Francis B.
Étonnant
Un peu plus de transparence.
Un peu plus de profondeur dans les basses.
Pas mal vu l’investissement raisonnable! Excellent.
pascal B.
petit tweeter
rapport qualité/prix exceptionnel pour ce petit tweeter qui associé à 1 large bande de 13 cm a permis de restaurer de façon...
Eric v.
connexion
Customers reviews - There are 19232 reviews.
WIMA MKS-2 Polyester Capacitor 5mm 63V 0.1µF WIMA MKS capacitors offer a good filter capacity for all applications. They ensure a long service life even at high temperatures.
must have!
une difference notable
AUDIOPHONICS WIRE Interconnect Cable Stereo XLR OFC Copper Gold Plated 1.5m The Audiophonics Wire range offers a selection of affordable yet high-performance cables, hand-assembled in our workshops in France. The Audiophonics Wire XLR cable features a...
Excellent cable XLR
N’enlève rien ni ne rajoute rien donc parfait
Rupert S.
Great hardware
I have been using this device with Volumio and the plugin (v309) for the past 10 months or so. Sound is great, directly into a Hypex amp over XLR cables. It also functions as a volume controller and I don't think I can hear much degradation at low levels compared to a dedicated LDR volume controller I had previously: Software is Ok but still has some minor bugs and hasn't been updated for a while as of writing.
Luca D.
ETI BP-20C Binding Post Gold Plated Pure Copper Ø19mm (Pair) The ETI BP-20C are very high performance terminal blocks at contained prices. Made of 1100 Series Hardened Copper conductor with 102% IAC (conductivity index), these terminals...
Very good stuff
The connectors are very well made, strong and elegant. The quality of the copper is absolutely top of the notch, and it sound as hi-end as the famous Oyaide SSC copper cable. I higly recommend this connectors for a serious upgrade
Richard Z.
I'am happy!
Hésitant entre 2 lecteurs réseau, j'ai soumis le dilemme au très disponible David Aubert d'Audiophonics . Que ferait il , lui, en tant qu'acteur? La réponse ne m'a pas laissé sans surprise! Aucun des deux. Et c'est LE moment où il me propose un lecteur qui ne payent pas de mine par son apparence mais qui fonctionne admirablement bien, avec des caractéristiques étonnantes . Voyez la description.
L'utilisation que je voulais en faire était toute simple: balancer sur mon ampli à tube Yaquin MS30, totalement revisité ( cap Mundorf suprême et autres petites bidouilles à ne pas faire rougir en face d'un Mc Intosh), ampli relié à - au choix- des enceintes DIY Dynaudio ( doubles parois sablées) ou des enceintes Tannoy mini autographe, toute la musique que j'aime à partir de Spotify.
Que dire?
C'est adictif !
Mansion spéciale pour David Aubert qui ne s'est jamais fatigué de répondre à mes nombreuses questions ( et à ne pas m'orienter nécessairement vers un appareil 3 ou 4 fois plus cher!).
Merci à lui pour l'excellent service/ conseil.
PS: j'attends avec impatience que le staff Spotify accomplisse sa promesse de 2021: proposer le Hi-res ...
Je soupçonne que si cela prend tant de temps, c'est qu'il nous prépare un coup d'éclat . J'ignore encore quoi...
Sinon, je vous le dirai
Jean-Pierre B.
ETI KRYO Banana Plugs Silver Plated Pure Copper Ø16 x 55mm (Set x4) These Kryo from ETI are top of the range banana plugs designed with exceptional components. It features a Tellurium Copper conductor with Silver plating for maximum conductivity...
Tres belles fiches
Ce que vous obtenez : 4 fiches bananes de très haute qualité
Ce que vous n'obtenez pas : les 4 fiches plus petites figurant sur la photo et dans la description du package en bas de la description du produit "4x Coques petits modèles"
Dommage, car j'aurais bien utilisé le modèle réduit côté enceintes et le modèle plus gros côté ampli (- 1 étoile)
Enfin notez qu'il s'agit de 4 fiches, si vous voulez équiper deux câbles stéréos côté ampli et côté enceintes il faut deux jeux soit environ 400 € port compris - j'avais cru que la présence des deux types de corps contribuaient à justifier le prix
Montage très facile avec deux vis de serrage pour le câble dénudé et deux vis sur la fiche pour le blocage du câble lui même (il vous faut un tournevis tête hexagonal 1.5), accepte du câble 5mm2 - Je les ai montées sur des câbles ELECAUDIO HP-25OFCS qui paraissent tout à coup très peu cher au regard du prix de ces fiches bananes.
Conclusion : très beau produit si vous n'avez pas besoin des petits corps de fiches et un très bon câble pour le prix de modèles montés de bonne réputation
Pour le reste Audiophonics toujours au top, expédition rapide quand les produits sont en stock
Bert D.
Small but great
A very handy volume control, top sound, no interference and beautiful to look at.
Raffaele V.
AUDIO-GD DA-7 Kit
Not simple but not complicated either. You need to pay attention to the cams and feeds and I highly recommend them.
one day of work, rechecking everything three times, It practically worked the first time. The sound is basically excellent, but can be improved with some adjustments that I will install in the future.
Non semplice ma neanche complicato. Bisogna porre anttenzione ai camlaggi e alle alimentazioni che consiglio vivamente le sue.
un giorno di lavoro, riconytrollando tutto tre volte, Ha praticamente funzionato al primo colpo. Il suono, di base ottimo, ma migliorabile con alcunio accorgimenti che intallerò in futuro.
François G.
Le problème : ronflette quand une TV et un ordi sont branchés simultanément sur une paire d'enceintes amplifiées à deux entrées.
Le transfo placé sur la ligne TV résout le problème.
Alex C.
Perfect amp
I have this driving a pair of KEF Q350s and they are perfect. Noise free. Incredible detail at any volume.
Excellents
Surpris et content de les voir au catalogue, peu de temps après en avoir fait la suggestion. Avant d'évoquer mon ressenti sur ces excellent kt88, je tiens à signaler que je suis épaté du sérieux et du respect qu' une entreprise comme Audiophonics manifeste envers ses clients. Bravo et merci pour votre excellent professionnalisme.
Quant aux Tube TAD kt88 STR, ils offrent une précision , du détail et de l' ampleur.
Tout est équilibré et bien dosé . Le grave et précis et tendu, médium riche, aigu filant et subtil. Une très bonne référence, le genre de Tube que l' on préfère...
Christophe H.
Pack Topping A50s Headphone Amplifier + D50s DAC + P50 Power Supply + TCR2 RCA Cable 25cm Black With this complete Topping pack, you have a turnkey solution to quickly and easily integrate an excellent audio system oriented towards high quality headphone listening. It...
ensemble compact et élégant
l'ensemble est très compact mais a un aspect plutôt qualitatif.
Acheté pour driver un casque sennheiser HD800s il remplit très bien son rôle avec une bonne réserve de puissance. Sonorité neutre et limpide, du tout bon !
Pierre P.
Excellent preampli à prix modéré. Du fil droit avec du gain
restitution très neutre.
la télécommande est un peu capricieuse.
Pierre P.
Le serrage dans la prise n'est pas top et le câble n'est pas tenu fermement. Pour le reste c'est OK
Marc f.
fonctionne nickel très simple d'utilisation
Bruno M.
Un excellent produit !
Délivre un message musical extraordinairement détaillé et nuancé. (utilisation avec casque Ortho dynamique Kennerton Thror et un ampli casque à lampes AudioValve Luminare)... Je pense même en recommander un second prochainement pour pouvoir en profiter sur un second équipement ...
Jérôme H.
Rien à redire sur l'usinage et le maintien des câbles. Pas de dégradation non plus du signal sonore sur mon installation. C'est absolument transparent. Pour ceux qui ne veulent pas inutilement se ruiner dans des fiches haut de gamme, c'est un choix idéal.
Xenofon T.
next time i order from china
a cheap solution for diy. Cover and bottom plate are not well to mount. Actually this is a insult.
Sliding nuts... come on!.
All in all i payed for a impression that hifi2000 dont give a fu..
I builded 2 preamps. This case war for my own. The other for a friend. His case was a wellbuild aluminiumcase, complete milled, ready to go, ordered from china.
Pascal g.
30 ans de certitudes audiophiles balayées en quelques secondes
Allez, je commence par 2 points négatifs : Le bluetooth est mauvais et les borniers HP n'acceptent pas les cables de grosse section avec fourches. Dommage, car cet ampli a des performances incroyables. Connecté à un streamer Aurender et un DAC Denafrips Pontus II en XLR, Il alimente à merveille mes capricieuses Thiel 2.4. Le registre grave est sublimé. Quelle énergie, présence et tenue ! L'aigu est fin et précis, la transparence est incroyable.Une prouesse à ce prix, et même bien au delà. J'ai possédé de nombreux amplis plus "ésotériques".. et beaucoup, beaucoup plus chers qui ne tiennent pas la comparaison (surtout dans le grave).La profondeur et la largeur de la scène sonore ne rivalisent pas encore avec des amplis HDG à x milliers d'Euros mais on parle ici d'un ampli à 249€ ! Mais commant font-ils chez SMSL ? La classe D a fait d'énormes progrès et ça s'entend clairement. ça donne envie de tester des modèles plus haut de gamme, Certaines marques "audiophiles " bien établies ont du soucis à se faire....
Et toujours une livraison ultra rapide de la part d'Audiophonics !
Excellent malgré (ou grâce à ! ) l'excès de basses
Je confirme beaucoup d'avis : rapport qualité/prix exceptionnel !
Associé au petit ampli Aiyima T9 (pourvu d'un DAC USB logiquement très basique à ce prix) , et tout aussi excellent en rapport qualité/prix mais dont le point faible est... le manque de basses en sortie ! , je vous laisse deviner l'avantage du mariage des deux.... , avec un rendu précis et une scène bien aérée sur mes FOCAL CHORA 806. Le son (Qobuz) qui sort alors de mon LENOVO (pas haut de gamme au demeurant) se révèle tout simplement comparable à celui d'un bon lecteur réseau...
Jean-Pierre B.
Le contexte :
Après avoir monté des pieds Kanto de 81 cm sous mes enceintes Blumenhofer Satellite Mini, initialement posées sur mon bureau, j'ai dû remplacer mes câbles MaxiTrans II de 2 fois 2,5 m par des câbles de 3.5 m au moins pour les relier à un Marantz Amp1. J'ai donc acheté 8 m de ce câble pour avoir 2 x 4 mètres et donc un peu de marge et je l'ai monté avec des fiches Bananes ETI KRYO.
Le montage :
Le câble est très épais avec une forte section et, si vous prévoyez un connecteur fourche ou fiche banane, assurez vous qu'il est assez grand (le ETI est limite). Sinon le montage est facile : dénuder le câble ne pose pas de problème particulier, le couper non plus (un gros ciseaux suffit).
A l'écoute :
J'étais persuadé que la notion de rodage était réservée aux moteurs de voiture, mais avec ce câble, je constate une très grande évolution après quelques heures d'utilisation : quelques fréquences stridentes se sont calmées et l'écoute est de mieux en mieux et globalement très bonne.
Conclusion :
Très bon câble avec un rapport qualité prix favorable, fortement recommandé si l'on cherche un câble dans une gamme de prix allant jusqu'à 50 euros le mètre, voire plus.
Ivan P.
Excellent product, very well made.
Ivan P.
Claude I.
Testé sur un système à haut rendement les résultats sont remarquables. L'écart entre les DACs premiers prix et le "haut de gamme" est beaucoup moins important qu'il y a 20 ans. Et ceci en tirant la qualité vers le haut. C'est l'ouverture et la spatialisation qui fond encore la petite différence. J'utilise le SU-1 comme une "carte son externe" pour extraire la musique de mon ordi et alimenter une bonne chaine de bureau. Résultat excellent.
Hugo B.
Very powerful
A single unit installed on a 3-seater sofa. The vibration is felt along the sofa at a third of the amplifier volume. I would definitely buy it again.
Adrien H.
Connecteur tout en métal, construction logique, prix raisonnable. Très satisfait.
Adrien H.
Très souple !!
Diamètre un peu gros mais qui correspond aux specs. La gaine est tres souple et permettra un routage facile du câble.
Adrien H.
Fonctionne parfaitement
Installé dans un ampli avec deux transfos toroidaux. Pas encore mesuré la différence de courant inrush mais le produit fonctionne parfaitement.
Fabien B.
Parfait!
Fabien B.
Fabien B.
Aleksandr V.
Great!
works great in the middle and high frequencies section
Waldemar C.
excellent - as all SC-Pure Ian.s clock.s
worth every penny....
Aleksandr V.
Great!
Aleksandr V.
JANTZEN AUDIO CROSS-CAP Capacitor 400V 22µF Jantzen Audio Cross Caps MKP 400V are considered the best value for money for the design of passive crossovers for loudspeakers. Made in Europe, this new competitor of the...
a good product for the low frequency section
I bought for the upgrade of the Dali opticon 8 crossover, I am very happy with the result!
Claude T.
Bizarre
Lorsque ce câble est apparu sur le site Audiophonics, j'ai cherché ce que pouvait bien être le traitement réalisé par la société Physis concernant la couche de carbone entourant le conducteur OFC.
J'avoue avoir bien ri et me suis demandé ce qu'il pouvait bien fumer après avoir lu les caractéristiques sonores apportées par leur fameux traitement.
Ne trouvant aucun commentaire sur le WEB, je me suis décidé à en commander, juste pour voir.
Pour mon système Tannoy D700 et ampli GATO 400S ce sera certainement le dernier câble.
Brièvement, les enceintes semblent avoir disparu et le son remplit toute la pièce... Je n'en dirais pas plus sur les qualités du produit. Très bizarre comme effet, et j'avoue ne pas trop comprendre.
Tubes ultimes
En paire appairee, ce duo offre une scène large, profonde haute ! 3d immersif !
Une sublime restitution dans tout le spectre.
Vraiment des tubes de haut vol et musicaux comme jamais.
Comparé à tung sol, TAD ecc803s, EH, ils sont loin mais très loin devant ! .
Transcendent un système hifi.
Jeanphilippe c.
Smsl ad18
Je vous raconte mon histoire je possède depuis quelque temps un amplificateur yamaha As701 connu de tous. A ma grande stupeur je me suis rendu compte que le son numérique du smslAD18 était pour moi un niveau au dessus. Clarté du timbre des voies. Le yamaha est très bon mais le Smsl a un son plus chaud. Il sont connecté à mes vieilles Philips rh 2253. À l’écoute sur celle ci c’est le Smsl qui gagne le match largement. Ce qui me fait peur c’est sa durée de vie. Espérons quil ne souffriras pas d’obsolescences. Merci à audiophonic pour sa rapidité. Je pense à l’avenir rester sur du numérique avec le Smsl a2.a bientôt. Je recommande ce produit.
Waldemar C.
Simply excellent !
worth every penny ....
ISMAEL C.
PINTA AMORTSON Bi5A PHD
Hello, good quality of the article. Fast shipping to Spain...perfect!!!
Patrick D.
Très bien avec un FOSI BT20A Pro
Avec mon FOSI Audio livré à l’origine avec une alimentation 32v, l’apport de cette alimentation 48v est bénéfique. Plus que la puissance , elle apporte de la matière et de la vivacité.
L’appareil paraît solide.
Un bon achat.
Patrick D.
C’est bien un ampli hifi
Ne pas se fier à sa taille. Il est puissant, le son est précis mais pas trop, vivant, délivrant une scène sonore crédible. Aucune fatigue auditive, les aigus sont doux et les basses bien tenues.
Je l’utilise avec un preampli XDUOO MT-603 qui dispose de 4 entrées dont 3 RCA, un lecteur réseau Yamaha WXC-50. Sur des enceintes bibliothèque KEF IQ10 ça donne vraiment bien. Le Bluetooth n’est pas super qualitatif, c’est juste pour dépanner. Les correcteurs de tonalité fonctionnent bien mais j’ai tout laissé à Odb, pour moi c’est très bien comme ça (après ça dépend de la pièce d’écoute).
Pour le prix franchement il fait bien mieux que certains amplis beaucoup plus cher !
Philip G.
Que dire...
Une claque. Installé dans mon FOSI V3 (48V), la différence est immédiate. Donne une tonalité d'ampli à tubes avec clarté et définition. Utilisé dans mon setup: Tinker Board+Volumio+Ares 2.
Un Must et pour le prix, y'a pas à hésiter...
david v.
ARYLIC S50 PRO+ Network audio player DAC ES9023 ADC WiFi AirPlay Bluetooth 5.0 aptX HD Arylic proposes with its S50 Pro+ a connected stereo preamplifier, having the particularity to take advantage of a complete connectivity with WiFi and Bluetooth 5.0 reception....
nikel sauf lecture usb
rien a dire sauf que la lecture avec clef usb bug pas mal
david v.
tres satisfait du son et de la puissance .
Kari J K.
Garba
Superb product,fast delivery,merci!
André G.
Fiches bananes wM de qualité
Ces fiches plaquées or sont pratiques et se connectent avec un excellent maintien et sont d un très bon rapport qualité prix. A recommander
jean luc d.
modification du module de controle
les condensateurs qui permet de crée une latence au niveau des vu metres , ne sont pas suffisant, il faut rajouter un condensateur en parallele sur les vu metres 220 uf 50 v bipolair.
remplacer l"ampli op par un lm 358 , les reglages des trims sont tres delicat . les condensateurs juste à cote du regulateur de tension c'est pas terrible.
Gilbert H.
Un bel objet de bonne facture. De bons contacts, des prises qui tiennent bien, et la possibilité de le fixer au mur ou sur un support en bois est vraiment un plus.
Par contre les prises n'ont pas d'obturateurs pour le sécurité enfants... donc non conforme à la NFC 15100, donc une étoile en moins.
Jacek C.
Very good choise
I didn't expect such good sound quality in all aspects for this price. Audiophonics service and delivery are, as always, at the highest level. I highly recommend.
