
Very good product.
I bought this dac/preamp to feed a headphone amplifier and i was stunned with this dac-tube preamp combo, my headphones never sounded so good, and i have a much more expensive high-end dac.
This is the best value for the money.
Vincent b.
très bon dac
dac ayant toutes les qualités qu'on peut en attendre.
les (-) j'ai déjà eu de plus beaux timbres mais le produit est neuf...
les (+) excellente dynamique et suivi mélodique. Maillon sensible car
c'est le premier dac qui offre autant de différences d'écoute à chaque changement de câble numérique. Meilleur résultat obtenu avec le câble AES/EBU de Canare. J'ai obtenu un resultat encore meilleur en le découplant avec 3 VIABLUE TRI SILVER et un mode NOS plutôt que OS préconiser par Gustard
Impressionnant !
IEC monté sur un Yarno SP1100 déjà utilisé avec des Viborg, c'est mieux y a pas à dire. Voir mon commentaire sur la Schuko. Bon we
Wouah
En premier lieu je tiens à remercier Patrick pour son analyse des prises secteur, super sympa et pro de ta part ;)
Je me suis effectivement décidé à me lancer sur ces connecteurs haut de gamme Furutech et j'aime mieux vous dire que durant le montage j'avais comme une impression de serrage de fesse assez prononcé me demandant si j'avais pas claqué 460€ dans du vent lol. Après avoir monté les Schuko et IEC sur mon Yarbo SP1100, j'ai lancé un cd juste sur mon petit Shanling Tempo. Ma première sensation fut un soulagement personnel; la décontraction revenue je me suis surpris à entendre mes Focal s'amuser avec la musique comme jamais. En effet mon ampli a trouvé plus de sérénité, les timbres, les fines dynamiques, la scène bien en place, tout est là mais en plus maitrisé, le son est plus propre je dirai. J'avais des Viborg qui me donnaient déjà de bons résultats mais là on passe un cran au dessus, c'est assez impressionnant. Prochaine étape, passage de mon dac R7 en Furutech aussi.
Encore merci à Patrick et aussi à Audiophonics, bonne journée à tous
eddy-pierre m.
Je voulais un selecteur pour mes pré-ampli HC et stéréo vers mon ampli Mc Intosh, je craignais des pertes, mais non. AU TOP ce produit. Meme pour les installations haut de gamme je recommande vivement.
François S.
Produit de qualité
Reçu rapidement.
3 détails.
Les vis supérieures et inférieures me paraissent un peu faibles. Je vais sans doute les changer.
Livré avec 4 pieds. Je suppose qu'il faut percer des trous pour les fixer.
La face arrière qui m'a été livrée est dotée d'un emplacement pour prise IEC.
Emmanuel G.
LUDIC POLARIS Power Cable Schuko IEC C15 UP-OCC Copper Gold Plated 2m The Ludic Polaris is a high quality power cable. It integrates patented UP-OCC Drawn® Copper conductors, allowing to obtain a high purity monocrystalline structure (higher...
Câble sérieux
Un très bon câble secteur compte tenu du prix au mètre ! connecteurs de grande qualité - écoute détaillée sans être analytique ni agressive - scène sonore large - extinction des notes aigües convaincante - pas de défauts prononcé mais câble très rigide !
Stéphane M.
WONDOM PS-BC12114 BCPB0 Power Supply on Battery BMS / Charger Module Lithium 26650 with Protections Battery cradle module 1x 26650 with protected USB-A output and direct port for power supply and mounting on Raspberry Pi.
Nouveau connecteur
Parfait pour alimenter un raspbery zero pendant des heures
Quel est le type de connecteur présent sur la carte (facilite son branchement)) ?
Jean C.
sounds very good and compliant with Linn Openhome player
Just finalized the port to run openhome on it, compliant with Linn devices for multiroom installation
see : https://github.com/jchassin/ohPlayer
open issue to contact me for support if needed
Hasni Z.
MUNDORF BL100 Air Core Coil 1mm 0.39mH Air coils, for physical reasons, are unbeatable in terms of precision on the restitution of the impulses, and are free of any distortion (contrary to ferrite coils). For this...
L’imprégnation de vernis du bobinage est un plus.
Très bon. Rapport qualité/prix
Hasni Z.
Utiliser pour RC Zobel, très bon rapport qualité/prix.
Hasni Z.
MUNDORF MRESIST SUPREME MRES20-6.8 Resistor 20W 6.8 Ohm The Mundorf MResist SUPREME resistance range offers products of exceptional quality. Having a real impact on the sound restitution, these resistances allow to obtain finer...
Très bonne résistance
Utilisée en L PAD pour atténuation après montage d’un premier filtre, je n’ai pas constaté de dénaturation du signal.
Très bonne résistance pour le passage du signal et vu le prix, cela serait dommage de s’en priver
Hasni Z.
JANTZEN AUDIO SILVER Z-CAP Capacitor 800V 10μF Jantzen Audio Silver Z-Cap capacitors maintain perfect sound neutrality and a very nice tonal balance. They are particularly suitable for use with a tweeter or midrange in...
Excellent pour le signal aigu
Vu la taille imposante de ce condo, on ne peut que saluer la qualité de fabrication.
Quand à l’écoute associé au D260, ça reste cohérent et très naturel, sans trop en faire niveau définition. Très musical, neutre, pas ce côté métallique retrouver sur d’autre marque ni de coloration. L’aération est bien là, bref c’est équilibré.
Une valeur sûr
Hasni Z.
Traitement et Livraison ultra rapide par audiophonics!
Merci à vous :)
Pour la qualité du câble, il reste plutôt silencieux grâce à son isolation au Téflon qui évite le contact direct avec l’isolant externe en PVC.
Utiliser pour le câblage interne bornier-filtre et filtre-mediumboomer.
gabriel m.
Très bien !
J'aurais vraiment aimé voir quelques graphes dans la description !
Sinon vraiment pas mal. J'ai monté un 2.1 avec du matos de récup : deux enceintes 30w JVC et un sub Samsung. Très content du résultat. Il faut juste penser à l'alimentation non fournie. Je n'ai pas réussi à me connecter au bluetooth mais je n'ai pas acheté pour ça alors, attention si c'est important pour vous !
Le code pour l'appairage Bluetooth est : 0123
Laurent M.
SHUGUANG 12AX7B / ECC83 Amplification Tube (Unit) This Shuguang 12AX7B amplifier tube will allow you to replace an equivalent model but also the 12AX7, ECC83 and 12AX7-T tubes or an integration on a DIY creation. With a double...
Parfaites
Lampes de qualités et contrôlées.
Livraison rapides et très bien protégée.
Merci.
Jozef Š.
Great sound upgrade, NOT 75 Ohm !!!
Excellent build quality, fine sound upgrade for interconnection type...but it is not 75 Ohm cable like was in description before my order...well not so suitable for digital coax type cable construction.
Jozef Š.
Unusable for coaxial cable
Excellent build quality but not suitable for coaxial cable.
Stunning cable
I run this cable for amplifier, CD and conditioner unit. It is sonically the most gorgeous I’ve used bettering Nordost by a long way.
I have it terminated with solid silver IEC’s and UK plugs and again, sound is stunning, especially the mid range depth and realism.
Stunning cable
I have used many €20-€30 p/m cables and so glad I jumped to this price level and even more so that the sonic improvements have been worth every penny.
Naturally, the first few weeks are a little light and muddy in the bass, but other out of the box includes more air around vocals abs terrific timing.
A very worthwhile cable upgrade.
Excellent cable
I changed out a V1 Nordost Blue Heaven RCA to a self made cable and the results were astonishing. It makes one wonder why you pay silly money for a brand with good marketing when you can make as good, or better, for a fraction of the costs.
François D.
Préampli McIntosh C2300
Très bonnes lampes sur la partie ligne du préampli C2300. La scène est plus large qu'avec les tubes d'origine avec un très bon medium et des graves qui se tiennent.
Roman R.
Compared this cable with the stock cable that goes with Marantz PM-8006 and instantly heard tighter bass. No soldering. Connectors are also Elecaudio.
Benoit s.
excellent!
je viens de d'installer ces fiches banane sur un câble audioquest relativement bas de gamme et je suis très agréablement surpris par le résultat sonore obtenu. La différence est plus que subtil!
La finition est certes un peu "cheap" mais pour celui qui cherche avant tout un nette gain sonore sans se ruiner c'est parfait
