Terrific cable
Tomasz C.
arnaud m.
Exelent
Customers reviews - There are 19317 reviews.
Martin W.
CONNEX SMPS2000RxE Switched Mode Power Supply Module 2000W +/-55V The SMPS2000RxE switching power supply is a very high efficiency model capable of developing a rated power of 2000W for a reduced space requirement. It will therefore be able to...
Ordered one to evaluate
Ordered one to evaluate. Perfect power supply with nice utilities and clear signalization. Lots of power reserve and good quality. Can use more of these.
Martin W.
Promising but very variable in quality
This is a beautiful and very promising power supply. First ordered one to evaluate this power supply. As it fulfilled all requirements I ordered another one. The quality of the first one and the second vary too much. Status signalization did not work on the second power supply and overall quality looked as if the second one was a cheap Chinese replica.
Martin W.
Power Plug Adapter Female US NEMA 1-15 / C Type to Male FR C Type This power adapter allows you to use US format power cables on European, Schuko or French plugs. The female part of the adapter can also be used for Type C / Schuko.
this works
It works but possibly better to exchange the complete power cable. often this is not so expensive.
Martin W.
DAYTON AUDIO DTA-2.1BT2 Class D 2.1 Amplifier Bluetooth with Tone Control 2x50W + 100W 4 Ohm Black The Dayton Audio DTA-2.1BT2 is a discrete amplifier capable of accompanying two speakers and a subwoofer. This makes it possible to create a compact 2.1 system, regardless of...
Brilliant Amplifier
Great connectivity flexibility and good power reserve. Very functional for quick and simple set-up of music in the garden or on the terrace. Can use a few more of these.
Pierre B.
Très bonne fiche banane, serrage des câbles par deux vis à 90 °, bonne longueur de câble à l'intérieur pour garantir à la fois la tenue et le contact.
Insertion très ferme dans les douilles femelles dans certains cas plutôt difficile mais au moins ça ne bouge pas et que le contact tiendra dans le temps.
Sur un ampli DIY j'ai les prises femelles de la marque, couple parfait. Très bon rapport qualité prix.
Pierre B.
Sur un ampli DIY j'ai les prises femelles de la marque, couple parfait. Super rapport qualité prix.
Fil rigide monobrin de qualité
Utilisé pour le câblage interne (fils volants) d'un ampli à tubes...
Aucun problème pour dénuder la gaine téflon
super produit !
Sheath 100% PTFE Transparent AWG18 Ø 1.0mm This PTFE insulation sheath allows to insulate a bare or already insulated conductor of 1mm diameter maximum. Transparent, it leaves the conductor visible.
gaine téflon
Utilisé pour isoler du fil d'argent
https://www.audiophonics.fr/fr/cable-nu-argent-or-cuivre/elecaudio-fil-pur-argent-999-o1mm-p-2828.html
Produit de qualité
fil argent
utilisé avec parcimonie; (l'argent coûte cher !!)
Pour câblage bus de masse, pour réaliser un pont etc...
isolé avec gaine téflon 1mm2
Ras pour la mise en oeuvre
Johann a.
ça marche!
Fait bien son travail, ça aspire fort!
Johann a.
Bonne idée
Belle trouvaille que ces petits bouchons, qui me pousseront à ne plus nettoyer mes sorties RCA pendant un bon moment. C'est simple, discret et assez élégant sur un appareil Hi-end. Un premier achat test que je renouvellerai très sûrement. Merci Audiophonics
Johann a.
Câble audiophile
Après l'achat de plusieurs modèles (autres couleurs: rouge puis blanc), même constat, c'est un excellent article. Belle isolation PTFE et conductivité parfaite, détaillé sans être agressive ni coloration (en Cinch). Mérite amplement ses 5 étoiles.
Charles B.
charles Browne
excellent product and delivery of item was very fast. The website was difficult to use. I had to place two separate orders to get what I wanted, because of Object Error. It only affects Audiophonics Website, and until I can resolve it I will not be able to order from Audiophonics.
Marc A.
TOPPING DX3 PRO V2 DAC 2x AK4493EQ Headphone Amplifier TPA6120A2 Bluetooth LDAC XMOS XU208 32bit 768kHz Silver The DAC combo and headphone amplifier DX3 Pro from Topping returns in a revised and improved V2, benefiting in particular from new practical features and ensuring even better...
Marc . 06
Excellent appareil qui tient ses promesses. La musicalité est là : l'utilisation des processeurs AKM 4493 EK est une évolution et une amélioration des AKAM 4490 réputés pour leur musicalité et utilisés dans certains amplis Haut de Gamme chez Marantz ,Denon ,Onkyo, etc...( voir sur le site de Asahi Kasei)
A noter les entrées nombreuses et variées qui permettent pratiquement tout les branchements.
Lisez attentivement le mode d'emploi, certaines fonctions ne sont opérationnelles qu'après (1 petit "reset")la mise en marche suivante:
1) Appui sur le bouton cranté de façade;2) Insert du jack de l'alimentation….accès aux réglages.
En mode DAC ,l'affichage permet de contrôler la fréquence de sortie de vos fichiers numériques et de vos appareils.
Exemples constatés:
-Samsung Galaxie 7:la carte Son permet la sortie des fichiers son jusqu' à 24bits 192 khz( Le DX3 affiche 192 khz en permanence)
-Portable Asus Zenbook 13.3 pouces Full HD I7 ou I5 carte son limitée à 48 khz : Les fichiers en 24/ 96 khz ne sortiront qu'en 24/48!!
Surprise donc selon vos appareils;leDX3 vous montre leurs limites!
Pour l 'entrée Wireless la qualité reproduite sera évidemment fonction de l'appareil émetteur pour profiter de l'APTx-HD ou du LADC..
Mes essais casques ont été effectués avec :
- Beyer Dynamics DT 1990 PRO (250 ohms) qui est la version pro de l'"AMIRON" HI-res(seul la présentation change) - Technologie TESLA.
- Audio Technica ATH-SR5 (HI-RES) Excellent petit casque fermé ,léger et plus fabriqué( 5-40 khz)….. Il n'était pas assez cher….
-TASCAM DA 3000:enregistreur audio/convertisseur AN/NA PCM 24:192 KHZ et DSD- appareil pro de studio.
BRAVO AUDIOPHONICS pour cet import!!!!
SEUL BEMOL: faites imprimer une traduction même limité au plus important de la mode d'emploi -une 1/2 feuille A4 n'est pas ruineuse!!
Alexandre M.
Utilisé sur raspberry PI
Testé pour convertir une alimentation 12V secourue par batterie plomb pour un projet d'alarme sur raspberry PI . Fonctionne bien , à voir sur la durée .
Vincent D.
Edit à mon avis précédent
Finalement mon problème venait d'une mauvais mise à la masse de la carte. Après un câblage correct (avec prise IEC 3 broches d'un côté et sur une multiprise Schuko de l'autre), le DAC est transfiguré et révèle tout son potentiel.
Les amplis-op Muses 8920 et OPA134 lui vont à merveille.
Le son est incroyablement propre, avec une très grosse dynamique, la séparation des instruments très bonne et toutes les extinctions de notes sont facilement suivies jusqu'au silence absolu.
Je lui mets 4 étoiles du coup car j'imagine qu'on peut obtenir encore mieux (la présence des voix n'égale toujours pas celle qu'on peut avoir sur une très bonne platine vinyle), mais j'imagine qu'il faut vraiment viser du matériel très pointu (à base de puces type ES9038 pro).
En définitive j'en suis très content.
Michel L.
Transfo sur mesure
Merci d'avoir bien voulu réaliser ce transformateur sans doute inhabituel dans ses caractéristiques puisque déclinant diverses tensions sur le primaire. La qualité torique en plus.
Pastorelli g.
DAYTON AUDIO SPA250DSP Class D Amplifier & DSP for Subwoofer Module 250W This Dayton Audio SPA250DSP features both a 250W Class D Subwoofer amplifier and a Subwoofer DSP, allowing you to control your subwoofer efficiently and accurately.
Tres bon ampli
Acheté pour driver un Focal 33Kx clos dans 30 litres, l'ampli est très pratique et extrêmement aisé à configurer via le logiciel et ses nombreuses facilités de réglages.
Dynamique et puissant.
Livraison rapide et correspondance avec Audiophonics parfaite pour les conseils et le suivi.
Pastorelli g.
Très bon petit ampli discret mais au combien efficace, versatile avec sa sortie sub.
Je drive avec une paire de 908 Spectral ainsi qu'un caisson clos avec un 33Kx par la sortie sub et un ampli SPA500DSP.
Service Audiophonics touours exemplaire !
Jean-Pierre S.
Argent
Commandé en cuivre/argent pour sertir des câbles tout cuivre allant dans des bananes cuivre plaquées argent. Juste installé. Correspond parfaitement à ce que j'attendais.
Jean-Pierre S.
Beau cable.
Je l'attendais depuis longtemps. J'avais lu beaucoup de commentaires sur lui. Commandé et installé. Premier constat beaucoup de naturel, de douceur et de micros détails sont apparus. Très bonne surprise, bien qu'il ne soit pas encore rodé, donc ça ne pourra je pense que se bonifier. Les voix sont superbes, les instruments de musique ne sont pas embellis mais tout parait très naturel. Bravo à ce produit. Attention cela doit aussi dépendre de l'installation, selon la configuration c'est comme en cuisine, un peu trop de sel ou de poivre et tout est à revoir.
Jean-Pierre S.
Belle qualité.
Bien fabriqué. Petit en main, mais efficace, enfichage dans les borniers très solide, fixation parfaite, ne bouge pas du tout. RQP plus que correct.
Jean-Pierre S.
Pratique.
J'appréhendais un peu son utilisation, n'ayant fait cela. En fait très facile, plus facile que je ne l’imaginais. Simple d'utilisation, remplit parfaitement sa fonction, résultat à la hauteur de mon attente. Parfais pour la douzaine de sertissage que j'avais à réaliser. Tarif compétitif.
Jean-Pierre S.
Tout cuivre!
Choisi pour rester en tout cuivre sur la voie centrale du HC. Il faut bien faire attention en enfilant les brins de cuivre à l'intérieur, ensuite sertir avec la pince. Résultat parfait pour avoir un très bon contact dans la fiche banane. Résultat sur les voix, très naturel et réaliste en live sur les concerts, ce que je recherchais.
Vincenzo v.
Oyaide
Exceptional cable, I use it to power the phono pre, sound in the clear medium / high never tiring with a super detail that makes the difference, the bass is good but with a slightly fuller and more controlled bass it would have been the perfect cable, at least for the my plant. Cable that is worth much more than its price. It needs at least 100 hours of running in. Excellent purchase.
Vincenzo v.
Viborg
Excellent product accepts large cables / wires. Excellent price / performance, recommended product.
Vincenzo v.
Viborg
Jean-Pierre S.
presse etoupe
Conforme à la description.
Bon serrage du câble
Daniel A.
An excellent product
- this linear power supply.
connexion hp
Ces borniers sont solides
et biens conçus
Toujours utile...
câble blindé
Les fils sont numérotés RAS
bon boîtier
La peinture est résistante
Bonne finition
Jacques S.
Excellente carte usb
Miguel M.
Excellent DAC
Bien sincèrement
Constantin C.
So??????
benjamin b.
Bon câble
Xavier M.
Xavier M.
Xavier M.
Vincent D.
Compliquée à mettre en oeuvre
Dioubar M.
Maxime D.
bel interrupteur
Marcel R.
marvelous amplifier
Parfait...
Comme toutes mes commandes:
délais ultra court
Petit bémol
Wolfgang G.
Voltage
Anders L.
Perfect light termination
bertrand f.
Tout bon !
Expédition rapide
Qualité visuelle parfaite
Rapport QP très bon
