Adam K.
Holo Cyan 2 - wysyłka do Polski
Na początku kilka słów o samym zakupie. DAC został bardzo szybko wysłany, był dobrze zabezpieczony i dotarł bez żadnych...
Francois P.
J'ai associé ce préampli avec l'ampli de puissance AUDIOPHONICS LPA-S450ET et j'avoue que je suis séduit par le...
dominique w.
Qualité apparente des connecteurs. Câble trés souple. Permet avant tout de profiter des bénéfices d'une liaison symétrique...
Customers reviews - There are 21106 reviews.
Excellent Coaxial
Excellent Coaxial rien de plus a ajouter
sebastien f.
Le fichier de calibration permet d'avoir des mesures au top, ainsi vous pouvez parfaitement corriger vos enceintes.
j'ai bien aimé le support micro fournit, ça évite de poser le micro par terre pour mesurer vos caissons de basses
Balazs L.
ASCILAB F6B Bookshelf Speakers 125W 4 Ohm 84dB White / Black (Pair) The AsciLab F6B are passive bookshelf speakers offering precise, powerful sound reproduction in a compact format. These 2-way speakers feature a 1“ aluminum dome tweeter...
A pair of speakers for sever consideration
Even after the very first days of use, I can state that these are superb speakers.
My listening room is relatively small, some 15 sqm only, so my setup is a near-field one. These speakers provide crystal clear stereo presentation with all details of the recording presented. The soundstage is solid and layered. Even of much played recordings the Ascilab could reveal new details.
The obvious point of comparison, is the pair of Quad S2 speakers I have used until now. They were highly acclaimed upon their debut, and were serving for my satisfaction as well. However, in terms of sound quality the Ascilab is simply a player of a much higher league.
All in all, I just can recommend these speakers for smaller room use without any reservation.
Bertrand L.
TOPPING CENTAURUS Balanced R2R DAC XMOS XU316 Bluetooth 5.1 LDAC PCM 32bit 768kHz DSD512 Silver Topping has collaborated with Holo Audio to design its new Centaurus balanced R2R DAC. This new high-performance device is based on the use of an ALTERA MAX II CPLD and no less...
Topping centaurus
Après une trentaine d'heures de rodage le son s'est épanoui progressivement ! Timbres réalistes avec beaucoup de naturel ! Je suis ravi ! Mon système est plutôt exigeant : Mastersound compact 845 associé à une paire de Kornhent ! Le centaurus est associé à mon petit wiim pro plus !
MASSIMO P.
AUDIOPHONICS CANARE Digital Coaxial Cable Ultra Coax 75 Ohm BNC-BNC 1m This Coaxial Ultra Coax 75 Ohm cable with male BNC connectors is assembled in France by Audiophonics, with top of the range components from Canare. This includes an ultra...
Top quality , audio band ends very controlled , perhaps the sheath is too stiff
Christian M.
FIIO SR11 Streamer WiFi Airplay Roon Ready 32bit 768kHz DSD256 Silver FiiO's SR11 network player is a compact, high-performance streamer designed to work in conjunction with the K11 DAC/headphone amplifier. Based on an X2000 processor, it is...
Rapport qualité/prix fantastique
Pour les possesseurs de la licence Roon, ne chezchez pas plus loin, mode Roon exclusif....branché sur une petite Powerbank (le Fiio consomme 3 fois rien), le résultat est splendide....rapport qualité/prix exceptionnel !!
(pour info, Fiio branché sur un très gros système multi-amplifié)
Eric K.
ampli de puissance
Parfait pour mon utilisation avec des enceintes Klipsch de 85W et un lecteur réseau Eversolo. Beaucoup de transparence. Basses et aigus très nettes ! Merci !
Marc W.
Excellente alternative
J'ai acheté ces prises IEC pour remplacer celles de mes câbles Charlin 5000 mkII. Les prises IEC Charlin se cassent en exposant les parties métalliques sous tension. C'est très dangereux. La qualité de construction de ces Viborg VF502G est bluffante. Tout simplement impeccable. Le montage sur les très gros Charlin 5000 mkII prouve la qualité de la conception. L'insertion dans les réceptacles de mes Classé CA2200 et Nord class D est ferme avec un "clic" sensoriel très positif. Elles ne vont pas en sortir toutes seules.
Je ne m'attendais pas à une amélioration du son en changeant seulement les IEC, après quelques heures de rodage j'ai constaté une amélioration au niveau des medium. Mon système est assez analytique avec mes 800D3. (Il m'a fallut pas mal d'années pour éliminer toute agressivité.) Avec les VF502G finition or, Les instruments ont acquis une présence encore plus réelle et plein de vie sans aucune agressivité. La macrodynamique est améliorée.
Bref, une réussite.
Jordan R.
Fait le boulot
Bon embout de câblage, bien long, bien calibré.
Juste utiliser la bonne pince pour le sertissage
Jordan R.
Fait le boulot
romuald m.
AUDIOPHONICS CONTRAST RCA Interconnect Cable Subwoofer LFE OFC Copper Triple Shielding 2.5m (Unit) The Audiophonics Contrast LFE (Low Frequency Effect) RCA cable, designed and assembled in our workshops in France, has been conceived to provide a high-performance signal...
belle finition.
top pour le raccordement de mes caissons REL en série pour la partie LFE.
romuald m.
top.
déjà plusieurs câbles de cette réf. pour mon installation.
top.
Marc S.
SMSL PL200T CD Transport USB XMOS 32bit 768kHz DSD512 MQA-CD The SMSL PL200T is a high-performance, versatile CD transport. It's based primarily on a P.A.S.S. (Precision Access Servo System) playback system developed by SMSL, plus an XMOS...
Gagne beaucoup avec une alimentation linéaire externe
J’utilise le transport CD SMSL directement relié au hub WiSA de mes enceintes actives Buchardt. Au début, les aigus étaient assez stridents, mais ce caractère s’est atténué après quelques heures de rodage. J’ai ensuite nettement pu améliorer la qualité sonore en remplaçant l’alimentation interne par une alimentation linéaire externe (PD Creative). Le rendu est alors devenu plus spatialisé et plus précis, et les stridences initiales ont complètement disparu.
Seul bémol : la correction d’erreurs de lecture est médiocre. La moindre poussière ou de très légères rayures sur le CD s’entendent sous forme de craquements à l’écoute.
Dominique M.
FOSI AUDIO V1.0G Class D Stereo Amplifier TPA3116 2x50W 4 Ohm This small Fosi Audio V1.0G integrated amplifier is an affordable, high-quality Class D stereo amplifier. It incorporates a TI TPA3116D2 amplifier chip enabling it to develop...
Surprenant, au bon sens du terme
J'ai choisi ce petit ampli pour remplacer un autre assez ancien qui venait de me lâcher. Il est monté en aval d'un pré-ampli SONY sur une petite station de montage. Côté puissance, c'est largement suffisant, la musicalité y est aussi. Vraiment surprenant vu la taille de l'appareil, surtout en comparaison des 5 kg de mon ancien ampli.
Très bon service de Audiophonics
Joel L.
DENAFRIPS ENYO 15TH Balanced R2R DAC 24bit 1536kHz DSD1024 Black The Denafrips Enyo 15TH DAC is an R2R digital-to-analog converter supporting high-resolution audio streams up to PCM 24bit 1536kHz and DSD1024. R2R technology enables Enyo to...
DAC absolument exceptionnel
Je partais pourtant d'une bonne base avec le DAC intégré de mon amplificateur Advance Paris A10 Classic relié à des Focal Aria 936 et à un caisson de basses Velodyne pour les infra basses.
Je trouvais néanmoins que sur certains morceaux avec beaucoup d'instruments, la scène sonore manquait de précision, et que pour les graves, le contrôle pouvait être meilleur.
Après quelques semaines de recherches j'ai fini par découvrir ce DAC sur des vidéos YouTube en anglais, ainsi que sur des sites internet américain (en France, à part quelques revendeurs audio qui parlent toujours des mêmes marques, il n'y a pas grand monde pour s'intéresser au sujet...)
Il n'y a donc pas de puce(s) Delta Sigma sur ce Denafrips, mais un réseau de résistances.
Une technologie R2R plutôt ancienne, et théoriquement dépassée...sauf que les DAC R2R sont aujourd'hui parmis les plus haut de gamme pour ce type d'appareil.
Cela m'a intrigué, j'ai continué à creuser le sujet et cela a tout changé.
J'étais sur le point de commander un Topping D70 Pro Octo (qui me semble excellent), et puis j'ai finalement basculé sur Denafrips Enyo 15th.
Il coûtait certes un peu plus cher, mais sans tomber dans l'excès, et en restant en cohérence avec le reste de mon matériel.
Il s'agit donc d'un DAC et de rien d'autre (pas de possibilité d'usage en tant que pré-ampli, pas de sortie casque, pas de Wifi, pas de bluetooth, pas d'écran...) mais il fait un travail incroyable, et j'ajouterai que sa construction impeccable en métal et son poids qui atteste de la présence d'une alimentation massive sont vraiment impressionnants.
Il sait faire tout ce que j'espérais pour corriger les petits défauts que je mentionnais, mais aussi beaucoup plus.
En résumé, excellente organisation de la scène sonore aussi bien en largeur qu'en profondeur, élargissement de la scène sonore, très bonne dynamique (particulièrement en mode OS), contrôle des graves jusqu'au plus extrêmes absolument remarquable, présence des voix des chanteurs ou chanteuses juste incroyable, très beau travail pour révéler une multitude de détails dans les médiums et les aigus.
Je dirais qu'auparavant mon ampli et mes enceintes fonctionnaient à 85% de leurs possibilités, et qu'aujourd'hui, ils ne sont pas loin des 100%.
Il n'y a qu'un défaut sur ce DAC: l'absence totale de mode d'emploi. J'ai juste trouvé une vidéo du constructeur de deux minutes et quelques, mais c'est trop court, pas suffisamment détaillé et pas vraiment éclairant.
J'ai fini par demander de l'aide à une IA générative, cela a été utile, mais c'est quand même dommage que l'on soit obligé d'en arriver là.
Michael D.
AUDIOPHONICS HPA-S450ET Power Amplifier Class D Stereo Purifi 1ET6525SA 2x450W 4 Ohm The Audiophonics HPA-S450ET power amplifier is based on a Class D architecture, using a pair of Purifi 1ET6525SA amplification modules, a Hypex SMPS1200A400 power supply and an...
Simply great
Wow! This replaces an older but still much respected analog amp. I didn't expect there to be such an improvement. But the music now just seems more present. Speakers are ELAC Velas and I think they benefit from the greater oomph that S450 provides. And the amp looks good too. I'm very happy with my choice. Thanks Audiophonics!
Sasa B.
Nc250s
Nearly two years after bought this product all i can say is brilliant. If you need power amp which you'll love for good price, this is it. No need to spend money for high cost devices. If you need to enjoy at home listening sound of music it' s recommended.
NEOTECH NEP-3200G Power Cable G-UPOCC Copper 6.63mm² Ø15.6mm Neotech's NEP range consists of high-end power cables using only the purest UP-OCC copper conductors. The NEP-3200G is no exception, with 16 Graphene + UP-OCC Copper conductors...
Tres bon cable sur mon (gros) integre
J'ai demande a Audiophonics de realiser une cable secteur sur mesure a partir de ce cable et de connecteurs NEOTECH NC-P313RH et NEOTECH NC-P303II.
La realisation en est tres soignee.
Ce cable a un seul defaut, il est tres raide donc ne soyez pas trop juste sur la longueur.
Je l'utilise sur un integre PASS LABS INT-60 qui a une tres grosse alimentation lineaire (Transfo de 1000VA).
Apres environ 500 heures d'ecoute, le resultat est tres positif.
Cet ampli est un tout petit peu trop riche et le cable a netoye legerement l'ecoute tout en gardant un chatoiement delicieux.
Les basses sont propres mais gardent un bonne densite. La scene sonore est large et profonde mais precise.
La dynamique est la.
Les voix et les instruments ont de la matiere.
Les timbres sont realistes.
C'est un cable tres equilibre et qui ne bride pas de grosses alimentations.
NIALL P.
FIIO BTR15 Balanced Headphone Amplifier Portable DAC ES9219MQ Bluetooth LDAC 32bit 384kHz DSD256 MQA This FiiO BTR15 portable DAC headphone amplifier is a small, affordable device, but no less high-performance, since it integrates a number of market-renowned components: dual...
Great quality
This tiny unit packs a punch, the audio quality is excellent!
I'm so happy I ordered a second one for a friend.
Sasa B.
Stripi
An exceptional product! The temporary Tannoy V1 Mercury speakers were oozing. Bass and treble as on some other speakers. When I silence the system the details are still present. Incredibly! How will it be when I hook up the Linton 85 Heritage? Esotericism!
Michael L.
SMSL PO100 2024 USB Interface XMOS XU316 to SPDIF Coaxial / Optical Toslink 24bit 192kHz DSD DoP64 Black SMSL unveils its PO100 2024, a digital interface USB to SPDIF coaxial / optical Toslink. This is based on an XMOS XU316 interface and a CK-02 clock circuit, it supports up to...
wiim ultra now showing 24 bit
Now my wiim ultra shows 24bit and i didn't even have to install any drivers, plug and play
Roger D.
AUDIOPHONICS STEALTH XLR Interconnect Cable XLR-XLR OCC Copper 0.75m (Pair) The Audiophonics Stealth range offers a selection of particularly high-performance, affordable cables, hand-assembled in our workshops in France. The Audiophonics Stealth XLR...
Q/P Très interessant
Excellente facture de câble pour un budget très correct.
Roger D.
PANGEA PREMIER XL BALANCED Balanced Interconnect Cable XLR-XLR Copper Cardas 0.6m (Pair) This Pangea Premier XL Balanced XLR-to-XLR modulation cable features exceptional workmanship. It features Cardas Grade one copper strands with PE tube...
Impeccable !
Suite a un changement de système en tout XLR, j'ai du investir en câblage, je suis très fan des câbles Cardas, mais je n'ai pas le budget pour un système 5.0.2 en tout Cardas, je me suis donc laissé tenté par cette paire de Pangea pour le front L/R.
La stéréophonie des Pangea est plus neutre que les Cardas que j'utilisais jusque là, qui ont tendance a "déplacer" les sons dans l'espace. Cependant je trouve Cardas un poil plus "musical" (très très subjectivement).
Niveau sonorité tout est très présent et riche.
Impeccable !
VADiM B.
Roger D.
TONEWINNER AT-500 AV Processor / Home-Theater Preamplifier Dolby Atmos 16 Channels 9.3.4 / 7.3.6 The Tonewinner AT-500 is an 8K home cinema processor designed for immersive configurations up to 9.3.4 or 7.3.6. It provides full decoding of Dolby Atmos and DTS:X formats,...
Très bien !
Le préampli tant attendu est arrivé et c'est un succès.
Sur mon ancien ampli AVR4700 j'utilisais un SMSL SU-9 pour écouter mes disques en stéréo et le rendu était très bon, ben je dois dire que sur ce préampli la différence avec le SU-9 devient très très subtile.
Sans corrections, j'ai beaucoup de basses, les infra-basses de "Welcome to the World of Plastic Beach" de Gorillaz sortent quasi aussi fortes que les basses "standard", il y'en a presque trop :-)
Je ne suis pas fan des logiciels de corrections de l'accoustique mais je vais tester le soft mis à dispo par Tonewinner pour voir si ça me parle.
J'ai eu un petit "bug" en changeant à la volée les entrées HDMI, mais rien de catastrophique (freeze). Reboot et hop c'est reparti.
A ce prix là, très content de mon achat.
NB: je drive des KEF R-900 (LR) et KEF série Q (SR), Topping B-200 (L/R) et Audiophonics HPA-HDN250N (6x pour le SR), pas de Sub. Câbles Pangea, Cardas et Audiophonics.
Steve D.
Sans artifices ou coloration!
Super service et livraison nickel. pour le câble, rien à dire, il s'efface et laisse passer le signal sans colorations. Vous allez entendre ce que vous avez à la source. très neutre de mon coté sur des enceintes maison 3 voies. Si vous chercher de la neutralité, ne dépenser pas plus, tout le reste c'est du marketing ou du "placebo" en fait. Moi c'est ce que je recherchait, neutre et invisible "soniquement".
Laurent E.
ATAUDIO L-4E6S Male USB-A to Male USB-B Cable Gold Plated OFC Copper 0.75m This ATAUDIO USB cable offers both high quality and luxurious design. It consists of a four conductor structure made of braided OFC 6N copper with excellent conductivity,...
Belle finition et qualité perçue, ce câble répond parfaitement pour la liaison entre un Dac Atoll et un streamer Innuos. Expédition rapide, comme d'habitude, par Audiophonic.
Sebastian L.
Épatant
Source eversolo. Enceintes klipsch rf-7.
Eh bas je suis sur le cul!
Cette boîte d'allumette arrive a remuer les difficiles rf-7 qui ont besoin de beaucoup de courant plus que mon gros ampli Primare a32!!! Vraiment épatant surtout quand ont prend en compte la différence de prix!
HERVE B.
FOSI AUDIO BOX X2 Phono MM Preamplifier with Tubes 2x6A2 Stereo Black With its BOX X2 tube preamplifier, Fosi Audio unveils an affordable, high-quality Hifi device for those wishing to enjoy the warm, coated sound of tube...
Petit mais costaud
Installé à la place d'un My Groove , réglé sur 39db , la dynamique par rapport à mon ancien appareil est indéniable et appréciable .Ensuite tout dépend de la qualité d'enregistrement des vinyles , mais pour le prix on peu l'acheter les yeux fermés .
Associés avec une platine P1 Rega cellule Bias 2 et ampli Prisma .
YANN P.
YANN P.
Organique
Merci à Audiophonics pour le bonus.
Monté en cable secteur pour mon subwoofer et ma barrette .
Au vue de la description technique, je m’attendais à un son étagé, de la précision, de la transparence et une large bande passante , c’est le cas mais la surprise, c’est son côté organique, fluide, son liant.
Au prix où est proposé ce cable, il faut avouer que la prestation est haut de gamme.
YANN P.
Conforme aux attentes.
YANN P.
CWS1 3-in-1 Cutting / Stripping / Cramping Pliers The CWS1 3-in-1 pliers have 3 functions. It will enable you to cut, strip and crimp cables.
Conforme, pratique
YANN P.
Soborthane
L’effet cumulatif d’absorbeurs sous :
L’amplificateur (pieds),
La barrette secteur (pieds),
Le subwoofer (pieds pico),
+ planche bambou avec des pieds caoutchouc / silicone
Tout cet ensemble a effectivement un effet sur la transparence du son.
YANN P.
Cuivre Occ
C’est la valeur ajoutée de ce produit et à un prix abordable.
SOVTEK 6H30PI / 6H30 / 6N30 / 6N30P Twin Triode Tube (Unit) This Russian-made, audiophile-quality 6H30PI power tube from Sovtek (sometimes also called 6H30, 6N30 or 6N30P), often used in pre-amplifiers, gives...
Tube excellent même en rodage sur mon Dac Ayon .. aucune brillance…audiophonics tjrs au top.. en plus le prix le plus bas du marché !
Thor S.
Extremely good amp for the price.
Great build quality and an impressive power reserve.
The amplifier arrived very well packaged.
My speakers (Canton Townus 90) were previously driven by a Denon 3700H AV receiver.
With this amp, the speakers feel far more controlled, authoritative, and overall noticeably bigger and more powerful.
Highly recommended!
Alex P.
EVERSOLO DMP-A6 GEN 2 Streamer 2x ES9038Q2M WiFi DLNA Roon Bluetooth 32bit 768kHz DSD512 The Eversolo DMP-A6 Gen 2 is a HiFi network player that seamlessly combines outstanding sound quality with cutting-edge technology. More than just an audio device, it's a new...
Very Nice!
Extremely nice product, especially at its price point. Noting more needed for any user who will decide to purchase it. Very impressive features, design and finish.
GENALEX GOLD LION Tube 12AT7 / ECC81 / B739 Gold Pins (Unit) The high-end Genalex Gold Lion Gold Pins double triode tube unveils a wide sound stage, characterized by expressive midrange, deep and precise bass and generously developed treble.
Très bien quand même
Reçu ce tube pour remplacer un 12at7 Electro Harmonix, à part les pins dorées c'est le même tube en bien plus cher.
Effectivement en inspectant l'intérieur de près et aux mesures, c'est exactement le même tube.
Il est très bien quand même, assorti à mes 2 autres tubes Genalex Gold Lion 12au7 qui donnent d'excellents résultats sonores.
Commandé un vendredi, reçu le lundi, top Audiophonics.
Daniele U.
LHY AUDIO RECEIVER LVDS HDMI to I2S Interface Module This LHY Audio Receiver interface module converts an HDMI LVDS signal into an I2S signal. It accepts PCM and DSD signals, enabling users to enjoy high-resolution files.
Very bad
I ordered this product.
1. It didn't arrive.
2. Another product arrived!!
Never again.
Highly not recommended.
Michele M.
DAYTON AUDIO DCS305-4 Speaker Driver Subwoofer 250W 4 Ohm 90dB 23Hz - 200Hz Ø30.5cm This standard Dayton Audio DCS305-4 subwoofer is ideal as a replacement for an HS subwoofer of the same size or for creating a subwoofer. Strengths: Power handling...
The subwoofer was well packed in a double boxe. The ratio quality/price is excellent and the shipment was quite fast.
Many thanks from Italy.
Sandy Clémence B.
BELLE ECOUTE
Très satisfaite de ces Tubes, sur mon CAYIN 845 SE
Sont elles des NOS ? je ne le pense pas; mais elles fonctionnent
délicatement bien, et je les apprécie sur toutes les musiques.
Douceur des timbres avérée, et spatialisation correcte.
Je laisse aux "ingénieurs" le soin de les mesurer. Moi, elles me conviennent très bien !
Sandy Clémence B.
BELLE ECOUTE
Enchantée de ce câble HP, sur un système "haut rendement" :
baffle ouvert : DAVIS 20DE8 Tweet ATOHM, Caissons de basses (Audax 330)
Ampli à tubes : 845 SE, 300 B Electro Harmonix, et 6SNT GT Tungsol)
Ce câble en cuivre pur et gaine "carbone" donne une écoute dépourvue de tout côté criard. (point délicat sur les HP large bde
haut rendement) Très Bien Sur Un Système Très Défini.
Jorgen Chr. D.
Extremely worthwhile upgrade - Antipodes
My Antipodes DX3 benefitted notably from this reclocker rendering a more open sound in all directions not to speak of the much better defined bass. You should try it too!
AUDALYTIC HP70 Headphone Amplifier Preamplifier Balanced Black The Audalytic HP70 is a high-end headphone amplifier and preamplifier designed to deliver exceptional sound quality thanks to its fully balanced and discrete architecture....
Excellent Preampli
Colis reçu en 24h. Merci Audiophonics
Je ne m’en sers qu'en preampli XLR et RCA
Cet appareil ne semble pas du tout un début de gamme
Le son est excellent et tout fonctionne tres bien y compris la télécommande
Menu très simple aucun besoin de manuel utilisateur.
J'en suis vraiment content.
Très bel appareil a recommander
Christian M.
Si vous utilisez Roon, et que vous cherchez un lecteur simple, n'allez pas plus loin...le Fiio SR11 est exceptionnel...si vous pouvez, branchez le sur une bonne alim linéaire ou une petite Powerbank.... donnez-lui un bon Dac, il vous le rendra bien...je l'ai acheté juste pour l'essayer....suis pas déçu....impressionnant !
PIERRE E.
nickel livraison emballage et le produit
encore en rodage sur une platine ancienne de type dual avec nouvelle cellule type ortofon , je peaufine les réglages et des 39 db cela s'entend déjà pour le prix c'est nickel et je profite du son tube en le couplant à mon ampli
je recommande vivement et ensuite je changerai peut être les tubes pour des plus qualitatifs
Jean-francois P.
Made in Japan, excellent
J'ai acheté cet adaptateur pour le relier à un DAP IBasso 260 depuis mes casques (TH909, Beyer T5, Grado). La qualité de fabrication est excellente, il s'enfiche solidement sans aucun jeu.
Le son est excellent, comparé à un adaptateur de base (que j'ai jeté).
Dan K.
best quality in tiny wire
I changed all wires for Neotech STDCT-12 in my tube power amp Copland CTA506 and resault is something I did not expect. A lot of life, soul, and body. Better than change for audio fuse SR pink.
Dan K.
THE best cable ever
Better than Topping TCX1 with 6N wire in which there is a cable from the Taiwanese company Serost M-3 under the armor.
This cable is wonderful.
