Terrific cable
Tomasz C.
arnaud m.
Exelent
Customers reviews - There are 19317 reviews.
Valentin S.
Un régal pour les oreilles et le portefeuille
E-30 : superb clarity and finesse, even has decent op-amp for an entry level system (OPA1612).
audiophonics: fast shipping, newest factory charge (2102XXX), ordered in march.
tres bien overall.
Byron P.
ALLO Acrylic Case for Raspberry Pi 4 + Allo DigiOne Signature Black This acrylic case designed by Allo is perfectly adapted to receive the Raspberry Pi 4 and Allo DigiOne Signature combo, while maintaining access to the different connectors of...
Simple easy to assemble case
A simple cheap acrylic case for the DigiOne Signature kit and RPI 4. If there were an aluminum/metal case I would have bought that instead.
Byron P.
Excellent sounding and looking network streaming device
This is an excellent Raspberry based network streaming kit that sounds like a high-end component. The aluminum case makes this look like a manufactured product and not a DYI.
I have mine hooked up to separates (preamp and multi-channel amp) and the dynamics, soundstage, and high-end are nicely presented.
In the download section you will find instructions for assembly and usage. Thankfully for me there is an English version as I do not speak French. The assembly instruction should be slightly updated as it shows an older version component for the display unit which has been updated to an LCD display but easy enough to figure out.
I think you will not be disappointed in the sound coming from this device or the convenience of having all your music or web based music stations at your fingertips. My music was accessed by both a solid state drive directly connected to the RPI unit and via NAS.
Lastly I was impressed how quickly I got the unit within 6 days from France to the USA and it was nicely packaged.
Damien M.
Aussi performantes que leurs grandes soeurs
Elles se présentent comme un copié collé de leurs soeurs , hormis le fait que sous le plaqué argent , ce n'est pas de cuivre dont elles sont constituées , rien n'est précisé , une lacune d'ailleurs dans le descriptif ;Je suppose qu'i s'agit d'un alliage de nickel ou de laiton.
Comme leurs aînés , leur ergonomie facilite l'accès au soudage, la vis de blocage du câble par le biais d'un manchon de plastique protège bien la soudure d'éventuelles contraintes mécaniques. Enfichées , le maintient de la connexion est exemplaire , rien à redire sinon que pour un prix inférieur de moitié , elles se révèlent aussi performantes (comparatif effectué entre deux cordons , chacun équipé de l'un des deux modèles).
Si c'était à refaire je m'équiperais exclusivement de ces dernières.
un grand classique
Attention à ce que les résistances, par ailleurs bien alignées, bien soudées, ne touchent pas les deux vis et écrous du carter, les écarter un peu si nécessaire. La rotation est un peu dure (rodage ?), c'est le prix à payer pour des contacts de qualité. Remplace avantageusement les modèles à pistes, mais on ne pourra le motoriser, trop de force pour faire tourner.
Parfait, on a tout d'avance
Toutes les tailles, prix raisonnable.
Cable Male USB-C 3.1 to Male USB-C 3.1 Super Speed 5A 10Gbps 0.5m This USB cable has a USB-C 3.1 connector on both sides and allows you to connect two devices with this connection, such as a smartphone and a recent laptop or tablet. The cable...
Cinq ampères, on prend !
Le câble USB 3.1 que l'on attendait, rapide, et du débit, enfin.
Enfin un filtre secteur deux pôles.
Difficile à trouver, et pourtant, bien utile ! Souvent le troisième pôle, la terre, amène plus d'inconvénients que d'avantages. Donc le format IEC C7 est très bien dans la plupart des cas. Indispensable.
Bien, mais usage domestique
Fabrication un peu légère, à déconseiller en usage professionnel. Qualité suffisante dans les autres cas.
VIBORG VE01R Power Plug Schuko Type F Pure Copper Silver / Rhodium Plated 250VAC 16A The Schuko Viborg VE01R uses high quality materials to ensure perfect electrical signal transmission. The contacts are made of pure Copper and benefit from a triple plating of...
Belle fabrication, et de vraies vis, et peut accueillir des câbles de 6 mm. Indispensable.
DAYTON AUDIO H812 Horn for compression chamber 800 Hz Dayton Audio horns are designed to operate smoothly until the lowest possible crossover frequency. whIt maintains consistent and predictable dispersion throughout the intended...
Pas cher, mais franchement mal fini
Prenez vos limes douces, les trompes arrivent, mal démoulées.
Les ébavurages, on s'en fiche, sauf quand c'est la gorge !
Les 25,4 mm (un pouce) de diamètre ne sont pas respectés, ce n'est même pas rond, c'est fâcheux, c'était le point important. La partie plane qui reçoit le moteur... n'est pas plane. Oui, ça fait des vagues, donc il y a des fuites là où c'est le plus critique. Il faut aplanir les bosses, reboucher les creux, à la résine, puis poncer. Pour quelques dollars de plus, à peine, on pouvait faire nettement mieux. Ce n'est pas cher, mais avoir tiré la qualité vers le bas à ce point, c'est incompréhensible. Alors, à vos outils ! Sinon, la coupure basse (moins de 1000 Hertz) est intéressante et elles sont solides.
chiostri g.
KHADAS TONE2 PRO DAC Headphone Amp ES9038Q2M 768kHz DSD512 MQA Full Decoder Red Meet the famous digital to analog conversion circuit (DAC) based on 32 bit ESS ES9038Q2M chip with PCM support up to 768 kHz and native DSD512 and even MQA. New headphone...
Khadas tone 2
Very good. Not so easy to use. Next I will buy the special balanced cables and the new Topping pre90
Denis f.
Parfaite
Pas encore installer, mais acheté pour une fabrication subwoofer en 38.
Poids final 45kg mais vu l'aspect des pointes je me fais aucun soucis elles sont très robuste et respire la qualité
Conforme à la descritpion
Bien reçu, livraison ok.
L'alimentation est très bien emballée.
Tension mesurée : 5,09 volts.
Branchée sur un Raspdac mini.
Samuel L.
Rapport qualité prix excellent, ne pas chercher plus loin pour câbler vos barrettes secteurs, vos filtres et transfo symétriseur, tirer une ligne direct.
Acheter sans modération !!!
Câble blindé 100% en plus !!! Qualité du cuivre excellente !!!
Samuel L.
Excelente facture
Pas la peine d'aller chercher plus loin. Câble très qualitatif et section largement suffisante pour toutes applications audio, gros ampli à tube, au gros classe A. Tout passe sans problème et qui peut le plus peut le moins. Câble monté avec les Furutech FI-11 et FI-E11, les meilleurs pour moi, et vous obtenez un câble hyper haut de gamme fait par vous même dans les règles de l'art. Avoir la même qualité en câble monté, il faut aller chercher entre 500 et 1 000€.
Samuel L.
Fait très bien le job. Pied dévissées sous un dac Schiit Yggdrasil, puis placement de ces 4 plots large base vers le dessous du dac. La légère adhérence fait que les pieds tiennent tout seul. Le dac est comme monté sur coussin d'aire ou gel spécial.
Avantages:
- Amortissement des vibrations environnantes parasites
- Surélévation du Dac pour qu'il puisse respirer convenablement
- Belle esthétique
A acheter avant tout autre "bidule" ésotérique. Le sorbothane c'est scientifique!!
Stevenn D.
DAYTON AUDIO UM10-22 Ultimax DVC Speaker Driver Subwoofer 500W 2x2 Ohm 85dB 25Hz - 1500Hz Ø25cm Dayton Audio's Ultimax series DVC subwoofers are specially designed to move energy and create clean, articulate, tense fast bass. Enjoy the best value for money available !...
Il se sera fait attendre mais ça en valait la peine.
installé dans un caisson clos dans une voiture et alimenté seulement par un petit Focal FDS 2.350 (ponté) il fait mon bonheur.
Franchement je ne regrette absolument pas, bien au contraire au vu du rendu, trés qualitatif aussi bien physiquement qu'auditivement.
Brian G.
great cable
This cable replaced a pair of Straightwire Serenades in my home audio system. Good bass reproduction and natural mids. Great value for money. No EMI noise.
David P.
Powerful device
You can do a lot of audio processing with this small unit as shown in this video:
https://www.youtube.com/watch?v=AqLGvlHuUfM
To reprogram the 256144-bytes EEPROM: connect the USBi programmer, move the jumper to USBi instead of self-boot and put the jumper on WE (write enable).
After you get "WRITE SUCCESSFUL": disconnect the USBi programmer, move the jumper back to self-boot, remove the WE/WP jumper (write protection) and connect a USB cable or a power source.
Jean Michel W.
Alimentation diy maison
Super boîtier pour une réalisation parfaite et élégante du projet. Expédition ultra rapide. Merci!
Anders L.
Good looking cd player with small fotprint
Perfect. Exactly what I was looking. A small cd player with digital out (the internal dac sounded good too). A bargain.
Thanh-Binh N.
Top !
Juste achetée pour le fun, pour avoir une belle prise...
Et là, ENORME surprise....Branchée sur mon DAC Mark Levinson N360S...Un changement radical au niveau son. J'ai écouté mes CD jusqu'à 3h du matin...Et je redécouvre tous mes CD du fur et à mesure....Produit que je recommande fortement....
Jean Luc V.
Dma70-4
HP de bonne musicalité .
Petit bémol sur la solidité des cosses. Un de cassé après un teste en débranchant.
Serge H.
Dac smsl 4493
Acheté en remplacement dun dac Cambridge coûtant 3 fois son prix.
Ce DAC est incroyable même avec une simple alimentation de 5v.
Tout y est : detail, ampleur, douceur.
Merci Audiophonics . Continuez à nous donner des produits à bon rapport qualité prix.
Søren Brolin T.
Gustard a22 after 2 weeks usage.
The DAC delivers very smooth and easy understandable voices. My ears just ask for more even after several hours listening. It has everything i hoped for, deep bass, smooth midrange and extended smooth treble. I use it with my Bluesound Node, high end amplifier and speakeers.
Yannick M.
Super module
Je m'en suis servi pour alimenter un subwoofer en dessous de 70Hz, mais je l'ai essayé en large bande.
En large bande, c'est pas mal.
Plutôt doux avec pas mal de dynamique.
Mais en utilisation subwoofer, c'est vraiment excellent.
plutôt plus riche et plus vif et "punchy" que les différents classe D que j'ai pu essayer (IcePower entre autres, que j'avais précédemment choisi car les hps s'affolaient moins à haut niveau qu'avec d'autres modules).
Là, malgré une puissance limitée (choix du transfo) vers 230W, c'est vraiment superbe.
J'y ai associé un filtre actif analogique complètement diy avec un correcteur Linkwitz intégré (pour avoir du 15Hz -3dB in room)...
utilisé comme cable secteur
Résultat détaillé on entend chaque voix détachées et différenciées sur un disque de choeur d'église . On ressent les ambiances des lieux d'enregistrement . Cependant les timbres des instruments sont moins aboutis et la scéne sonore moins épanouie par rapport au cable secteur yarbo cuivre/argent avecles mêmes connecteurs ( viborg or/ argent) . Un bon choix toutefois en tant que cable secteur ( cablé selon le schéma de audiophonics). Il s'agit juste d'une affaire de goût .
Ali B.
excellent dac
Ce dac est une belle surprise,une qualité d'écoute audiophile,je recommande ce produit,
Ali
Ali B.
c'est un bon adaptateur bon rapport qualité-prix.
Audiophonics très réactif parfait.
Ali
Clément E.
Excellent tube
Un très bon tube 6DJ8, plus neutre et ouvert que le même tube de chez JJ Electronics.
En revanche, il nécessite un bon temps de rodage, les tubes en ayant souvent besoin contrairement aux circuits d'amplification à transistor. En commandant un nouveau tube pour remplacer mon précédent, j'entends clairement la différence.
Carlos N.
Excellent tube
Montage sur un lecteur CD Line Magnetic Audio LM 215 CD. Timbres incroyable, tube avec une grande richesse de basses, médium avec une belle attaque et un soyeux hors du commun, aigu d'une délicatesse et une transparence redoutable comme rarement entendu. La richesse harmonique de se tube est redoutable. Par rapport au tube d'origine les triodes son plus massif ce explique l'extension du grave et du sous grave. Tube à recommander pour ceux qui cherchent la perfection.
Nigel B.
Very happy with this kit. Easy to put together and sounds very good. You do need to use the correct version of volumio, which is downloadable on this site. Colour screen is nice too!
Bonne base en un pouce
Je vais la compléter sur les côtés (tout l'arrière) avec des plaquettes de marbre et d'acajou, puis la remplir avec du béton de résine qui va rigidifier et densifier les parois exponentielles. Pour le look, et pour le son.
Joris J.
Male USB-B to Male Micro USB OTG Cable 50cm This high-quality OTG USB cable includes OFC copper conductors and gold-plated connectors (USB-B / Micro USB). In addition, being OTG you will be able to use it to connect USB...
Beter than iFi
I had the iFi 15 cm micro USB OTG with a another quality 50cm to USB-B,
but this cable sounded immediatly more clear and direct, including bass.
Joris J.
VISHAY ERO MKP1837 Polypropylene Capacitor 5mm 160V 0.1μF Vishay's ERO capacitors are polypropylene film MKP capacitors. They offer good performance in a compact size.
Big improvement
I replaced WIMA decoupling caps in my DAC with these VISHAY and ik Made a big difference; more detailed highs, more spacious.
I coulant immediatly hear it but it took a about 10 hours to settle down smooth
RENE R.
PANGEA FIRST SE Phono Cable RCA / RCA with Ground 1.25m The Pangea Premier SE is a high end vinyl turntable cable incorporating a ground conductor is a neat design. It integrates Cardas and OFC Copper conductors, PE insulation and...
cable pangea premier se
super cable d'un rapport qualité prix excellent. Seul bémol qui lui coute une étoile (à mon avis) peu de différenciation sur les fiches.
Le marquage rouge n'est pas terrible, seul ramm fait pire!!!
Michel B.
Unity Gain Buffer Symmetrizer / Desymmetrizer XLR RCA 2x AOP LM4562 2x LM317 This unity gain buffer offers dual connectivity, both unbalanced with stereo RCA input and output and balanced with 3-pole XLR input and output. In addition, it also takes on...
Vraiment bon
Je viens de tester l'appareil au banc d'essais, j'utilise un analyseur de distorsion Hp333A qui date un peu mais qui reste fiable.
Le test porte sur la chaîne complète càd symétriseur, transport du signal via 50m de câble, désymétrisation et mesure. C'est très bon! Le niveau d'entrée max est de +18dbu, la sortie est à +24dbu, ce qui est normal car si le gain du désymétriseur est unitaire le fait de passer d'un signal symétrique vers asymétrique va augmenter le niveau de 6dbu (pour que ce ne soit pas le cas le gain de cet étage devrait être de 0.5). La distorsion est faible, limite de la mesure de mon analyseur, 0.015%, en réalité elle doit encore être bien en dessous. Le rapport signal bruit est plus grand que 100db et j'ai oublié de faire la bande passante mais ce n'est pas bien grave. En conclusion je dirais que l'appareil convient pour des applications professionnelles, vu le niveau qu'il accepte et les performances mesurées. Si vous êtes passionné de hifi il sera aussi du plus bel effet parmi les autres pièces de votre installation.
Antoine L.
J'ai acheté ce combo DAC/ampli pour aller avec un casque Philips SHP9500 pour découvrir l'univers du son Hi-Fi casque... et je ne suis pas déçu!
Produit de bonne finition, très simple à mettre en place. Tous les accessoires sont fournis.
Largement assez puissant pour mon usage, très content de mon achat.
François C.
Stainless Steel Switch with White Light Circle 1NO1NC 230V 3A Ø16mm Silver This 1NO1NC stainless steel bistable switch allows easy integration into your DIY projects. It has a white light circle that visually indicates the status of the button.
Très bien, LED ok sous 5v.
Bon à savoir, la LED fonctionne également très visiblement sous 5V. J'avais peur qu'elle se voit mal, mais il n'en est rien. Tant mieux pour tous ceux qui ont ce genre d'alim.
GUILLAUME C.
préampli Riaa
Bonjour, je voulais savoir si toutes les entrées sont identiques ou si l'une d'entre elles possède un préampli Riaa afin de brancher une patine vinyle...
Ce n'est pas le bon endroit pour poser des questions produit.
Et non même chose ici (pas d'entrée phono) ce serait spécifié dans la fiche.
GUILLAUME C.
préampli Riaa
Non aucun préampli phono sur ce produit.
Toutes les entrées sont niveau ligne.
Reynald D.
Très bon transfo utilisé pour une PCB préampli à tube, branché en parallèle même si c'était inutile vu les besoins du préampli en courant.
Pas un bruit etc.Je recommande
LAURENT G.
DIY Aluminum Case Silver Front Panel 260x155x60mm This brushed aluminum case is ideal for the integration of a DIY audio project, such as an amplifier, preamplifier or DAC. Rugged, it will allow you to effectively protect your...
Robuste
Très beau boîtier ,bien fini. Le corps est en alu anodisé brosse,très rigide,l'ajustement est parfait.Très bon rapport qualité prix.
Michel B.
Belle pièce
Magnifique boîtier en alu, un peu gros pour la fonction mais qui inspire confiance. Je l'utilise pour alimenter deux enceintes de monitoring actives Quested dont les entrées sont symétriques, le signal provenant de la sortie monitoring auxiliaire, asymétrique, de la console. Ce symétriseur remplace deux transfos dont les rapports de transformation n'étaient pas tout à fait adaptés. Le son est excellent, meilleur qu'avec les transfos. Je n'ai pas encore eu l'occasion de passer l'engin au banc d'essais mais je prévois que le test sera positif. L'appareil est un peu cher, j'en ai construit un du même genre dans un volume moitié, pour la moitié du prix, il est moins beau, pas moins bon, et c'est sans compter les heures de travail. L'appareil est utile pour les liaisons de grande longueur, si on veut bénéficier de la réjection du mode commun dans les liaisons symétriques. Si ce problème ne se pose pas, ça marche très bien en mettant le point froid à la masse, on peut faire des économies.
Un engin utile pour résoudre le" hum & buzz" dans les installations sérieuses. Autre bon point: sa réversibilité.
Cavacece a.
Really good
I use the ibasso dc04 with tidal or USB audio player pro. Mi iem is campfireaudio. It is good. I' m thinking to sell my dal after this purchase
Albert h.
lecture cd
très bon appareil car je cherchai un ampli ayant les qualités d'un tube sans en avoir l'usure, employé avec préampli à tubes et casque électrostatique Sennheiser unipolaire 2002 de 40 ans et lecteur cd Marantz avec convertisseur 24/192 khz ,avec musiques classique et jazz incroyable les détails
Alexis J.
Splitter HDMI ARC to SPDIF Coaxial Optical RCA Jack 3.5mm DTS Dolby AC-3 5.1 This compact audio extractor will allow you to simply extract the audio signal from an HDMI ARC input stream and then output to Coaxial, Optical, RCA stereo or an amplified...
Ca remplit son rôle !
Parfait pour extraire le son d'une sortie HDMI (ARC) d'un téléviseur ou rétroprojecteur, et l'injecter en optique dans un ampli. Ca marche !
Christophe V.
Un avis mitigé
La marque et son produit sont connus et reconnus.
Mais l'humain ne retient pas que le bon mais aussi le mauvais.
En effet payer plus de 8 euros pour une livraison en 24-48h, n'a pas été une bonne idée.
En effet GLS n'a pas respecter ses engagements.
Livraison avec 1 jour de retard.
Chez GLS cela semble "normale"......
Audiophonics n'y est pour rien certes.
Mais il faut savoir que les services de livraison ne sont pas forcement bon.
andoni g.
works well
i use for conect a meze clasic with balanced 2,5 to a headphone amp with 4,4 and works well, no problem
