Matt H.
The AS6 is a beautifully constructed piece of equipment, inside and out.
I used to use 2 Cisco 2960 switches modified for...
Jelte D.
Smart little helper
Very well designed and built simple little tool to start all your equipment at once but in the order desired.
Too bad it does...
Ludovic F.
Valeur sûre en numérique
Excellente alternative aux câbles coaxiaux sur mesure : mêmes caractéristiques techniques (75 ohms réels), très belle qualité...
Customers reviews - There are 20225 reviews.
fabien D.
Moyen dans l'ensemble
Manque de clarté et de scène 3d. Ne vaut pas la qualité d'un bon vieux tube des années 60.
Sebastian B.
Definitely good
It's amazing, and for very little money.
Endless space, not so much energy in the midrange. Rich bass, smooth highs.
It will replace all my other cables (even the expensive ones).
The details are very clearly audible.
Brice D.
TOPPING PRE90 Balanced / Single-Ended Preamplifier NFCA Black Topping's Pre90 is a high-performance preamplifier based on a fully balanced circuit and high-performance NFCA modules. It also benefits from a high quality volume attenuator...
Télécommande
Pour régler le désagrément de la télécommande, il suffit d' installer un déport d' infrarouge et tout devient nickel par la suite ....
Michael L.
DAYTON AUDIO IMM-6C Measurement Microphone USB-C for Android / iOS Smartphones and Tablets Turn any phone or tablet with a USB-C connector into a high-quality audio measurement device with the Dayton Audio iMM-6C USB-C measurement microphone. Each iMM-6C is...
Good mic
I needed a better mic for room correction for my wiim amp PRO, after downloading calibration tools, it works as intended and as precise as possible
Anders J.
DC 5V Jack Filter with Supercapacitor to Jack DC This DC 5V jack filter with supercapacitor allows you to obtain a clean power supply for your Hi-Fi equipment and appliances, thanks to 4 supercapacitors 20F - 3.0V and an...
Perfekt
Fungerar perfekt till IFI Zen Dac 3 och Blue 3
Klart fint ljud med djupare bas med Beyerdynamic DT 900 PRO X
François R.
belle amélioration
A remplacer comme câble numérique un câble optique bas de gamme entre mon ampli avec DAC i et un lecteur -réseau.Nette amélioration du son ,en précision en pureté.Un achat à conseiller
Enrico D.
ATAUDIO POLARIS Male USB-A to Male USB-B Cable OCC Copper Silver Quad Shielding 0.75m The Polaris USB-A male to USB-B male cable from ATAudio offers a very nice build quality for optimal performance. It features 7N OCC copper conductors and silver-plated 7C OCC...
Un câble USB de grande qualité
La qualité de fabrication est irréprochable, le câble est souple mais solide, avec de très bonnes finitions. Branché entre mon DAC et mon streamer, j’ai tout de suite remarqué une meilleure stabilité et une scène sonore plus précise. Le rapport qualité/prix est vraiment très bon, comme toujours chez Audiophonics. Livraison rapide et soignée. Je recommande vivement !
David C.
XDUOO DM-01 Headphones Amplifier DAC CS43131 XMOS XU316 Bluetooth 5.4 32bit 384kHz DSD256 MQA The xDuoo DM-01 is a DAC and headphone amplifier based on the use of audiophile components integrated within a most singular form factor. It is based on a CS43131 DAC /...
Avant de l'essayer j'ai viré le tube d'origine pour le remplacé par un ELECTRO-HARMONIX GOLD 12AU7/ECC82!! Puis enfin trouver le temps pour l'écouter avec un MEZE AUDIO CLASSIC 99. Mes premières impressions sont : a wouhais quand même!! Sous ces apparences de jouet retro c'est du sérieux, l'écoute est très agréable tout y es, précision, équilibre tonal et cette petite chaleur dans les voix sans exagération. Je n'irais pas dans le lexical audiophile, mais perso il me convient pleinement.
La liaison Bluetooth est qualitative en plus d'être très stable, en USB-C avec un câble permettant les hauts débits l'écoute en HI-RES sur QOBUZ est vraiment excellente!!!
Concernant le produit en lui même la qualité de fabrication est superbe, tout comme le soin apporté au packaging. Pour la couleur selon les photos des sites il peut paraitre plus bleu que vert.. il et bien vert! Personnellement je n'ai pas mis de sticker sur son ventre car ce dernier s'allume de couleur différente en fonction du débit audio, car ils sont a peine translucide.
Bref une petite folie que je me suit faite & que je ne regrette pas!!
Niels G.
SMSL PL200T CD Transport USB XMOS 32bit 768kHz DSD512 MQA-CD The SMSL PL200T is a high-performance, versatile CD transport. It's based primarily on a P.A.S.S. (Precision Access Servo System) playback system developed by SMSL, plus an XMOS...
Solid performer
This CD-ransport is a solid, reliable performer. This may sound a little boring, but it is really a high praise. The SMSL faithfully reproduces whatever music is in the "groove" with no hanky-panky and no colouring, both classical and rock/pop. They have spent the money where it matters, not wasting anything on fancy gadgets. If you wamt an honest, faithfull reproduction this is for you. Highly recommended.
Miguel O.
Satisfaction totale
Le gain est immédiatement audible : Une écoute plus propre, un détourage plus précis des sources et une fluidité nouvelle qui rend la musique plus naturelle et authentique.
Associé au câble JDC-1215, lui aussi d’une excellente facture, cet investissement raisonnable s’avère pleinement satisfaisant et remplit parfaitement ses fonctions
Et pour ne pas gâcher son plaisir, sa présentation est discrète et élégante.
felix q.
FURUTECH FI-INLET IEC Rhodium Plated The contacts of this Furutech IEC receptacle benefit from the brand's α (Alpha) treatment. This consists of a two-step process to maximise conductor performance.
ca sens bon la qualité
acheter afin de remplacer des embases ELECAUDIO installer sur des amplis Marantz
Ils ont l'air bien plus costaud et ils tiennent bien mes câbles d'alimentation (mieux que mes anciens ELECAUDIO)
Je ne peux pas dire si il y a une amélioration du son
Mais en terme de connexion il fait bien le boulot
chris p.
FIIO KA17 Balanced Portable DAC Headphone Amplifier 2x ES9069Q THX AAA 78+ XMOS XU316 32bit 768kHz DSD512 MQA With its KA17 balanced portable DAC headphone amplifier, FiiO unveils a compact high-performance device. The KA17 incorporates high-quality components such as two ES9069Q DAC...
Great for the price
Despite being kind of warm it does everything really good recommend.
Patrick E.
Magique !
Cela fait deux semaines que j'écoute ces prises Oyaide C-004 ...Quelle surprise ! Comment une prise peut- elle influer sur l'écoute et ce dans de telles propensions ! Dès les premières minutes , on se rend compte que ce produit est exceptionnel . Quelles transparence ! La musique est vivante , les graves tenus ,mordants . Les attaques de notes sont nettes . La dynamique et la vitesse sont impressionnants . Cette prise apporte un plus dans le plaisir d'écoute , car attaques , nuances , ruptures rythmiques contribuent sans cesse au plaisir d'écoute où subtilités et expressivité excellent ! Le seul point délicat peut être un aigu un peu typé dans les plus autes fréquences ; En effet ,les cymbales peuvent semblées simplifiées , manquant de matière et de raffinement . Il faut l'associer à un câble neutre et surtout une schuko transparentes et bien timbrée , raffinée dans les aigus , comme les ETI legato cuivre plaquées or . Dans un système équilibré , neutre , pas analytique et clair , ce produit peut vous donner le sourire ! Quel bonheur !
Van Loi n.
SHANLING H7 Portable DAC AK4499EX AK4191EQ Headphone Amplifier Bluetooth 5.0 XMOS 32bit 768kHz DSD512 Silver With the H7, Shanling unveils a portable DAC and headphone amplifier with integrated player, based on high-end components such as an AK4499EX DAC chip accompanied by its...
Magnifique!
Ce DAC/Ampli est en sortie d'un Imac M4 ainsi que d'un Iphone 14 +.
Tient la dragée haute face à un DAC R2R de Audio-GD.
Et un son en plus musical, en plus apaisée.
Bravo Shanling.
Patrick E.
Magique !
Cela fait maintenant deux semaines que j'écoute ces oyaide C-004 . Dès les premières écoutes , c'est l'étonnement ... Comment une prise peut elle agir de la sorte et pas que légèrement ! Les changements sont énormes par rapport à une prise furutech moyen de gamme F11(CU) . Meilleure transparence , détails mais surtout mélodies d'accompagnement qui apparaissent comme par magie ! Vitesse ,dynamique ,transitoires , grave tenu, mordant et nuancé . Voix pures et expressives , aigus détaillés mais un peu typés dans les hautes fréquences . (légère brillance , simplifification des cymbales ,léger manque de raffinement ),
Le rodage améliore l'écoute . L'expressivité , l'émotion sont omnis présents ..; La rytmique et les attaques de notes participent à une écoute plaisante , vivante . Il faudra marier ces prises C-004 avec des câbles neutres , mais aussi et surtout avec des shucko neutres , transparents et raffinés , comme les ETI legato cuivre plaqué or . Ne conviendrait pas dans un système analytique ,clair . Mais dans un système équilibré , quel bonheur !
LAURENT G.
Pratique et efficace
appareil conforme à la description.
Suffisant pour animer un système c=secondaire dans une petite pièce. Réglages de tonalité simple et pratique comme c'était le cas autrefois. Utile et indispensable pour gérer la dépendance à la fréquence et/ou les enregistrements déséquilibrés.
Avec l'alimentation de 32 V, la puissance est cependant limitée (4entre 40 et 70 W selon impédance des enceintes), mais je le savais avant de concrétiser l'achat. Pour un aperçu des performances réelles, il vaut mieux consulter les mesures faites sur le site ASR. Pour disposer d'au moins 100 W, l'alimentation de 48 V est indispensable mais sera un surcout.
Peut-être serait-il judicieux de moduler le prix en fonction de l'alimentation fournie en laissant le choix au client dès l'achat.
Laurent G.
Fabien L.
Cela fait plusieurs que je prends ce câble pour mes installations (même dites haut de gamme).
Il est largement suffisant et fait ce qu’on lui demande.
Aucune coloration… bref un achat sûr.
Brice D.
Ce pré -amplificateur est excellent malgres sa télécommande.
J ai profité de la promotion faite (-15%) par audiophonics pour l acquérir.
Toutes les critiques ou commentaires que j' ai pu lire sur cet article sont justifiés.
Charles B.
essentielles
Le modèle en cuivre beryllium est vraiment la connection de base, de tous les tests effectués pas mes amis et collègues c'est la connexion qui laisse le moins d'empreinte sonore ou de coloration, c'est presque l'absence de fiche. La seule difficulté est la soudure, il faut un support qui m'absorbe pas la chaleur et une panne assez fine mais pas trop.
Paul B.
The DAC is new so…
Purchasing and delivery was fast and efficient. The DAC is easy to set-up. Using the remote to scroll through the options makes it much easier than trying to do it through the button on the unit. You will need two AAA batteries for the remote (not supplied). How does it sound? It’s a DAC. It works, doesn’t add any audible distortion, so it sounds like all other DACs that don’t add audible distortion! The Topping replaces a North Star Design 192 mkII DAC from 2007. The Topping is considerably smaller, supports higher sample rates (over 192 as if that makes an audible difference!) but, most importantly for me, has a USB input. Maybe in 18 years I will revisit this review to comment as to the longevity of the Topping! Price to performance up to now…excellent!
István R.
Neotech NEP-3003G vs Oyaide Vondita
Lehetőségem van első néhány órás hallgatás után összehasonlítani ezt a két PC kábelt. Schulko oldalon Oyaide P-046E, IEC oldalon Furutech FI-25(R) csatlakozókkal, melyek csak tesztelési időre, lettek felszerelve.
Psaudio PPP regenerátorról PP DHT csöves erősítőt táplálnak 230V/50Hz árammal.
Érdekes és első pillanatban is hallatszik a két kábel eltérő karaktere. Határozott a különbség.
Vondita közép-magas tartományban kerekít, finoman és kevesebb élénkséggel zenél. Lényegesen melegebb, kicsit puhább és sötétebb hátterű, de nem lassú hangzású a NEP-3003G-hoz képest. Nekem úgy tűnik, kevésbé feltűnően mutatja a felvételi hibákat. Ha csak ezt hallgatnánk, teljesen oké, kifogástalan bársonyos hangzású.
Ezzel szemben a NEP-3003G közép-magas tartományban többet mutat, Vondita-hoz képest talán még zavaróan többet is. Hangszerhangok szépen elválnak egymástól anélkül hogy összemosódnának, úgy hogy nem válik analitikussá, lecsengések megmaradnak. Felső középtartományt enyhén forszírozza, néhány dinamika csúcsnál nem elég sima, amit ezzel szemben Vondita frekvencia emelkedésével lassú eséssel tisztán ad elő, vagy eltakar.
Természetesen mindkét kábel keveset változni fog 100-200óra után. Továbbá azért is mert megkapják az előző kábelemről a már bejáratott csatlakozókat is, Furutech FI-E48NCF(R) és NEOTECH NC-P303II. NEP-3003G enyhén forszírozott felső-közép tartományt várom kiegyenlítődni, Vonditata nem tudom hogyan fog változni.
A Vondita-t én nem a csöves erősítőmhöz terveztem, hanem a CA851N streamer-hez, a NEP-3003G pedig a PP triódás csöves erősítőmhöz. A fali konnektor és PPP áramregenerátor között már egy ideje NEP-3003G a tápkábelem, körülbelül vártam azt a hatást amit ott is tapasztaltam.
Véleményem szerint Vondita optimális lehet kemény, gyors és esetleg száraz hangzású SS erősítőhöz vagy ahogy fórumokon említik, digitális erősítőhöz, digitális forrásokhoz.
Ps:
Első néhány óra után a kábelek megkapták az előző kábeleim bejáratott csatlakozóit. A Vondita a forrás CA851N-t, a NEP-3003G csöves erősítőmet táplálják. A hangzás térbeli pozíciója tovább élesedett, hangsugárzóról leválás már-már zavaróan intimmé vált, zenészek itt állnak, énekelnek előttem. Egy dolog viszont maradt, az a közép-magas forszírozottság, amit korábbi rendszer kábelezésemnél nem hallottam. Nehéz eldönteni, ez az új AC kábelezés okán van így, vagy korábban a felvételek hibái el voltak fedve. Talán ez utóbbira gyanakszom, mert felvételenként nem is egyformán hallom. Az is felmerült bennem, ez a Furutech rhodium szárazabb, nyersebb magas tartománya eredménye, amit én részben kompenzálok a kábel IEC oldalán aranyozott NEOTECH NC-P303II csatlakozóval.
Tuan Bao H.
TUNG-SOL 12AT7 Tubes Triodes (Matched Pair) These Tung-Sol 12AT7 triode tubes feature a beautiful design, using quality materials. They have improved dissipation and are ideal for power or reverb systems.  They are...
Appairé
Bien vérifier qu'ils sont bien appairé
BEATECHNIK X LHY AUDIO LPS-A6-MKII Linear Power Supply Module for Eversolo DMP-A6 GEN 2 220V Designed specifically for the Eversolo DMP-A6 GEN2 (Standard and Master Edition versions), the LHY Audio LPS-A6 MKII linear power supply stands out thanks to its high-end...
Produit très bien conditionné et livré rapidement.
Qualité de fabrication au rendez-vous et très facile
à installer dans mon Eversolo DMP-A6 Gen2.
Fonctionne parfaitement, j'attends une période
de rodage pour constater les améliorations à l'écoute.
Merci à Audiophonics
Johan L.
ELECTRO-HARMONIX KT88EH Platinum Tubes (Matched Quad) These Electro-Harmonix tubes are world-renowned for their warm analog sound. The Electro-Harmonix KT88 EH is often referred to as the "Ultimate KT88".
Promising tubes
Promising tubes still burning in. Quick handling of order and shipping.
Johan L.
TUNG-SOL 12AX7 Tubes Triodes (Matched Pair) The Tung-Sol 12AX7 are high-gain dual triode tubes of superior quality with ultra-low microphonic effects and ensuring a wide soundstage and warm, musical sound reproduction....
Good tubes
Good tubes still burning in and quick handling and shipping.
Johan L.
Great DAC, great service
Great DAC and quick order handling and shipping.
leonid D.
3E Audio 260-2-29A
The module is made of very high quality. I connected a 36 volt 400 watt power supply to the power supply, but set the voltage to 38 volts. After working for more than 6 hours, the amplifier radiator is slightly warm. I'm happy with the sound, everything is in its place. A few comments (maybe the manufacturer will take into account) - it would be good if an XLR-RCA input switch and missing chips were installed. The delivery was very fast, thanks to Audiophonics.
Amaral E.
Top cable sector
Magnifique câble. J'ai eu d'excellents câbles de grandes marques, comme Kimber, Furutech, Nordost, Qued, Transparente Cable. Mais aucun n'a fait autant pour le mieux que ce Neotech, il bat tout ce que j'ai entendu jusqu'à présent en terme de câble d'alimentation, avec des performances en extrêmement haute résolution, des timbres ouverts et soyeux et en plus une scène immense comme je n'aurais jamais cru possible, une séparation instrumentale inhabituelle, remet chaque instrument à sa juste place de manière absolument sublime et tridimensionnelle. Ce n'est pas bon marché, mais je n'aurais jamais pensé qu'ils offraient autant pour un prix raisonnablement modéré. La technique innovante du graphène avec du cuivre OCC de haute pureté explique peut-être ses hautes performances. Félicitations à Neotech, vous avez ici un câble gagnant à tout prix.
Dominique L.
Headphone Balanced Cable Jack 4.4mm to 2x Jack 3.5mm OFC Copper 1.5m This cable has been designed to accompany HiFi headphones with detachable cable. It features two balanced 3.5mm jack connectors and one balanced stereo 4.4mm jack connector. The...
Surpris ...
J'ai commandé ce câble sans marque, pas très cher, pour tester la prise casque jack 4.4 de mon ampli Aune S17 symétrique sur un casque Hifiman.
Dans un premier temps, à la réception, je suis surpris et déçu par le look un peu bas de gamme de ce petit câble livré dans un sachet plastique transparent comme une pièce détachée.
Je le branche en faisant bien attention aux canaux droit et gauche pas faciles à lire sur les jacks. De suite, je me rends compte que le volume sonore est plus important à niveau égal sur l'ampli. D'habitude j'écoute entre 33 et 38 sur l'ampli, là avec ce câble, entre 25 et 30. 1er bon point.
2ème bon point, la séparation et la présence des instruments. Hifiman est réputé pour cela mais, avec ce câble, on va un peu plus loin qu'avec le câble d'origine . J'aime beaucoup car c'est un des critères importants pour moi.
Pour le reste, timbres, définition etc ... je n'ai rien noté de réellement diffèrent.
Voila ce que j'ai ressenti , qui n'est peut être valable que dans mon système, dac symétrique et ampli symétrique en classe A.
Ce câble remplace désormais le câble Hifiman . J'ai mis 5 étoiles pour le rapport qualité/prix.
Ammar j.
Great value transparent pre
Excellent price for a transparent preamp with high enough V out (XLR) to drive the Hypex Fusion amps in my active speakers. Nice large clear display, remote works well. Took around 2 weeks from order to receipt, worth the wait. Beware, the remote was packed in the outer shipping box, not in the inside box with preamp and power cord. Almost threw out!
David H.
Superbe câble
Franchement quel abus de beaucoup de fabricants qui nous prennent pour des pigeonnes 44 euros le câble il laisse s exprimer parfaitement les electronique qu il relie alors que j ai un câble a 890 euros qui et même pas capable d en faire autant ces un bouchon a coter vraiment très en colère d’avoir mis autant d argent dans une arnaque car a 44 euros ces le juste prix !!!
De la dynamique
J’ai acheté cet ampli pour ma télé mais j’ai immédiatement été frappé par la qualité de l’écoute . Alors je l’ai branché sur mes focal Kenya et surprise , le son est supérieur à un ampli classe À qui coûte 10 fois son prix . En plus le Bluetooth est super qualitatif, jamais entendu ça jusqu’alors . Le Dac est de super qualité . Bref, je la laisse pour mon gros système et j’ai acheté un autre petit ampli pour ma télé . Je recommande totalement !
Xavier C.
FOSI AUDIO V1.0G Class D Stereo Amplifier TPA3116 2x50W 4 Ohm This small Fosi Audio V1.0G integrated amplifier is an affordable, high-quality Class D stereo amplifier. It incorporates a TI TPA3116D2 amplifier chip enabling it to develop...
Très bon ampli avec une belle puissance dynamique !
Commande expédiée très rapidement et reçue également en un délai vraiment très court avec DPD.
Associé avec le préampli Fosi P3, le préampli phono MM FOSI BOX X1, ces 3 classes D achetés ensemble sont une belle surprise pour remplacer un vieil ampli intégré de classe AB. Les enceintes Auditor NX-70 sont ressuscitées ! Elles sortent d'une douce torpeur sans défaut avec soudain une nette dynamique, une belle clarté musicale, un grave soutenu et des aigus bien vifs,
Xavier C.
FOSI AUDIO P3 Tube Preamplifier 2x JAN5654W Headphone Amplifier Bluetooth 5.1 aptX aptX HD The Fosi Audio P3 is a compact, high-performance preamplifier. It features two JAN 5654W tubes and a QCC3031 Bluetooth receiver chip. A...
Excellent préampli à tubes très dynamique et musical
Commande expédiée très rapidement et reçue également en un délai vraiment très court avec DPD. Une belle surprise que ce préampli à tubes qui prend le relai d'un vieux ampli intégré de classe AB. Les enceintes Auditor NX-70 sont ressuscitées !
Xavier C.
Très bon préampli phono MM
Commande expédiée très rapidement et reçue également en un délai vraiment très court avec DPD. Redécouverte des vinyles et son très agréable. Aucune fatigue d'écoute.
Xavier C.
Excellent commutateur
Commande expédiée très rapidement et reçue également en un délai vraiment très court avec DPD. Aucun souci de connexion.
Xavier C.
ATAUDIO KING WOLF RCA Interconnect Cable 6N OFC Copper Shielded Gold Plated 1m (Pair) These ATAudio King Wolf RCA cables feature quality construction with OFC 6N insulated copper conductors for excellent signal transmission. The braided copper shielding...
benjamin b.
non standard
La longueur "enfichable" de la fiche femelle n'est pas au standard et est trop courte. Sur les façades arrières de certains appareils elle ne s'enfonce pas assez manquant de contact et tenant mal. Risque de débranchement / d'arc électrique et ou de chauffe .
Sur un câble de ce prix, ce n'est pas normal …
J'ai acheté ce câble pour un gros ampli qui demande du jus et est inutilisable.
insatisfait
Nicolas g.
Content du résultat
Installé sur sur primo-installation (advance paris myconnect 250 + dyanudio special forty) j'aime beaucoup le résultat.
Les brins de la tresse sont fins par rapport à ce que je m'étais imaginais vis à vis de la photo.
Henri c.
JANTZEN AUDIO SILVER Z-CAP Capacitor 800V 1.5μF Jantzen Audio Silver Z-Cap capacitors maintain perfect sound neutrality and a very nice tonal balance. They are particularly suitable for use with a tweeter or midrange in...
grande finesse
ces condensateurs nécessitent un temps de 'rodage' de quelques heures, ( grande différence ) ils offrent un rendu sur les tweeter exceptionnel , l'amplificateur ne doit pas avoir un son 'dur' et le filtrage
ne doit pas faire travailler les tweeter trop bas.l'écoute est d'une grande finesse, extrême aigu,réverbération ,transitoires.
SMSL SU-X DAC 2x ES9039MSPRO XMOS XU316 Bluetooth 5.1 aptX LDAC 32bit 768kHz DSD512 MQA-CD SMSL unveils a state-of-the-art DAC with its SU-X model. The SU-X adopts not only two ESS Technology ES9039MSPRO DAC chips, but also an XMOS XU316 USB interface, enabling it to...
Excellent DAC
Acheté début Août je ne donne mon avis que maintenant . J'étais possesseur d'un SMSL SU-6 et déjà très impressionné par son naturel , je voulais voir ce que donnait son grand frère le SU-X .
La musicalité a progressé partout :
- scène sonore plus vaste
- fluidité plus importante
- plus de détails mais restants à leur place
- plus de douceur avec une très grande dynamique
-grave abyssal mais beaucoup plus tendu
- grande intelligibilité
Le produit touche à la perfection au point que le Streaming , à mon humble avis détronne complètement le CD avec en plus une très grande facilité d'utilisation et un énorme gain de place .
Je me suis risqué à ouvrir l'appareil :
- les composants sont très qualitatif
- le montage est extrêmement soigneux
- il ne devrait y avoir aucun problème de fiabilité car même les produits High End ne font pas mieux sauf à estampillé certains composants avec leur nom .
En résumé ce produit semble toucher du doigt la perfection car en 45 ans d'expérience je n'avais entendu de tel ni chez moi ni dans les salons ni dans des auditorium . Pour mon humble avis les CD et les Vinyls c'est pour les collectionneurs et c'est aussi une noble passion .
Évidement je recommande vivement ce produit et trouve qu'il n'est pas stratosphérique .
Très cordialement.
Philippe Tremblais
PS Merci à Audiiophonics pour avoir répondu à toutes mes questions .
AIYIMA TUBE-T3 Phono MM Tube Preamplifier 2x 6A2 Black The Aiyima Tube-T3 is a simple and affordable phono preamplifier for MM turntables. It features two 6A2 tubes and a three level gain control, 39dB, 42dB and 45dB, allowing it to...
De plus en plus incroyable, mais toujours aussi vrai !
Je reprends mon avis posté sur le câble secteur :AUDIOPHONICS STEALTH Câble Secteur Schuko C15 Cuivre OFC Blindé 3x3.5mm² 1.5m :
" Incroyable mais vrai...
Branché à un ampli Taga Harmony 25 B, a permis d'obtenir un son d'une pureté et d'un détail incroyables, et surtout sans AUCUNE dureté à une paire de Focal Aria 906, magnifiques enceintes biblio, mais aux aigus un peu durs pour mes oreilles jusqu'à présent, malgré plusieurs essais de différentes combinaisons ampli/câble de liaison enceintes-ampli/ pièces...
J'étais sur le point de m'en séparer, mais là il n'en est plus question !
Il va de soi que je ne regrette qu'une seule chose : ne pas avoir acheté ce câble secteur plus tôt, le jeu en valant largement la chandelle en l'occurrence... "
J'ai donc branché sur ce système le préampli phono AIYIMA, dopé aux lampes GE5654, et en sortie de DAC, FX 01, lui-même en sortie de mon ordi (Qobuz).
Résultat : un gain d'un cran encore au-dessus, la chaleur du tube apporte un plus léger mais indéniable, adoucissant encore les aigus et renforçant les basses, dans une fort belle scène sonore claire et aérée... magnifique !
J'en utilise un autre en préampli phono sur un autre système, avec les tubes 6A2 d'origine cette fois, en sortie d'une Project debut III montée en OM 5E ; il y a un gain (meilleure définition du son dans son ensemble) par rapport au préampli Project d'entrée de gamme, correct au demeurant...
Christian M.
AIYIMA A70 MONO Mono/Subwoofer Class D Amplifier TPA3255+NE5532 1x300W 4 Ohm The Aiyima A70 Mono is a Class D amplifier based on a chipset comprising a TPA3255 amplifier chip and a NE5532 OPA. It is capable of delivering power up to 300W @ 4 ohm....
Perfect deal
Received 2 items quickly.
Thomas L.
Besser als Keces P6
After quick delivery to Germany, I unpacked it and connected it to my Jcat XE Evo USB card with the original cable. Initially, the sound was a bit muddy. After a week of break-in, I noticed better dynamics, more bass, and deeper bass. The soundstage details are good; I'll be reordering an Audiophonics DC cable in the next few days to get even more out of it.
I'm very satisfied with the LPSU 100. Thank you very much and best regards from Berlin.
Jean-Pierre Z.
Ce vu-mètre est bien linéaire sur tout le spectre audio ,il est facile à encastrer bien qu'il soit quasi impossible de trouver un trépan de 34mm de diamètre ... le look rétro est bien sympathique , le rétro-éclairage est très agréable , et s'il existe des dispersions entre plusieurs exemplaires , c'est sur la luminosité de l'éclairage d'un exemplaire à l'autre et non sur les performances en terme de linéarité .ou de balistique.
donc rapport qualité/prix imbattable
Franco F.
TOPPING D90 III DISCRETE Balanced Discrete DAC Bluetooth 5.1 32bit 768kHz DSD512 Silver The D90 III Discrete balanced DAC from Topping is the parallel to the D90III using a 100% discrete digital/analogue conversion module. Here, conversion is performed by a PSRM...
A beautiful DAC, rich in color, dynamics, and musicality. The first thing that struck me was the bass—clean, articulate, and powerful—but then the dynamics, detail, and deep, well-focused imaging finally came to the fore. Very good.
Elom G.
Pour un usage quotidien avec un DAC bluetooth Radson earstudio. Le son est clair et équilibré; pas Gand chose à lui reprocher.
A ce prix là, ça vaut vraiment le coup !
didier N.
ok
Benoit d.
7HZ X CRINACLE ZERO II In-Ear Monitors Dynamic IEM Ø10mm USB-C with Mic Silver The 7HZ x Crinacle ZERO II in-ear monitors are dynamic IEMs that are affordable but no less powerful. An evolution of the 7Hz Salnotes Zero, they feature a number of...
-très bon son ! très ample dans les graves sans aucune exagération et sans devoir ajuster parfaitement les embouts.
-Les embouts sont très confortables.
-La connectique entre les écouteurs et le câble semblent robustes et sont même un peu dures.
-le cable est préformé pour s'ajuster facilement derrière l'oreille et bien tenir sans gêne
Par contre
- il n'y a pas de vraie notice,
- difficile de mettre en place les embouts : J'ai légèrement déformé la grille du conduit en m'y prenant mal, il n'y a aucune explication sur les différents embouts fournis (il semble y avoir des variation de taille et de diamètre interne, mais c'est pas clair), les couleurs des embouts sont diverses mais je ne les trouve pas terribles
- le câble pour ce modèle USB-C fait très cheap et a tendance à s'emmêler
Robert C.
FOSI AUDIO ZP3 Balanced Preamplifier NE5532 The Fosi Audio ZP3 is a balanced preamplifier based on NE5532 AOPs. It offers interference-free sound reproduction over a wide dynamic range, minimizing ground loop effects. The...
It is difficult to open and change the OPAs. Acrylic side plates are annoying.
