marc g.
Dominique R.
Hautement recommandé
Paulo D.
François C.
IBASSO DC06PRO Portable DAC / Headphone Amplifier 2x ES9219C 32bit 384kHz DSD256 MQA 16x Ibasso unveils a new version of its DC06 portable DAC/headphone amplifier, the DC06 Pro. Compact, it features 2 ES9219C DAC chips and volume control knobs, new advanced features...
IBASSO DC06PRO DAC
Apporte un gros + sur iPAD. Son de meilleure qualité. En revanche rien de mieux sur un Samsung S23 Ultra.
NEUTRIK NC3MX-BAG 3 Way Male XLR Connector Silver Plated Ø8mm (Unit) This 3-pin XLR male Neutrik NC3MX-BAG connector allows quick and easy assembly, consisting of only 4 pieces and no screws. It benefits from a compact design, a sturdy Zinc shell...
Comme sa version femelle, bonne fiche qualitative et neutre .
Fiche de bonne facture avec un rapport qp très bon. Facile à mettre en oeuvre.
Cote son, elles me semble assez neutre .
zeljko j.
Good wire. Very fast shipping . I will buy from you again.
Jochen M.
LHY AUDIO BATT-USB Regulated Linear Power Supply on Battery 5V 2A This LHY Audio BATT-USB regulated linear power supply module uses four 21700 batteries with a capacity of 4900mAh (a total of 9.8Ah) and an ultra-low-noise LDO LT3042 linear...
Basically a fine thing
I bought two devices. Both have an audibly positive effect on music playback with the devices now supplied with clean power (rpi/WiiM/Dac). The first device is flawless. The batteries of the second device are weak. The batteries are empty after approx. 3 hours. Two green LEDs still light up, then the device switches off. On the first device, the batteries last for at least 5 hours without any problems until all LEDs go out.
Marc L.
Ces fiches sont parfaites. Très faciles à mettre en oeuvre et le système de vis permet au câble d'être parfaitement attaché.
olivier P.
Pour HF en actif
Utilisé pour driver une compression 114db en actif asymétrique afin de supprimer le souffle.
Essai transformé, l'oreille à 20cm de l'embouchure du pavillon plus de souffle il reste juste un très faible bruit électronique inaudible avec un peu de recul.
Léger ploc à l'extinction suivant ordre d'arrêt et chauffe quand même malgré la faible puissance demandé mais moins que mon ancien classe A.
Donc je préconise cet ampli lilliputien pour cette application et pour le reste je croise les doigts
Stephane N.
Acheté pour un second système, c’est un très bon ampli, bien fabriqué et aux qualités musicales réelles.
Stephane N.
Mise à niveau réellement audible
En remplacement d’un MCap standard dans le filtre d’une paire de JERN AUDIO 11s, l’opération n’est pas si simple, la taille du Suprême est 4 fois plus importante !
Mais l’entreprise et le temps passé en valent le coup.
Tout est bien plus homogène, certaine crispation des aiguës ont disparue ( câbles Nordost sans pitié ).
L’investissement financier est fondé.
Ravi de ce produit.
Ralph L.
Vielen Dank an das Audiophonics Team!
Seit 35Jahren ist HiFi für mich ein Hobby. Viele Geräte sind seit dem gekommen und auch wieder über den Gebrauchtmarkt gegangen. Was soll man sagen? Ab und zu braucht man
halt wieder was neues … Dieses Mal sollte es ein Class D Amp werden um in meinen langen
Hörsitzungen nicht so viel Strom zu verbrauchen. So groß würden meiner Meinung nach die Unterschiede nicht sein wenn man doch nur die Endstufe tauscht …dachte ich. Doch nach dem Audiophonics mir 2 verschiedene Class D Endstufen geschickt hatte wollte ich schnell wieder meine alte Endstufe zurück … doch die war bereits verkauft. Dann sind 2 von diesen kleinen LA 90 d angekommen … Und jetzt bin ich wieder sehr glücklich mit dem Klang in meinem System. Die Maximale Lautstärke ist sowieso nicht wichtig für mich und nur wenn es laut sein soll sind hier Abstriche zu machen … klar mit den kleinen Verstärkern kann man keine Bäume ausreißen. Einen LA 90 d würde ich nicht für Lautsprecher unter 88dB empfehlen … Und zwei auch nicht für Lautsprecher unter 86 dB Wirkungsgrad. Ansonsten können die alles was ein Verstärker um 5000 Euro kann … die Frage ist also nur wieviel möchten Sie ausgeben? Wie laut hören Sie? Und welche Lautsprecher haben Sie?
Stephane N.
Excellente qualité et très bon résultats sous un AUDIOMAT Arpège Référence.
vincent g.
Trés satisfait !
Il vient remplacer un vieux Technics SU-V460. Le Fosi est alimenté par un préampli DAC Tangent et alimente des Focal Chorus 705v.
Tout s'accorde très bien, un son clair et précis comme ce que je souhaitait.
Jyrki K.
Jyrki
Dry and precise. No Color the sound. Hard, not soft.
I recommend.
Jyrki K.
Jyrki
The transformer was loose and allowed to move and rattle inside. Just a little tightening of the screw and the problem is gone.
The power supply supplies power to the Volumio Rivo network player and the Pro-Ject Pre Box S2 Digital DAC.
The power source opens up the sound and brings more separation. It feels like there is more power and the dynamics increased. Hears more details in the recording.
I recommend.
Gilbert H.
Bon Connecteur, mais...
Un bon connecteur d'un prix tout à fait raisonnable. Seul regret, la partie métallique du connecteur n'est pas reliée à la broche centrale par une vis comme sur les autres connecteurs de ce type, elle n'est donc pas reliée au chassis , dommage... donc une étoile en moins
jean michel G.
Belle surprise
Après avoir longuement utilisé un Audio GD 19 SINGULARITY qui m'a donné de belles écoutes, ce Topping est un passage pour l'écoute du DSD. DAC très musicale, apporte une belle précision des notes. Passage directement en mode NOS des sa mise en route.
Emmanuel A.
Un excellent câble qui ne paye pas de mine malgré un prix bas
Pas besoin d’autre chose
Yassin B.
j'avais l'ancien modèle dont j'étais très satisfait.
Suite à sa panne, j'en ai profité pour une mise à jour.
Encore mieux.
Pour ceux qui o,t une imprimante 3d, je mets à dispo un boitier :
https://www.thingiverse.com/thing:6473605
bonne écoute,
Un câble secteur impressionnant
La taille du câble est énorme et la fabrication est vraiment de qualité. Branché sur un ampli casque Audio GD, le résultat auditif donne une belle musicalité. Du grave à l'aigu tout semble parfaitement équilibré. Pour un prix raisonnable c'est un très bel équipement.
Mauro M.
AUDIO-GD R-27HE R2R DAC Balanced Class A Headphone Amplifier Preamplifier 32bit 384kHz DSD512 Silver A new creation from Audio-GD, the R-27HE is a balanced R2R DAC ladder with a built-in headphone amplifier and ACSS preamplifier. This improved version of the R-27 now features a...
Definitivo
E' improbabile che, se non si guasta (ma la mia esperienza con gli apparecchi Audio-GD è positiva dal 2014) io pensi di cambiare questo all-in-one semplicemente meraviglioso.
Il suono è melodia pura, la flessibilità elevatissima.
L'unico difetto, se vogliamo trovarne uno, è l'imbarazzante sistema di menù per le regolazioni, anche le più semplici come gli ingressi e le uscite.
Miroslav B.
VMV D2R
The DAC has excellent sound, detail and space.
The aluminum body and remote control make the device an elegant addition to the audio set.
Crackling when changing the sample rate of the track being played.
In variable mode, the DSD signal is at full volume. Need to convert the signal DSD to PCM!
When turn on DAC and start playing, transmit the signal for 1 second in full power! Only in Variable mode !
DAC is ideal to connect it to a preamplifier.
Jérémy G.
Bluffant
Associé au bt20a pro de fosi audio, ça devient plus intéressant. Ce qui surprend le plus, ce sont les graves, très présent, il faut pouvoir régler le gain.
Fait parfaitement le job et sa petite preamplification est vraiment très appréciable pour des enceintes à faible rendement donc difficiles à driver.
Olivier L.
Fonctionne très bien avec le wifi 5, streaming très facile, stable, interfaces multiples qui reconnaissent même les autres appareils, très bien pour le multi-room. Améliorable avec un DAC extérieur ce qui me semble une meilleure stratégie qu'un modèle de la même marque avec un meilleur DAC interne (Pro Plus). Et quel tarif rikiki !
Edgar T.
XDUOO TA-26S Tube balanced Headphone Amplifier / Preamplifier 6N8P 6N5P The TA-26S from xDuoo is a tube headphone amplifier, with a nice design that reveals a smooth, warm and accurate sound. It embarks for that a 6N8P tube for the preamplification...
The magic of electronic tubes
An inexpensive headphone tube amplifier with a great audio quality out of the box.
It improves as the time goes by.
A great amplifier that puts all my high impedance headphones singing with authority.
Probably my best bargain in Hi-fi.
Outstanding.
pascal B.
TRIANGLE OPERA OS100C Speaker Cable OFC Copper 2x1.5mm² Developed by Triangle, Opera speaker cables guarantee excellent electrical signal transmission quality. To achieve this, they incorporate braided OFC copper conductors, each...
cable HP
excellent rapport qualité/prix pour ce cable au mètre en cuivre étamé
pascal B.
prise din
très pratique avec son serrage à vis latéral ; rare de trouver des prises din doréees
pascal B.
banane dorée
avec une soudure à l'argent, assure un contact optimal pour les liaisons HP/amp
Gérard G.
Très bon ampli de puissance qui a vraiment de la "pêche" !
Son très détaillé dans les basses, médium et aigus, ne chauffe pas.
Le son parait légèrement plus froid qu'un ampli classe A/B mais semblerait parfois un peu plus détaillé.
Attention simplement aux câbles que vous allez utiliser pour connecter le préampli à cet ampli car le son ne sera pas exactement le même.(perte dans les aigus, basses plus "boum boum" avec certains câbles)
Je pense avoir trouvé les bons et je suis super satisfait de cet ampli !
Magnus A.
Great value
This amp delivers insane value for money. It will likely surpass many amps that cost much, much more. The sound is incredible clean with black background and sounds very smooth and liquid. This is an end game amp.
Fabrizio R.
NEOTECH SOCP-14 Wiring Cable UP-OCC Copper PVC 14AWG Ø 3.5mm The Neotech SOCP-14 cable is a high quality 14AWG UP-OCC copper cable with PVC insulation. Its design makes it an ideal cable for audio.
Lovely speakers cable,nude in cotton sleeve without external pvc
Jérôme T.
LINDY LH700XW Wireless Headphone Active Noise Cancellation ANC Bluetooth 5.0 aptX 20Hz-20kHz The Lindy LH700XW headphones offer excellent sound quality, combined with a Bluetooth 5.0 wireless connection supporting the high-resolution aptX transmission codec. It also...
un bon casque
Je l'utilise dans les transports.
Le casque est bien construit. L'isolation passive est suffisante sans recourir à la réduction électronique la plupart du temps. Mais parfois c'est bienvenu pour avoir un peu de calme. Evidement l'audio est filtré également.
Le casque isole bien de l'extérieur en plaquant efficacement les oreillettes, j'ai donc rapidement chaud et je crains que le casque ne soit pas très utilisable en été.
L'étui de transport est bien pratique. Le casque n'a pas de logo voyant et c'est très bien comme cela.
La qualité audio est bonne mais pas excellente pour une oreille audiophile. Il n'y a pas de résonnances particulières ou d'équalisation désagréable.
Pour finir, je trouve le prix est un peu élevé.
Didier f.
beaucoup de détail mais...
beaucoup de détails mais malheureusement la scène sonore est étriqué.tous les instruments sont consentrés sur un même point,le centre des enceintes.dommage.
Paul L.
Amplifier Board Class AB 4 Channels TDA7388 4x45W 4Ω This four-channel Class AB amplifier module is based on the use of a TDA7388 chip,capable of delivering 45W per channel at 4Ω.
Ampli
Très bon article, fonctionne parfaitement
Brice D.
Aluminium Damping Foot 30x10mm Silver (Unit) This damping feet made of Aluminum and Rubber is ideal for stabilizing and absorbing the vibrations of your speakers and HiFi devices.
R.A.S
Très bien comme d'habitude.
Musical et chaud sur le médium.
Je confirme la musicalité exceptionnelle de ce câble sur le registre médium-aigu des enceintes.
J'ai gardé pour le registre grave, le Sommercable Elephant en 2x4 mm2 mis ensemble (section 8mm2) après avoir mis mes Cabasse Caravelle M2 en bi-câblage.
Ne pas hésiter à bi-câbler vos enceintes avec ce câble Mogami 3103 pour les médiums-aigues.
Bravo à Audiophonics pour la livraison éclair.
Excellents en tout point.
J'ai refait les filtres de mes Cabasse Caravelle M2 (9 condensateurs et 7 selfs puis une résistance) entièrement avec cette série de condensateurs.
Tout simplement parfaits.
Les dimensions surtout du condensateur 6.8 µF sont impressionnantes, j'ai dû utiliser une plaque de contre-plaqué sur les 2 faces dans mes enceintes.
Ne pas utiliser cependant cette série Z-Cap superior sur haut-parleurs isodynamiques ou à ruban, préférez les Mundorf Suprême Classic dans ce cas.
Livraison Audiophonics toujours aussi rapide, bravo !!
Impressionnant déjà par les dimensions...
Ce condensateur est énorme, bien vérifier s'il rentre dans votre filtre.
Mis en série à la suite du même en 3.3 µF pour mon aigu Cabasse Dom 4/4.
J'ai utilisé une plaque de contre-plaqué sur les 2 faces tant les condensateurs Z-Cap Superior et les selfs Jantzen sont surdimensionnés.
Médium Cabasse Dom 12 avec 2 condensateurs identiques en 2.2 µF montés en parallèle pour obtenir les 4.4 µF requis en série sur mes Cabasse Caravelle M2.
Le son est extrêmement transparent, superbement timbré et jamais agressif, avec le rodage (300 heures au moins pour un condensateur) ça promet !!
A noter que cette série de condensateurs Jantzen Z-Cap superior ne convient pas du tout sur les hauts-parleurs isodynamiques ou à ruban, une catastrophe sur médium-aigu AMT Ess à l'unanimité de l'assemblée d'audiophiles... leur préférer dans ce cas les Mundorf Suprême Classic.
Audiophonics toujours au top de la livraison, commandés le vendredi et reçus le lundi, on ne peut pas faire mieux.
Toujours au top
Matériel de qualité, emballage soigné, expédition rapide, suivi de commande rassurant.
Robert C.
Excellent power supply for streamers and DACs
This is my second IFI Audio Ipower X power supply.
It proved in practice and tests to be excellent choice for low noise power supply for digital sources.
Ilari M.
Great amplifier for subwoofers
Ilari M.
Very good amplifier…Great valuue for money….
Ilari M.
Super amplifier….Great value for money….
Pedro Q.
Cyan 2 - great improvement
Extremely harmonious and firm in all ranges; perfect distinction between the various types of sounds and musical genres; I love the switching mode...easy (with streamer by USB and CD Player by Coaxial). Top delivery from Audiophonics.
eric l.
XDUOO LINK V2 Portable USB DAC CS43131 32bit 384kHz DSD256 Gray The xDuoo Link V2 portable DAC follows the design and concept of its big brother, the Link, in a version with improved performance.
tres bon dac son clair,tres detaille avec des casques de bonnes qualite (je possede l'hifiman sundara closed back et le sundara).
Patrice W.
Excellent de Wendel
Utilisés pour remplacer des pieds en plastique, ces pieds en aluminium apportent une touche très design à mon ampli Emotiva et répartissent bien le poids de 10 kilos. Ses anneaux caoutchoucs évitent toute interférence avec mon processeur. Je recommande
Martin K.
Mein neuer Standard-Stecker
Der NYS373 bekommt man ja an jeder Ecke. Wahrscheinlich weil er für den Preis sehr gut verbindet. Ein bisschen schwierig zum Löten, aber wenn man das hinbekommt, hat man eine sehr gute Verbindung. 6mm ist wirklich ein wenig kapp, für ein RG58 passt er aber sehr gut. Ist mein neuer Standard-Stecker.
Martin K.
Kann sich sehen lassen
Nach dem Brexit auf der suche nach einem Hifi-Zubehör-Laden in der EU Nachbarschaft. Bin ich auf diesen hier gestoßen. Jetzt habe ich schon ein paar mal bestellt und bin sehr zufrieden.
Wie bei diesen sehr guten Cinch-Einbaubuchsen. Ich hab jetzt schon einige getestet, aber mit diesen bin ich sehr zufrieden. Es passen fast alle Stecker, und sie sind sehr gut verarbeitet. Unterhalb dieses Preises bekommt man nichts vergleichbares. Ab hier beginnt High-End.
Bastiaan v.
AC/DC Switching Power Adapter 100-240V AC to 12V 5A DC This power adapter delivers a power of 60W, with a voltage of 12V for a current of 5A. Its output connector is a DC 5.5/2.5mm jack (5.5/2.1mm compatible).
Impeccable !
Bien meilleure qualité que l'adaptateur 12V 3A quelques euro moins cher. Avec l'adapteur de 3A j'avais toujours un léger hmmmm 50Hz dans mes hauts parleurs. Avec ce modèle de 5A aucun problème, pas l'ombre d'une petit bruit gênant. Donc parfait comme source de courant pour mon petit dac.
Alain E.
Conquis
Tout D'abord un grand merci à l'équipe d'Audiophonics pour l'envoi très rapide. J'ai acquis ce lecteur réseau pour écouter ma musique dématérialisée (Deezer prem. pour moi) sur mon ancienne mais honorable chaine. Branché en RCA sur mon ampli NAD avec des cables un cran plus qualitatifs que ceux fournis, l'écoute me procure un gain qualitatif appréciable par rapport à la connection depuis le PC que j'utilisait avant.
L'application est très stable, les mises à jour fréquentes et les réglages multiples. Le plus est évidemment la présence d'un equalizer 10 Chanels (graphique et métrique) qui permet d'accéder à un ajustage du son en fonction de son environnement ou de ses goûts. La navigation est intuitive et fluide, le passage d'une source à une autre très rapide et les options aisément paramétrables. Je ne suis pas un audiophile accompli mais je peux dire que ce lecteur me procure un plaisir renouvelé à l'écoute de mes playlists. Dans la même fourchette de prix, j'ai longuement étudié l'offre existante et 5 appareils se sont pour moi détachés (Wiim pro, Pro+, Taga harmony, Argo solo et Octavio). Mon choix s'est porté sur le Wiim pro + pour sa connectique qui le rend très polyvalent, une entrée Ethernet pour la stabilité qui se révèle sans faille et équipé d'un DAC recommendable. Je ne parlerai pas des autres capacités de transmission, de pilotage ou de multiroom que je n'ai pas testé mais qui ajoutent un intérêt à ce boitier . Certains le considéreront sous l'angle du DAC intégré avec une préférence pour une marque précise. Je n'ai pas d'arguments à faire valoir dans ce domaine, l'AKM 4493 se trouve embarqué et apprécié dans des systèmes de gamme supérieure. Enfin, une évolution sur la base d'un très bon streamer sera toujours possible grace à ses multiples sorties avec un DAC externe plus haut de gamme . Pour moi, grace à ce lecteur complet et polyvalent, l'expérience est concluante, je ne peux que conseiller.
Christophe v.
MATRIX MINI-I 4 DAC ES9039Q2M Streamer DLNA Airplay 24bit/768kHz DSD512 MQA The successor to the Mini-I 3, the Mini-I 4 is a versatile, compact device offering the functions of DAC, and, the latest addition to the Mini-I series, network player. Matrix...
MATRIX MINI-I 4 DAC
Très satisfait de ce DAC lecteur réseau.
L'avantage c'est que je n'utilise plus qu'un seul appareil au lieu de Dac séparés + lecteur réseau.
Complet sur ses connectiques, j'ai su y brancher ma platine vinyle grâce à son entrée auxiliaire.
Le son est doux, naturel est bien équilibré. L'écran est bien réactif, et l'application très simple d'utilisation et sans accros jusqu'ici.
Je lui trouve cependant 2 défauts.
Le premier, c'est qu'il faut vraiment monter le volume au dela des 50, voire 60 pour commencer à entendre du son, lorsqu'il est utilisé en preampli.
Le deuxième, c'est qu'il n'est pas WiFi, ce qui est dommage pour les personnes intéressées par ses qualités et fonctionnalités, mais qui ne peuvent pas le faire fonctionner sans.
Grand plus que J'oubliais aussi, c'est sa télécommande physique, qui permet de gérer l'appareil sans passer par l'application. Je l'ai commandé en plus car comme j'utilise un ampli à lampe sans télécommande, je peux gérer le volume via le lecteur.
