YANN P.
Excellente barette secteur
Jeroen v.
Jeroen
Kah Yeow K.
Great cable for REL
John B.
Amanero Combo 384 Review
Amanero Combo 384 review.
I received the module quickly and in good condition.
I purchased this module because I was looking for a low jitter USB interface that supports PCM up to 384 KHz. I am a MAC user and the Amanero works fine on a MAC without the need for drivers.
Jitter performance is not the best, it gets bad above 96KHz Some suggest to use XMOS-based USB receivers for sample rates above 96 KHz.
The whole point of using isochronous USB audio with asynchronous feedback and two local master clocks is to get low jitter .....
Major reasons for this are poor power supply decoupling, not the best master clocks and a FPGA that injects significant jitter. I2S timing signal from the Atmel processor has lower jitter.
The I2S clock and data signals are not correctly aligned, alignment gets critical at 352.8 KHz and 384 KHz.
The 3V3 regulator is not the best in terms of noise, line & load regulation & PSRR. I replaced it with a pin compatible LP5907-3V3 that offers better performance. Linear Technology has even better one's (LT3045).
I also improved power supply decoupling using chokes (2.2mH) and low esr V-polytan capacitors. Passive filtering of the master clock supply offers biggest improvements in jitter performance.
I replaced the master clocks with lower jitter clocks from Kyocera Electric.
The suggested digital isolators will add 100ps of extra jitter (typical) and input-output coupling capacitance is rather high (4pF).
I am now very pleased with the modified Amanero module.
Only 4 stars because I had to modify the module in order to get desired performance.
Nicolas V.
Bonne alim. souci de finition.
Bonne alimentation, tension très stable.Possibilité de faire ajuster la tension à la commande (7v dans mon cas)..et la tension personnalisée est écrite sur la petite étiquette au dos !
Fonctionnement très silencieux. Chauffe peu, mais non testée sous forte charge.
Boîtier de fabrication robuste avec des matériaux de quallité (alu) mais souci de finition :
Le feeling, et le bruit, de l'interrupteur est très médiocre
pieds en silicone mal collés, non alignés sur mon appareil
Défaut d'alignement assez important de 2mm entre la façade et le corps du boîtier sur un côté de l'appareil. pbl de Tolérances de fabrication ou d'assemblage.
petite led blanche comme témoin de marche: sympathique et tendance...mais pas rationnel pour une alim. Un détail.
Melvin L.
excellent petit amplificateur
petit amplificateur qui tiens ses promesses.
aucun soucis des la mise en service, prêt a fonctionner !
ampli ayant une bonne puissance en réserve.
je recommande.
bernard d.
1877PHONO LEVEL 10 Precision Bubble Level Vinyl turntable This high-precision bubble level allows for quick and easy horizontal positioning of your turntable.
Beau produit, très précis mais un peu lourd en comparaison à d'autres produits.
hugues g.
Je confirme l'excellence de cet ampli
Voila mon 1er test avec des Altec monitor III était déjà très bien, mais j'ai trouvé qu'il chauffait un peu et manquait de punch pour la puissance annoncée donc j'ai pensé a faire le même teste avec toujours le même mini DAC relié au PC, mais cette foi ci avec une paire de colonne jamo S406 en 6 ohms et là... j'ai tout compris, cet ampli est vraiment une bombe pour celui qui connait à faire les bon dosages (c'est un métier). Impossible de le pousser à fond (risque de péter les vitres a cause des basses) dans ce test mais aux max il garde très très bien la conduite de la palette sonore c'est vraiment Top, là vraiment j'ai vraiment apprécié la griffe sonore et je reste sur des colonnes en 6 ohms pas plus pour lui (l’idéale et en plus ça chauffe beaucoup moins !!! et on gagne plus de punch) . Voila , je vous recommande cet ampli avec une paire de colonne (moi je vais m'en trouver une autre paire encore meilleures pour cet ampli car il en vaut vraiment la peine croyez moi) et n 'oubliez pas un DAC (y en à des très bon sur ce site). voila j'ai tout dit et si vous entendez un tout petit bruit insignifiant après l'allumage c'est normal c'est des composants qui travaillent. AUDIOPHONICS est discret mais tout le monde en parle car ils ont du bon matos et accessible aux non initiés MERCI à toute l'équipe !!!
Nicolas V.
Bonne qualité.
Bonne qualité de fabrication. Intéressant de pouvoir acheter juste l'exemplaire voulu sans acheter tout un jeu.
Peter P.
Perfect Bluetooth receiver
Bluetooth as good as you can get it for a stable transmission of music files from ie your iPhone to your DAC in a high quality stereo setup. Easy install, no dropouts, even with high resolution files. You only pay for the best Bluetooth card and not for an extra DAC or other functions you don’t need.
Peter, Denmark
Olivier L.
ARYLIC COBBLESTONE WiFi Receiver AirPlay UPnP DLNA Multiroom 24bit 192kHz The Arylic Cobblestone is a WiFi receiver that allows you to easily and efficiently stream your files from your network, smartphone/tablet or your favorite streaming services....
Bon boitier
J'ai deux lecteurs iEast depuis plusieurs années et j'enrage régulièrement avec des pertes de connexion, des coupures lors de la lecture...
Je les utilise pour écouter Qobuz.
Pour installer à la campagne, j'ai d'abord acheté des Chromecast qui sont catastrophiques lorsqu'ils sont pilotés par un : il est très difficile de lancer la lecture, le son apparaissant parfois... ou pas ! Probablement un problème de compatibilité avec Apple.
Pour les remplacer, j'ai donc acheté un Arylic qui fonctionne parfaitement. L'installation est très simple et le pilotage avec l'appli iEast permet de lancer Qobuz parfaitement. La liaison est stable et je ne constate aucune coupure, moins qu'à mon domicile principal avec les boitiers Qobuz...
Le son est bon, la puce de conversion apportant une sonorité agréable.
Il ne rate sa cinquième étoile que du fait de l'absence d'une sortie numérique qui aurait permis d'associer un DAC externe.
Mais au regard du prix, il ne faut peut-être pas trop en attendre.
Guy L.
guy13
excellent câble de Furitech. Son très pur et musical
Guy L.
guy13
très bon rapport qualité/prix pratique à connecter. La définition suit
Guy L.
guy13
son très fin et belle définition plan sonore bien espacé
paul p.
Mes enceintes de 40kg étaient initialement sur leurs pointes d’origine sur pièce de monnaie que j’avais ajustées avec grand soin. Je ne m’attendais donc qu’à une légère amélioration car tout le système était déjà bien optimisé.
Pourtant force est de constater que l’ensemble des paramètres du son y gagne, ce qui en fait au global un réel pas en avant supplémentaire : précision et maîtrise du grave, scène sonore accrue en taille et stabilité , expressivité générale, micro détails supplémentaires ,...
Finalement un seul regret, ne pas les avoir achetées plus tôt !
Un accessoire juste indispensable au vu l’amélioration sonore /prix.
Nb : après essai sur les patins de feutrine livrés avec, je les ai enlevés car impossible de stabiliser proprement les enceintes, grave baveux et son détérioré par rapport aux pointes d’origine
David m.
génial
je le possède depuis plus d'un mois, j'ai très vite remplacer le tube (qui n'est pas si mauvais) par un electro Harmonix (j'ai aussi testé le Tung-sol qui rend bien également)
c'est un très très bon preampli casque qui possède également des sorties pour l'ampli de puissance... pratique quand vous y brancher un ordinateur pour écouter votre musique avec. Mon casque est un Sennheiser TR 180. le son est incroyable ! seul point négatif... le cd driver fourni ne fonctionner pas chez moi... un petit tour sur le site pour telecharger les drivers et tout est rentré dans l'ordre...
emballage nickel et livraison hyper rapide. site ultra sérieux
Nicolas V.
Câble de qualité
Utilisé pour raccorder un conditionneur USB et un DAC . Très bonne qualité de fabrication apparente. Câble épais et assez rigide, gage de sérieux .Ergonomie des fiches.
L'intérêt d'un tel cordon est toutefois discutable, le rendu sonore étant identique à un câble basique à 2 €.
Nicolas V.
Câble basique mais bien fabriqué. Forte section (1;5 mm2) par forcément utile pour la plupart des applications, un câble en 1 mm2 devrait être proposé. Prix intéressant.
Nicolas V.
Produit de bonne qualité, à un prix imbattable.
Petit détail : la prise USB A est inversée , ce sui peut obliger à vriller un peu le cordon, peut-être dommageable dans le temps sur un cordon court de 0.45m .
Rendu sonore identique à un cordon 'Audiophile' (sur mon système)
Dominique B.
Parfait pour mon utilisation
Parfait pour mon utilisation, entre une platine CD à sortie fixe et un système de sonorisation informatisé, me permet d'agir rapidement sur le volume sans rentrer dans la programmation. Pas de souffle , volume cranté très pratique pour être sûr de rester calé sur une position. Aspect sécurisant. Bonne qualité.
Alain L.
facile à monter, solide. ne dénature pas les qualités des conducteurs, neutre et celà c'est parfait.
Alain L.
connecteur facile à monter, solide.
je pense que son intérêt principal est sa neutralité qui ne dénature pas la qualité des conducteurs utilisés ce qui n'est pas le cas de tous.
Karl d.
Yarbo sp-2200 power cable
All of the Yarbo line of mainscable are great.
but if you want to have a little more transparent and analytical sound,than take this one.
Florent L.
flo
Super le pied la qualité est là foncer!!!
hugues g.
j'étais intrigué par celui-ci et je l'ai écouté
Réception du colis sans problème, c'est un ampli très solide et discret coté boitier et matériel !!! Je lui ai mis des Altec monitor III au derrière juste pour le test et je lui ai joint un petit "FX-AUDIO FX01 DAC" pour le relier au PC.Sur Foobar 2000 et j'ai lancé Salsa , Reggae et du Disco. Voilà !!! Je trouve que cet ampli à un gros son bien voluptueux et chaleureux et pas besoin de pousser on percoit bien le spectre sonore. Cest du bon audiophile pour son mini prix. Après c'est à vous de lui adjoindre ce qui va l'enrichir.Moi je pense lui trouver des petites colonnes et y brancher ma vieille platine Thorens, parce que ce son me rappel quelque chose. Juste petite remarque inutile, ne vous inquiétez pas le bestio chauffe mais à juste proportion, les évents d'aération et les composants sont prévus pour !!!
Jean Emmanuel H.
Utilisé sur une platine vynile Sansui SR 222. Je confirme le ressenti sur le même câble utilisé entre mon DAC et l'ampli (le même en rouge). Surprenant en transparence et en musicalité. Nettement supérieur à mes anciens câbles NBS à 400€.
Jean Emmanuel H.
Très bon câble pour le prix, neutre et transparent. Légèrement supérieur à un Real AN-99
GIANLUCA B.
Suono molto buono
Amplificatore piccola e versatile il suono rispetto al mio presidente molto migliorato soprattutto nelle basse frequenze consigliatissimo
Sebastien M.
Ampli FDA non audiophile...
Après toutes les éloges lus ici et la (Qobuz etc...) comme quoi l'ampli FDA Alientek D8 valait normalement 10 fois sont prix, donc il aurait dû surpasser les ampli a 1000€, et que c'était une révolution, je me suis lancé...
Une fois branché a mes enceintes Elipson 4I avec des câbles HP puretrans et un bon câblé de modulation, voici mon ressenti :
Une claque!!!!!! De médiocrité !!!!!
Des grosses basses mise en avant peuvent impressionner des non initiés, pareil pour les autres registres, ce n'est pas équilibré du tout, bref il ne vaut pas 10 fois son prix mais il vaut son prix.
Concernant Audiophonics, c'est juste top, ils répondent au flots de questions très vites.
L'envoie le jour-même, rien a redire
Bernard D.
Voltage Adapter Converter 12VDC to 19VDC 8A 150W Convert 12V DC to 19V DC with this compact 150W step-up converter that will give you a stable power source.
Très bon produit !
Produit efficace et fiable qui tient parfaitement la puissance indiquée. Ne chauffe pratiquement pas !
MARCO F.
Connecteur GX16
j'ai commandé ce produits pour une realisation personnel et je doit dire que c'est un bon produit de chez Audiophonics ...je ne regrette pas cet achat chez Audiophonics.....
Jean-Daniel B.
La qualité de maintien du contact parfaite pour le prix d'une prise de qualité.
Brassage facile.
Jean-Daniel B.
Simple à câbler mais pourquoi 2 tailles de torx pour un même produit ?
Sinon bonne qualité.
Jean-Daniel B.
Il y a de la place pour souder proprement. Le réducteur en plastique se retire facilement pour un diamètre de câble supérieur.
Rien à redire pour le rapport qualité/prix.
joel c.
bonne fabrication pour leprix
Après une longue écoute je l'ai remisé dans mon tiroir fourre tout car il et moins bon que ma liaison optique , il resserre l'image , moins de piqué et de réponse transitoire , ma liaison optique est libre sans tassement , ça pétille , c'est la joie c'est peut être a cause de certains défauts o combien agréables , ce coax est trop sérieux pour moi ....
Solution impeccable pour une double installation hifi Home cinéma avec deux amplis dédiés. Je n'ai pas entendu de différence de qualité d'écoute depuis que mes enceintes et mes deux amplis sont branchés sur ce sélecteur bien conçu et qui semble être de qualité. Une petite manip sur le sélecteur et on passe de l'un à l'autre simplement. Deux installations dédiées en une, excellent!
Dimitrios M.
Overall great Service
Great product. Works as expected. Excellent service.
huseyin t.
Smallest enclosure for decent sound
İ was searching for small full range drivers for long time to house in very small enclosure.spx21 probably best alternative for this aim.0.3 liter enclosure with 19 mm.diameter and 15 cm length port ,very impressive sound.mids and highs are excellent but if you're lover of bass this driver might not right for you.its loud but if you push the volume it's get distorted especially in notes under 150.i am not sure about the building quantity if you consider the magnets felt down,i still wonder what was the reason coused this.it wasn't a big problem for me I could fix it with two component epoxy bonding.worked well for me but it shouldn't broken this easy.probably i expect too much from a driver less than 16 EURO.this driver has a great potential if monacor built them with little better quality.
Frédéric D.
Impressionnant
De la vieille école, mettre une connection bluetooth en hifi, no way. Eh bien, très agréablement surpris !
Stephane B.
Une valeur sûre
Je possède la version 2017 (acheté en Juin)
Il est lourd, il chauffe, il est vivant, profond, puissant et délivre la musique avec amour. Jusqu'à ce jour le meilleur ampli que j'ai possédé .
Je confirme l'avis de Frédéric A. : inutile d'essayer les Ampli classe D style Hypex ou Icepower.
Stephane B.
Son exceptionnel en DLNA avec dac externe
Ce petit boitier bien construit procure un rendu sonore à un DAC connecté en USB ou coaxial absolument bluffant : grande profondeur et largeur de scène, début et fin de notes saisissants, à ce prix je me demande quel est son concurrent.
Seul bémol : le firmware est mal programmé, il fonctionne de façon capricieuse en dlna et reste très instable avec un dac connecté en USB.
Utilisé comme lecteur de fichier local c'est une affaire, le rendu dépasse largement une Digione, d'après mes essais et d'autres retours sur les forums audio.
Stephane B.
Belle dynamique mais écoute fade et ennuyeuse
Cet ampli est assemblé dans un beau boitier sobre et solide.
à l'écoute sur des JBL 4430, avec une digione signature en source, il drive parfaitement les 38cm, normal avec un facteur d'amortissement aux environ de 1000.
Je me suis emballé au départ, séduit par la plage dynamique qui explose tous les amplis de classe A-B.
Après 48h d'écoute, repassant sur mon Audio Gd Master 3, je me suis rendu compte immédiatement à quel point le Ncore 250 était fade, trop mat, manquait de détourage sur les voix et les instruments, en un sens "normalisait" la musique, finalement je suis déçu par cette signature plutôt ennuyeuse.
Sur le papier il est redoutable, au niveau émotionnel, il ne m'a pas touché.
Attention : les modules Hypex vibrent en émettant un buzz comparable à un petit néon, émanant du boitier, même l'ampli éteint, il faut le savoir si vous projetez de l'installer dans une pièce par exemple dans laquelle vous dormez.
 (9)
Pascal C.
Protection modules for stereo speakers 12V 16A (Pair) This double mono protection module consisting of two cards will allow you to properly protect your speakers.
très bon module de protection.
J'ai acheté ce module de protection pour éviter les "plocs" d'allumage et extinction d'un module d'amplification TPA3255.
C'est très bien construit et la temporisation est assez longue. Impeccable.
Johannes g.
DIY Box / Case 100% Aluminium 260x311x90mm Silver Pannel This aluminum-grade case with a thick 8mm faceplate is perfect for designing class D preamplifiers, DACs or power amplifiers for a professional quality finish. This box comes...
bon rapport qualité prix
pas trop mal fini, certains trous sont à la limite du bord mais ne gênent en rien pour visser. tout rentre parfaitement les filetages sont bien fait, aucun soucis.
Jerome L.
Genial
Je me suis monté un dac preampli, branché a un module dac sabre.
Je souhaitais tester et je suis renversé! Niveau son Ca joue dans la même cour que mon dac rme a 1000e(Sans les nombreuses options de ce dernier indispensables en studio)
Je n ai pas changé les aop, n en ai nullement ressenti le besoin a vrai dire, cablé en xh avec les cable audiophonics a embout plaque or et a un potentiometre alps 50k c est vraiment impressionnant (surtout à la vue du budget...!)
Merci audiophonics de proposer cette qualité en diy!
Le DAC parfait
Après avoir essayé plusieurs DACS delta sigma, dont certains très bons, je suis revenu à mes premiers amours, la conversion R-2R.
Ce qui m’a définitivement convaincu c’est que, sur ce modèle, les réglages se font enfin en façade, sans avoir à ouvrir pour jouer avec les jumpers.
Au déballage, ce qui surprend c’est la qualité de finition de ce bébé de 5 kg. Pas de chichi, l’essentiel, sobre et très alu.
Je l'ai ouvert, dedans c'est de toute beauté. C'est a regretter que le capot ne soit pas transparent.
CONFIGURATION D'ECOUTE
Carte USB Hifi avec alimentation séparée et filtrée
Streaming par USB Qobuzz Hi-RES Via AUDIRVANA (sur échantillonnage désactivé)
Purificateurs secteur sur ampli et Dac
Ampli à Tubes Line Magnetic
Enceintes Tannoy et cables Mogami 3103
Dac en position NOS
A la première écoute, la chose qui saute aux oreilles c’est l’image sonore, la spatialisation est grandiose. Le son est holographique, gauche, droite, centre, avant, arrière, les musiciens sont devant vous.
Les détails fourmillent à profusion, le moindre frottement de brosse sur une cymbale est audible. Les silences sont vraiment profonds également.
Le son est nerveux, mais pas agressif, la dynamique est incroyable, c’est vivant.
Parlons des timbres.....la référence que tout le monde connais le mieux c’est la voix.
Je peux vous dire qu’elles sont d’un naturel incroyable, c’est vraiment analogique.
C’est un peu comme la balance des blancs en photo…quand la voix sonne vraie et juste, tout le reste est bon.
Diana Krall est a 2 mètres de moi et on entend le moindre grain de sa voix suave, sans sibilance et aigu artificiel
Bref, les timbres sont très neutres, sans coloration et correspondent à ce que le preneur de son a voulu.
Vraiment un superbe DAC, surtout pour ce tarif.
Avant de les expédier Audio-GD fait fonctionner les dac une centaine d’heures, mais ils disent que la maturité sonore arrive après 500h…ca promet
Merci à David Aubert et son équipe pour leurs bons conseils d’avant et après achat.
TRES BONNE MUSICALITE
Cette modeste évaluation s'adresse à ceux qui cherchent un câble optique de qualité et aussi aux sceptiques persuadés que tous les câbles numériques se valent. Sur ce dernier point, je suggère toujours d'essayer plusieurs câbles et de ne mettre à contribution que ses oreilles pour se convaincre des différences, parfois considérables, parfaitement perceptibles à une ouïe même peu entraînée! Commençons par l'aspect mécanique de ce câble optique VIABLUE H-FLEX pour déplorer se très grande rigidité. Il est concevable que le fabricant ait volontairement adopté cette conception afin de dissuader l'utilisateur de couder le câble, ce qui s'avère généralement fatal à la fibre optique! Compte tenu de ce point, on prendra soin de choisir un câble d'au moins 1 mètre car la version 0.5 mètre risque de vous confronter à d' insolubles problèmes de connexion. D'autre part, il faudra aménager un certain espace entre l'arrière de vos appareils et le mur. Sur un plan purement musical, ce qui est bien évidemment l'essentiel, ce VIABLUE se révèle être une belle surprise. Par rapport à l'excellent câble coaxial numérique CANARE (en vente sur ce site), le VIABLUE va peut-être encore un peu plus loin en transparence. Les timbres sont très naturels, d'une agréable véracité. Le soyeux des violons est préservé et les attaques du piano étonnent par leur très grande précision au prix toutefois d'une certaine atténuation du feutré, feutré que l'on perçoit mieux avec le coaxial CANARE. Les capacités de résolution du VIABLUE sont de premier ordre, les détails se perçoivent avec aisance sans accentuation gênante. La dynamique épouse le discours musical sans que l'on constate la moindre contraction, tout cela s'obtient sans aucune dureté, quelque soit le registre exploré. L'image stéréo, enfin, est tridimensionnelle avec toutefois une dimension atmosphérique légèrement moins "palpable" qu'avec le coaxial CANARE. En résumé, un câble très musical apte à satisfaire le mélomane, et une aubaine dans cette gamme de prix;
SHUGUANG TREASURE 6CA7-Z Amplification Tubes (Matched Pair) Shuguang's 6CA7-Z power tubes incorporate a grid with gold wires and a glass with black internal HPCC (High Polymer Carbon Compound) coating. The latter has the...
Comparaison de la famille de tubes EL34
https://blog.thetubestore.com/audiophile-review-el34-family-tube-comparison/
Marc B.
couplé à 2 enceintes colonnes elipson prestige 3i et un chromecast-audio en entrée, le rendu sonore est excellent. Le service audiophonics est de plus très réactif, et il m'a envoyé rapidement le câble d'alimentation manquant. J'ai longtemps hésité avec un ampli FDA mais je ne regrette absolument pas mon achat.
Une petite remarque sur mon installation: en collant l'oreille sur l'ampli, j’entends une vibration du transfo torique du à mon alimentation, qui ne s'entend évidemment pas dans les enceintes et n'est pas audible à ma place d'écoute.
Jean-Daniel B.
Maintient de la prise parfait, le cordon ne bouge plus par rapport à l'IEC d'origine..
Myrielle m.
bien donc 5 étoile
furutech FP-TCS31 bien attention par contre le câble secteur furutech alpha 3 avec des prise secteur furutech rhodium Fi 48-R il est vraiment sublime rapidité du signal franchement rien à dire la classe rester dans la gamme rhodium rien n'a voir avec le cuivre bien sur voir salon hifi Munich 2019
Yannick M.
superbes connecteurs
J'ai essayé ces connecteurs sur du câble Neotech Nemoi 3220, et je dois avouer que c'est la première fois que j'entends une si grande différence/amélioration en remplaçant des connecteurs RCA.
Et ici, c'est surtout la densité sonore qui fait un bond. Il y a davantage de définition sur toute la bande passante, mais ça se fait "par" la densité.
ça force vraiment à une écoute non intellectuelle, on est à l'opposé du monde de la sur-définition éthérée, ce qui pourrait même faire croire à un manque de définition sur une séance d'écoute trop courte, ou mal orientée.
Ne passez pas à côté !
David b.
NICHICON KZ MUSE HiFi Audio Capacitor 100V 220μF The capacitors of the KZ Muse series can be used in particular for the processing of audio signals in devices requiring the best possible quality. They offer excellent performance.
ideal pour recap un ampli de 30 ans
Au premier abord l'ampli ne se porte que mieux. Avec les condos d'alimentation changés plus un bruit de 50 hz mal filtré.
c'est reparti pour 30 ans
