Pascal H.
Marc C.
Customers reviews - There are 19409 reviews.
Max Michel D.
EXCELLENTE QUALITE POUR AUDIO
Cette soudure est vraiment TOP pour faire vos cables audio.
Qualité d'écoute au rendez-vous sur vos cables.
Max Michel D.
EXCELLENT
Connecteur RCA/BNC de grande qualité
Ecoute parfaite sur branchement sur convertisseur
Hugo Darien O.
good
after weeks i feel the signal is to bright
Pavel V.
Balanced Interconnect Cable Jack 6.35mm TRS Male to XLR 3-Pole Male OFC Copper 75cm (Pair) These affordable cables are balanced male Jack 6.35mm TRS to male XLR 3-Pole interconnect cables. They are shielded and the conductors are made of 99.99% pure 4N OFC copper for...
Solid cables
Solid and well-looking cables for balanced interconnection at a good price.
Pavel V.
Excellent amplifier
- the power supply produces a very slight high-piched noise (~4kHz) that can be noticed from a 0.5-1m distance (or more) in silent environment (esp. from behind) ; the sound is different when the amp is off and when it is on (NC252M-based amps don't do this)
- if you plan to use the RCA inputs, expect sensitivity to ground-loops, esp. if you have a more complex sond system; if it includes a USB device (e.g. a DAC), you may need a proper USB isolator (a cheap one based on Adum3165 is just good enough)
- it is a pity that the XLR and RCA inputs cannot be switched remotely via some extension or upgrade; just some connector/header bypassing the mechanical switch would be very useful for a DIY implementation using relays
- ideally, remote switching of the gain (e.g. depending on the selection of the XLR or RCA input) would be fantastic (but possibly too complicated)
Pavel V.
AUDIOPHONICS HPA-H250NC Power Amplifier 6 Channels Class D Ncore NC252MP 6x250W 4 Ohm The Audiophonics HPA-H250NC is a 6-channel Class D power amplifier based on three Hypex NCore NC252MP modules. This version is aimed in particular at audiophiles and home...
Excellent amplifier
Excellent amplifier. The only missing features are switchable RCA inputs and possibly adjustable gain (but that would be probably complicated and significantly more expensive with NC252MP modules).
André A.
Exceptionnel
Je viens enfin de brancher mon ampli de puissance. Après avoir attendu le temps de chauffe nécessaire, c'est une révélation. J'ai l'impression d'avoir de nouvelles enceintes. Je découvre le potentiel de mes Triangle Esprit Antal EZ, grosse montée au niveau des basses, impressionnant, un caisson de basse s'avère inutile. Mon ampli Yamaha RN1000A se concentre sur les médium haut et sur les aigus.
Pour info, suite au conseil donné ( merci encore aux équipes d’Audiophonics, technique et réactif) j'ai réglé mes curseurs sur un gain de + 29dB pour avoir le même niveau de volume.
Efthymios X.
NEUTRIK NC4FD-LX-B Female 4 Pins XLR Socket Gold Plated This Neutrik NC4FD-LX-B base, belonging to the DLX range, has 4 poles with gold plating and a metal body. The DLX range offers compact connectors with ground contact, allowing...
As expected, good for its price.
Efthymios X.
The typical furutech quality, nothing to add.
Jean-Louis L.
Audiophonics a largement dépassé mes attentes en assistance et conseils, sans parler de sa réactivité et de son amabilité. WIIM Mini m'apporte exactement le service espéré avec une belle efficacité, Acheter cet équipement chez Audiophonics c'est top, merci pour tout !
VINCENT N.
Très bon transfo
J'avais commandé 2 transfos. Celui-ci comme l'autre respire la force tranquille. Très bonne construction, les fils de sortie sont d'un bon diamètre, les bouts sont bien étamés, les tensions aux secondaires sont identiques. Entièrement satisfait de mon achat.
VINCENT N.
Ce transfo respire la force tranquille. Très bonne construction, les fils de sortie sont d'un bon diamètre, les bouts sont bien étamés, les tensions aux secondaires sont identiques. Entièrement satisfait de mon achat.
François C.
LHY AUDIO LPS160VA 19V Linear Regulated Low Noise Power Supply 230V to 19V 7A 160VA This LHY Audio LPS160VA regulated linear power supply provides great stability for any high-quality audiophile DIY project. All the necessary technical...
indispensable
Installation sur un Mini PC I9, elle a remplacé l'alimentation d'origine haut la main et contribue au silence électrique de la sortie USB et réseau du logiciel HQPlayer.
Quelque peu imposante tout de même...
Gurhan O.
5239
Happy with the result. Need another 3m piece
Rossano F.
Tubes préamplification
Après l’achat de 4 tubes Golden Lion KT 88, j’ai acheté 2 tubes de la même marque pour la preamplification de mon amplificateur à tubes Fezz Titania !
Les graves sont plus profonds ! Les médiums plus clairs et les aigus plus fins !
Je suis très satisfait de cette évolution et je recommande audiophonics pour sa qualité de service et ses prix concurentiels…
Martynas D.
Topping E70 velvet
In my opinion, the product is well made and works fine. Would not hesitate to purchase a second unit if needed.
Shop experience is excellent, bought from the shop multiple times.
Bruce M.
Excellents résultats
Acheté en remplacement d'un Bluesound Node de 2016. Très satisfait du rapport qualité prix : amélioration nette de la qualité audio et bonne qualité de fabrication et de finition. Nécessite juste quelques connaissances très basiques pour accéder à l'interface utilisateur (expliqué dans le manuel) et sélectionner le mode de transmission réseau. Utilisé sans problème avec Roon (code livré avec l'appareil pour 2 mois gratuits) pour transmettre depuis Qobuz vers un DAC externe en utilisant la sortie SPDIF avec connexion RCA. Egalement testé avec câble USB. Testé également en mode UPnP avec logiciel Audirvana mais des problèmes de bruits blancs lors des changement de fréquence ou de bits dans la numérisation entre les fichiers : problème non résolu avec l'assistance technique Audirvana. Donc au final, utilisé avec Roon en attendant peut être la mise à jour du RED pour gérer Qobuz Connect.
En transport réseau (sans DAC interne donc), je crois que c'est parmi les meilleurs appareils dans cette gamme de prix et il bénéficie d'excellentes critique sur le Web. J'envisageais initialement un Lumin U2 (5000 €) mais je ne regrette pas du tout mon choix au final !
câble équilibré, naturel, sans acidité, juste parfait. Entre mon DAC et mon intégré Il est équipé des xlr eizz ez-206, j'ai rien entendu d'aussi naturel. En fait, je crois que c'est la 1ere fois que j'ai l'impression d'écouter la musique sans "entendre" le câble.
Excellente découverte, tout comme le cable secteur de la même marque NEP-3003G. J'ai équipé le dac avec ce dernier et rien a redire, ça le fait.
Cable dac
Equipé de fiches cuivre plaquées or, excellent rendu sur mon dac, c'est naturel, équilibré et ça respire. J'ai préféré ce câble à d'autres en raison de son prix raisonnable, je suis agréablement surpris.
Pas rodé et c'est déjà trés bon. Excellent rapoort qualité prix.
Dominique O.
5 étoiles - très bonne qualité
ai monté ces câbles sur des fourches plaquées or avec soudure à l'argent des embouts ; (sur tubes ampli de puissance KT88)
anciens câbles 2,5 carré ; nouveaux Elecaudio 5,1 carré ;
résultats :
- ciselé des médiums aigus complètement différent (amélioré) ;
- transitoires d'attaque améliorées ;
- basses généreuses sans être floues ;
par contre, étonné d'avoir rencontré un phénomène de rétractabilité de la longueur : sur les 3 m commandés je n'ai reçu que 2m80 , ce qui a rendu le raccordement des H.P. délicat à effectuer !
est-ce dû au transport par poste  ?  ??
Philippe S.
DIY OEUF JMLab/hp Atohm
Utilisé pour modifier des "oeufs" jmlab en plâtre en enceintes bass reflex avec des haut-parleurs Atohm Absolute Séries (kit EURUS E-5). Adaptation de l’évent parfaite.
Jerome C.
Copper / Silver Wiring Cable 4mm² PTFE Sleeve Ø3.6mm Red This 3.6mm diameter cable has a single 4mm² conductor made of Silver plated OFC Copper. This provides excellent signal conductivity while providing the conductor with high...
En alimentation secteur, performant mais rodage très long.
J'ai utilisé ce fil de câblage pour recâbler une barrette secteur que j'ai optimisé , amortissement, câblage interne, filtrage passif.
L'écoute se fait au casque Sennheiser HD 600, Focal Clear , lecteur streamer Atoll ST 300 et ampli casque Sennheiser , donc l'acoustique de la pièce n'intervient pas.
Pour bien saisir le "gain" du bloc secteur, son cordon secteur est absolument basique, cordon générique 3 X 1mm2 de même pour les appareils.
C'est un fil de câblage qui fait très "premium" avec un PTFE très fortement serré sur un multibrin dont le placage argent, de bonne qualité ne se fait pas la malle lors du serrage sous vis.
Il nécessite un très long "rodage" comme il est coutume de dire dans le milieu audiophile , et je dois avouer que j'ai traversé des doutes avant que ce câblage se "réalise" enfin, il ne se passait rien même à 30 heures, comptez 60 heures.
A 60 heures l'écoute s'assouplie enfin car au début c'est dur et très "dans la face" donc pas écoutable, par contre ça devient bigrement intéressant à 60 heures avec un équilibre qui ne pêche pas par un aigu insistant (c'était ma crainte avec le placage argent )
L'ensemble est plus clair par une sensation de transparence accrue, clair mais pas maigre car du grave au médium la matière est là.
Le grave est très lisible, il plonge bas et donne une tension et articulation qui apporte au réalisme, on retrouve cette sensation sur les cordes de guitare.
Je gagne en transparence et les timbres se réalisent mieux, sur les voix c'est également tout bénef.
En fait les contours sont plus nets sur l'ensemble du message.
Les détails sur les fréquences aigus sont plus évidents.
Je pense qu'à la base le match de mes appareils est bon, donc il est possible que ça ne colle pas sur un match déjà limite sur l'aigu.
60 heures de rodage propose une restitution encourageante, je mets un léger bémol car j'attends encore un peu + de souplesse à l'écoute , je fais confiance au commentaire de notre ami anglais, ce câblage devrait se bonifier encore ....
Gérald F.
Transfo sur mesure
Top produit !
L’attente est longue mais ça vaut le coup !
VIABLUE T8 SOLDER Gold Plated RCA Connectors Ø9.5mm (Pair) These RCA T8 Solder connectors from Viablue feature a high quality design. They feature 24k" gold-plated contacts for enhanced conductivity and...
Très bien !!
Fiches utilisées pour monter un câble numérique blindé en argent pur monobrin Xangsane XS-1001Ag diamètre 9mm.
Très bien au niveau des soudures et des vis qui bloquent bien le câble.
Il a fallu que je frotte avec du papier de verre pour réduire le diamètre de la gaine du câble Xangsane qui est un peu trop épaisse et la rentrer avec de la vaseline, les fiches n'y sont pour rien.
Top livraison Audiophonics !!
Hugues E.
AUDIOPHONICS GXDC-25 Power Cable Jack DC 5.5/2.5mm to GX16 OFC Copper for LHY Power Supplies 1m This Audiophonics power supply cable, assembled in our workshop in France, is composed of a Jack DC 5.5/2.5mm connector and a GX16 connector. It can only be used with LHY power...
Câble secteur DC
Apporte un vrai plus , plus d’ouverture , scène plus ample , pas d’agressivité ni effondrement de la dynamique, un petit rodage et que du bonheur
Olivier b.
Interconnect Cable Female XLR to Male XLR Gold Plated 1.31mm² 7.6m This XLR female to XLR male modulation cable offers very good performance at a low price. It has a conductor cross-section of 1.31mm², is shielded and has gold-plated...
Câbles achetés il y a quelques temps car mon préampli hifi est positionné sur le côté de ma salle et assez éloigné des amplis (blocs monos). La qualité de fabrication est excellente, les câbles sont souples et facile à mettre en oeuvre, les fiches XLR robustes. J'ai eu l'occasion de les comparer avec des câbles 1er prix et il n'y a pas photo, le son est très nettement meilleur. Je craignais vu la longueur de perdre en détail et d'avoir du souffle par rapport à des RCA plus courts... il n'en est rien, aucun souffle y compris avec un pré ampli à tubes (bien entendu cela dépend du matériel) et la restitution musicale est top. Je recommande ce produit sans réserve, en remerciant Audiophonics pour assurer une logistique parfaite et ce depuis des années.
Vincent M.
Niveau bien lisible de par sa taille. Prix très correct. Top !
Vincent M.
Parfait. Qualité prix impeccable. Content de mon achat.
Nicolas D.
qualité de son et belle facture
Taille réduite, esthétique sobre, très silencieux en fonctionnement, mais surtout excellente qualité sonore.
Je ne l'utilise qu'en transport et non en Ripper.
Chose curieuse : je préfère la connexion en USB-C sur un Dac plutôt que le coaxial : la différence est audible.
La télécommande "texturée" est jolie et agréable à l'usage.
Seul bémol : une fois le CD inséré, lenteur pénible avant de pouvoir lancer la lecture. Également : pas d'alimentation fournie.
Je ne regrette absolument pas pour autant !
Vincent B.
SHANLING CR60 CD Player Ripper Sanyo HD850 Silver With its CR60, Shanling unveils a relatively compact, space-saving Audio CD player/ripper. The CR60 is based on a Sanyo HD850 laser head and a Philips drive mechanism for smooth...
Transport CD compact et performant
Super appareil !
Lecture performante, bruit de lecture très faible, super connectique, la télécommande pratique, pas grand chose à lui reprocher...
Le seul défaut : l'accessibilité au bouton de passage vers le mode "ripper"... mais c'est pas le fonctionnement quotidien pour cet appareil.
Une petite rallonge usb-c règlera le manque d'accessibilité à la prise usb.
Pour ceux qui veulent un appareil compact pour lire leur CD-thèque, ne dépensez pas plus !
Nicolas D.
Très agréablement surpris
Premier achat sur ce site.
Connecté à des enceintes DIY de 30 ans dont je n'arrive pas à me lasser (base Seas speakers). D'abord surpris puis bluffé par la limpidité du son : aucune agressivité, détail et rendement important.
Connectique de très bonne facture. Esthétique sobre comme j'aime. J'hésitais avec le 2x500 w mais la puissance est très suffisante.
Bref : je recommande. Vivement !
Eemeli T.
DAYTON AUDIO MX10-22 Speaker Driver Subwoofer 400W 4 Ohm 86dB 25Hz-500Hz Ø25.4cm Designed to produce maximum output at an unbeatable price, this MX10-22 Max-X dual voice coil subwoofer from Dayton Audio has all the features you'd expect from a...
A great driver with a couple of caveats
Sonically and aesthetically MX10-22 performs well - a powerful motor, large double voice coil, nice looks and high excursion capabilities make this a good choice. I'm running two of these with a 350WPC class-D PA-amp in 60-liter reflex enclosures tuned to about 23Hz, and they perform beautifully both in listening to music and when watching movies.
The caveat considers part of the structural design of MX10-22. Binding posts on the driver (which are of nice quality) are placed so wide and up on to the basket that they make installing the driver into an enclosure very hard, especially if the baffle of the enclosure is thick - you cannot just drop it into place and be done with it. I had to bend the binding posts downward as much as I was able to, and to carve two slots into the mounting hole for the posts AND to work the driver into the mounting hole at an angle to get it in. In my case the front baffle of the enclosure is 40mm thick.
Other than that, this is a great driver especially considering the price.
Denis E.
Que demander de plus ? Parfait rapport Q/P !
Bel aspect qualitatif, facilité de soudage (effectivement l'isolant ne fond pas) et serrage du contact parfait (bien serré mais en restant souple sans blocage).
Pour finir je suis satisfait du son : utilisé avec une platine vinyle Audio Technica AT-LP 2022 ça fonctionne parfaitement.
Rob W.
RAMM AUDIO S8MC Interconnect Cables RCA OFC Copper 1m This RAMM Audio S8MC RCA-RCA modulation cable offers good quality at a very affordable price. The cable conductors are single-stranded OFC copper. The cable features an aluminum...
Good value for money
Excellent quality RCA to RCA cable, with directional arrows. I would buy again.
Alain M.
Amplificateur casque résolument audiophile
Je suis pleinement satisfait de cet achat. Connecté à un DAC GUSTARD X26 III (XLR), mes écoutes se font avec un casque HIFIMAN HE V4 et c'est pour moi un véritable plaisir. La musique s'exprime délicieusement avec douceur et subtilités dans toutes les gammes de fréquence. Voix et instruments sont parfaitement définis et ce, quelque soit le style de musique écoutée.
Marcel R.
DAYTON AUDIO TD20F-4 Speaker Driver Tweeter Neodymium 20W 4 Ohm 90dB 3000Hz-20kHz Ø1.9cm The Dayton Audio TD20F-4 silk dome tweeter incorporates an optimized diaphragm that combines low mass, superb damping and a carefully calculated dome profile, delivering an...
excellent petit tweeters peut être utilisé dans le haut de gamme
Ange M.
très bon quad
commandé en remplacement d'un quad GEC NOS sur un Luxman A3600 pour les laisser au repos, j'ai été très agréablement surpris du fonctionnement de ces KT88 qui n'ont rien à envier aux GEC, toutes les fréquences sont détaillées, les basses précises, un vrai bonheur
frederic t.
Fabrication propre , pratique à utiliser, aucun problème à l'installation. Il drive très bien mon hifiman sundara.
Au niveau sonore, c'est exactement ce que je recherche et rien à lui reprocher.
Le seul défaut que je vois est le bruit que fait l'alimentation au niveau de la prise. C'est léger mais suffisant quand je n'écoute pas le casque pour que je regarde à la remplacer.
Marylène C.
Beaucoup plus facile à monter que des neutrik-rean, ici on a de la place pour souder, tout est logique et bien pensé.
Probablement une très bonne résistance à l'arrachement (je n'ai pas essayé), le câble fait de suite bien fini avec la petite gaine souple à la base de la fiche.
Marylène C.
On pousse les murs
Monté avec des RCA Amphenol il apporte une aération que je n'aurais jamais soupçonné avoir besoin d'éprouver sur mes enceintes.
Aucune dureté
comparé à Mogami Neglex et Canare.
Mogami trop typé et medium en avant,
Canare rien à reprocher, effet plus typé studio pour moi. C'est très bien aussi mais vraiment cet Albedo est redoutable par exemple sur du metal comme Infected Rain il aide vraiment à détourer chaque détail et évite un effet massif brouillon qui peut se ressentir.
Albedo: Aération, clarté, naturel
Mogami Neglex: peu de détail en haut, démonstratif, celui que j'aime le moins
Canare: le câble passe partout qui se fait oublier, peut-être la référence la plus neutre? Ca se discute je pense.
Simple et efficace
J'ai opté pour cette fiche par manque d'espace entre l'embase IEC et l'interrupteur (alimentation verticale) à l'arrière de mon DAC.
Serrage des conducteurs efficace, et la fiche ne bouge pas une fois en place. En ce qui est de la terre, une cosse,sans doute en cuivre, est fournie, il suffit de la sertir, donc pas de soudure. La qualité furutech avec un bon rapport qualité prix.
Jonathan T.
Works well, but room for improvement
I have a couple of these running 24x7 in a modified HighPi Pro case which works fine.
These devices don't work well during a "brown-out" condition and sometimes don't come up properly unless you wait a good few minutes between boots.
This behaviour seems to be due to the way this board resets - it just has a 100k pull-up resistor which is not sufficient. I intend on trying a MCP100 Supervisory Controller to mitigate this but could also use a pin to a spare GPIO port to reset for when this condition happens. I would love to see a future revision of this board that has a proper reset circuit.
Extra points if a dedicated steel case with heatsinks was available.
Pierre T.
SMSL DL100 DAC 4x CS43131 Headphone Amplifier XMOS XU316 Bluetooth 5.1 LDAC 32bit 768kHz DSD256 MQA-CD With the DL100, SMSL offers us a high-performance DAC incorporating quality components such as a combo of 4 Cirrus Logic CS43131 chips, an XMOS XU-316 USB interface and a...
Bonne surprise
J'ai mis un peu de temps à poster l'avis, le temps de tester plus longuement.
Actuellement installé sur un LD systems Dave 10 g4x, téléviseur Panasonic, écoute Spotify premium, Netflix, pièce traitée (bass trap accordée, panneaux absorbeurs et déflecteurs). Le Dave 10 s'est réveillé, et bien réveillé. L'aération, instruments à leur place, l'image 3D et profondeur m'a surpris. Je pensais que le résultat serait bien en deçà de ce que j'ai pu lire suite à l'avis du premier acheteur et de l'avis d'amir. Ce dac est finalement bien placé dans sa gamme de prix. Pas de souffle sur le Dave pouvant sortir 110 db dans le salon. Sans mesures, la distorsion à l'air maitrisée. Sur les films et streaming, le son ne déborde pas, l'intimité ou la brutalité est parfaitement retranscrit. Le dialogue se passe largement de voie centrale (je possédais une salle HC dédiée avec dirac), on sait bien qu'en config 2.1 le placement est primordial. Je n'ai pas eu besoin de me torturer l'esprit (le traitement sonore y joue forcément). Le mariage avec le Dave 10 était osé, bien m'en a pris.
La sortie casque est testée que sur le jack 6.3mm, avec un akg 551 tweaké pour la musique, fermeté du signal originel aux petits oignons, aucunes sibilances, sauf dans les limites auditives où la distorsion se fait clairement sentir. Test nº2 sur superlux hd 681 evo cheap et tweaké également pour les films uniquement (le akg est orienté hifi-limite monitoring suite au tweak) je ne reconnais pas mes modifications, les dialogues se recentrent, les effets sont à leur place et ne partent pas dans tous les sens, ils collent précisément là où doit être l'effet. Les parties musicales prennent une belle ampleur. Donc ravi de ce dac qui fais vraiment le job, plus que je pensais.
Mon avis n'engage que moi dans une pièce traitée.
nicolas g.
Il y a mieux
Je trouvais le sons terne et avec un manque d'image sonore et de spécialisation, bien évidemment j,ai roder le tube je lui et laisser sa chance, jusqu'à se que je le remplace par un JJ ELECTRONC 6SN7 et la des le départ tube neuf sa na rien avoir, le sons et directement HIFI de limage de l'ampleur, bref je suis déçu des ELECRTO-Harmonix ils sons loin des JJ ELECTRONIC sur un systeme XDUOO TA-26S. Rien que sur les comparaisons YouTube il y a de la différence.
Johan v.
Very engaging and musical DAC
After getting rid of a ground loop by insulating the grounding metal part of the Schuko plug with duct tape it turns out to be a
very nice DAC.
Dear Topping engineers signal ground and safety earth are not the same thing so don't connect them together!
I used only the coax SPDIF input so far.
I wanted to eliminate the long warmup time of my tubed pre amp and tubed DAC and this works well now I can listen to music without having to wait for an hour for everything to sound right.
Oh and how does it sound?
What I lost in depth and spacial definition is more than made up for in musical detail and instrumental timbre is good missing nothing.
Very even sound balance with enough bass and body treble is fine mid range great the music is very engaging and in my system conveys emotion very well so far so good after 36 hours of being switched on.
Thomas G.
Fait le job, très robuste et très bonne qualité de fabrication. Attention cependant c'est un câble très épais et donc peu flexible.
Peteris B.
Peter
good quality, good price
Peteris B.
NEOTECH BRDCC-24 Braided Flat Wiring Cable UP-OCC Copper Litz Wire 24AWG 0.2mm² Neotech BRDCC wires are an excellent UP-OCC copper solution. Professor Ohno's UP-OCC process is recognized in the manufacture of high quality HiFi cables. Cotton (70%) and...
Peter
good soldering, good wire
Patrick K.
Sonic master
These cables are true gems, I have many interlinks , from mogami with low mass elecaudio connectors and chord C-line, to XLO reference , signature, wireworld gold eclipse 8 is my daily driver and beats the pants off of all else that came through… however a cable I constructed with this
Manuel G.
RAMM AUDIO 60600GT Female XLR Connector Tellurium / Berrylium Copper Cryogenic Treatment This RAMM Audio 60600GT XLR female connector offers a beautiful design quality, ensuring a particularly efficient audio signal transmission. The connector is made of tellurium...
Mitigé
Jusque maintenant j’étais très satisfait de la marque Ramm audio pour les améliorations audio qu’elle apporte. Je suis cependant plutôt mitigé sur la conception de ce connecteur XLR. Le pas de vis pour connecter le fil de masse flottante est plus petit que les autres et trop petit pour à la fois insérer les 3 brins et la vis de serrage. Il faudra faire un choix. D’autre part les pas de vis sont très fragiles car l’alliage utilisé est mou.
Montage donc difficile. Rien à redire cependant sur le rendu sonore.
