Patrick G.
tres bonne conception
Abdoulaye D.
Soudure
Abdoulaye D.
Pince 3 in 1
leo h.
Uc330 board plus ultracaps
Extremely good.
leo h.
Powersupply
Incredible good
Rainer K.
1877PHONO FINA-OCC MKII Shielded Power Cable OCC 3x2mm² 1.5m After the success of the now famous Legion, 1877Phono offers a new power cable based on PC-OCC copper and 24k gold plated connectors. The FINA-OCC is made of high purity copper...
Zavino Fina
I saw the cables for the first time at the Hifi Days in Hamburg. I was already convinced of the quality back then. Ultimately I ordered the "Zafvino Fina" for my Goldnote-PH 10 phono preamplifier. An absolute win for my hi-fi system. The quality of the cable matches the device and the price is appropriate. I will use the same cable for my power supply for my Transarotor turntable.
Unfortunately, the cables are hardly available at all in Germany. I was all the happier that I can order the cables (including the larger series) here in France.
Michael N.
Superb mechanical and audible quality
Solid and stable mechanical construction. Everything fits here, easy but efficient. Hugh difference in regard to "gold plated" compared to other connectors!
Tonal very fine, well balanced and detailed - best connectors I ever bought!
Michael N.
Incredible fine and balanced!
Absolute fine dissolving cable , light and well balanced, does not add or subtract anything, natural flow.
Compared to Tunami V2 it is better in resolution - it is finer, incredible balanced in all aspects. The fist cable where I do not miss a thing or find it overdrawing - just perfect!
Joseph C.
Je m’y attendais pas
J’utilisais un Réal câble eca préfabriqué qui jusqu’à présent me donnait entière satisfaction pour connecter mes sources cd/dvd.
Depuis l’acquisition d’un Streamer Atoll Ms120, et malgré une centaine d’heures de rodage, le côté sec et les duretés dans les aigus ne s’estompaient pas..
Au vu des prix pratiqués dans les câbles préfabriqués abusifs, j’ai décidé de me monter celui-ci avec des rca Amphemol.
Sans même être rodé, de suite le son est bcp plus équilibré sans cette prédominance dans les aigus, une fluidité extraordinaire, ça descend très bas même à faible volume !
Apparemment, se marie avec Atoll à la perfection !
Thierry N.
Joli boitier, très bien fini... bien supérieur à des boitiers du même type (1MII, IFI audio...).
Connection immédiate à mon smartphone (pourtant pas très récent) - Codec bluetooth LDAC (en série sur tout smartphone depuis android 8.0). Le son en sortie coax et avec le LDAC est vraiment d'une qualité qui n'a rien à voir avec le sbc, on est vraiment qualité CD et à l'oreille pas de différence en sortie de mon ampli - dac avec mon lecteur cd hifi.
Sortie RCA, signal interprété par le dac intégré, semble tout à fait honorable peut être un peu moins d'ampleur que mon dac hifi mais je ne peux rien affirmer, car pas assez de temps d'écoute...
Pour le prix je suis ravi de pouvoir simplement et sans réseau, véhiculer de la musique sans fil avec une qualité plus que correcte. J'avais peur de la qualité Bluetooth qui ne m'a jamais vraiment séduit mais les codec LDAC, apt-x lossles ou LHDC remettent les pendules à l'heure. Le LDAC et LHDC largement intégrés sur smartphones sont vraiment équivalent au CD si notre fichier source est lui-même correct (Flac...)
jean luc L.
Jantzen Audio Waz Coil 12awg 1mH
Super comme toujours !! Une meilleure définition des timbres, réalistes plus raffinée.
Jean-Pierre D.
Une très belle restitution claire, détaillée et musicale
Jusqu’ici, mon câble de référence était le Cardas Clear Cygnus (deux fois plus cher) en cuivre, ce Neotec m’a conquis avec ses médium et aigu doux et très fins. La scène musicale est très ouverte, il y a beaucoup de micro-détails, je craignais avec un câble avec conducteurs argent de perdre en texture au niveau des timbres, il n’en est rien. La reproduction des voix et instruments à cordes par exemple est superbe, cela me semble dépasser ce que fait le Cardas qui a une restitution sur les voix et instrument assez vive.
Donc, sur les critères habituels, détails, transparence, précision tonale, résolution spatiale, il me semble sensiblement au-dessus du Cardas avec un prix canon. L’image sonore d’un orchestre avec ce Neotec est transparente, spacieuse, communicative, dynamique et tonalement correcte, sans manquer de fluidité.
jean luc L.
le livreur a jeté le colis (carton trop léger a mon gout) par dessus la porte de mon domicile, une des self et légèrement impacté mais pas de différence sur le son.(Jai la vidéo de l interphone) Ouf j ai eu peur !!
sinon les self Jantzen c est vraiment Top , sur le médium cela apporte beaucoup de velouté et réalisme !!
Philippe c.
Y A PAS PHOTO !
Nouvel ampli casque ....j'en suis ravi ! ...après déception sur déception , j'ai enfin trouvé celui qui me convient . Puissance, précision du message, plans respectés . Conseils d'Audiophonics bienvenus ! Merci.
Stephen R.
Soundcare superspikes for Hi Fi electronics
I have used the standard model before on speakers and liked these so I thought i would try these on my DAC. Really impressed and will be getting another set once back in stock.
Really a 5 star unit but no screws included, obvious really as what length would they supply its component dependent so figure that one out if you need to. Plenty of self adhesive options.
Improved sonic's where a definite for me.
Jean-Christophe M.
Une amélioration sonore garantie
Je dois avouer que j'étais très sceptique quant à la différence qu'un changement de câble RJ45 pourrait apporter. Je pensais qu'un simple câble de flux de données binaire de 0 et 1 ne pouvait pas altérer la qualité sonore d'une mini-chaîne, en l'occurrence la CR 612 de chez Marantz.
J'ai donc décidé de faire un test et ai été agréablement surpris par le rendu sonore. Une scène sonore plus aérée et détaillée s'est dégagée, représentant un véritable gain qualitatif pour mon équipement.
Sincèrement, je recommande ce câble, qui est d'ailleurs le moins cher par rapport à d'autres concurrents sur le marché.
Merci à l’équipe de Audiophonics pour la rapidité de la livraison de ma commande.
Christophe D.
100%
Simple et efficace, on trouve plein de tuto partout, un must pour chaque DIYer !
Christophe D.
ARYLIC S10 Streamer RJ45 WiFi DLNA AirPlay Bluetooth 5.0 24bit 192kHz Arylic presents with the S10 a compact and versatile streamer, integrating both WiFi and Bluetooth 5.0 connectivity. It will allow you to broadcast and control your music...
Mitigé... mais 5 étoiles quand même !
Efficace, stable, discret, avec une appli simple ; le DAC d'origine n'est pas extra, normal vu le tarif. J'ai commandé un Sabre, on verra si c'est mieux. La lecture des .flac sur l'USB laisse parfois quelques "blancs", mais ça ne plante pas... Dommage qu'on ne puisse pas mettre un répertoire en favoris. L'accès à mes NAS serait tellement plus rapide.
Frederic G.
J’ai testé de très nombreux câbles haut-parleur, de 2.- le mètre à plusieurs centaines de francs le mètre. Aucun ne m’a apporté autant de satisfaction que ce simple monobrin d’argent pur de 1.3 mm, gainé avec du coton de 1.5mm.
J’ai possédé des câbles argent cryogénisés de 0.5 mm qui sonnaient très rapides et détaillés mais le rendu était clairement ascendant et fatiguant par manque de corps.
Le rendu du 1.3 mm en simple câblage est neutre, équilibré, dynamique et transparent. Tout est à sa place à un niveau impressionnant. Le grave est rapide et puissant.
Avantage supplémentaire: plus besoin de bananes, de fourches, de soudures…Une petite boucle pour le bornier et c’est tout.
1.3 mm fonctionne parfaitement avec mes enceintes de 93db, longueur des câbles 2,50 mètres, ampli 2x200 W.
Vraiment bien !
Pressé de recevoir ce préampli pour essayer mon nouveau gros bloc à tubes, vraiment pas déçu.
Ce serait un comble que mon nouveau preamp à tubes HDG ne soit pas mieux sachant qu'il coûte 40 fois plus cher.
A 30 euros ce préampli est une bonne solution pour test.
La diode rouge sur le bloc de la prise secteur est un phare la nuit, un détail.
Livré en 24 heures chrono après une modif de commande, la version argent-silver n'étant finalement pas dispo, je l'ai eu en noir, vu ce que je vais en faire...
Top Audiophonics, comme d'hab !!! Merciiiiiii.
Top anti-vibrations.
Et ça colle fort, impossible de le replacer après application.
Super plaque de bitume pour intérieur d'enceintes, caissons de basses et même platine vinyle ou lecteur CD.
Découpée au cutter c'est vraiment bien.
Plaques livrées en 24 heures chrono !!
Marc T.
Remarquable
Surprenant, ce petit appareil. Il n'a peut-être pas la meilleure fiche technique, mais voilà : il FAIT de la MUSIQUE ! Et avec une précision telle (je l'utilise comme dac-préampli) que je distingue nettement le caractère des divers câbles que j'utilise en sortie. Un très bon RCA, par exemple, "sonne" mieux qu'un XLR courant.
On frôle le haut de gamme pour un prix très abordable.
Grand coup de chapeau au Japon et à la Chine !
DECEVANT...
Possesseur d'un Aiyima A07 et d'un "A07 PLUS", il faut reconnaitre que cet Aiyima A07 MAX est déroutant et décevant. Certes la transparence est très bonne mais les timbres sont monochromes, gris, sans saveur. Cordes acides et piano manquant singulièrement d'harmoniques. tweaké avec différents Ampli Ops (TLE2142 CP, 1612, ou LM4562), rien n'y fait! L'Aiyima A7 (simple) ou "l'A07 PLUS" équipés d'AOP LM4562NA font beaucoup mieux.
Ferenc M.
effective
I use it for dampening the metallic noise of the top/bottom of my amplifier chassis. It went completely silent after the modification.
PAS MAL ...MAIS PEU PUISSANT.
Restitution de bonne qualité avec une bonne définition et absence d'agressivité. Les basses manquent un peu de tension, cause probable d'une puissance trop modeste (il faut en effet régler le volume entre 75 et 90 sur une échelle de 100 pour avoir un niveau réaliste sur enceintes de bon rendement (90 db))
Olivier C.
FOSI AUDIO P3 Tube Preamplifier 2x JAN5654W Headphone Amplifier Bluetooth 5.1 aptX aptX HD The Fosi Audio P3 is a compact, high-performance preamplifier. It features two JAN 5654W tubes and a QCC3031 Bluetooth receiver chip. A...
Ouverture du son
Je viens d'une préamp FX-AUDIO TUBE-03 à Tubes 6K4, et je trouve une nette différence d'ouverture de son.
Par contre, moins puissant j'ai l'impression, le volume faut le pousser !!
Par contre, quel son supérieur !!!
Seul bémol, le bluetooth qui n'est vraiment pas excellent, et je le compare au bluetooth du AIYIMA A08 PRO qui, je trouve, reste meilleur.
Sinon, très bon son et j'aime son esthétique avec cette petite lueur bleue des tubes ...
Matt M.
Big Surprise!
Paired with Ian's IV board, this modest trans is a serious contender for best money spent in audio for me. Upstaging a Twisted pear Mercury IV. Got a free board from Ian and just wanted to see how this topology sounded. Big Surprise!
Matt M.
Tamed Dylan's Harmonica!
Great Clock, especially for the money. Nice upgrade from the stock FifoPi Q7 clocks. Sound is calmer and recordings with harsh treble (sorry Bob) are much improved ;-) Benefits from lengthy break-in period.
František B.
BEATECHNIK x LHY AUDIO LPS-A6 220V MK1 Linear Power Supply Module for EverSolo DMP-A6 Gen 1 The LPS-A6 linear power supply module has been specially designed to enhance the power supply stage of EverSolo DMP-A6 and DMP-A6 Master Edition network players by replacing the...
František Baran
Děkuji za rychlé dodání BEATECHNIK x LHY AUDIO LPS-A6. Po výměně napájecího zdroje se zvukově moje audio sestava skočila o třídu víš .Vřele doporučuji. Super obchod a prodejce moc děkuji . Baran
pascal T.
Correction acoustique très efficasse en hifi et facile a mettre en oeuvre. Basses beaucoup plus propres et punchy,je voulais aussi l utiliser en passe haut pour supprimer des infra parasites sur certains enregistrements ,c est fait..
Joseph J.
Remplace très avantageusement les HP "grave" d'origine sur enceintes de bibliothèque Yamaha. Bons graves pour la taille de l'hp.
Patrick R.
Bien moins cher que la FI50, elle semble faire le job pour avec une très belle qualité des matériaux et facilité de montage.
Patrick R.
Qualité du produit
Très belle qualité de fabrication. Qualités sonores sur un Furutech S55N très satisfaisantes pour alimenter les équipements réseau.
Patrick R.
Lieu conçue et meilleure facilité de montage que la GX16 classique.
Le diamètre élargi est appréciable avec gaine coton par exemple. Qualité globale du produit.
Incroyable !!
Ce minuscule préamp à un son incroyable, il faut juste mettre des bons tubes NOS ( j'ai mis des Sylvania ) et remplacer le potar voir comme dit plus haut " En réalisant un pont diviseur avec une résistance 47 kohms série et une 1.5 kohms parallèle "
Je ne sais pas jusqu'où il peut aller ... en remplaçant des condos ou des résistances qui sont sur le trajet du signal ... à tester ... !!
Aussi une alim linéaire ou sur batterie ...
Je pense que le potentiel in finé est très très élevé ... pour un prix modique ... !
Raphael K.
10 années !
je ne noterais pas 5 car il faudrait qu'il dure plus de 10 ans pour mériter la note ! (comme de bon vieux appareil vintage !) cependant je ne peu pas dire de mal sur la qualité de cette alimentation car 10 années s'est pas forcément mauvais pour du découpage ! , voila je passe commande de nouvelles alim après 10 années d'utilisation des ncore 400 , je précise que j'étais équipé des 1er versions et les appareils restais presque tout le temp sous alimenté !
Excellentes fiches bananes
Une nette amélioration du rendu sonore (elles remplacent les Viablue ts qui sont pour le prix excellentes).Elles sont plus naturelles, et le grave est plus précis.
Système d'auto serrage très efficace, les connecteurs ne bougent pas et le contact est optimal.
Seul bémol, le prix...
Didier C.
Amélioration notable
Installé entre ma box Orange et un streamer 3D Lab nano platinum V5. Donc écoute uniquement en streaming et avec Qobuz studio. L'amélioration s'est faite sentir au bout d'une semaine : une musique qui donne l'impression d'être plus fluide, avec moins d'aspérité, une plus grande sensation d'espace et avec un placement plus précis des musiciens. Dans l'ensemble, les disques moins bien enregistrés passent mieux qu'avant et les bons sont encore meilleurs !
Un apport important à mon avis sur un système résolvant.
Kulcsar A.
GOOD
Moondrop is the best IEM, sound ok clear.
danny r.
mr
Colissimo is a terrible courier. 17 days and nothing. Dhl never ever any problems. Always deliverde quickly to Austrtalia
Renaud D.
DD TC44PRO Portable DAC 2x CS43131 Lightning Male to Jack 4.4mm Female 32bit 384kHz DSD256 Following on from the TC44B and TC44C portable DACs for smartphones, DD HiFi has unveiled the TC44PRO, the third generation in its range. It features...
Fantastique
Je cherchais un Dac pour pouvoir relier mon casque avec un câble symétrique 4,4mm à mon IPhone et je recommande ce produit le son est fabuleux les graves les médiums et les aigus sont à leur place on entend chaque détail. Je ne regrette pas mon achat et je le conseille à tous les amateurs de musique classique en plus le prix n’est pas excessif compte tenu de la qualité. Foncez si vous souhaitez améliorer le son de votre iPhone.
Patrice D.
Equilibre......Ouverture.......
Bien que mes enceintes pas complètement au point (prototype en voie d'amélioration) il me tardait de tester ce câble surtout aux avis positif par ici.
Sitôt reçu,sitôt branché. Terminaison Yarbo roduim côté ampli et câble nu vers enceintes. Pas le choix pour le moment en attendant les fiches pur cuivre red copper. Comparé au 4mm2 cuivre standard j'ai gagné en précision de scène et plus de détails également. Mais à contrario je trouvais le son plus montant qu'avant. Ce qui était loin de me plaire. Une résistance de 5 Ohms au niveau des aigus et ça me convenait mieux. L'avantage d'être en DIY. Mais c'était encore loin de me satisfaire. J'entends beaucoup parler de rodage. J'y crois pas trop. Pour les enceintes oui. Le temps que les suspensions des Hp s'assouplissent.
J'ai laissé les écoutes un moment car je ne me retrouvais pas par rapport aux avis que j'ai pu lire. Puis quelque temps après j'ai rallumé le système me disant qu'au pire ça partirait pour le home cinéma. Et là comme par magie j'ai retrouvé le grave qui me manquait. J'avais bien plus de corps que lors de la première écoute.
Sur Teddy Swims Tennessee Whyskey en Live j'ai retrouvé le grain de voix. Les claquements de doigts sur Ode to Billy Joe de Patricia Barber étaient plus réalistes et les nuances se faisaient mieux ressentir. Les cordes de violon sur Sarasate: Zigeunerweisen, Op. 20 interprété par SoHyun Ko paraissent plus authentique.
Après plusieurs écoutes, la sensation que tout rentrait dans l'ordre. Que tout était à sa place. J'ai lu aussi par ici que les voix étaient mise en avant. Pas pour moi. Quant on va à un concert, généralement le chanteur est devant l'orchestre, pas l'inverse.
Pour ceux qui sont sur le point de finaliser l'optimisation de leur système, voici un câble à prendre en considération. J'avais hésité avec le mogami 3103. Et suis partis sur l'Elecaudio 250CC sur les conseils de MR Aubert que je remercie.
Emilian C.
orea indigo
I installed them under the speakers , Marten Parker Duo Diamond Edition. The sound has improved a lot.
Karsten G.
Kaufempfehlung
Habe 12 Stück in silber.
Alle Flächen sind makellos, alle Gewinde laufen sehr gut und die Gummis sind perfekt aufgeklebt. Die Gummis sind sehr weich und rutschfest.
Preis, Kaufabwicklung, Versand und Verpackung top, wie man es von audiophonics gewohnt ist.
Klasse!
Jean-François A.
Condensateur parmi les plus musicaux
Condensateur installé dans une alimentation séparée de tuner Radio. Il y a longtemps que je voulais les essayer. Une grande réussite avec une musicalité très présente sans outrances ou pointes de tonalités désagréables. Grande clarté mais très naturelle. Vraiment très beau. Le meilleur condensateur d'alimentation essayé à ce jour.
Thomas J.
Imbattable dans son genre et à ce prix
Imbattable si vous comprenez
Sur ce créneau tarifaire et si on fait le compte de la techno embarquée, de la qualité de conception et des possibilités DAC/ Ampli casque, cet appareil largue toute concurrence.
Il faut cependant prendre en compte l'orientation analytique un peu sèche. Avec un Beyer DT 900 Pro la matière et la définition sont somptueuses mais épuisantes.
Fonctionne de manière superbe avec un HE-500 et un LCD-2 Closed Back. Il y a peut-être une piste pour une certaine apétence pour les orthos ?
Sur un Koss ESP 950 en mode DAC, ça manque un peu d'ampleur et de maitrise mais sans doute aussi bon voire certainement meilleur qu'avec n'importe quel autre DAC à prix équivalent.
Je l'utilise en ce moment comme préamplificateur, avec un ampli Rega mira dont je me sert comme simple ampli; comment dire , je suis subjugué par sa transparence quelque soit le niveau sonore, le fruité des timbre et relief stéréo; du coup je squeeze le préamplificateur du Rega. beaucoup moins bon.. Et sans aucune manipulation autre que l'actionnement de la clé sur la face avant, je l'utilise comme amplificateur de casque ( AKG, Sennheiser, Bose ). Ecoute de musique symphonique, vocale, musique de chambre etc. Bravo.
Nicolas D.
MOGAMI W3103 Câble Haut-Parleur Cuivre OFC 2x4mm² Ø12mm
J'apprécie Mogami pour les câbles de modulation.
Le W3103 ne démérite pas et malgré le prix un peu élevé il mérite 5 étoiles.
Très bonne articulation du grave avec, s'il le faut, une capacité à laisser passer toute la puissance de l'ampli sans crispation. Un câble équilibré et très riche sur tout le spectre. Pas de sensation de masque ou de manque dans l'aigu sans pour autant être fatiguant.
Je retrouve un équilibre du grave à l'aigu même à faible volume sonore.
Remplace avantageusement un bon Sommercâble sur mon système extrêmement délicat et résolvant.
Nicolas D.
VIBORG VB401 Fiches Banane Cuivre Pur Red Copper Ø4mm (Set x4)
Très bien ! Aucune dégradation du son et pratique pour essayer différentes enceintes.
Qualité de fabrication excellente.
Nicolas D.
Fourches Cuivre plaqué Etain Ø3.2mm (Set x10)
Très pratique pour connecter facilement les câbles HP en sortie d'un ampli QSC ISA 450.
Bonne qualité et bon contact, aucune dégradation du son.
Attention par contre elles sont souples et il faut les adaptées en fonction du diamètre du câble .A manipuler avec délicatesse mais une fois en place ne bouge pas.
Markos M.
Efficace ...
Petit appareil assortie d'un excellent logiciel sur smartphone ... simple à configurer avec multiples réglages. N'a pas les possibilités de ses grands frères mais suffisant ...
Markos M.
DAYTON AUDIO GS2.1 Active Subwoofer with 2.1 Amplifier 30W + 2x15W The Dayton Audio GS2.1 is a unique and versatile solution for full range reproduction in small spaces. This compact active subwoofer is equipped with a 6.35cm (2.5") driver, a...
Performant ...
Petit appareil qu'on peut monter sous étagère étant le complément idéal pour mes enceintes Artsound AS 410 assorties d'un amplificateur de qualité ... discret, performant au point que mon entourage s'étonne de la qualité issue d'enceintes faisant 16 cm de coté ...
Gilbert T.
Excellente alimentation linéaire
Acheté en complément d'un raspberry Pi 3+ et d'un AUDIOPHONICS I-SABRE V4 DAC ES9023 TCXO. Aucun bourdonnement à signaler et tensions parfaites.
