Richard H.
Dayton Audio BST-300EX
précis et chaleureux
Eric v.
bonne prise
naturel et finesse
Bonsoir, voici mon 2 eme vondita ,un sur l ampli et la sur mon alimentation allo shanti pour mon phono. Ce cable a une tres grande resolution, medium fin et tres fluide ,un beau timbre corsé , une tres bonne dynamique , j ai eu une vingtaine de cables secteurs c est certainement le plus naturel! Franck
Ioannis P.
XANGSANE XS-5N Banana Speaker Cables OCC Copper Silver Plated 3m (Pair) Xangsane's XS-5N speaker cables are made up of 12 strands of silver-plated 5N single-crystal OCC copper to ensure electromagnetic impermeability and perfect conductivity. Each...
This is a very high quality product, I think it will satisfy most casual users, and for me it is about the maximum I'm willing to spend on cables. However the quality exceeded my expectations. About the sound, It is very hard to comment, I'm no specialist, I just tried to match the quality of the cables to the quality of my speakers and I think they serve the purpose. The shipping, packaging, and overall professionalism of this store is exemplary.
Michael S.
Does not work with Raspberry Pi 5
Works with older Raspberries, but not with Pi 5
Vandestienne S.
JANTZEN AUDIO COMPACT MKT 001-8150 Axial MKT Capacitor 160V 33µF Jantzen Audio's Compact MKT capacitors are made from the highest quality metallized polyester film available. Jantzen Audio has succeeded in making these capacitors more compact...
jantzen mkt 160v 33uf
bon condensateur fait tres bien le boulot bien meilleur que ceux qui etait installer sur mes magnat transpuls 1500
Vandestienne S.
JANTZEN AUDIO COMPACT MKT 001-8140 Axial MKT Capacitor 160V 22µF Jantzen Audio's Compact MKT capacitors are made from the highest quality metallized polyester film available. Jantzen Audio has succeeded in making these capacitors more compact...
jantzen mkt 160v 22uf
Vandestienne S.
JANTZEN AUDIO COMPACT MKT 001-8120 Axial MKT Capacitor 160V 15µF Jantzen Audio's Compact MKT capacitors are made from the highest quality metallized polyester film available. Jantzen Audio has succeeded in making these capacitors more compact...
jantzen mkt 160v 15uf
Vandestienne S.
JANTZEN AUDIO COMPACT MKT 001-8100 Axial MKT Capacitor 160V 10µF Jantzen Audio's Compact MKT capacitors are made from the highest quality metallized polyester film available. Jantzen Audio has succeeded in making these capacitors more compact...
jantzen mkt 160v 10uf
Vandestienne S.
JANTZEN AUDIO COMPACT MKT 001-8070 Axial MKT Capacitor 160V 5.6µF Jantzen Audio's Compact MKT capacitors are made from the highest quality metallized polyester film available. Jantzen Audio has succeeded in making these capacitors more compact...
JANTZEN AUDIO COMPACT MKT 001-8070 Condensateur MKT Axial 160V 5.6µF
Fabrice M.
Etonnant
Après des câbles hors de prix puis des Mogami 3103, puis des Elecaudio HP 250CC qui faisaient tous deux déjà mieux que les premiers mais sans être complètement satisfaisants (problèmes d'équilibre entre les différents registres), j'avais fini par remettre des vieux Sommercable orbit 2,5 mm2 (4,10 euros le m !) qui marchent très bien entre mon petit accuphase (E210) et des Tannoy D700.
Apparemment , passer d'environ 5mm2 à 2,5 serait bénéfique dans mon installation (?).
Cela m'a donné l'envie d"essayer un autre câble en 2,5 et devant les commentaires dithyrambiques concernant le Ludic , je me suis lancé.
Et bien je confirme: le clavecin (pas facile pourtant...), le piano, les cuivres, les voix lyriques, le jazz en petite formation, un gros symphonique, tout passe en faisant passer le matériel au second plan . Révélateur sans agressivité, une variété de timbres que je n'avais pas avec cet équilibre du grave à l'aigu.
Hautement recommandable si l'on veut arrêter de se poser des questions et profiter seulement de la musique.
Jean-Jacques B.
ATAUDIO V7 Modulation Cable RCA-RCA 7N OCC Copper 0.75m (Pair) This RCA stereo modulation cable ATAudio V7 is a perfect solution to upgrade and improve the connections between your HiFi devices. The choice of materials has been scrupulously...
Parfait!
Maison hautement recommandable:
Conseils tjs convaincants
Envois très soignés en 48h
Le câble ATAUDIO V7 me convient parfaitement pour relier mon préampli à mon tuner pour un excellent rapport qualité prix performance!
Je remercie votre équipe, à bientôt!
Power Cable GX16 to Jack DC multi-ended 5.5/2.5mm and 5.5/2.1mm 1m This affordable, high-quality power cable features a 2-pin GX16 female connector (also known as an aviation connector)  and a  DC 5.5/2.5mm and 5.5/2.1mm jack...
Cable not work at linear Power12 v
This Cable not works with my linearPowersupply 12 V 5A
RENAUD C.
Beau coffret tout aluminium
Un boîtier onéreux, mais solide et bien refroidi pour accueillir mon futur ampli MOSFET 2 x 150 W (Projet 101 de Elliott Sound Products sound-au.com).
Gaspard G.
Surprenant petit ampli. Très bon rapport qualité /prix.
Attention il ne fonctionne pas et coupe épisodiquement si on monte les deux voies en parallèle pour écouter en mono sur une seule enceinte.
Gaspard G.
DAYTON AUDIO DC28FT-8 Speaker Driver Dome Tweeter Silk 50W 8 Ohm 89dB 1300Hz - 20kHz Ø2.8cm This 28mm silk dome tweeter is strongly inspired by the prestigious Nordic solutions and provides a silky, pleasant sound and high capacity for detail. With a straight-line...
Très bon rapport qualité/prix
C'est la troisième fois que je commande ces tweeters. La façade est très commode pour l'insérer dans de petites enceintes, type bibliothèque. La réponse est bonne, détaillée. Elle vaut effectivement celle de produits plus chers.
Gaspard G.
DAYTON AUDIO DSA115-8 Speaker Driver Woofer / Midbass Aluminium 35W 8 Ohm 86dB 63Hz - 11kHz Ø10.2cm This DSA115-8 bass/low-midrange driver supports a power of 35W RMS (70W max) for an impedance of 8 Ohm. It is capable of reproducing a frequency range from 63Hz to 11kHz. Its...
Très bon HP, utilisé dans une enceinte de petit volume, le son est détaillé avec un grave présent et propre (accordé à 58hz).
Enfin !
Je n' ai jamais trop apprécié les câbles Neotech ( y compris le nemoi 1220), mais celui ci fait exception a la regle. Équilibré, construction cogérante et section de bonne dimension.
Très bon câble.
Allez y
J' ai remplacé les fil xlr interne d' origine de mon ampli 3e audio diy par ceci, petit gap sympa... Juste faire attention car tout les fils sont noirs
Amaral E.
Best
Meilleur achat, gifle. Merveilleux câble à tous les niveaux, non seulement en termes d'excellente qualité de construction, mais surtout en termes de performances sonores. En plus de 25 ans, j'ai essayé différents câbles de plusieurs marques réputées à plus de dix ou vingt fois le prix de celui-ci. J'ai dû refaire tout mon système, qui a gagné en naturel, en transparence et surtout en émotion. Félicitations à Audiophonics pour nous avoir proposé ces merveilles à petits prix, mais avec de hautes performances.
Amaral E.
Peut-être le meilleur câble que j'ai essayé depuis plus de 30 ans, même comparé aux câbles coûtant plus de 400 €. (J'avais déjà Furutech, Neotech, W&M, Yarbo, Qed, Audioquest). Ce que fait ce câble en présentant l'image sonore est phénoménal et dans tous les paramètres, nous avons un son plus cristallin, des basses rapides et en même temps très naturel et plein d'énergie. Les médiums et les aigus avec une excellente beauté et transparence du timbre. De construction simple mais exemplaire, la magie de la performance sonore est aussi capable de grâce à la qualité du cuivre là où il n'y en a pas. doit être étranger à la fabrication européenne.
Pascal j.
AUDIOPHONICS OBSIDIAN Interconnect Cable RCA-RCA Pure Silver 0.75m (Pair) Optimal audio signal transmission without any defects is what we offer you with the Audiophonics Obsidian premium RCA interconnect cable. Its pure silver conductors and...
Je vais commander ces câbles car je recherche la perfection sonore sur mon système hifi.
je voudrais juste dire qu'hormis pour un moteur thermique dans un véhicule, je ne crois pas du tout au rodage des câbles hifi en tout genre.
Même avis pour les appareils hifi ( amplis, sources etc. )
Juste tout au plus laisser un temps de chauffe de 15 ou 20 mn avant de les utiliser. ( 30 mn pour le amplis à tubes )
Ceux qui vous disent la même chose sont des pros honnêtes, comme Mr David Aubert ( Audiophonics )
Les autres sont des vendeurs.
Florian C.
Sublime mais impitoyable
Je passe d'une P-046 à cette P-004 après avoir économisé patiemment et ne regrette absolument pas mon petit coup de folie. Maintenant les connecteurs valent littéralement aussi cher que mon câble secteur (Gigawatt LC-3 mk1) mais j'ai l'impression d'avoir atteint un sommet. Assez impitoyable avec le câblage en amont ça vaut le coup de "bidouiller" un peu à l'oreille au niveau du choix des connecteurs le temps d'atteindre l'équilibre tonal approprié. Je m'attendais à un son extrêmement ouvert et aéré avec des basses peut-être légèrement timides mais que nenni : ça sonne charnel et droit mais sans dureté avec un aplomb et une fluidité enthousiasmants. Je m'interrogeais par rapport à une éventuelle montée en gamme de l'amplificateur : plus maintenant.
Florian C.
Sublime mais intransigeante
Je passe d'une P-046 à cette P-004 après avoir économisé patiemment et ne regrette absolument mon petit coup de folie. Maintenant les connecteurs valent littéralement aussi cher que mon câble secteur (Gigawatt LC-3 mk1) mais j'ai l'impression d'avoir atteint un sommet. Assez impitoyable avec le câblage en amont ça vaut le coup de "bidouiller" un peu à l'oreille au niveau du choix des connecteurs le temps d'atteindre l'équilibre tonal approprié. Je m'attendais à un son extrêmement ouvert et aéré avec des basses peut-être légèrement timides mais que nenni : ça sonne charnel et droit mais sans dureté avec un aplomb et une fluidité enthousiasmants. Je m'interrogeais par rapport à une éventuelle montée en gamme de l'amplificateur : plus maintenant.
David R.
ZD-735B Adjustable Soldering Iron Kit with Stand 60W 500°C This soldering iron kit lets you perform basic soldering tasks. The set consists of a ZD-735 soldering iron, a ZD-11C soldering iron holder, a ZD-190 desoldering...
Chauffe vite, résistance courte bien pratique pour du travail de précision.Je n'ai pas au moment où j'écris, assez de recul pour juger de la qualité et de la durabilité, mais parfait pour de l'occasionnel.
David R.
Bonne qualité, peut-être un peu lourdes pour un appareil léger comme un DAC qui versera vers l'arrière.
Elles sont un peu larges, vérifiez l’écartement des borniers sur l'appareil auquel vous destinez ces Fiches.
Comme Cédric J, j'ai fini par souder la tresse du câble au corps, pas eu besoin de modif pour cela.
Kimmo A.
Great
Works like a charm right out of the box. Easy setup. Only bad thing is the power LED, which is a bit too bright for my taste, but still this is a great product.
Didier G.
LHY AUDIO SW-6 SPF Network Switch 5x RJ45 1x Optical Fiber Black With the SW-6 SPF,  LHY Audio  offers us a network switch featuring 5 RJ45 ports, one of which is digitally isolated, a fibre optic SFP port and a BNC input connected...
Très bon switch réseau
Ce switch réseau arbore une très belle qualité de construction. Connecté à une TV, un NAS et un streamer (port SFP non utilisé), il améliore remarquablement la restitution audio et vidéo. Le switch apporte acuité, présence et relief d’image à la restitution. La musique semble également plus fluide et apaisée.
Jean-Pierre E.
AUDIOPHONICS HPA-S450ET Power Amplifier Class D Stereo Purifi 1ET6525SA 2x450W 4 Ohm The Audiophonics HPA-S450ET power amplifier is based on a Class D architecture, using a pair of Purifi 1ET6525SA amplification modules, a Hypex SMPS1200A400 power supply and an...
Amplificateur Exceptionnel
Je viens de remplacer mon ampli Roksan K3, considéré comme très bon sur beaucoup de forum hi-fi par cet ampli et je suis impressionné par le gain obtenu dans tous les domaines (Transparence, bande passante , timbres, spatialisation). Pour prendre une métaphore sportive, plusieurs divisions d’écart.
Mon installation :
Source: Qobuz + Rivo
Dac/preampli: Smsl D400ex
Enceintes : Triangle Magellan Cello 40 th anniversaire
La Classe D d’amplification supplante toutes les autres classes et les remplacera très rapidement.
Jean Pierre.
Guillaume C.
Très bon DAC
J'ai acquis ce Dac pour remplacer LE Dac AUDIOPHONICS U-SABRE USB 24Bit/96kHz ES9023 TCXO qui n'est plus reconnu par Windows 10 depuis une mise à jour récente.
Ce Soncoz LA QXD1 écrase le Dac audiophonic U sabre dans le registre médium. Médium beaucoup plus présent, aéré et défini. le grave quant à lui est en léger retrait et l'aigue est comparable au U Sabre. bref que du bonheur. je lui est adjoint une formule 1 en alimentation, l'ALLO SHANTI Alimentation Linéaire Régulée Double 5V 3A à 199€. les transitoires et les attaques des notes sont fabuleuses avec cette alimentation. Malgré la discontinuité du produit chez Audiophonic ( c'est bien dommage), on peut encore commander ce DAC sur certains sites.
Marylène C.
comparé au Fosi V3
Voici mon ressenti après pas mal d'écoutes sur du Carl Cox, Iron Maiden remasterisé, Epica,Arch enemy, Stella Rose…
Comparé au Fosi V3 stéréo j'ai l'impression avec le Hypex d'entendre 3x plus de petits détails, d'éléments présents dans les enregistrements qui participent à l'ambiance et à l'immersion.
Sensation de calme dans la musique, tout est là, on peut pousser le volume, tout reste imperturbable et "paisible".
Comparée à l'écoute au casque les enceintes repassent devant.
L'écoute au Fosi ressemble peut-être davantage à mon expérience en class A/B (Harman, Marantz), sans arriver à mettre de mots dessus, c'est un peu plus chatoyant mais semble perdre un peu en justesse au passage. Le Hypex donne l'impression de prendre plus son temps et d'être plus lent, clairement 3 minutes 40 ne sont pas remplis de la même façon.
Est-ce que ça vaut le coup de mettre 5x le budget du Fosi dans un bloc Hypex
audiophonics? Sur mon instal et sous réserve qu'il tienne dans le temps je dirais que oui sans hésiter. En gardant en tête qu'on a déjà de quoi se faire plus que plaisir avec un V3 stéréo
S'il fallait grossièrement caricaturer avec le Fosi on est devant une chaîne Hifi, avec le Hypex Ncore on est au studio
Jean-Baptiste S.
Bluetooth 5.0 Receiver Transmitter Micro SD RCA Jack 3.5mm This small Bluetooth 5.0 receiver and transmitter offered at a low price will allow you to broadcast your music wirelessly to a classic audio system or a headphone for example.
Qualité audio médiocre
Bonjour. Bon, dur de rédiger un avis négatif tant j'ai toujours apprécié les produits d'audiophonics.
J'ai déjà acheté ce type de produit en chine et chez aldi... Chacun à très bas prix. Donc je pense pouvoir comparer.
La qualité audio de celui-ci est vraiment très mauvaise. Honnêtement passez votre chemin, c'est le meilleur conseil que je puisse vous donner.
David E.
Aux amateurs de bel objet
Le support est vraiment beaucoup plus beau en vrai qu'en photo. Il est massif, et constitué de petits patins au dessous pour assurer sa stabilité. La gravure Dynavox est de très belle facture (mais pourra être occultée suivant le casque posé), et outre ça, ben il fait son travail parfaitement !
David E.
Un rapport ualité prix défiant toute concurrence
Fiches bananes chinoises, livrées avec clé allen pour le verrouillage du câble, et également avec 2x deux petites gaines thermorétractables (deux rouges, deux noires).
La finition n'appelle strictement aucune critique, le verrouillage dans les borniers est ferme et inspire confiance. Un mini regret concernant la surface en contact : j'ai l'impression qu'elle est un peu plus réduite qu'avec une fiche banane traditionnelle (en corolle), mais je suppose que c'est un parti pris pour assurer le verrouillage en position, et je suppose également que ça ne perturbe en rien la transmission du signal.
En résumé, ces fiches sont absolument parfaites pour leur usage et n'auront pas du tout à rougir de finaliser un montage de câble de haut vol, surtout à ce tarif incroyable.
Ivan Ž.
Great volum control
For the price, this is unbeatable. I recommend it as a budget upgrade. There are superior volume control regulators, but for this price, no way.
Ivan Ž.
VAN DEN HUL THE BAY C5 HYBRID Coaxial Cable Silver Plated OFC Copper LSC Shielded 0.452mm² Ø5.2mm The Van Den Hul The Bay C5 Hybrid is a coaxial cable with a high quality design and excellent transmission performance. It consists of a silver plated OFC copper center...
Great price for a great cable, I use it as interconnect cable.Make your self a preaty decent cable, I will buy again.
Konstantinos D.
Pangea power cable
There is definite improvement over the sound quality with this cable. Audiophonics excellent with their shipping and customer service. UPS shocking. Worst courier company.
Uwe G.
Highend Signalkabel
Allround Audioverbindung.
Das 2534 als Tonarmkabel spielt auf hohem Niveau, besser als namhafte Referenzhersteller.
Für ein Tonarmkabel mit SME 5P Stecker (Elecaudio) verwende ich je 2 Adern für links und rechts, das Schirmgeflecht für Masse.
Bin mit dem DIY Tonarmkabel überaus glücklich.
Für die RCA Cinchstecker isoliere 18cm ab und das Schirmgeflecht verdrillen. Die Adern 4cm kürzen und für die Cinchstecker konfektionieren.
Mit den 5mm Schrumpfschläuchen von Audiophonics funktioniert es tadellos.
Viel Spaß beim testen.
Michel S.
VEZZOSO X36 Balanced DAC ES9039PRO HDMI I2S SPDIF USB XMOS AES 32bit 768kHz DSD512 This X36 DAC from Vezzoso is a high-fidelity DAC that incorporates quality components such as an XMOS XU216 USB interface, an ESS Technology ES9039PRO DAC chip and a Qualcomm...
OMNI (Objet Musical Non Identifié)
Ne cherchez pas VEZZOSO sur la toile, vous ne trouverez ni site dédié ni test, au mieux une poignée de modèles vendus sur un grand site de E-commerce asiatique.
Cette marque chinoise semble spécialisée dans la production de DAC et sa diffusion principalement limitée au marché intérieur.
Il faut donc faire avec une notice en chinois (merci Google Translate) très succincte et une mise en route un peu atypique. En effet lors du premier allumage l'appareil se met en veille forcée et affiche un compte à rebours de 66 minutes.
Dixit le fabricant ce délai est destiné à reformer les condensateurs et stabiliser l'alimentation. Il indique également que ses produits sont pré-rodés en usine durant 72 h et qu'il en faut encore autant pour que l'appareil atteigne son plein potentiel.
Pour le prix d'un TOPPING ou d'un SMSL milieu de gamme le VEZZOSO délaisse les alimentations à découpage habituelles et offre un couple de transformateurs toroîdaux suivi d'un filtrage sérieux. Le reste des circuits est à l'avenant avec des composants de belle qualité et une implantation exemplaire.
A l'écoute les résultats ne se font pas attendre. Ce DAC délivre un son de haute volée digne d'appareils valant le double.
Ici la précision ne se fait pas au détriment de la douceur et les timbres sont d'une grande fidélité aussi bien sur les instruments acoustiques que sur les voix. La séparation est impeccable dans le sens de la largeur mais aussi en profondeur révélant parfois des effets de studios jusque là masqués. Enfin les signaux de faible amplitude sont parfaitement restitués et insufflent une belle respiration à la musique.
Ce DAC "exotique" présente donc une superbe sonorité doublée d'un rapport qualité/prix exceptionnel.
Thierry D.
Qualitatif
Je n'utilise pour l'instant que la fonction lecteur en sortie optique (24bits/44Khz). Le boitier est solide, et malgré quelques vibrations les premières minutes d'utilisation, je n'ai rien à redire sur le fonctionnement de cet appareil. La seule remarque concerne l'afficheur qui n'est utile qu'à quelques centimètres tellement il est petit. Assis dans mon canapé, il m'est impossible de lire le numéro de piste ou encore le temps écoulé.
Le rapport qualité/prix me semble tout à fait convenable. Reste à voir à l'usage sur a durée.
Emilio L.
très bon cable
Suite à un changement de placement des HP, les distances ampli-enceintes se ont largement raccourcies et donc j'avais besoin d'un nouveau cable HP. Suggéré par M. Aubert (Audiophonics) ce cable convient très bien à mes enceintes à 3000€. Qualité irréprochable, rendu sonore equilibré dans tout le spectre. Je suis très content de cet achat avec un pris assez modique.
Régis C.
AUNE S17 PRO EVO Discrete Class A Balanced Headphone Amplifier Preamplifier 7500mW 32Ω Black With its S17 Pro EVO, Aune unveils a powerful Class A headphone amplifier that can also be used as a preamplifier in a Hi-Fi installation. This headphone amplifier features...
Cet ampli va réveiller vos casques !
Vous trouvez votre association casque/source molle, sans vie, avec un son plat...et bien cet ampli a la particularité de ramener à la vie et de magnifier n'importe quel casque ou intra pas sensible.
C'est une claque monumentale pour moi, peut-être l'effet whaou de la nouveauté mais après une semaine, c'est le pied!
Une scène 3D fabuleuse, une extension abyssale dans les basses et des aigus soyeux pas agressifs.
Mes casques sont Hifiman HE1000 Stealth et Meze Empyrean OG
Relié en XLR à un dac Eversolo Z8.
En courant bas, il plafonne à 52° et monte à 61° en haut au bout de 2h. (Température ambiante de 21°)
Cet ampli est vraiment le meilleur parmi tout ceux que j'ai eu. Je le recommande à 200%.
Audiophonics toujours au top!
Thierry V.
IFI HDMI ISILENCER HDMI Female to HDMI Male EMI Noise Suppressor iFi Audio's HDMI iSilencer is an HDMI filter designed to reduce noise and jitter in your signal and protect your equipment from surges that can be caused by electrostatic...
Sur oled sony avec mon lecteur uhd pana 820, on voit la difference en terme de colorimetrie, profondeur d image c est indeniable, par contre sur decodeur sat, je ne vois pas de difference...un bon achat pour de bonnes sources à la base
Matt H.
Excellent quality
I bought this Viborg plug to replace a knockoff Furutech Rhodium plug that I got free with something. There was an immediate increase in sound quality. Sweet high frequencies instead of the Harshness I had with the knockoff Furutech plug.
sébastien w.
Coup de coeur
Un câble très musical.
Bande passante très étendue, aucune agressivité. Très belle surprise pour un audiophile.
J'ai des câbles dans ma collection qui coûte 100x son prix ....... qui peut être presque comparable
sébastien w.
Suprise sur le gâteau
Ne cherchez plus, pour un prix dérisoire vous gagnez sur toute la ligne.
Changer juste cette embase vous donnera un son beaucoup plus naturel que l'origine. (Metalique , froid
) Les timbres plus juste, l'image sonore mieux défini et surtout les effets FX sur les instruments que l'on
entend plus longtemps . A soudé avec étain 10 % argent .
Thomas G.
TOPPING D50 III DAC 2x ES9039Q2M XMOS XU316 Bluetooth 5.1 LDAC 32bit 768kHz DSD512 Black Topping's new D50 III desktop DAC has been updated to deliver even better performance than its predecessors. It now features two ES9039Q2M DAC chips and an XMOS XU-316 USB...
Acheté pour alimenter un ampli casque Lake People. Il remplit parfaitement son rôle, le son est neutre, transparent et plein d'énergie. La fonction EQ est idéal pour égaliser un casque.
En points négatifs : alimentation non fournie et l'application pour le paramétrage de l'égaliseur n'est disponible que sur PC.
Emilio L.
PANGEA AC-14SE MKII Power Cable IEC C7 Triple Shielding OCC / Cardas 3x2mm² 1.5m Based on a mix of solid strands and Litz wires, this cable is especially designed for your audio sources. The Pangea AC-14SE MKII cable is specially designed for source...
je recommande
Acheté pour remplacer le câble alimentation de mon streamer/preampli/dac Yamaha WXC-50. Ce streamer se trouve très près de la livebox que soupçonne introduire des parasites dans le Yamaha via le câble secteur. Avec le nouveau câble je cherche à éliminer ces courants parasites induits par le rayonnemet électromagnétique de la box. Le câble est assez lourd et il remplie bien son rôle. Attention quand même au poids par rapport à l'embranchement dans le dispositif: il peut se déconnecter de façon inopinée. Est-ce que le câble rempli son rôle ? Je trouve que l'image sonore a un bien meilleur rendue, plus large et les instruments mieux localisés.
Gregory D.
XDUOO MX-01 Bluetooth 5.3 Transmitter aptX Adaptive xDuoo's MX-01 is a high-performance Bluetooth 5.3 transmitter. It incorporates a Qualcomm chip, a guarantee of stability and quality. The MX-01 is capable of transmitting...
Le premier transmetteur reçu était défectueux et j'ai dû le renvoyer, mais Audiophonics l'a vite remplacé et m'avais bien tenu au courant du traitement de ma réclamation. Le nouveau transmetteur a bien fonctionné tout de suite. L'installation était fait dans 5 minutes. 4 étoiles pour xduoo, 5 étoiles pour Audiophonics.
Gregory D.
Bonne qualité, bien travaillé, rien à dire.
Claude G.
EVERSOLO DMP-A6 GEN 2 Streamer 2x ES9038Q2M WiFi DLNA Roon Bluetooth 32bit 768kHz DSD512 The Eversolo DMP-A6 Gen 2 is a HiFi network player that seamlessly combines outstanding sound quality with cutting-edge technology. More than just an audio device, it's a new...
Un lecteur réseau de premier ordre
Couplé en XLR avec un AUDIOPHONICS LPA S400 ET et utilisé comme pré-ampli, cet appareil doté d'une connectique très complète peut être piloté par une télécommande dédiée.
L'application léléchargeable est conviviale et ergonomique et la scène sonore est vaste et la restitution précise.
Très heureux de cet achat, les conseils de David Aubert sont toujours judicieux...
Boy H.
Awesome!
Got it combined with the Amanero Combo768 interface (i2s). Sounds better than my Topping D30Pro.
