jevgenijs S.
Simply great!
My speakers never sounded this good! A very clear and open sound without being fatigue! The tone controls are very effective!
Reinhardt S.
VIABLUE EPC-4 Silver Balanced Interconnect Cable Ø3.9mm
sehr gute Qualität,sehr empfehlenswert
Reinhardt S.
NEUTRIK NC4MX-B 4 Gold Plated
Customers reviews - There are 20865 reviews.
Julien L.
DAYTON AUDIO CLASSIC B65 Bookshelf Speakers 40W 6 Ohm 85dB 55Hz-20kHz Black (Pair) Dayton Audio's Classic B65 bookshelf speakers are passive speakers featuring a 16.51cm woofer and a 2.54cm silk tweeter capable of handling up to 40Wrms of power under a 6 ohm...
Bibliothèque Dayton Audio
Bien reçu. Colis toujours très bien emballé comme à l'habitude de Audiophonics. Ça reste de l'entrée de gamme mais plutôt bien fini. Bon rapport qualité prix.
Raffaele S.
DAYTON AUDIO IMM-6C Measurement Microphone USB-C for Android / iOS Smartphones and Tablets Turn any phone or tablet with a USB-C connector into a high-quality audio measurement device with the Dayton Audio iMM-6C USB-C measurement microphone. Each iMM-6C is...
Convenient mic for Room Correction
I'm using it with WiiM RoomFit room correction with an Android mobile and is recognized automatically, works and delivers on fine tuned measurements. Being small it's convenient vs other alternatives if you do not need a tripod. The box it comes with - aluminum small case with protection foam - is convenient for storage and safety of the mic itself.
Eelco R.
AUDIOPHONICS OPA1612 Dual OPA DIP8 (Unit) The Audiophonics OPA1612 operational amplifier is based on an authentic Texas Instrument 1612 chip. This OPA provides very good electrical and audio performance. It provides a...
Sounds musical and detailed
I used this opamp in a WHAMMY DIY HPA and i’m really happy with the result. I hear loads of details and with the HiFiMan HE6, the combination is very musical. Hand and feettapping is included. I haven’t used other opamps yet so no idea what it could sound like with other options but for now, this is more than good.
Denis B.
DVD / Audio CD Player USB 3.0 This high-speed DVD / CD audio player operates plug-and-play via USB-A 3.0 or USB-C 3.0 connectivity, thanks to a supplied adapter. It plays CDs and DVDs, and can also burn to...
Parfait pour le prix
Parfait pour ripper mes CD sur Eversolo DMP A8.
Connectique USB C et A.
Je retire une étoile car j'aurais aimé une sortie audio.
Paul M.
AVIS CONFORME
Pour le prix, le DAC est idéal pour obtenir une excellente sonorité de la télévision et d'un lecteur Blueray-DVD.
Paul M.
AVIS CONFIRMANT CEUX D'AUTRES AUDIOPHONIPHILES
1.- Seul inconvénient mineur : difficile à porter avec des lunettes.
2.- Casque assez hénaurme, dans le genre heaume-cinéma idéal pour regarder les Visiteurs ; plus sérieusement, on s'habitue et on savoure la musique.
3.- Une révélation : la spatialisation : l'écoute génère la visualisation des musiciens à l’œuvre, voire même des paysages d'une musique descriptive ; j'en suis venu à sélectionner les enregistrements produisant cet effet.
4.- Excellent rendu sonore, sans être fatigant.
Une découverte grâce à AUDIOPHONICS !
franck G.
transfo sur mesure réalisé pour ampli a tubes vintage
réalisation parfaite pour une cabine leslie 147. l'ampli était alimenté en 220V ce qui à notre époque en 240V surchargeait les étages en courant continu.
Avec ce transfo les tensions obtenues sont excellentes entre 235V et 240V en entrée, d'autant que le transfo est réalisé avec trois primaires 230V , 240V et 250V.
produit idéal pour tout matériel vintage
remerciements à l'équipe d' Audiophonics pour ses conseils avisés
franck G.
Jean-François A.
Fiche RCA
Fiche RCA parfaite et d'un excellent rapport qualité/prix.Trés Recommandé.+++++
Jean-François A.
Fiche RCA
Je recommandes ces fiches Neutrik Rea d'un excellent rapport qualité/Prix et absolument suffisant pour toutes les liaisons de qualité.Trés Recommandé.+++++
Jean-François A.
Cable d'enceintes
Ce n'est pas la première fois que je laisse un avis sur ce cable.Je l'utilise et le recommande à toutes mes connaissances.Cable neutre et d'un trés bon rapport qualité prix.Je le recommande particulièrement sur tout les systèmes des années 80 et 90 qui possèdent tous des cables anciens qui sont oxydés.Le système reprend une belle musicalité.Trés Recommandé.+++++
Jean-François A.
Heatshrink Braided Tubing 2:1 8mm Black This 8mm diameter heat-shrinkable Nylon braided sleeve gives your cables a clean finish. The 2:1 ratio of this sleeve means that when heated to between 80 and 120°C, the...
Gaine de finition
Cette gaine m'était incollue , c'est la première fois que je la met en oeuvre.Il y a une technique afin de bien réaliser la réduction avec la chaleur et il ne faut pas cahauffer trop sur la "couture" mais plutot sur le plat.Prix bas.Recommandé
Jean-François A.
Wiring Cable Single Strand Silver Plated OFC Copper PTFE Sheath 0.5mm² Ø1.3mm Red This wire is ideal for internal wiring on DIY projects. It consists of a 0.5mm² silver-plated OFC copper single-strand conductor. This cable is...
Cable pour cordon de modulation
Trés bon cable pour réaliser des cordons de modulation avec des fiches RCA Neutrik Rea.Prix contenu et musicalité parfaite neutre et sans outrance.Trés Recommandé.+++++
Jean-François A.
Wiring Cable Single Strand Silver Plated OFC Copper PTFE Sheath 0.5mm² Ø1.3mm Black This wire is ideal for internal wiring on DIY projects. It consists of a 0.5mm² silver-plated OFC copper single-strand conductor. This cable is...
Ce cable est excellent pour confectionner des cordons de modulation.Rendu musical neutre sans gras ni outrance dans la restitution.Trés Recommandé.+++++
Giovanni P.
bluffé par la qualité
j'étais vraiment impressionné par la qualité visuel et tactile de ces câbles. épais, robuste, fixation solide sur les sorties et entrées rca.
!!!!!! A savoir - ce sont des câbles qui ne se plient pas facilement tant qu'ils sont solides !!!!!!
Je l'utilise de mon CD Transport à mon DAC.
Giovanni P.
Je l'utilise de mon Lecteur réseau/streamer à mon DAC.
Frédéric G.
AUDALYTIC DR70 DAC R2R Streamer Roon AirPlay UPnP Bluetooth 5.0 32bit 768kHz DSD512 Black The Audalytic DR70 is a high-end network DAC designed for demanding audiophiles, combining discrete R2R architecture, advanced network connectivity, and extensive compatibility...
Son naturel (selon MOI…)
Son très décontracté avec une belle ampleur dans le bas et un haut non fatigant. Sur ma configuration un peu montante (Arcam Sa 20 et Boréa Br9 et sources ) Ça a bien calmé le jeu! sans éteindre la musique bref du tout bon pour ma part
Delacour j.
FLAGSHIP KIMBERS Speaker Terminals Pure Copper Ø15.4 x 64mm (Pair) These Flagship Kimbers  speaker  terminal are designed using high-quality materials. Their contacts are made of pure copper, while the clamping nut is made of brass...
Des borniers solides.
Une mise en oeuvre aisée: serrage parfait sur les câbles internes de mes JMlab 706 Opale, serrage aisé sur mes câbles d'enceintes...du solide et surtout des contacts en cuivre. Pourquoi se ruiner en câbles d'enceintes coûteux pour les connecter sur de la vulgaire ferraille ?
Claude D.
SILKLINE ZUKI III Balanced DAC 2x AD1955 XMOS XU208 32bit 192kHz Black The Silkline Zuki III is a balanced DAC based on a combination of two Analog Device AD1955 analog conversion chips and an XMOS XU-208 USB interface. This configuration allows it...
un super DAC très musicale.
J'ai découvert cette marque avec leur préampli dac ZUKI1, qui pour moi était de très haut niveau pour son DAC.
Avec le ZUKI3 c'est encore un cran au dessus. Fini pour moi la course aux puces AKM et ESS, J'ai enfin trouvé le DAC qui ne convient il sonne très analogique avec un grave ferme bien tenu, un très beau médium et un aigu soyeux.( J'ai un système à haut rendement, charge Onken 38 cm AUDAX, pavillon Array chambre de compression 2 pouces RADIAN 950 et un tweeter Fostex T900A en tri amplification active Ncore, préampli DIY BA2018 W.COLBRUN de l'ingénieur des préampli PASS).
J'avais écouté un DAC Accuphase qui utilisait les mêmes puces AD1955 mais que je n'avais jamais pu me payer.
Vous n'êtes pas obligé de me croire mais maintenant j'écoute de la musique et je ne me pose plus de question.
Merci AUDIOPHONICS de nous faire découvrir des produits de cette qualité.
Alexandru N.
TCS31 Review
I've never had a similar experience with any cable I've bought for audio. I knew from other reviews that this cable has a long break in time and that it may sound bad when it's new.
Well, it sounded so bad when new that I questioned my hearing and my system to the point that I even thought about giving up on hifi altogether and selling all my stuff. I'm not kidding, it was that bad. The sound was bright, flat and completely lifeless. It was a pure anxiety creating device.
After about 5 days of leaving my integrated amplifier (Nu Vista 600.2) on with this cable it suddenly came to life and now it's better than any power cable I've tried, even more expensive ones.
I'm giving it 5 stars because the end result is totally worth it, but be prepared for a rollercoaster ride in the first few days. After two days it sounded decent, but then it sounded bad again, only to settle after 5 days.
I can't even begin to understand how a power cable can do this.
Philippe d.
SMSL PL150 CD Player CS43198 Black The SMSL PL150 is a CD player based on a CS43198 DAC chip, a Philips mechanism and a PLL (Phase Locked Loop) circuit for high-quality playback and conversion of your favorite CDs.
Il n'est pas gapless
Petit lecteur très bien fini. Acheter pour sa compacité et son style. Et du style il en a. Deux reproches cependant, l'intensité lumineuse de l'écran n'est pas réglable et surtout la lecture n'est pas gapless malgré ce que peuvent dire certaines vidéos youtube. Mais pour le prix c'est compréhensible.
Merci à audiophonics pour son suivi et la qualité de l'expédition parfaitement emballée.
marc g.
ARYLIC UP2STREAM HD DAC Streamer ES9038Q2M WiFi DLNA AirPlay 2 Bluetooth 24bit 192kHz The Arylic Up2Stream HD DAC presents itself as a network player with integrated DAC, both versatile, practical and scalable, which will allow you to set up a complete and...
Voici 3 mois qu'il tourne à la maison. J'ai fait un montage tordu, puisqu'il sert de préampli à des enceintes amplifiées Beolab 8000: le 5V qu'on peut récupérer sur la carte permet d'envoyer la tension qui va déclencher les enceintes. Mais ce n'est pas son seul intérêt: les connexions sont bien plus nombreuses qu'il n'y paraît. Par exemple, j'ai ajouté l'encodeur de volume proposé par Arylic... mais pas pour ce produit. Et ça marche! Je suis ravi du résultat sonore (surtout sur mes B&O). Pleins de possibilités pour les bricoleurs.
Au chapitre des déceptions: l'afficheur vendu a part, ridiculement petit et difficile à intégrer. Le bouton de reset / changement de source situé à l'arrière: il m'a fallu le dessouder de la carte pour le déplacer en face avant. Mais au bout d'un travail acharné, le résultat est là...pour les passionnés de DIY car des appareils tout faits à ce prix, on en trouve des déjà très bien. Et c'est compatible avec les Wiim! Que demande le peuple?
Dominique R.
TOPPING PRE90 Balanced / Single-Ended Preamplifier NFCA Silver Topping's Pre90 is a high-performance preamplifier based on a fully balanced circuit and high-performance NFCA modules. It also benefits from a high quality volume attenuator...
Hautement recommandé
Après 20 ans passés avec bonheur avec un ampli intégré à lampes de 30 watts en classe A (Audiomat Opéra pour le cité, marque française) et pas mal de changements de lampes, j'ai eu envie d'un retour aux transistors. Tant qu'à faire je voulais quelque chose qui ait "du muscle" et beaucoup de transparence, quelque chose de différent. Après pas mal d'hésitations, de lectures et quelques essais heureux de ChiFi (baladeurs, DAC, ampli casque …) je me suis tourné vers le combo Topping Pre90 + Topping B200.
J'ai un test très simple pour savoir si un système me plait : est-ce qu'à l'écoute de voix féminines j'ai des frissons, suis-je ému ?
Et avec ce combo la réponse est oui, trois fois oui !
Ce combo est alimenté en amont pour la musique digitale par un lecture réseau Auralic Aries et un DAC Audiomat Tempo 2.7 et pour la musique analogique par une platine vinyle Rega P3, cellule Rega ND7 et ampli phono Primare R15, il alimente en aval une paire de Jean-Marie Reynaud Offrande V1 (impédance 4 ohms, très stable sur la plage de fréquences, je le précise car pas mal de tests des B200 indiquent qu'ils ne sont pas fait pour les enceintes dont l'impédance descendrait en dessous de 4 ohms).
Paulo D.
Paulo D.
Pas fiables
Bonne représentation musicale, un peu grasse quand même mais agréable. Le gros problème est la durée de vie des tubes ! Un an , environ 80 heures max.
Dommage
DENAFRIPS PONTUS 15TH DAC R2R NOS Balanced 1536kHz DSD1024 Black The Denafrips Pontus 15TH NOS R2R balanced dual-mono DAC represents an excellent high-end digital-to-analog conversion solution, offering ececption sound performance. Here,...
Un DAC au rapport qualite-prix extraordinaire
Le DAC est exploite principalement via son entree I2S reliee a un Streamer Metronome "Le Streamer" par un cable Tubulus Concentus V2.
J'utilise aussi l'entree Coaxiale et optique avec respectivement un lecteur de CD et un televiseur.
J'ai eu zero problemes avec toutes les entrees utilisees et les deux sorties analogiques.
La fabrication est tres soignee: L'objet est lourd et solidement construit et tous les connecteurs sont de bonne qualite.
La bande passante est etendue, l'image ample en profondeur et en largeur et la position des instruments precise.
Les basses sont tendues mais sans exces, les mediums sont incarnes et les aigus ciseles mais jamais agressifs.
Les timbres sont justes et tres tres legerement chaleureux mais ce serait tres exagere d'appeler ca une coloration.
Le DAC a pu processer tous les formats que je luis ai envoye jusqu'a 352 kHz et DSD 512 sans aucun probleme.
Il chauffe a peine et je le laisse sous tension en permanence.
La version 15 est en fait tres proche d'un Venus 12 mais vendu a la moitie du prix initial de ce dernier ce qui en fait une vraie affaire.
Daniel G.
BEATECHNIK x LHY AUDIO LPS-A6 MK2 220V Linear Power Supply Module for EverSolo DMP-A6 GEN 1 Designed specifically for the Eversolo DMP-A6 GEN 1 (Standard and Master Edition versions), the LHY Audio LPS-A6 MKII linear power supply stands out thanks to its high-end...
alim Eversolo DMP A6
livré en 3 jours top ! évolution importante sur la qualité d'écoute vraiment un bon achat
Un cable tres tres abouti a un prix contenu
Le cable est tres bien construit avec des composants de haute qualite.
Il est utilise entre un DAC Denafrips Pontus 15 et un ampli integre Pass Labs INT-60.
Il se rodera peut etre et mes impressions sont basees sur les premieres 24 heures:
La bande passante est etendue et equilibree. Il ne semble pas y avoir de frequences appuyees ou au contraire en retrait.
Les basses sont profondes et tendues mais sans cet exces qui les rendrait seches.
Les aigus sont etendus et ciseles sans aucune agressivite.
L'image est ouverte, precise et aeree.
Les timbres sont justes et les instruments et voix incarnees.
Les details sont presents sur l'ensemble du spectre mais jamais intrusifs.
Il n'y a aucun trainage mais pas non plus de hate et l'ecoute laisse une impression de plenitude.
En comparaison avec plusieurs cables cuivre OCC et Argent que je possede l'Obsidian les surpasse a moins de 3 fois le prix de certains.
michel l.
AMANERO COMBO768 Digital Interface USB 1536kHz to I2S / DSD The Combo768 is an USB audio device adapter designed for OEM applications. USB PCM audio data (2 channels) accepted as input are converted into an I2S stream or a native DSD...
Amanero 768
Pour mise à jour d'une version 384 vers une 768, interface Roon Rock, vers DAC, RAS, tout est Ok, mon ressenti, est une amélioration
Patrick G.
MUNDORF ACW105BK Wiring Cable Copper / Silver / Gold PTFE 0.20mm² The Mundorf ACW105BK is a high quality wire with a high conductivity. Thus, its conductors are made of a high purity copper/silver/gold mix and insulated by a PTFE sheath. This...
tres bonne conception
Abdoulaye D.
Soudure
Merci à l‘ensemble de l‘équipe AUDIOPHONICS.
Respects mérités.
Abdoulaye D.
CWS1 3-in-1 Cutting / Stripping / Cramping Pliers The CWS1 3-in-1 pliers have 3 functions. It will enable you to cut, strip and crimp cables.
Pince 3 in 1
Respects mérités.
Abdoulaye D.
Pince 2 in 1
Respects mérités.
Abdoulaye D.
Câble Symétrique audio
Respects mérités.
Marc D.
Vivement recommandé!!!
Câble de très haute qualité, construction qualitative et solide, résultat sonore exceptionnel pour un prix archi contenu.
Merci aussi à Audiophonics pour le sérieux et la rapidité du suivi de la commande.
Jesse D.
FX-AUDIO DS07 Balanced DAC ES9068AS XMOS XU216 Bluetooth 5.1 QCC5125 LDAC 32bit 768kHz DSD512 MQA FX-Audio unveils its DS07 balanced DAC, a compact, high-performance device with an original appearance. FX-Audio's DS07 is made from a complete range of...
Pas au point ! … dommage :(
Avis technique (objectif):
- on entend très clairement le cliquetis intempestif des relais liés à la 'programmation' de la puce de contrôle.
Leur remplacement par des 'dispositifs à puces' offrant la même fonction doit être sérieusement envisagée par le constructeur en proposant une révision de cet appareil.
La lecture de fichiers en conservant le format DSD est impossible avec 'Music Bee': cela doit pouvoir être corrigé via une révision du firmware (peut-être ?).
Vraiment très regrettable car aucun bruit de 'POP' n'est émis par cet appareil quelque soit le 'cas de figure' en utilisation, ce qui est un point très positif puisque nombreux appareils même bien plus récents et/ou onéreux ont ce genre de problème.
Avis personnel (subjectif):
Le rendu sonore de cet appareil est bien moins 'bon' qu'avec un TOPPING E50 et l'écart se creuse encore plus par rapport à un TOPPING DX5 qui utilisent tous deux le même type de puce SABRE ES9068AS (le DX5 en à 2).
En résumé;
Une 'révision' (modèle corrigé) de cet appareil doit être réalisée par le constructeur pour que cet appareil soit une option d'achat envisageable et intéressante auquel cas cet appareil restera plutôt une option a éviter selon moi…
La lecture DSD fonctionne parfaitement avec Foobar par exemple.
José M.
Pour une salle dédiée
À noter l'excellent prix du site Audiophonics, et la rapidité de livraison ! Le Dayton est installé sous un lourd canapé 2 places. Il est alimenté par un ampli QSC USA 900. Le résultat est bon, me reste à affiner pour optimiser. Bien content de det achat !
Je pense toutefois qu'il faut un ampli puissant pour l'alimenter...
Jean-Marc L.
JANTZEN AUDIO CROSS-CAP Capacitor 400V 8.2µF Jantzen Audio Cross Caps MKP 400V are considered the best value for money for the design of passive crossovers for loudspeakers. Made in Europe, this new competitor of the...
Qualité européenne et bon rapport qualité/prix. Envoi rapide et sans délai
Ont remplacé les SCR PZA de mes enceintes, kit Audax BEX 40 vieilles de plus de 40 ans.
J'ai choisi les Jantzen Audio Denmark Cross-Cap pour un compromis qualité et utilisation dans un système vintage. Origine européenne, à défaut d'être française.
J'en suis très satisfait.
Bravo pour la réactivité Audiophonics. Envoi très rapide et sans délai, emballage optimisé. Que du bon.
Jean-Marc L.
JANTZEN AUDIO CROSS-CAP 001-0269 Capacitor 400V 16µF Jantzen Audio Cross Cap capacitors offer a high level of performance and quality at a very reasonable price. This is a versatile model, using metallized polypropylene foil.
Jean-Marc L.
Fabrice H.
Ampli à tube
Remplace avantageusement des MKP basiques montés en inter-étage pour un cout raisonnable.
Médium-aigu plus clair, plus aéré. Voix et instruments plus naturels.
Je conseille
Dominique R.
TOPPING EXT90 Input Extension for Topping PRE90 / A90 DISCRETE Silver The Ext90 is a device to be associated exclusively with the Topping Pre90 and A90 Discrete, allowing these to enjoy more inputs. Thus, by combining the devices, you have two...
Dominique R.
TOPPING B200 Power Amplifier Mono Discrete 200W 4 Ohm Silver The Topping B200 power amplifier is a mono amplifier based on a discrete-component NFCA amplifier circuit. This enables it to achieve a considerable power level while...
Marc J.
Clip for Speaker Front Panel Attachment Metal (Unit) This clip will allow you to simply and efficiently attach the covers of your speakers to the front panel.
Attention au inserts plastique ; percer à 11mm, sinon avec un perçage de 10 les clips s'écrasent et les picots acier ne rentrent plus.
Thomas R.
DAYTON AUDIO DC250-8 Speaker Driver Woofer 70W 8 Ohm 88dB 25Hz - 2500Hz Ø25.4cm The Dayton Audio DC250-8 woofer is ideal for integration into a 2 or 3-way speaker system. It offers an excellent price/performance ratio, with very good sound performance,...
Impressionnant
Après avoir tenté de sauver mes HP Seas vintage de toutes les manières sans succès (Bobine endommagée) je me suis résolu à tester ces dayton Audio "pour voir ", et j'ai été agréablement surpris du rendu. Le rodage n'est pas encore passé mais je suis déjà bluffé sur les premières heures d'écoute. Le profil est bien plus "sec" sur le papier mais à l'oreille j'ai été scotché Wow. Même sur des styles modernes il descend très (très) bas sans broncher. Hâte de voir rodage Fini mais je suis déjà conquis.
Patrick R.
Satisfaction totale
J’ai eu pas mal de DACs dans des gammes de prix très différentes, purs FPGA, Sabre, AKM, et R2R.
Je trouve que le Cyan2 propose un produit plus que convaincant par son côté naturel et très équilibré du grave à l’aigu. Certains DAC iront probablement plus loin dans l’ouverture et la définition mais la musicalité du Cyan2 au prix proposé est particulièrement captivante. Une écoute fluide, naturelle, douce et très subtile. J’adore!
philippe B.
Qualité correcte, prix correct, facile à souder et à mettre en œuvre.
philippe B.
dominique w.
Indispensable à toute installation !
On connait l'importance des câbles en audio. Indispensable pour une parfaite alimentation de la section Hifi. Créer une ligne dédié avec sa propre ligne de terre, isolée du reste est LA VRAIE solution. Grâce à cet excellent câble trés technique en réalité en cuivre OCC (affiché OFC) utilisé dans les domaines industriels sensibles, c'est possible de par son prix contenu. Pas besoin de boiboite magique, de conditionneur, de filtre trés couteux ou de câbles à 1000E Aprés une période de rodage de 2 mois environ sur une installation ou chaque appareil est déjà équipé de câbles spécifiques (Cuivre OCC, Prises cuivre plaqué DIY à quelques dizaines d'Euros), les performances du système sont transcendées.
dominique w.
Spike Pad Stainless Steel 40x12mm (Unit) This Ø40mm 304 stainless steel spike pad is designed to absorb vibrations from your HiFi equipment, reducing resonance effects and giving a cleaner sound reproduction....
Trés bien
Large, lourd et doté d'un revêtement anti dérapant dessous. Tout ce qu'il faut pour parfaire le découplage acoustique de l'enceinte. Le prix est excellent compte tenu de la qualité. Cerise sur le gâteau, chaque pièce est soigneusement emballé dans une boite individuelle, presque comme un trésor.
