indispensable
A...
Alexandre G.
petit mais costaud
Emmanuel L.
Bien utile
Le...
Customers reviews - There are 19478 reviews.
Stephane M.
Agréable à manipuler. Prévoir une alim 12VDC pour la diode (ce que je n'avais pas compris). A toutes fins utiles, la diode consomme 10 mA et reste bien visible avec une tension de 9V; c'est même plus agréable à mon goût.
Andoni G.
Be careful
Don’t conect your Amps or active subs or high energy demand sistems
This power surge is for small devices like dvd, dac, router, light etc etc
Is only 10 a power my mcintosh for example I’d 25 a
Daniel G.
OEAUDIO OEOTG Lightning to USB-C OTG Cable 12cm The OEOTG from OEAudio is a USB OTG cable of excellent quality, benefiting from a careful design, using components to ensure very good performance.
Excellent câble d'une bonne rigidité. Le son est transmis de façon parfaite la prise lightning est bien maintenu sur mon mobile ce qui n'est pas le cas pour tous les câbles. La qualité est là. Le service client que j'ai eu l'occasion de tester (panne informatique de la poste) est compétent et rapide (moins de 8h pour la réponse . Très bonne enseigne, très bon produits je reviendrai. A+++
Michael D.
FX-AUDIO D502BT Amplifier FDA TAS5342A Subwoofer Output Bluetooth 5.0 2x60W 4 Ohm Silver The FX-Audio D502BT is, as its name suggests, the successor to the D502. The D502BT takes over its base and components, but this time it comes with a Bluetooth 5.0 receiver,...
Backup for my Advance Paris AMP
Due to some issues with my main AMP (right channel is not working), i just used the FX-AUDIO D502BT as a backup amp for my living room (TV, PC and BT connected).
And what should i say, it is surprisngly good. Not the punch of the Advance amp, but not way behind that.
Perfect and easy to setup for me with the Sub out as well.
Normally i just bypass sound settings or EQ, but in case with the FX-AUDIO D502BT is just set to EQ preset no. 4, this works best for my ears and listening style.
5 stars from my side for price efficient small amp.
Mathieu P.
Excellent câble, scène plus large, plus de détails, grave plus profond et net
Il faut compter une dizaine d heures avant d avoir un bon résultat.
Je ne regrette pas
Igor H.
Problème de connexion
Quand il n'y à pas de musique le dac se connecte et se déconnecte tout le temps ? Sinon très bon produit, bien fini, bon son
Nicolas J.
Petit ampli pauvre en fonctionnalités mais qui mesure vraiment très bien pour son prix.
Je n'ai pas fait de test ABX mais l'écoute est très plaisante. Mon autre ampli est un intégré bas de gamme Pioneer de même puissance de référence A209-R.
Le VOLT+D est très silencieux à faible volume (bon rapport signal/bruit, bien meilleur que le Pioneer).
Je l'utilise en écoute de proximité sur de petites biblio Monitor Audio Monitor 100, avec l'alimentation vendue séparément sur Audiophonics (19V 3.15A). Le réglage de gain de 20dB est largement suffisant dans ces conditions d'écoute (potard de volume à 8 positions du max).
Au besoin il y a 2 switches sur le dessous à changer de position pour passer à 26dB de gain, et il est possible d'utiliser des alimentations plus puissantes.
Guillaume F.
Fountek FR135EX
Monté dans une enceinte à ligne de transmission, ce haut-parleur émet un son très propre. Pour sa taille, c'est impressionnant de descendre aussi bas dans les graves.
Le seul point faible est l'aspect visuel, notamment avec la mousse visible au niveau du cache-noyau.
Je recommande ce petit large bande de bonne facture.
Stefano Z.
wonderful streamer
I really wanted to ear the difference from my PC to a real streamer, and I wanted that every euro I spent for a streamer was on the streamer performance (so no DAC attached, no bells and whistles). This IS it. I usually struggle to ear differences between DACs so I was so surprised when I played the first track through the digione sig. The staging, clarity, less fatiguing sound was a huge step forward. I am totally happy.
One CONS: the preinstalled volumio was not original, so not up-gradable, so I had to buy extra hardware to flash the drive again and the extra money spent for the volumio version was a waste. You are better off choosing the roopie version and flash whatever on your own. I bought it with Nirvana, for me the result is already super satisfying, I don't feel the need to go with shanti, but I don't even know what I may be still missing, only that I am fine like this.
Antoine G.
Il me sert à alimenter l'ampli AUDIOPHONICS TDA-S50 Class D 2x 70W 4 Ohm, et le résultat est bluffant. J'ai bien plus de puissance que je ne l'imaginais, et il n'y a aucun souffle.
Antoine G.
Appareil remarquable
Avec une alim de 36v 6A, j'ai bien plus de puissance que je ne l’imaginais. Finition impeccable, petit et discret. Irréprochable côté qualité sonore. Aucun souffle. Il me sert, avec des enceintes bibliothèque, à sonoriser la zone 2 de mon installation audio-vidéo. J'ai fait passer un câble HDMI, j'ai un moniteur d'ordi avec sortie casque, et j'ai branché l'ampli dessus.
jean luc L.
https://www.audiophonics.fr/index.php?id_product=4635&controller=product
livraison rapide , multiprise solide
Farzad E.
CL-400W Amplifier Board TDA7498E 2.0 / 2.1 / 4.0 Bluetooth I2S HDMI 4x120W 4 Ohm This complete and versatile CloudyX CL-400W amplifier module has the particularity of being able to operate in stereo mode (2.0), 2.1 or 4.0. It is capable of developing a power...
Très déçu de la qualité sonore en sortie avec beaucoup de bruit
Cyril V.
AUDIOPHONICS EVO-SABRE PACK DIY avec Roon Labs
Acheté début 2020, j’ai pris le temps de tester l’AUDIOPHONICS EVO-SABRE PACK DIY DAC Symétrique 2xES9038Q2M.
Avec l’entrée USB je suis déçu, le son est moins percutant. Je ne serai dire pour quelle raison, surement ma source USB (Serveur NAS ou Raspberry PI 4) ! De toute façon, je ne souhaitais pas utiliser cette entrée en l’achetant.
Le résultat est meilleur avec le Raspberry PI (interne au boitier utilisant les GPIO en I2S). Le son est dynamique, précis sans être analytique comme les autres DAC Audiophonics DIY utilisant également l’ESS SABRE 9038Q2M. Je pense que c’est lié au filtre a phase linéaire et ou la gestion du DPLL.
J’ai changé les AOP de sortie par des BURSON AUDIO SUPREME SOUND SS OPAMP V6 Classic AOP Simple (pour info, pas besoin d’adaptateur). A mon oreille cela n’a pas changé grand-chose (A l’époque où j’avais changé les AOP j’avais des enceintes et un ampli bas de gamme de 20 ans d’âge).
J’ai mis en place un dissipateur thermique sur le Raspberry Pi 4 qui s’intègre bien entre le PCB et le PI (Geekworm Raspberry Pi 4 11mm Embedded Heatsink (P165-B)). Ce qui m’a permis de gagner quelques degrés.
J’alimente le DAC avec l’alimentation proposé par Audiophonics (MEAN WELL Adaptateur Secteur Alimentation 100-240V AC vers 9V 4A DC ) avec un filtre ifi
J’ai remplacé l’écran de droite SPI par un écran DSI en couleur et tactile de 4,3 pouces (4.3inch DSI LCD Capacitive Touch Screen Display 800×480). J’ai dû le coller avec du double face en façade. Ce n’est pas des plus esthétique (ce n’est pas moche non plus) mais c’est fonctionnel. Je vois les jaquettes, je peux passer au morceau suivant, diminuer ou augmenter le son en appuyant sur l’écran.
Utilisateur de Roon, j’utilise la distribution Ropieee qui s’intègre parfaitement au DAC notamment la gestion du volume, l’écran tactile DSI (non SPI). J’ai testé d’autres distributions, Ropieee tien le haute du pavé avec Volumio en termes de restitution sonore.
Pour info, j’utilise ce DAC comme préamplificateur sur un amplificateur Audio-GD A1 et depuis 3 semaines sur des enceintes Triangle Magellan duetto. Le tout sonne très très bien.
Les plus :
- Rapport qualité prix
- Qualité de fabrication
- Pas mal d’entrées (GPIO(I2S), USB, TosLink, SPDIF, Bluetooth)
- En sortie XLR et RCA
- Module DAC symétrique Double ES9038Q2M
- Possibilité de choisir les AOP de sortie
Les moins :
- RPI I2S : 384kHz / DOP128. J’aurai préféré une liaison DSD Direct 512. Est-ce que c’est possible avec le Raspberry PI ? ou Est-ce lié au FGPA Altera Max ?
En conclusion
Très bon produit en therme de son. J’ai aimé le monter moi-même et le modifier pour mon utilisation (Roon Player). L’intérêt de ce produit est le prix, l’électronique de bon niveau, la flexibilité d’utilisation, mise à jour à moindre frais. Si Apple sort un nouveau protocole Airplay 3 (implémentation dans l’OS) ou un futur Bluetooth 6.0 (via clé USB ou changement du RasPI) vous pouvez mettre à jour après que la communauté est sortie la mise à jour.
Stéphane C.
J'ai commandé ces fiches bananes pour remplacer de très anciennes WBT , livraison rapide et sérieuse comme toujours.
les fiches sincèrement elles sont de très bonne qualité , d'un point de vue fabrication et résultat sonore. Je possède un bon système et la différence sonore est bien réelle .
Je recommande ces fiches sans hésitations.
Stéphane.
reginald B.
Fait le job!
Enfin testé ce weekend sur des b2 d&b, ça s'est très bien comporté, alimenté par 6 batteries 12v en série, un bonheur. On verra dans le temps mais c'est du sérieux.
Tomáš N.
PSVANE tubes
The first switch-on, a fuzzy, obscure, crooked, bad sound, but improving during burning, after 30 hours of listening accurate fast bass, beautiful clean mids and highs with perfect microdynamics, amazing holography 3D stage, very nice warm character, I think they are the best from EL34 line, (better than everything I've heard so far including gold lion kt88) the only small disadvantage for me (just when compare) is not such dynamics and such deep bass as on KT88. I am very very happy with this.
Produit correct
Boîtier tôle emboutie, avec façade de belle facture en aluminium, montage aisé et intuitif, prix décent. Un seul bémol négatif, faites hyper attention en manipulant le boîtier, les arêtes vives des radiateurs sont aussi coupantes qu'un scalpel... Je vous recommande fortement de ne le manipuler qu'avec des gants (pas en tissus ni en nitrile), sinon mettez les mains sur les façades antérieures, et postérieures.
Content de cet achat
Par rapport à la génération précédente, il est à présent possible de couper totalement l'alimentation à l'arrière du boîtier, les fiches HP sont plus qualitatives, le boitier est plus large er fait plus chic, belle évolution, il ne me reste plus qu'à l'écouter voir s'il y a amélioration, mais ça, j'en doute, le module interne semble identique, et comment améliorer le son de quelque chose d'aussi fidèle dans la reproduction sonore.
Merci Audiophonics, excellent rapport qualité prix.
Mikael I.
zimmerman
I give it 10 stars I love this cable can only recommend it to anyone how wants good
natural with large sound stage
Mikael I.
zimmerman
Nice for the price and good for tick cables
Mikael I.
zimmerman
noel s.
SHANLING UA1 Pro Adapter DAC USB-C ES9219C 32bit 384kHz DSD256 80mW 32 Ohm Black Whether you are using a latest generation smartphone that lacks an analog audio output (compatible directly with your headphones / headphones) or you simply want to improve the...
Géant !!!!!!!!!!!!
Extrêmement satisfait
Utilisant avec mon Mi 10 il change radicalement la qualité du son
Même avec mon autre dac plus cher je trouve celui ci nettement meilleur.
Christian T.
Comparé directement avec un câble secteur à 1500 €, le NEOTECH NEP-3001 est à égalité pour 10x moins cher.
Je suis très satisfait merci audiophonics.
Vincent B.
Une rolls
Cable de super facture, robuste et de qualité.
Une Rolls.
Vincent B.
CYK Stereo Cable XLR-3 Male / RCA Male Gold plated 24K OFC Copper 2m This affordable RCA male to XLR male CYK cable is ideal for ensuring good conductivity to your signal with its OFC copper conductor.
Fabrication OK mais aucun repérage G-D du coté XLR
Tout est dans le titre. On se demande comment on peut concevoir un câble audio sans repérage de voie gauche-droite d'un coté du cable (ici du coté XLR).
Vincent B.
SHANLING MTW100 V2 In-Ear Monitors IEM Bluetooth 5.0 White The Shanling MTW100 V2 headphones, particularly practical, allow a stable and efficient transmission of your music. Knowles loudspeakers and the intelligent design of these IEMs...
oreillettes très simples d'utilisation, discrètes, de bonne qualité audio, aucun problème de connectivité avec un PC, avec iPhone. Bref excellente expérience. Je recommande vivement pour qui ne veut pas se ruiner dans des oreillettes BT.
IMAGE STEREO SANS PROFONDEUR
Beaux timbres et transparence correcte. Points négatifs: le niveau de détail pourrait être meilleur avec des micro-informations qui passent à la trappe. Image stéréo manquant singulièrement de plans en profondeur ce qui rend la restitution d'un orchestre symphonique abstraite, irréaliste. Le Sabaj A4 qui embarque les même puces fait beaucoup mieux.
Bof
C’est un câble pas cher mais heureusement, car contrairement aux autres avis, il ne m’a pas emballé pour l’instant. Il a déjà tourné 20 heures et il reste fermé sauf dans les aigus ou il s’en sort. Il dégraisse trop en bas et il écourte trop les fins de notes.
Dans les mêmes prix, le Canare et surtout l’orbite 240 font bien mieux.
Ecouté sur deux ensembles différents avec le même constat.
Atoll in 100 et cd 100 en SE
Sur hp triangle Antal xs refiltrées et recablées.
Ampli et cd Roksan K2 sur focal chorus 826 v recablées
Câble et prises secteur Oyaide Tunami pour les deux ensembles
KRISTIJAN B.
Super konektor
i connetori sono perfeti!
Chi sa saldare non avra nessun problema.
Cosiglio aquistare!
Bengt N.
Superb DAC its outstanding control
I can agree on all positive reviews, plus the excellent control possibilities such as the optional volume control. I have not tested the I2C input yet, but it is tempting to try. This DAC is perfect for my 4 channel DSP crossover filter. Recommended!
Bengt N.
USB to I2S Interface XMOS XU208 32bit 384kHz DSD256 This USB to I2S digital interface includes an XMOS XU208 chip supporting high sampling rates up to 32bit PCM 384kHz and DSD256.
Works very well
No problems at all. The I2S input from this device gave an improvement on the sound quality from my DSP, compared to my previous SPDIF input. Recommended!
Jean Michel P.
Excellente fiche IEC
Cette fiche IEC est de très bonne fabrication et l'insertion dans mon ampli Denon est très franche . Le cuivre pur apporte réellement un plus à l'écoute par rapport aux plus basiques IEC Schurter ..
Définition ,douceur ,largeur de spectre et image tout semble magnifié. A marier avec un très bon câble secteur pas nécessairement cher
Bengt N.
Working well
This remote receiver is working well in the volume control/input selector PCB after a small modification. Instead of soldering it straight with pins 1-2-3, it should be mounted 1-3-2., two of the leads swapped. After this it is fine!
And you should know that it is not working without the display attached...
Petit transformateur pas cher, belle qualité, la tension est respectée, 0.1v près, très silencieux et facile à mettre en œuvre. Attention à ne pas tirer sur les câbles de sortie, j'en ai malencontreusement arraché un. Ce transfo est tellement bien fait, qu'il est facile de le démonter, et de ressouder le fil, ce que j'ai fait.
Une petite amélioration : Un schéma des bobinages interne serait un plus, afin de ponter en série ou parallèle entrées ou sorties, afin d'avoir le meilleur couplage possible.
Merci Audiophonics pour la qualité de ce composant.
Jean-Pierre Z.
Attention
après quelques mesures (un vieux Tektro AA501 et un géné Tektro SG 505) Source 150 et 50 Ohms c'est bien meilleur avec les 5532 .
Mais il y a plus gênant : l'impédance de sortiedépend du gain imposé au circuit 1X ça va 20X 30X ...bonjour les dégats , Ne pensez pas charger sur 10K avec un gain autre que 1X sous peine d'écroulement du niveau de sortie et d'augmentation de la distorsion , donc utilisable avec une charge d'au moins 100k.
6 mètres de de câble vrai 75 ohms
Pour recâbler toute mon installation. Facilité de montage et résultat parfait, pour un prix basique, avec une connectique amphenol au top et de jolies gaines viablue pour le repérage des câbles. Look et finition pros avec un son superbe . Du sérieux!
Guy L.
simple, permet de remplacer facilement des ancien bornier lors de la restauration d'ancien ampli. Bornier largement suffisant et garde un look pas trop moderne.
pierre b.
très bien pour le prix
ne vous ennuyez pas à acheter une barrette secteur Naim qui vous coutera bien plus cher pour un rendu similaire...
le mauvais avis précédent ne correspond pas à mon expérience.je recommande cette barrette secteur
David G F.
12v trigger
Like most audio-a-holics I love to power up my rack one unit at a time. However replacing power switches is expensive to ship 70 lb amps plus the down time. Imaging my glee to find a true audiophile solution, well engineered, uniquely simple and elegant. Best part Made in France, Merci from a happy Canuck.
Melvin L.
très bon câble RCA
excellente tenue des fiches.
plaquage OR durable dans le temps.
soudures très bien faites.
câble de forte section, reste souple néanmoins.
attention a revisser les prises RCA (reçu les miennes un peu desserrés)
je recommande.
Melvin L.
module très efficace
bonne conception.
convient très bien pour remplacer les PCB d'amplificateurs a base de STK pour certains modèles.
fonctionnement au repos silencieux.
je recommande.
Melvin L.
fonctionne mais attention a la LED
fonctionnel en tout points.
néanmoins attention a la LED lorsque l'on dépasse les 24VDC...
elle finit par griller ! (il aurait fallu une résistance + élevée)
l'ensemble peut être poussé a 26VDC sans problèmes.
Melvin L.
très bon micro de mesure
pied solide.
câble de 5 mètres appréciable lorsque l'on as un peu de distance.
présence d'un fichier de calibration unique au micro.
port USB solide.
mesures qui se font sans soucis avec REW.
je recommande.
Melvin L.
fait son travail
il as permis de rendre + silencieuse ma console M3eemthree hotline MN8.
réellement efficace.
je recommande.
Melvin L.
excellent boitier
ajustements très bien fait.
finitions au top.
livré avec de la visserie en rab.
je recommande.
Melvin L.
très bonne qualité !
excellentes connectiques haut parleurs.
se soude très bien.
le câble est bien serré dans le logement prévu pour.
je recommande.
Melvin L.
correspond pas a la description mais fonctionne
j'ai reçu une version avec TDA7491P qui est un circuit classe D.
le schéma n'est pas le bon !
(pas pratique pour ajuster le montage)
toutefois, il est fonctionnel...
Gildas g.
Fait son boulot
Un bon câble à un tarif plus que raisonnable.
Le résultat est bon, la restitution est bien détaillée.
Je ne m'en lasse pas.
Christian T.
Je ne m'y attendais pas !!
J'avais un câble secteur payé plus de 500 € qui avais reçue plusieurs récompenses etc ...et j'ai commandé un morceau de 1m de se câble ELECAUDIO CS-361B; au début pas trop convaincue de l'apport de se câble par à port à mon câble à plus de 500 €
J'ai monté se câble avec des fiches FURUTECH PIEZO Céramique FI-50
le résultat final donne un son bien meilleur que sur mon câble de référence vraiment bluffant.
Pour être sur que l'amélioration ne venait pas que des connecteur FURUTECH j'ai interchangé, le verdict est sans appelle, l'ELECAUDIO reste meilleur.
Un son largement plus naturel et réaliste je n'en reviens toujours pas pour un bout de câble payé 25€
Je suis vraiment satisfait des produits audiophonics et des choix proposé, on y gagne vraiment rapport qualité prix.
