Maik B.
Maik B.
Fast shipping.
The sound is excellent. Ranked 5th out of many...
Theodoros R.
NICE OPAMP
VERY NICE OPAMP FOR THE MONEY!!
Customers reviews - There are 19109 reviews.
DIMOKRITOS D.
Best souding plug for the money, and more
In terms of sound quality, the plug easily betters ANY in its price range and also many much more expensive ones. But it has idiosyncrasies in its structure that make it less easy to use by non experienced users. The slot head screws that are used to hold the wires in place are certainly more difficult to use than the more common Allen screws used buy other manufacturers but the job can be done perfectly if you know or understand how to screw them without damaging the head. Don’t use ANY screwdriver but one that is no wider than the screw itself so that it can follow the screw into the hole, if needed. While screwing, try to keep the screwdriver strictly in line with the axle of the screw and centered into the slot and apply as much force as you can, pushing the scew to the direction of the screwing but without disturbing the balance. Do not overtighten any screw on the plug! Also mind you that the cable clamping system can only fix cables with diameter larger than 12mm and up to 18mm
jean-françois v.
IAN CANADA UCCONDITIONER PRO Ultra Capacitor Conditioner Board 5V The Ian Canada UcConditioner Pro 5V is a ultra capacitor signal conditioner module for use with a 5V power supply. It will significantly improve the quality of your power supply...
Upgrade Alim Linear PI pour 5V du FIFO PI Q7 II
Petit retour d'expérience sur ces supercondos de chez Ian Canada. En effet, dans mes autres post sur mon streamer audio à base de produits Ian Canada je ne suis pas déçu de cet upgrade de supercondos en sortie de l'alimentation 5V régulée Linéar PI de chez Ian Canada, tout ça pour alimenter le reclocker FIFO PI Q7 II !! Même si l'apport en qualité n'est pas aussi flagrant, il y a tout de même un petit gap avec ce qui suit :
- Une amélioration de la scène sonore (plus d'espace)
- Une dynamique plus grande
- Une séparation des instruments et surtout des voix
- Des fins de notes plus silencieuses
- Des voix plus naturelles et très charnelles
- Des graves très tendus et très propres
- des micro détails très lointains auparavant qui se détachent nettement
- Un son très analogique sans les effets du numérique et sans les inconvénients de l'analogique
A noter que dans cet upgrade j'ai aussi changer les Horloges de mon reclocker FIFO PI Q7 II par des SC Pure, Il est donc difficile de dire si c'est l'horloge qui l'emporte sur cet upgrade ou l'ajout des supercondos.
Dans tous les cas après lecture de bien des avis sur les forums concernant les DACs, les Reclokers, les alimentations ou les horloges et après avoir vérifié par moi même en upgradant petit à petit mon streamer audio (cela m'a pris 2 ans et ce n'est pas fini) à base de Raspberry 4 avec des produits de chez Ian Canada. Il y a à chaque fois une amélioration de la qualité sonore du système qui est très nette à condition d'avoir des enceintes capables de révéler ces différences. Pour ma part je suis en Haut Rendement, bi-amplifé avec en amont un filtre actif Najda tweaké muni de sorties analogiques épaulé par des Ampli OP de compétition de chez Sparkos Labs (les plus haut de gamme, du pure class A). Pour les HP Altec 414 Z (30 cm) , chambre de compression TAD 2001 (membrane Béryllium d'origine) + Pavillon DIY (tournage CNC).
Pour finir beaucoup de passionnés se chiffonnent sur les forums de discussion pour afficher leurs préférence bec et ongle concernant tel ou tel Dac. Après avoir écumé beaucoup d'info à ce sujet j'ai retenu ce qui suit chaque dac a sa signature sonore avec nos préférences personnelles. Cependant même un dac qui au premier abord ne nous a pas plus peu se révéler redoutable après avoir changé les alims, les horloges, le reclocker, etc... C'est ce que j'ai pu vérifier en construisant mon propre système, voilà pour mon avis perso. Si cela peut servir pour prendre des décisions dans des réalisations futures, c'est plutôt cool.
Jean-François.
AUDIOPHONICS GXDC-21 Power Cable Jack DC 5.5/2.1mm to GX16 OFC Copper for LHY Power Supplies 1m This Audiophonics power supply cable, assembled in our workshop in France, is composed of a Jack DC 5.5/2.1mm connector and a GX16 connector. It can be used with LHY power...
Mettre un Olflex secteur en amont de cette trés bonne alim.
Le câble d'Alimentation Jack DC 5.5/2.1mm vers GX16 Cuivre OFC (pour Alimentations LHY) fourni avec cette alim fournissant du 15v, est correct.
Par contre, le câble secteur IEC en amont de 3x0.75mm2 fourni d'origine, est une vraie daube, il gâche vraiment cette alim qui est au demeurant excellente.
Je recommande donc fortement d'utiliser à cet endroit un Olflex de 3x1,5mm2, lequel apporte une lumière et une transparence des plus agréables.
Dominique M.
Bi amplification
Difficile à monter,pas d’indications de montage,faut-il garder les fils argentés ou les supprimer comme le montre une vidéo you tube?dans l’expectative je l’ai les enroulées autour du cuivre.
Des précisions de montage de la part d’ audiophonics seraient bienvenus au prix de ce câble.
Ceci dit je ne regrette pas cet achat,le son est vraiment bon sur tous les critères.
Un avis de quelqu’un en ayant aussi l’expérience en France peut être ?
Theodore A.
EIZZ EZ-213 XLR 3 Pin Male and Female Connectors Rhodium Plated Ø10mm Black (Pair) This pair of EIZZ EZ-213 XLR connectors consists of one male and one female XLR connector. They feature 99.99% pure copper contacts with non-magnetic rhodium plating.
Very good connector
Sound is really good, not however like the top connectors, there is a difference. For the money however the sound worths every penny.
My problem is that I used 10mm cable and the fixing screws, either sunk (had to put extra sleeve to reach 11mm) or in two cases the plastic where the screws reside was broken. Its a pity. My recommendation to EIZZ. Put an extra hardened plastic ring where the screws will reside and make them a little longer.
Theodore A.
Amazing cable
This cable provides tons of detail without fatigue!. Impressive voices. It worths every penny. And certainly a big upgrade from my previous (a good cable of 60EUR/m). Totally recommended, just get it. Used it with EIZ rodium connectors - because I prefer screw than soldering on interconnects
Marko J.
Alps potentiometer
Works great. It's been really hard to find these, but thankfully audiophonics has them!
Marko J.
Great!
Fast delivery, very safe packaging. Banana plugs are great quality, easy to install. Recommend!
Armin w.
RCA Sockets Rhodium Plated Pure Copper (Pair) These affordable yet high-quality RCA sockets are made from rhodium-plated pure copper for optimum conductivity and resistance to corrosion and oxidation.
good, hard to solder
Need a massive amount of heat to solder the outer ring
david h.
AUDIOPHONICS TPA-SW25F Class D 2.1 Amplifier TPA3116D2 2x50W + 100W 4 Ohm Black This 2.1 Class D amplifier based on a TPA3116D2 chip offers high quality sound reproduction in a compact and robust format. It delivers indeed a power of 2x50W under 4Ω...
ampli
ampli de qualiter
david h.
monacor
enceinte vibrante de qualiter
david h.
haut parleur
de grande qualiter et un son tres bon
david h.
DAYTON AUDIO DCS165-4 6-1/2" Classic Speaker Driver Subwoofer Kevlar 100W 4 Ohm 87dB 36Hz - 1100Hz Ø16.5cm This 16.5cm subwoofer speaker has a 36hz cutoff frequency. It allows the design of small subwoofers of quality and affordable. A simple amplifier in class D of 100W RMS RMS or 4...
subwoofer
un subwoofer de grande qualiter je recommande
Stéphane M.
1ér Planar HifiManifFLY
Un son très équilibré cristallin ! un vrai régal ! Très détaillé, le surround très précis aussi mais je m'attendais a plus spacieux mais comme il est très ouvert, alors oui j'ai l'impression d'entendre des hp autour de moi. Quand j'écoute ma ambeo en mettant ce casque sur mes oreilles eh bien je peux entendre tous les sons de ma ambeo + caisson de basse, donc un casque fait pour des endroits très calmes pas comme chez moi près d'une autoroute et aéroport ! mais comme il fait 92dB et avec mon Ifi Zendac v2 à fond eh bien ce n'est pas dérangeant. Très très bon casque et le prix est en train de fondre ce qui en fait un excellent rapport qualité prix.
Jean-Yves F.
Utilisé pour recaper un ampli Luxman L230.
Modèle identiques aux originaux.
Fonctionne parfaitement avec un ESR hyper faible
Jean-Yves F.
Condensateur hautes performances
J'ai "recapé" un Luxman L230 de 1985 initialement équipé de Condensateurs Rubycon et Elna Audio avec des Nichicon KZ Muse et j'en suis ravi. Il a maintenant une dynamique et une transparence qu'il n'a sans doute jamais connu auparavant !
C'est bien plus qu'une réparation, c'est un vrai upgrade qualitatif !
Jean-Yves F.
NICHICON KZ MUSE HiFi Audio Capacitor 25V 100µF Nichicon's KZ Muse series of electrolytic capacitors is ideal for processing audio signals in devices requiring high quality capacitors.
Jean-Yves F.
Jean-Yves F.
Jean-Yves F.
NICHICON KZ MUSE HiFi Audio Capacitor 100V 220μF The capacitors of the KZ Muse series can be used in particular for the processing of audio signals in devices requiring the best possible quality. They offer excellent performance.
Pedro P.
GUSTARD X30 DAC 4x ES9039SPRO + ES9311Q XMOS XU216 Airplay 2 DLNA 32bit 768kHz DSD512 MQA Black With its X30, Gustard unveils a DAC of exceptional performance and versatility. In fact, this DAC features no less than four ES9039SPRO DAC chips coupled with an ES9311Q linear...
DAC très addictif !
Attention, personne ne vous le dira, ce DAC est hautement hallucinogène, mais heureusement pas toxique ;-) Ce qui frappe d'emblée c'est son caractère organique dénué des artéfacts qui nous accompagnent depuis le début de l'ère digitale. Il faut un certain temps d'adaptation, comme pour se débarrasser d'une mauvaise habitude, après on passe avec aisance de l'autre côté du miroir, on se retrouve dans un espace où chaque son surprend par son réalisme, vous ne vous posez plus de questions d'audiophile insatisfait... Si vous êtes à la recherche d'un DAC hors du commun, celui-ci vous comblera à coup sûr. Musicalement parfait, j'en dirais pas autant de sa télécommande peu en rapport avec le pédigré de l'appareil. Ce DAC est muni d'un potentiomètre à relais, à mon avis fort peu pratique, mais surtout, il enlève une grande part de la magie dont il est capable. A utiliser en position "fixed" pour passer outre et à utiliser avec un préampli haut de gamme. Il se marie très bien avec mes amplis Audiophonics à base de modules Purifi et Sparkos, ils se sont adaptés avec plénitude et extrême fidélité au nouveau chef d'orchestre !
Laurent z.
Excellent RPQ
A ce tarif je n’ai jamais trouvé mieux. Doux, detaillé, aéré et équilibré. Mention spéciale pour le grave bien assis mais sans trainage. Une belle découverte
patrick a.
Qualité de fabrication !
La musicalité suit !
Elom G.
Très bon aop, doux et chaleureux, sur fosi V3. Je recommande
Arnaud r.
Simracing
Un petit Dac nobsound employé à 50 de gain, 1 Bst-1 visser sous le baquet et un autre sous les pédales.
Restitution parfaite sous LFE iracing, avec leur plage de fréquence limitée.
Le serrage doit être ajusté finement ( 1 ou 2 Nm), voir amorti sous les écrous. Cela pour bénéficier de l’amplitude des fréquences.
Trop serré rend un brouillon haute fréquence.
Exemple, le passage des rapports envoie une bonne tape.
Aucune chauffe dans ses conditions…. À voir dans le temps
Sebastien W.
FIIO Q7 Portable Headphone Amplifier DAC THX AAA-788+ ES9038Pro XMOS XU316 Bluetooth 5.0 32bit 768kHz DSD512 MQA FiiO presents with its Q7 an extremely powerful and complete portable headphone amplifier and DAC, taking advantage of a high-end design to allow you to enjoy your music at its...
Impeccable...
pour alimenter mon Sennheiser HD 820 avec une bonne autonomie.
Parfaitement compatible avec l'app UAPP (Android)
Fernand B.
très bon rapport qualité prix et livraison rapide
DANIEL M.
Optical Toslink Switch Selector 4 Inputs to 2 Outputs This Toslink Optical Switch integrates 4 inputs and 2 outputs. The selection of the outputs is very simple thanks to the button on the front panel or via the supplied remote...
Une bonne matrice optique 4 x 2. J'aiguille trois entrées TOSlink vers 2 sorties. Ça a marché sans problème à la mise en route...
DANIEL M.
Je n'ai pas testé toutes les configurations mais il a marché dès que je l'ai branché sur mon lecteur BluRay Sony qui n'a qu'une sortie coax.
Frank G.
Klangbild mehr analog
Habe die Karte mit etwas Geduld in meinen Roon Rock Server eingebaut, und war überrascht wie gut der Klang sich über die Zeit verbessern konnte. Die Karte braucht auf jeden Fall eine längere Einspielzeit ( min. 70 Stunden) um jeglicher Art von Spitzigkeit zu verlieren. Danach klingt Sie einfach wunderbar homogen ,entschlackt und erzeugt ein größeren schwärzeren stillen Hintergrund. Klanglich macht Sie nochmals ein großen Schritt nach vorne, wenn man die Karte mit einem externen Linearen Netzteil betreibt. Tolles Produkt
Olivier L.
Mon vieux caisson reprend vie
Bonjour, ce haut parleur est parfait pour réparer mon vieux caisson caisson de basses Yamaha YST-SW30. La réponse en fréquence est idéale. Important, ne pas oublier à vérifier la fréquence de coupure dans votre ampli.
Merci et bonnes fêtes à tous.
Olivier L.
Krzysztof M.
[GRADE S] ELECAUDIO CS-361B Power Cable OCC PTFE 3x2.5mm² Double shielding Ø17mm 90cm Refurbished product - Grade S 90cm long pre-cut cable
Perfect!
Produit conforme à la description, livraison rapide et sûre. Merci pour une transaction réussie!
Krzysztof M.
Perfect!
Krzysztof M.
Perfect!
jean-françois v.
Upgrade horloge Accusilicon vers SC Pure
Petit retour d'expérience sur cette nouvelle horloge SC Pure de chez Ian Canada. En effet, dans mes autres post sur mon streamer audio à base de produits Ian Canada je ne suis pas déçu de ce changement d'horloge !! Même si l'apport en qualité n'est pas aussi flagrant, il y a tout de même un petit gap avec ce qui suit :
A noter que dans cet uprgrade j'ai aussi mis des supercondos en sortie de l'alimentation 5V régulée Linéar PI de chez Ian Canada pour alimenter le reclocker FIFO PI Q7 II.
Pour finir beaucoup de passionnés se chiffonnent sur les forums de discussion pour afficher leurs préférence bec et ongle concernant tel ou tel Dac. Après avoir écumé beaucoup d'info à ce sujet j'ai retenu ce qui suit chaque dac a sa signature sonore avec nos préférences personnelles. Cependant même un dac qui au premier abord ne nous a pas plus peu se révéler redoutable après avoir changé les alims, les horloges, le reclocker, etc... C'est ce que j'ai pu vérifier en constuisant mon propre système, voimà pour mon avis perso.
Jean-François.
Viborg ?
Rien a voir avec la qualité habituelle de Viborg. Des vis indevssables, un corps d' habillage très cheap. Cependant, la fiche de contact semble de qualité au regard du tarif
Dominique B.
Pourquoi vouloir plus gros et cher ?
Je suis agréablement surpris par ce tout petit ampli de puissance .
Surpris par sa petite taille et par la taille de l’alimentation 48v/5amp plus imposante que l’ampli.
Surpris par la qualité de fabrication . Un bloc mono à 149€ avec son alim déportée , il faut trouver où placer ces « petits éléments » car le choix est grand du fait de leur taille .
Passons à l’écoute .
Pour son achat je me suis basé sur les mesures Audio science review . Elles sont d’un haut niveau , on est dans le classement des meilleurs amplis mais son prix est ridiculement bas !
On est juste derrière un Nad C298 stéréo, à 2300€ !
J’ai branché mes 2 blocs Fosi V3 mono en XLR avec des câbles Audioquest Red River qui valent aussi chers que mes 2 Fosi V3 mono . C’est disproportionné voire idiot mais je n’ai que ces câbles .
J’ai donc débranché mes blocs mono Purifi Audiophonics pour y mettre les Fosi .
Première remarque , la différence entre les 227 w du Purifi et les 120w du Fosi est nette .
C’est normal , environ -3db à 1 mètre .
Après plusieurs heures de chauffe et d’écoute , je ne suis pas déçu, le son est clair, ciselé , les basses sont sèches et profondes . Ça descend bas . La dynamique est présente .
On écoute sa musique , ses films avec du plaisir .
Par rapport à mes Purifi qui coûtent 4 fois plus chers, je vous assure que la différence de prix n’est pas justifiée .
Le Purifi MPA-M400ET est plus puissant et au final il se dégage un son plus plein et plus équilibré à mon oreille . Cela reste très subjectif .
Si 120 watts /8 ohms( 240w /4 ohms) vous suffisent , alors à ne pas hésiter .
Caractéristique aussi à prendre en compte, cette petite boite tient les 2 ohms !!!
Après des heures d’utilisation, le boitier est un peu chaud mais rien d’alarmant . Beaucoup moins qu’un ampli Nuprime STA9 ou qu’un préampli Marantz av8805 , matériels que j’ai possédés .
Au final je recommande ces blocs mono qui à ce prix sont un véritable cadeau .
Si vous voulez booster un ampli audio vidéo , cela peut être une solution peu coûteuse même en rca . Vous pourrez régler le gain sur 25 ou 31db .
Sur un préampli comme des Marantz AV10 , Anthem av60,70 , Arcam etc…… pas la peine d’allez chercher des 5, 7 ou 16 canaux hors de prix .
Moi je vais alimenter mes LCR avec mes Purifi et mes 12 autres canaux avec les Fosi v3 mono .
Cela en fait beaucoup à empiler mais ils sont petits .
Je suis en salle dédiée en 9.2.6 .
Claude C.
Trés bien, grande amélioration du son PC.
Reconnu imédiatement sur pc Win10.
Utilisé sur installation basique pour karaoké depuis un PC pour les enfants.
Amélioration immédiate de la musicalité des bandes son.
Connectique bien plus fiable que le jack, plus de parasite et bruit de fond.
Bref, le B. A; Ba pour ecouter correctement du son depuis un PC, d'autant plus vu le faible cout.
jean-marie G.
DDHifi TC07S USB-C Cable Pure Silver / OFC Copper OTG 50cm The DD TC07S cable consists of a male USB-C OTG connector on both sides. The cable features an optimized structure with perfect separation of the data and power conductors to...
Bon produit fonctionne sans problème
Fonctionne sans problème sur iPad Pro, associé au Chord Mojo2, et aussi au Earmen TR1.
lezzoum h.
Bonjour, je remercie tout d’abord les équipes d’Audiophonics pour leurs efforts, le produit est arrivé 48 heures après la commande, la demande a été faite un Lundi, le mercredi je l’ai récupéré au point relai, de mon choix, après avoir été averti par SMS par le transporteur. Le carton du produit était dans un 2ème carton d’Audiophonics, aucune trace ou impacte qui montre que le produit a été mal mené.
Le produit lui même était bien protégé, nickel, livré avec un câble secteur, un câble USB, une carte de garanti, et un mini disque. Le seul hic est qu’il n’y a pas de manuel d’utilisation, surtout pour savoir le fonctionnement du slot mini-SD, qui reste un mystère pour moi. Enfin, j’ai téléchargé un manuel en Anglais, mais le slot SD n’y est pas mentionné.
Je ne suis pas un testeur de DAC, mais je vais essayer de partager ma modeste expérience avec mes mots à moi.
Le Gustard X 30 remplace mon ancien DAC Topping D 90, que j’utilise depuis presque 5 ans. Je vais donc naturellement le comparer à ce dernier, malgré que ce n’est pas la même gamme de prix car le D 90 est 4 fois moins chère que X 30.
Je l’utilise comme un pure DAC, relié par câble USB sur un Mac. Le logiciel est Audirvana, Le X 30 est branché sur un préampli LA-4 de marque Sugden et un bloc de puissance de la même marque SPA-4, fonctionnant en classe A, et une paire d’enceinte de marque B&W 702 S2 à évent arrière, qui est d’ailleurs semi obstrué, à 60 cm du mur postérieur. Mon salon fait 26 mètre carré.
Le filtre courant est de marque Powergrip YG-2, les câbles secteurs et XLR de marque Audioquest, câbles HP sont Silver HD12 HP de chez Viard audio.
J’écoute tous genre de musique, du classic, du jazz jusqu’au musique du monde et même de l’éléctro. Mes fichiers vont du MP3 au DSD 64 et 128, alors attachez vos ceintures car la musique décolle !
La première impression c’est Waouh, Waouh, Waouh, la scène sonore est énorme, et la chose qui attire l’attention c’est le grave, qui rempli la pièce, sans localiser d’où sa vient, j’aurais jamais imaginé que les 702 ont un tel grave, qui est maitrisé, classe A oblige.
Le X 30 a environ 100 heures de fonctionnement, on va dire qu’il est presque rodé en une dizaine de jour.
La scène sonore : Oui la scène sonore est large, elle rempli tout le mur postérieur, avec une certaine image 3D. Les instruments ne sont pas derrière le mur, mais avec une profondeur de 2 mètres environs, le son est projeté plutôt vers l’avant, les différents instruments sont très séparés. Quoi que avec certains enregistrements, on écoute du son derrière le mur, dans les hauts médiums.
La dynamique : Sans blabla, il est très dynamique
Le timbre : Très agréable, mieux que le D 90. Ce qui attire l’attention le timbre de la batterie.
La transparence et les aigus : Oui il y a de la transparence, le son est beaucoup plus détaillé que le D 90, les aigus sont espacés, non agressifs. On entend très bien les coups de fourches du batteur sur les cymbales et même sur les tambours. Les aigus sont là, on les recherche pas. Tout simplement.
Le médium : Dans ce spectre je n’ai pas ressenti beaucoup de différence avec le D 90, qui est connu pour être doux. Ici, nous avons plus d’espace, le timbre des instruments et la voix est beaucoup mieux.
Le grave : Oui il y a du grave, beaucoup plus que D 90. On entend et on sent les vibrations des cordes de la contre basse. Cela me donne l’impression que les graves semblent sortir d’enceintes plus volumineuse, et qu’ils remplissent la pièce, tout simplement.
Le DSD : Je le compare avec mon lecteur Denon BD 2012, sachant que le SACD n’est pas sa fonction principale car il est considéré comme lecteur Blu Ray. L’écoute est complètement différente ! Waouh ! Je le redis..
Le son est totalement différent lorsque j’écoute un même album en résolution 24 bit/192 Khz et en DSD. La différence est vraiment flagrante, croyez moi.
Par ailleurs le changement de résolution lors de l’écoute continue, n’est pas accompagné d’un bruit, contrairement avec D 90, branché en XLR.
Leș filtres PCM : On entend une discrète déformation du son, fruste, lors du passage d’un mode à l’autre, et parfois il est très discret, le mode « Gentil » adoucis relativement l’écoute.
Le Mode NOS : Il reste très subtile. Pour ma pars, j’ai remarqué peu de changement avec mon système actuel.
Voila, j’ai fait comme j’ai pu pour vous partager mon expérience avec ce Gustard X 30. Vous l’avez compris, je suis très content de mon achat, et de l’évolution de mon système.
 (9)
Étienne F.
Parfait sous Linux
Fonctionne tres bien sous Linux : reconnu sans probleme, et presente ses volumes a ALSA (alsamixer).
Le son est vraiment bien aussi :D
jean-françois v.
Pour finir beaucoup de passionnés se chifonnent sur les forums de discussion pour affichier leurs préférence bec et ongle concernant tel ou tel Dac. Après avoir écumé beaucoup d'info à ce sujet j'ai retenu ce qui suit chaque d
Jean-François.
Slobodan V.
vishay dale
excellent service, good packaging and fast delivery - recommended
Jean-Marc M.
Excellent et indispensable
Cela fait à présent trois semaines que j'utilise cette alimentation linéaire régulée sur mon lecteur réseau Octavio Stream.
Sur mon installation la différence est impressionnante. Tout est sublimé du grave à l'aigu, les voix sont encore plus réalistes, l'aération, les silences, ...
Pour information mon lecteur réseau me sert uniquement pour la lecture de Qobuz. Il est relié en optique toslink à un préampli à tubes , ampli à tubes et enceintes à HP à excitation et à haut rendement (LB8EX d'EMS Acoustics).
Sur mon alimentation le câble secteur est un Réal Câble Kapton et l'alimentation est reliée au lecteur Octavio via un câble Qed USB A vers USB C.
Cette alimentation est indispensable pour tirer le meilleur de vos sources en 5V.
Un grand merci à Audiophonics pour créer un tel produit, à un prix abordable et avec un rapport qualité prix exceptionnel.
Raymond M.
LETSHUOER S12 PRO Dynamic Planar-membrane In-Ear Monitor IEM 16 Ohm 102dB 20Hz-20kHz The LETSHUOER S12 PRO earphones have been designed to bring a unique touch to the range, offering a pro quality in terms of settings. Using brand new 14.8mm planar...
Ecouteurs oui, câble non
Les écouteurs sont super (c'est du planar top niveau) mais le câble est à jeter illico... il étouffe complètement le son, j'ai pu le vérifier en le remplaçant par celui livré en standard avec mes 7Hz Timeless: c'est le jour et la nuit, l'écoute est transformée, puissante, aérée, normale quoi. C'est un peu limite de fournir un câble de piètre qualité avec ces écouteurs...
Antonio D.
Super amplificateur, très neutre, dynamique enorme, beaucoup de réalisme et transparence, sans jamais fatiguer a l´ écoute.
Je l´ utilise avec mon DMP A8 directement et j'en suis très satisfait.
J'avais dans ma liste des ampli coutant 2 ou 3 fois son prix, de marques très réputées et je le préfère a tous sans regarder au prix.
Je viens de lui changer les AOP audiophonic par des sparkos 3602, mais trop tot pour un avis, mais au premières écoutes il me parait que le son a les basses et dimensions différentes, pas nécessairement mieux, mais je n'ai que 3 heures d'écoute.
Mes audiovector QR7 sont maintenant bien alimenter et son devenus tous ce que je voulait, merci Audiophonic.
Marcel O.
Gustard H26 highly recommended
I love the product. Outstanding built quality. The audio quality is phenomenal. I don’t know if it can actually get any better. In classical music, I can clearly hear more instruments, subtle nuances, and layers that were hidden from me with the old headphone amplifier.
My current audio setup is as follows:
Streaming Tidal Direct on the Eversolo DMP A6 Master Edition with LPS, connected via USB cable to the Gustard A26 DAC, connected via XLR to the Gustard H26, headphones used Hifiman HE1000SE.
I can highly recommend the product from my own initial experience.
Javier C.
Great Power Supply for Chord Hugo TT2
High quality power supply for Chord Hugo TT2 DAC which needs a maximum of 4 Amp
Low heat dissipation temperature on the heatsink
Vincent C.
Top génial
Toute la famille peut streamer sa musique. Son vraiment au top, j'adore!!!
