Martin Å.
Great for the price!
Zacharias L.
Very good but...
Pavol B.
Peter R.
EXICON ECX10P20 Transistor MOSFET (2SJ162) Exicon MOSFETS have been specifically designed for high power linear use. They offer high voltage capability, high slew rate and low distortion, making them the ideal choice for...
replacement type
I used the ECX10P20 transistor as a replacement for the discontinued SJ162 transistor to fix a problem with our power amplifier in the KS SAT MKII PA system. It works perfectly without any circuit modifications.
Delivery was prompt.
Many thanks to Audiophonics. A reliable company.
Replacement type
Peter R.
EXICON ECX10N20 Transistor MOSFET (2SK1058) Exicon MOSFETS have been specifically designed for high power linear use. They offer high voltage capability, high slew rate and low distortion, making them the ideal choice for...
replacement type
I used the ECX10N20 transistor as a replacement for the discontinued SK1058 transistor to fix a problem with our power amplifier in the KS SAT MKII PA system. It works perfectly without any circuit modifications.
Replacement type
Remus C.
FX-AUDIO DAC-A10 DAC ES9018K2M Tube Preamplifier 6N3 Bluetooth 5.1 aptX HD LDAC 24Bit 192kHz FX-Audio's DAC-A10 is a versatile, high-performance tube DAC/preamplifier with a relatively compact form factor. It is based on quality components such as an ESS ES9018K2M DAC...
Rapport qualité prix imbattable, la qualité d'écoute sera au rendez vous à seule condition de changer les tubes chinoises fournies par des tubes russes série militaire, la différence tant vraiment notable. Fabriqués selon des cahiers de charges plus exigeantes au niveau endurance, les tubes russes série militaire 6N3P-E (6Н3П-Е) chauffent moins. La puce de réception Bluetooth 5.1 QCC5125 de chez Qualcomm qui permet au DAC-A10 de supporter les codecs Bluetooth haute résolution : SBC, ACC, aptX, aptX LL, aptX HD et LDAC est un plus. Ecoute sur casques Sennheiser HD 650
Gabriel G.
LHY AUDIO LPS50VA Linear Regulated Low Noise Power Supply 230V to 5V 2.5A 50VA Here's a stable, regulated linear power supply for any high-quality audiophile DIY project. All the necessary technical refinements are incorporated in this power supply...
Alimentation linéaire
Amélioration par rapport à ma précédente alimentation linéaire. Je l'utilise pour alimenter un rpi5 (6.5A 5V)
Mikael M.
HIDIZS MP145 In-Ear Monitor IEM Planar Magnetic 30 Ohm 104dB 20Hz-40Hz Titanium The HIDIZS MP145 in-ear monitors are IEMs with an ultra-wide 14.5mm planar magnetic driver. They feature an audiophile design with no less than 7+7 N52H magnets. In terms of...
Duo mp145 & Penon audio liqueur O
Ne sous-estimer pas ces écouteurs ! Une foi trouvez les bon emboue , le son est énorme !
J'ais essayé les Dunu S&S ... La bass n'est pas de trés bonne qualité ...
Penon liqueur B .... Boff
Penon liqueur O : Excellant !! Spécialisation , bass , sous bass ( infra ) pur ! Avec filtre gris ( équilibré ) , il est muni de filtre rouge pour encore plus de basse .
En comparaison avec les Focal Elegia , hifiman Arya , Dt 900 x rien ne m'a procurer du plaisir ,
le mP145 et Penon O est mieux pour moi .
Seul le EMU TEAK est aussi bon en basse fréquence ... Et apporte également une meilleur image et scene sonore ... En revanche , l'Emu est moin vif , moin dinamique ( plus doue ) .
Le planaire du hidizs lui donne certaine avantage .
Source qobuz + UAPP en mode Bit perfect + Aune Yuki + topping NX7 .
Ne compté pas en retiré le meilleur de cette écouteur avec un simple d'ongle . ( 30 ohms )
Samu T.
Difficult solder
Difficult solder coax cable ground to that wide tiny hole. Plug is not attractive to magnet and that is very good.
PIERRE R.
XANGSANE XS-5N Banana Speaker Cables OCC Copper Silver Plated 2m (Pair) Xangsane's XS-5N speaker cables are made up of 12 strands of silver-plated 5N single-crystal OCC copper to ensure electromagnetic impermeability and perfect conductivity. Each...
câble xangsane XS-5N
Excellent produit qui donne une reproduction remarquable du grave à l'aigu avec de la dynamique et de la précision . C'est mon meilleur à ce jour !
Kimmo A.
Great
Works great, good value for the price.
Jean-Pierre f.
AIYIMA T9 Amplifier TPA3250 Tubes 2x 6K4 Bluetooth 5.0 2x60W 4 Ohm The Aiyima T9 is a versatile and affordable integrated amplifier, ideal for setting up an audio system without breaking the bank and without multiplying the number of devices....
perplexité et mise en garde
Une seule étoile car j'y entends plus d'inconvénients que de plaisir, même à ce petit prix.
D'abord, le plus gênant, c'est ce volume sonore quasi incontrôlable à l'écoute de la plupart de mes CDs et flac, mes 2 principales sources de musique. Aiyima me dit qu'il n'y a pas de mise à jour possible sur le fait que l'avant-dernier cran du volume sonore reste trop élevé. Un cran de plus, et le son est coupé. La seule façon d'y remédier est de passer par l'ordinateur, où il faut y baisser le son interne pour pouvoir ensuite contrôler celui du T9, dommage. Ce "détournement" permet quand même de profiter des radios internet via l'ordi ou de Youtube par exemple.
Autre inconvénient, ce clic intermittent et récurrent dès qu'on laisse en veille le T9, qui signale sa mise en pause. Il est léger mais vraiment pas indispensable.
Enfin, il faut absolument changer les tubes et utiliser un DAC externe pour obtenir un son plus acceptable. Malgré cela, la stéréo reste simplement confinée dans les enceintes, sans réelle scène sonore.
Bref, je ne le recommande qu'à certaines conditions d'utilisation et d'exigence musicale.
Pascal G.
Hélas mitigé.
L'appareil en soi est très bon. Construction irréprochable, son à l'avenant, connectique complète.
Malheureusement, pour moi qui écoute beaucoup de SACD, cet appareil n'est pas adapté à cet usage car je n'utilise pas de préampli et donc le réglage du volume sur le DAC est primordial, ce que ce D2R n'est pas en mesure de faire.
En effet, malgré le paramètre PRE MODE sur variable, le volume avec un stream DSD est irrémédiablement réglé à 0.0db, c'est à dire sortie à fond sur mes blocs de puissance ce qui a failli faire sauter mes enceintes.
J'ai contacté SMSL Chine et j'ai reçu la réponse suivante, je vous la livre telle quelle (littéralement) :
"The DSD of D2R cannot control the volume. It is Normal, there is a chip issue". Sans plus de formes.
Ceci est non seulement extrêmement malpoli mais surtout totalement inacceptable d'autant moins que nulle part ce défaut n’est indiqué, ni dans le marketing ni dans la notice sous forme de mise en garde vu les implications potentielles léthales pour vos HP. Que le circuit intégré ne fasse pas le job est une chose, ne pas prévenir le futur acheteur de cette situation en est une autre.
Bref je suis mitigé et ça m’embête car le son en PCM (NAS, Qobuz, transport CD) est vraiment excellent, surtout à ce prix.
J’ai deux autres DAC SMSL, M400 et M500, au demeurant excellent eux aussi. Les deux convertisseurs ont toujours fonctionné sortis de leurs boites sans rechigner et avec tous les formats d’encodage disponibles. Là ce n’est pas le cas et j’en suis navré puisque forcé de le retourner.
5 * pour tout sauf pour la conception (1 *) clairement baclée et la mésinformation inexcusable et dangereuse pour l'équipement.
on a pas sur les mêmes finitions ou design que d'autres connecteurs plus chers mais le rendu sonore est au mois aussi bon voire plus naturel pour 3 fois moins cher...
Olivier L.
L'ampli idéal
J'ai eu pas mal d'ampli et souvent pas 100% satisfait mais là j'ai été convaincu dès les premières écoutes. Le son est fantastique tout simplement.
Autant j'ai été déçu par un ampli comme le topping LA90, qui a de bonnes mesures mais est pouratnt très mauvais à l'écoute.
Je n'ai pas encore le comparer à mon ampli de référence mais je suis super content. J'ai l'impression qu'il est diffcilie de trouver mieux à ce prix.
Marc F.
Super sauf l'alim
Excellent petit ampli, pratique et quasi. Mais l'alim à découpage fait du bruit, j'envisage de la changer pour une autre.
Catalin C.
Incredible
I was a cable skeptic, thinking that a decent cable is more than enough for my KSE1200. I bought NEMOI 1220 cable out of curiosity mainly, after seeing all the reviews here.
Oh Boy, I wasn't prepared for all the changes I've got: more details, fuller and lusher (!) sound with better soundstage. Nothing like what people say about silver cables.
It's true that my previous cable was way cheaper, made with DCA16GA, but still, it's just a cable...
I'm impressed, I wish I tried this cable before.
Thank you audiophonics and to all those who post their reviews.
Impressionnant !!
Dans le cadre d’une évolution progressive de mon système en 5.2 Je viens de m’équiper de 2 bloc mono LPA-M750ET (1ET9040BA) qui sont branchés sur les sorties Pre-Out d’un Yamaha RX3060 (qui a terme sera remplacé par un préampli multicanal plus performant). Mes enceintes principales un peu exigeante (Panneaux Magnepan 1.7i) étaient depuis quelques mois alimentées par un HPA-S500ET (1ET7040) qui déjà m’avait bluffé, mais là avec les 2 bloc mono (choisi pour des questions d’intégration plutôt que la version double mono qui doit avoir le même rendu sonore j’imagine). C’est une autre dimension, séparation des canaux, profondeur, très analytique, je redécouvre quasiment toutes les prises de son. Le réglage du gain est un plus incontournable pour pouvoir associer ces amplis avec les sorties pré out du Yamaha. Le HPA-S500ET est passé sur les enceintes arrière (JMLab Micron Titane) ça les a bien réveillés ! Prochaine étape un bloc mono pour la voie centrale (Dynaudio Gemini). Merci à Audiophonics pour les conseils et rapidité d’expédition.
Pavel Z.
AV
I will write one review for all ordered goods.
I appreciate a very good approach to the customer in an effort to help in every situation. Very good communication, responses to questions come almost immediately. Thumbs up. I believe that such an approach is standard.
Goods: I ordered the brand of goods on recommendation. I think it's OK.
Max Michel D.
EXCELLENTE QUALITE POUR AUDIO
Cette soudure est vraiment TOP pour faire vos cables audio.
Qualité d'écoute au rendez-vous sur vos cables.
Max Michel D.
EXCELLENT
Connecteur RCA/BNC de grande qualité
Ecoute parfaite sur branchement sur convertisseur
Hugo Darien O.
good
after weeks i feel the signal is to bright
Pavel V.
Balanced Interconnect Cable Jack 6.35mm TRS Male to XLR 3-Pole Male OFC Copper 75cm (Pair) These affordable cables are balanced male Jack 6.35mm TRS to male XLR 3-Pole interconnect cables. They are shielded and the conductors are made of 99.99% pure 4N OFC copper for...
Solid cables
Solid and well-looking cables for balanced interconnection at a good price.
Pavel V.
Excellent amplifier
- the power supply produces a very slight high-piched noise (~4kHz) that can be noticed from a 0.5-1m distance (or more) in silent environment (esp. from behind) ; the sound is different when the amp is off and when it is on (NC252M-based amps don't do this)
- if you plan to use the RCA inputs, expect sensitivity to ground-loops, esp. if you have a more complex sond system; if it includes a USB device (e.g. a DAC), you may need a proper USB isolator (a cheap one based on Adum3165 is just good enough)
- it is a pity that the XLR and RCA inputs cannot be switched remotely via some extension or upgrade; just some connector/header bypassing the mechanical switch would be very useful for a DIY implementation using relays
- ideally, remote switching of the gain (e.g. depending on the selection of the XLR or RCA input) would be fantastic (but possibly too complicated)
Pavel V.
AUDIOPHONICS HPA-H250NC Power Amplifier 6 Channels Class D Ncore NC252MP 6x250W 4 Ohm The Audiophonics HPA-H250NC is a 6-channel Class D power amplifier based on three Hypex NCore NC252MP modules. This version is aimed in particular at audiophiles and home...
Excellent amplifier
Excellent amplifier. The only missing features are switchable RCA inputs and possibly adjustable gain (but that would be probably complicated and significantly more expensive with NC252MP modules).
André A.
Exceptionnel
Je viens enfin de brancher mon ampli de puissance. Après avoir attendu le temps de chauffe nécessaire, c'est une révélation. J'ai l'impression d'avoir de nouvelles enceintes. Je découvre le potentiel de mes Triangle Esprit Antal EZ, grosse montée au niveau des basses, impressionnant, un caisson de basse s'avère inutile. Mon ampli Yamaha RN1000A se concentre sur les médium haut et sur les aigus.
Pour info, suite au conseil donné ( merci encore aux équipes d’Audiophonics, technique et réactif) j'ai réglé mes curseurs sur un gain de + 29dB pour avoir le même niveau de volume.
Efthymios X.
NEUTRIK NC4FD-LX-B Female 4 Pins XLR Socket Gold Plated This Neutrik NC4FD-LX-B base, belonging to the DLX range, has 4 poles with gold plating and a metal body. The DLX range offers compact connectors with ground contact, allowing...
As expected, good for its price.
Efthymios X.
The typical furutech quality, nothing to add.
Jean-Louis L.
Audiophonics a largement dépassé mes attentes en assistance et conseils, sans parler de sa réactivité et de son amabilité. WIIM Mini m'apporte exactement le service espéré avec une belle efficacité, Acheter cet équipement chez Audiophonics c'est top, merci pour tout !
VINCENT N.
Très bon transfo
J'avais commandé 2 transfos. Celui-ci comme l'autre respire la force tranquille. Très bonne construction, les fils de sortie sont d'un bon diamètre, les bouts sont bien étamés, les tensions aux secondaires sont identiques. Entièrement satisfait de mon achat.
VINCENT N.
Ce transfo respire la force tranquille. Très bonne construction, les fils de sortie sont d'un bon diamètre, les bouts sont bien étamés, les tensions aux secondaires sont identiques. Entièrement satisfait de mon achat.
François C.
LHY AUDIO LPS160VA 19V Linear Regulated Low Noise Power Supply 230V to 19V 7A 160VA This LHY Audio LPS160VA regulated linear power supply provides great stability for any high-quality audiophile DIY project. All the necessary technical...
indispensable
Installation sur un Mini PC I9, elle a remplacé l'alimentation d'origine haut la main et contribue au silence électrique de la sortie USB et réseau du logiciel HQPlayer.
Quelque peu imposante tout de même...
Gurhan O.
5239
Happy with the result. Need another 3m piece
Rossano F.
Tubes préamplification
Après l’achat de 4 tubes Golden Lion KT 88, j’ai acheté 2 tubes de la même marque pour la preamplification de mon amplificateur à tubes Fezz Titania !
Les graves sont plus profonds ! Les médiums plus clairs et les aigus plus fins !
Je suis très satisfait de cette évolution et je recommande audiophonics pour sa qualité de service et ses prix concurentiels…
Martynas D.
Topping E70 velvet
In my opinion, the product is well made and works fine. Would not hesitate to purchase a second unit if needed.
Shop experience is excellent, bought from the shop multiple times.
Bruce M.
Excellents résultats
Acheté en remplacement d'un Bluesound Node de 2016. Très satisfait du rapport qualité prix : amélioration nette de la qualité audio et bonne qualité de fabrication et de finition. Nécessite juste quelques connaissances très basiques pour accéder à l'interface utilisateur (expliqué dans le manuel) et sélectionner le mode de transmission réseau. Utilisé sans problème avec Roon (code livré avec l'appareil pour 2 mois gratuits) pour transmettre depuis Qobuz vers un DAC externe en utilisant la sortie SPDIF avec connexion RCA. Egalement testé avec câble USB. Testé également en mode UPnP avec logiciel Audirvana mais des problèmes de bruits blancs lors des changement de fréquence ou de bits dans la numérisation entre les fichiers : problème non résolu avec l'assistance technique Audirvana. Donc au final, utilisé avec Roon en attendant peut être la mise à jour du RED pour gérer Qobuz Connect.
En transport réseau (sans DAC interne donc), je crois que c'est parmi les meilleurs appareils dans cette gamme de prix et il bénéficie d'excellentes critique sur le Web. J'envisageais initialement un Lumin U2 (5000 €) mais je ne regrette pas du tout mon choix au final !
câble équilibré, naturel, sans acidité, juste parfait. Entre mon DAC et mon intégré Il est équipé des xlr eizz ez-206, j'ai rien entendu d'aussi naturel. En fait, je crois que c'est la 1ere fois que j'ai l'impression d'écouter la musique sans "entendre" le câble.
Excellente découverte, tout comme le cable secteur de la même marque NEP-3003G. J'ai équipé le dac avec ce dernier et rien a redire, ça le fait.
Cable dac
Equipé de fiches cuivre plaquées or, excellent rendu sur mon dac, c'est naturel, équilibré et ça respire. J'ai préféré ce câble à d'autres en raison de son prix raisonnable, je suis agréablement surpris.
Pas rodé et c'est déjà trés bon. Excellent rapoort qualité prix.
Dominique O.
5 étoiles - très bonne qualité
ai monté ces câbles sur des fourches plaquées or avec soudure à l'argent des embouts ; (sur tubes ampli de puissance KT88)
anciens câbles 2,5 carré ; nouveaux Elecaudio 5,1 carré ;
résultats :
- ciselé des médiums aigus complètement différent (amélioré) ;
- transitoires d'attaque améliorées ;
- basses généreuses sans être floues ;
par contre, étonné d'avoir rencontré un phénomène de rétractabilité de la longueur : sur les 3 m commandés je n'ai reçu que 2m80 , ce qui a rendu le raccordement des H.P. délicat à effectuer !
est-ce dû au transport par poste  ?  ??
Philippe S.
DIY OEUF JMLab/hp Atohm
Utilisé pour modifier des "oeufs" jmlab en plâtre en enceintes bass reflex avec des haut-parleurs Atohm Absolute Séries (kit EURUS E-5). Adaptation de l’évent parfaite.
Jerome C.
Copper / Silver Wiring Cable 4mm² PTFE Sleeve Ø3.6mm Red This 3.6mm diameter cable has a single 4mm² conductor made of Silver plated OFC Copper. This provides excellent signal conductivity while providing the conductor with high...
En alimentation secteur, performant mais rodage très long.
J'ai utilisé ce fil de câblage pour recâbler une barrette secteur que j'ai optimisé , amortissement, câblage interne, filtrage passif.
L'écoute se fait au casque Sennheiser HD 600, Focal Clear , lecteur streamer Atoll ST 300 et ampli casque Sennheiser , donc l'acoustique de la pièce n'intervient pas.
Pour bien saisir le "gain" du bloc secteur, son cordon secteur est absolument basique, cordon générique 3 X 1mm2 de même pour les appareils.
C'est un fil de câblage qui fait très "premium" avec un PTFE très fortement serré sur un multibrin dont le placage argent, de bonne qualité ne se fait pas la malle lors du serrage sous vis.
Il nécessite un très long "rodage" comme il est coutume de dire dans le milieu audiophile , et je dois avouer que j'ai traversé des doutes avant que ce câblage se "réalise" enfin, il ne se passait rien même à 30 heures, comptez 60 heures.
A 60 heures l'écoute s'assouplie enfin car au début c'est dur et très "dans la face" donc pas écoutable, par contre ça devient bigrement intéressant à 60 heures avec un équilibre qui ne pêche pas par un aigu insistant (c'était ma crainte avec le placage argent )
L'ensemble est plus clair par une sensation de transparence accrue, clair mais pas maigre car du grave au médium la matière est là.
Le grave est très lisible, il plonge bas et donne une tension et articulation qui apporte au réalisme, on retrouve cette sensation sur les cordes de guitare.
Je gagne en transparence et les timbres se réalisent mieux, sur les voix c'est également tout bénef.
En fait les contours sont plus nets sur l'ensemble du message.
Les détails sur les fréquences aigus sont plus évidents.
Je pense qu'à la base le match de mes appareils est bon, donc il est possible que ça ne colle pas sur un match déjà limite sur l'aigu.
60 heures de rodage propose une restitution encourageante, je mets un léger bémol car j'attends encore un peu + de souplesse à l'écoute , je fais confiance au commentaire de notre ami anglais, ce câblage devrait se bonifier encore ....
Gérald F.
Transfo sur mesure
Top produit !
L’attente est longue mais ça vaut le coup !
VIABLUE T8 SOLDER Gold Plated RCA Connectors Ø9.5mm (Pair) These RCA T8 Solder connectors from Viablue feature a high quality design. They feature 24k" gold-plated contacts for enhanced conductivity and...
Très bien !!
Fiches utilisées pour monter un câble numérique blindé en argent pur monobrin Xangsane XS-1001Ag diamètre 9mm.
Très bien au niveau des soudures et des vis qui bloquent bien le câble.
Il a fallu que je frotte avec du papier de verre pour réduire le diamètre de la gaine du câble Xangsane qui est un peu trop épaisse et la rentrer avec de la vaseline, les fiches n'y sont pour rien.
Top livraison Audiophonics !!
Hugues E.
AUDIOPHONICS GXDC-25 Power Cable Jack DC 5.5/2.5mm to GX16 OFC Copper for LHY Power Supplies 1m This Audiophonics power supply cable, assembled in our workshop in France, is composed of a Jack DC 5.5/2.5mm connector and a GX16 connector. It can only be used with LHY power...
Câble secteur DC
Apporte un vrai plus , plus d’ouverture , scène plus ample , pas d’agressivité ni effondrement de la dynamique, un petit rodage et que du bonheur
Olivier b.
Interconnect Cable Female XLR to Male XLR Gold Plated 1.31mm² 7.6m This XLR female to XLR male modulation cable offers very good performance at a low price. It has a conductor cross-section of 1.31mm², is shielded and has gold-plated...
Câbles achetés il y a quelques temps car mon préampli hifi est positionné sur le côté de ma salle et assez éloigné des amplis (blocs monos). La qualité de fabrication est excellente, les câbles sont souples et facile à mettre en oeuvre, les fiches XLR robustes. J'ai eu l'occasion de les comparer avec des câbles 1er prix et il n'y a pas photo, le son est très nettement meilleur. Je craignais vu la longueur de perdre en détail et d'avoir du souffle par rapport à des RCA plus courts... il n'en est rien, aucun souffle y compris avec un pré ampli à tubes (bien entendu cela dépend du matériel) et la restitution musicale est top. Je recommande ce produit sans réserve, en remerciant Audiophonics pour assurer une logistique parfaite et ce depuis des années.
Vincent M.
Niveau bien lisible de par sa taille. Prix très correct. Top !
Vincent M.
Parfait. Qualité prix impeccable. Content de mon achat.
Nicolas D.
qualité de son et belle facture
Taille réduite, esthétique sobre, très silencieux en fonctionnement, mais surtout excellente qualité sonore.
Je ne l'utilise qu'en transport et non en Ripper.
Chose curieuse : je préfère la connexion en USB-C sur un Dac plutôt que le coaxial : la différence est audible.
La télécommande "texturée" est jolie et agréable à l'usage.
Seul bémol : une fois le CD inséré, lenteur pénible avant de pouvoir lancer la lecture. Également : pas d'alimentation fournie.
Je ne regrette absolument pas pour autant !
Vincent B.
SHANLING CR60 CD Player Ripper Sanyo HD850 Silver With its CR60, Shanling unveils a relatively compact, space-saving Audio CD player/ripper. The CR60 is based on a Sanyo HD850 laser head and a Philips drive mechanism for smooth...
Transport CD compact et performant
Super appareil !
Lecture performante, bruit de lecture très faible, super connectique, la télécommande pratique, pas grand chose à lui reprocher...
Le seul défaut : l'accessibilité au bouton de passage vers le mode "ripper"... mais c'est pas le fonctionnement quotidien pour cet appareil.
Une petite rallonge usb-c règlera le manque d'accessibilité à la prise usb.
Pour ceux qui veulent un appareil compact pour lire leur CD-thèque, ne dépensez pas plus !
Nicolas D.
Très agréablement surpris
Premier achat sur ce site.
Connecté à des enceintes DIY de 30 ans dont je n'arrive pas à me lasser (base Seas speakers). D'abord surpris puis bluffé par la limpidité du son : aucune agressivité, détail et rendement important.
Connectique de très bonne facture. Esthétique sobre comme j'aime. J'hésitais avec le 2x500 w mais la puissance est très suffisante.
Bref : je recommande. Vivement !
Eemeli T.
DAYTON AUDIO MX10-22 Speaker Driver Subwoofer 400W 4 Ohm 86dB 25Hz-500Hz Ø25.4cm Designed to produce maximum output at an unbeatable price, this MX10-22 Max-X dual voice coil subwoofer from Dayton Audio has all the features you'd expect from a...
A great driver with a couple of caveats
Sonically and aesthetically MX10-22 performs well - a powerful motor, large double voice coil, nice looks and high excursion capabilities make this a good choice. I'm running two of these with a 350WPC class-D PA-amp in 60-liter reflex enclosures tuned to about 23Hz, and they perform beautifully both in listening to music and when watching movies.
The caveat considers part of the structural design of MX10-22. Binding posts on the driver (which are of nice quality) are placed so wide and up on to the basket that they make installing the driver into an enclosure very hard, especially if the baffle of the enclosure is thick - you cannot just drop it into place and be done with it. I had to bend the binding posts downward as much as I was able to, and to carve two slots into the mounting hole for the posts AND to work the driver into the mounting hole at an angle to get it in. In my case the front baffle of the enclosure is 40mm thick.
Other than that, this is a great driver especially considering the price.
Denis E.
Que demander de plus ? Parfait rapport Q/P !
Bel aspect qualitatif, facilité de soudage (effectivement l'isolant ne fond pas) et serrage du contact parfait (bien serré mais en restant souple sans blocage).
Pour finir je suis satisfait du son : utilisé avec une platine vinyle Audio Technica AT-LP 2022 ça fonctionne parfaitement.
Rob W.
RAMM AUDIO S8MC Interconnect Cables RCA OFC Copper 1m This RAMM Audio S8MC RCA-RCA modulation cable offers good quality at a very affordable price. The cable conductors are single-stranded OFC copper. The cable features an aluminum...
Good value for money
Excellent quality RCA to RCA cable, with directional arrows. I would buy again.
