Jean-François D.
Impeccable !
Vasilios K.
Ça Chauffe !
Customers reviews - There are 19304 reviews.
thierry d.
tres pratique
très bon boitier pour avoir deux amplis sur une paire d'enceinte. Envoie très rapide et bien protégé.
Rainer E.
Perfect price / performance ratio: test it yourself against your DAC
I bought this DAC somewhere else (at the same price) since at that time it was not in stock (now it is again), but it is the perfect combination with 13626 Aluminum Case for Khadas Tone Board and 11827 Damping Feet 10x5mm (Set x4) from Audiophonics.
This DAC has got the very latest converter chip which is also found in current very, very expensive DACs (for 5800 Euro ...). Of course I could not compare, but I compared it with my M-Audio 2496 in my computer and my 1980s Musical Fidelity Pan CD Player (with Tubes). And I have to say, it outplays the M-Audio card in terms of dynamic (some space resolution) and is on a par with my Pan (even if you use an old CD ROM drive with SPDIF out to feed the Khadas board). This is also great about this product, you can feed it with any SPDIF source and use the USB only for power supply. The SPDIF works once there is no digital signal coming from USB. It is also not very picky concerning the quality of the USB power. But also streaming music via a PC is very gratifying, listening to TiDAL Hifi/Master such a pleasure. If you don't believe me, try it against your DAC .... It works with the Windows driver from the internet and even much easier with Linux (Ubuntu 18.04) just by plugging in without any fuddling around with ALSA .... This product is highly recommended. Thank you Audiophonics for offering it optionally with a nice aluminium case!
Rainer E.
Almost perfect case for the Khadas Tone Board
The case gives the little DAC board the justification and the robustness to play along with your other HIFI components, thank you Audiophonics !
It would deserve 6 stars if you had added four very small aditional components: 2 spacers M2*5 mm female-female and 2 screws M2*5 mm. The issue is, that the distance of the board to the bottom plate with the three holes (according to the drillings in the front plate) is exactly 5 mm, and not 7 mm, which is the size of the original Khadas spacers ... It is enough to fix the two rear spacers, since the board is also fixed at the front plate via the 3 RCA sockets. And one small piece of paper with a drawing please! M2 spacers and screws are difficult to get, almost only via the internet and in a set of 270-300 parts which costs approximately another 10 Euro! Please Audiophonics, add above mentioned components (for additional 1-2 Euro) and make the life easier for everyone building the case. Because if you use the Khadas spacers you are going to bend the board and/or the front plate, which in long term is not ideal.
But then again: with this case you finally have product which does not have to fear any comparison ! Add 11827 Damping Feet 10x5mm (Set x4), and it is perfect.
Jean-Michel D.
LOXJIE P20 Balanced Tubes Headphone Amplifier 2x 6N3 Black The Loxjie P20 is a small balanced tube headphone amplifier. It carries a pair of high-quality 6N3 tubes mounted on a high-performance and perfectly calibrated amplification...
Impeccable ampli casque(s)
Son neutre et parfait sur des casques même haut de gamme ( Sennheiser HD600 etc..) Fabrication impeccable. Entrées et sorties symétriques rarissimes à ce prix. Consommation testée : 9,9 watts. Aucun bruit de fond audible.
Jean-Michel D.
Produit Neutrik d' origine parfait
Qualité Neutrik au top. Ne pas acheter des copies chez un fournisseur douteux. Audiophonics vend des produits certifiés d' origine
Jean-Michel D.
Excellent galet mais ( lire mon avis )
Produit très bien usiné et beau design sauf que le poids ( 400 gr ) risque de surcharger le moteur d' entrainement surtout à entrainement direct
Marc L.
Yarbo sp 1100 PW
Depuis déjà un moment que je m’enrichie de différents commentaires. Je tente donc un premier avis. Tout d’abord, c’est un excellent cable mais pas polyvalent . Il doit trouver sa place sur une chaîne qui a déjà une tendance dirigée vers la neutralité. En assoCIation avec des fiches Neotech cuivre. Je lui trouve un bon détachement des différentes fréquences . Il a tendance à faire ressortir le médium grave et peut parfois contribuer à l’affaissement de la scène sonore jusqu’a ce qu’on lui trouve un bon emplacement . Ce qui a amené une bonification des timbres . C’est vraiment perceptible sur des instruments acoustiques ou encore sur les attaques de note d’un piano. Actuellement, je l’associe à ma prise au mûr vers le filtre et sur mon Dac. Chez un ami, c’était en association avec le préamplificateur que les résultats étaient les meilleurs. Pour ce qui est des fiches , j’ai utilisé des Neotech en cuivre plaqué or que j’avais sous la main mais je crois qu’il pourrait profiter de fiches qui amènent moins de structure et de poids. Ou qui conserve ces atouts tout en étant légèrement plus neutre et étendu, . En espérant que ces fiches existent . J’ai pensé à la Neotech rhodium mais je suis assez réfractaire à ce plaquage. Des avis sur des associations de fiches seraient le bienvenue . Nouvelle furutech plaqué argent sur la partie mâle ? Merci
Stephane L.
Bon.
Acheté avec un ampli TINYSINE TSA3118B Bluetooth aptX TWS 2x50W, le module fonctionne bien.
Connecté en Bluetooth (connecteur blanc) Il introduit quelques bruits parasites dans les HP, mais c'est très faible et disparait avec la musique.
Fonctionne aussi très bien avec les RCA connecté.
Stephane L.
TINYSINE TSA3118B Amplifier Module TPA3116D2 Bluetooth aptX TWS 2x50W This amplifier module from TinySine is based on a TPA3116D2 amplifier chip that can deliver up to 2x50W while offering very good efficiency thanks to its Class D architecture....
L'ampli fonctionne très bien. Le bluetooth n'injecte aucun parasite dans les HP (peut-être parce le module n'est pas intégré directement dans les circuits de la carte, simplement "pinoché"). Il y a un léger souffle (normal en audio) dans les HP lorsqu'il n'y a pas de musique, mais qui disparait lorsque la musique est lancée, même à très faible volume.
J'ai aussi connecté en RCA (avec de simples coupleurs en amont) un lecteur CD et une platine vinyle disposant déjà d'un pré-ampli.
Ça fonctionne très très bien.
Côté puissance, il est presque trop puissant pour mes HP de 40W sous 4 Ohms.
Enfin, il ne semble pas vraiment chauffer même après plusieurs heures d'utilisation.
Seul bémol : il fait un "double bip" assez fort (limite gênant) à l'allumage. Et l'usage d'un contrôleur de volume numérique TINYSINE TSA1020 (connecté en bluetooth -connecteur blanc- et en RCA), introduit quelques minis parasites dans les HP. De même cela disparait avec la musique.
Après une mauvaise expérience d'un ampli d'une autre marque (bruits importants dans les HP, etc.) sur le site, je suis très satisfait de ce second achat.
John B.
Amanero Combo 384 Review
Amanero Combo 384 review.
I received the module quickly and in good condition.
I purchased this module because I was looking for a low jitter USB interface that supports PCM up to 384 KHz. I am a MAC user and the Amanero works fine on a MAC without the need for drivers.
Jitter performance is not the best, it gets bad above 96KHz Some suggest to use XMOS-based USB receivers for sample rates above 96 KHz.
The whole point of using isochronous USB audio with asynchronous feedback and two local master clocks is to get low jitter .....
Major reasons for this are poor power supply decoupling, not the best master clocks and a FPGA that injects significant jitter. I2S timing signal from the Atmel processor has lower jitter.
The I2S clock and data signals are not correctly aligned, alignment gets critical at 352.8 KHz and 384 KHz.
The 3V3 regulator is not the best in terms of noise, line & load regulation & PSRR. I replaced it with a pin compatible LP5907-3V3 that offers better performance. Linear Technology has even better one's (LT3045).
I also improved power supply decoupling using chokes (2.2mH) and low esr V-polytan capacitors. Passive filtering of the master clock supply offers biggest improvements in jitter performance.
I replaced the master clocks with lower jitter clocks from Kyocera Electric.
The suggested digital isolators will add 100ps of extra jitter (typical) and input-output coupling capacitance is rather high (4pF).
I am now very pleased with the modified Amanero module.
Only 4 stars because I had to modify the module in order to get desired performance.
Nicolas V.
Bonne alim. souci de finition.
Bonne alimentation, tension très stable.Possibilité de faire ajuster la tension à la commande (7v dans mon cas)..et la tension personnalisée est écrite sur la petite étiquette au dos !
Fonctionnement très silencieux. Chauffe peu, mais non testée sous forte charge.
Boîtier de fabrication robuste avec des matériaux de quallité (alu) mais souci de finition :
Le feeling, et le bruit, de l'interrupteur est très médiocre
pieds en silicone mal collés, non alignés sur mon appareil
Défaut d'alignement assez important de 2mm entre la façade et le corps du boîtier sur un côté de l'appareil. pbl de Tolérances de fabrication ou d'assemblage.
petite led blanche comme témoin de marche: sympathique et tendance...mais pas rationnel pour une alim. Un détail.
Melvin L.
excellent petit amplificateur
petit amplificateur qui tiens ses promesses.
aucun soucis des la mise en service, prêt a fonctionner !
ampli ayant une bonne puissance en réserve.
je recommande.
bernard d.
1877PHONO LEVEL 10 Precision Bubble Level Vinyl turntable This high-precision bubble level allows for quick and easy horizontal positioning of your turntable.
Beau produit, très précis mais un peu lourd en comparaison à d'autres produits.
hugues g.
Je confirme l'excellence de cet ampli
Voila mon 1er test avec des Altec monitor III était déjà très bien, mais j'ai trouvé qu'il chauffait un peu et manquait de punch pour la puissance annoncée donc j'ai pensé a faire le même teste avec toujours le même mini DAC relié au PC, mais cette foi ci avec une paire de colonne jamo S406 en 6 ohms et là... j'ai tout compris, cet ampli est vraiment une bombe pour celui qui connait à faire les bon dosages (c'est un métier). Impossible de le pousser à fond (risque de péter les vitres a cause des basses) dans ce test mais aux max il garde très très bien la conduite de la palette sonore c'est vraiment Top, là vraiment j'ai vraiment apprécié la griffe sonore et je reste sur des colonnes en 6 ohms pas plus pour lui (l’idéale et en plus ça chauffe beaucoup moins !!! et on gagne plus de punch) . Voila , je vous recommande cet ampli avec une paire de colonne (moi je vais m'en trouver une autre paire encore meilleures pour cet ampli car il en vaut vraiment la peine croyez moi) et n 'oubliez pas un DAC (y en à des très bon sur ce site). voila j'ai tout dit et si vous entendez un tout petit bruit insignifiant après l'allumage c'est normal c'est des composants qui travaillent. AUDIOPHONICS est discret mais tout le monde en parle car ils ont du bon matos et accessible aux non initiés MERCI à toute l'équipe !!!
Nicolas V.
Bonne qualité.
Bonne qualité de fabrication. Intéressant de pouvoir acheter juste l'exemplaire voulu sans acheter tout un jeu.
Peter P.
Perfect Bluetooth receiver
Bluetooth as good as you can get it for a stable transmission of music files from ie your iPhone to your DAC in a high quality stereo setup. Easy install, no dropouts, even with high resolution files. You only pay for the best Bluetooth card and not for an extra DAC or other functions you don’t need.
Peter, Denmark
Olivier L.
ARYLIC COBBLESTONE WiFi Receiver AirPlay UPnP DLNA Multiroom 24bit 192kHz The Arylic Cobblestone is a WiFi receiver that allows you to easily and efficiently stream your files from your network, smartphone/tablet or your favorite streaming services....
Bon boitier
J'ai deux lecteurs iEast depuis plusieurs années et j'enrage régulièrement avec des pertes de connexion, des coupures lors de la lecture...
Je les utilise pour écouter Qobuz.
Pour installer à la campagne, j'ai d'abord acheté des Chromecast qui sont catastrophiques lorsqu'ils sont pilotés par un : il est très difficile de lancer la lecture, le son apparaissant parfois... ou pas ! Probablement un problème de compatibilité avec Apple.
Pour les remplacer, j'ai donc acheté un Arylic qui fonctionne parfaitement. L'installation est très simple et le pilotage avec l'appli iEast permet de lancer Qobuz parfaitement. La liaison est stable et je ne constate aucune coupure, moins qu'à mon domicile principal avec les boitiers Qobuz...
Le son est bon, la puce de conversion apportant une sonorité agréable.
Il ne rate sa cinquième étoile que du fait de l'absence d'une sortie numérique qui aurait permis d'associer un DAC externe.
Mais au regard du prix, il ne faut peut-être pas trop en attendre.
Guy L.
guy13
excellent câble de Furitech. Son très pur et musical
Guy L.
guy13
très bon rapport qualité/prix pratique à connecter. La définition suit
Guy L.
guy13
son très fin et belle définition plan sonore bien espacé
paul p.
Mes enceintes de 40kg étaient initialement sur leurs pointes d’origine sur pièce de monnaie que j’avais ajustées avec grand soin. Je ne m’attendais donc qu’à une légère amélioration car tout le système était déjà bien optimisé.
Pourtant force est de constater que l’ensemble des paramètres du son y gagne, ce qui en fait au global un réel pas en avant supplémentaire : précision et maîtrise du grave, scène sonore accrue en taille et stabilité , expressivité générale, micro détails supplémentaires ,...
Finalement un seul regret, ne pas les avoir achetées plus tôt !
Un accessoire juste indispensable au vu l’amélioration sonore /prix.
Nb : après essai sur les patins de feutrine livrés avec, je les ai enlevés car impossible de stabiliser proprement les enceintes, grave baveux et son détérioré par rapport aux pointes d’origine
David m.
génial
je le possède depuis plus d'un mois, j'ai très vite remplacer le tube (qui n'est pas si mauvais) par un electro Harmonix (j'ai aussi testé le Tung-sol qui rend bien également)
c'est un très très bon preampli casque qui possède également des sorties pour l'ampli de puissance... pratique quand vous y brancher un ordinateur pour écouter votre musique avec. Mon casque est un Sennheiser TR 180. le son est incroyable ! seul point négatif... le cd driver fourni ne fonctionner pas chez moi... un petit tour sur le site pour telecharger les drivers et tout est rentré dans l'ordre...
emballage nickel et livraison hyper rapide. site ultra sérieux
Nicolas V.
Câble de qualité
Utilisé pour raccorder un conditionneur USB et un DAC . Très bonne qualité de fabrication apparente. Câble épais et assez rigide, gage de sérieux .Ergonomie des fiches.
L'intérêt d'un tel cordon est toutefois discutable, le rendu sonore étant identique à un câble basique à 2 €.
Nicolas V.
Câble basique mais bien fabriqué. Forte section (1;5 mm2) par forcément utile pour la plupart des applications, un câble en 1 mm2 devrait être proposé. Prix intéressant.
Nicolas V.
Produit de bonne qualité, à un prix imbattable.
Petit détail : la prise USB A est inversée , ce sui peut obliger à vriller un peu le cordon, peut-être dommageable dans le temps sur un cordon court de 0.45m .
Rendu sonore identique à un cordon 'Audiophile' (sur mon système)
Dominique B.
Parfait pour mon utilisation
Parfait pour mon utilisation, entre une platine CD à sortie fixe et un système de sonorisation informatisé, me permet d'agir rapidement sur le volume sans rentrer dans la programmation. Pas de souffle , volume cranté très pratique pour être sûr de rester calé sur une position. Aspect sécurisant. Bonne qualité.
Alain L.
facile à monter, solide. ne dénature pas les qualités des conducteurs, neutre et celà c'est parfait.
Alain L.
connecteur facile à monter, solide.
je pense que son intérêt principal est sa neutralité qui ne dénature pas la qualité des conducteurs utilisés ce qui n'est pas le cas de tous.
Karl d.
Yarbo sp-2200 power cable
All of the Yarbo line of mainscable are great.
but if you want to have a little more transparent and analytical sound,than take this one.
Florent L.
flo
Super le pied la qualité est là foncer!!!
hugues g.
j'étais intrigué par celui-ci et je l'ai écouté
Réception du colis sans problème, c'est un ampli très solide et discret coté boitier et matériel !!! Je lui ai mis des Altec monitor III au derrière juste pour le test et je lui ai joint un petit "FX-AUDIO FX01 DAC" pour le relier au PC.Sur Foobar 2000 et j'ai lancé Salsa , Reggae et du Disco. Voilà !!! Je trouve que cet ampli à un gros son bien voluptueux et chaleureux et pas besoin de pousser on percoit bien le spectre sonore. Cest du bon audiophile pour son mini prix. Après c'est à vous de lui adjoindre ce qui va l'enrichir.Moi je pense lui trouver des petites colonnes et y brancher ma vieille platine Thorens, parce que ce son me rappel quelque chose. Juste petite remarque inutile, ne vous inquiétez pas le bestio chauffe mais à juste proportion, les évents d'aération et les composants sont prévus pour !!!
Jean Emmanuel H.
Utilisé sur une platine vynile Sansui SR 222. Je confirme le ressenti sur le même câble utilisé entre mon DAC et l'ampli (le même en rouge). Surprenant en transparence et en musicalité. Nettement supérieur à mes anciens câbles NBS à 400€.
Jean Emmanuel H.
Très bon câble pour le prix, neutre et transparent. Légèrement supérieur à un Real AN-99
GIANLUCA B.
Suono molto buono
Amplificatore piccola e versatile il suono rispetto al mio presidente molto migliorato soprattutto nelle basse frequenze consigliatissimo
Sebastien M.
Ampli FDA non audiophile...
Après toutes les éloges lus ici et la (Qobuz etc...) comme quoi l'ampli FDA Alientek D8 valait normalement 10 fois sont prix, donc il aurait dû surpasser les ampli a 1000€, et que c'était une révolution, je me suis lancé...
Une fois branché a mes enceintes Elipson 4I avec des câbles HP puretrans et un bon câblé de modulation, voici mon ressenti :
Une claque!!!!!! De médiocrité !!!!!
Des grosses basses mise en avant peuvent impressionner des non initiés, pareil pour les autres registres, ce n'est pas équilibré du tout, bref il ne vaut pas 10 fois son prix mais il vaut son prix.
Concernant Audiophonics, c'est juste top, ils répondent au flots de questions très vites.
L'envoie le jour-même, rien a redire
Bernard D.
Voltage Adapter Converter 12VDC to 19VDC 8A 150W Convert 12V DC to 19V DC with this compact 150W step-up converter that will give you a stable power source.
Très bon produit !
Produit efficace et fiable qui tient parfaitement la puissance indiquée. Ne chauffe pratiquement pas !
MARCO F.
Connecteur GX16
j'ai commandé ce produits pour une realisation personnel et je doit dire que c'est un bon produit de chez Audiophonics ...je ne regrette pas cet achat chez Audiophonics.....
Jean-Daniel B.
La qualité de maintien du contact parfaite pour le prix d'une prise de qualité.
Brassage facile.
Jean-Daniel B.
Simple à câbler mais pourquoi 2 tailles de torx pour un même produit ?
Sinon bonne qualité.
Jean-Daniel B.
Il y a de la place pour souder proprement. Le réducteur en plastique se retire facilement pour un diamètre de câble supérieur.
Rien à redire pour le rapport qualité/prix.
joel c.
bonne fabrication pour leprix
Après une longue écoute je l'ai remisé dans mon tiroir fourre tout car il et moins bon que ma liaison optique , il resserre l'image , moins de piqué et de réponse transitoire , ma liaison optique est libre sans tassement , ça pétille , c'est la joie c'est peut être a cause de certains défauts o combien agréables , ce coax est trop sérieux pour moi ....
Solution impeccable pour une double installation hifi Home cinéma avec deux amplis dédiés. Je n'ai pas entendu de différence de qualité d'écoute depuis que mes enceintes et mes deux amplis sont branchés sur ce sélecteur bien conçu et qui semble être de qualité. Une petite manip sur le sélecteur et on passe de l'un à l'autre simplement. Deux installations dédiées en une, excellent!
Dimitrios M.
Overall great Service
Great product. Works as expected. Excellent service.
huseyin t.
Smallest enclosure for decent sound
İ was searching for small full range drivers for long time to house in very small enclosure.spx21 probably best alternative for this aim.0.3 liter enclosure with 19 mm.diameter and 15 cm length port ,very impressive sound.mids and highs are excellent but if you're lover of bass this driver might not right for you.its loud but if you push the volume it's get distorted especially in notes under 150.i am not sure about the building quantity if you consider the magnets felt down,i still wonder what was the reason coused this.it wasn't a big problem for me I could fix it with two component epoxy bonding.worked well for me but it shouldn't broken this easy.probably i expect too much from a driver less than 16 EURO.this driver has a great potential if monacor built them with little better quality.
Frédéric D.
Impressionnant
De la vieille école, mettre une connection bluetooth en hifi, no way. Eh bien, très agréablement surpris !
Stephane B.
Une valeur sûre
Je possède la version 2017 (acheté en Juin)
Il est lourd, il chauffe, il est vivant, profond, puissant et délivre la musique avec amour. Jusqu'à ce jour le meilleur ampli que j'ai possédé .
Je confirme l'avis de Frédéric A. : inutile d'essayer les Ampli classe D style Hypex ou Icepower.
Stephane B.
Son exceptionnel en DLNA avec dac externe
Ce petit boitier bien construit procure un rendu sonore à un DAC connecté en USB ou coaxial absolument bluffant : grande profondeur et largeur de scène, début et fin de notes saisissants, à ce prix je me demande quel est son concurrent.
Seul bémol : le firmware est mal programmé, il fonctionne de façon capricieuse en dlna et reste très instable avec un dac connecté en USB.
Utilisé comme lecteur de fichier local c'est une affaire, le rendu dépasse largement une Digione, d'après mes essais et d'autres retours sur les forums audio.
Stephane B.
Belle dynamique mais écoute fade et ennuyeuse
Cet ampli est assemblé dans un beau boitier sobre et solide.
à l'écoute sur des JBL 4430, avec une digione signature en source, il drive parfaitement les 38cm, normal avec un facteur d'amortissement aux environ de 1000.
Je me suis emballé au départ, séduit par la plage dynamique qui explose tous les amplis de classe A-B.
Après 48h d'écoute, repassant sur mon Audio Gd Master 3, je me suis rendu compte immédiatement à quel point le Ncore 250 était fade, trop mat, manquait de détourage sur les voix et les instruments, en un sens "normalisait" la musique, finalement je suis déçu par cette signature plutôt ennuyeuse.
Sur le papier il est redoutable, au niveau émotionnel, il ne m'a pas touché.
Attention : les modules Hypex vibrent en émettant un buzz comparable à un petit néon, émanant du boitier, même l'ampli éteint, il faut le savoir si vous projetez de l'installer dans une pièce par exemple dans laquelle vous dormez.
 (9)
Pascal C.
Protection modules for stereo speakers 12V 16A (Pair) This double mono protection module consisting of two cards will allow you to properly protect your speakers.
très bon module de protection.
J'ai acheté ce module de protection pour éviter les "plocs" d'allumage et extinction d'un module d'amplification TPA3255.
C'est très bien construit et la temporisation est assez longue. Impeccable.
Johannes g.
DIY Box / Case 100% Aluminium 260x311x90mm Silver Pannel This aluminum-grade case with a thick 8mm faceplate is perfect for designing class D preamplifiers, DACs or power amplifiers for a professional quality finish. This box comes...
bon rapport qualité prix
pas trop mal fini, certains trous sont à la limite du bord mais ne gênent en rien pour visser. tout rentre parfaitement les filetages sont bien fait, aucun soucis.
