Une révélation
Gionatan R.
Bello ma fragile
Mi piace molto questo eccitatore. Per le dimensioni che ha il suono è buono, però i due punti di connessione sono molto fragili...
François G.
Customers reviews - There are 19456 reviews.
Jürgen M.
Software not good!
I don‘t recommend from point of Software. The hardware seems to be fine but the device operation lead into disappointment. The first issue is a jumping volume sometimes you change the input. Mainly if you switch to the Pi input. It jumped to 100% which is annoyingly loud. The second issue is that none of the Pi distributions worked as expected. I tried all three. Some show issues withe second display, some cannot read from my Synology NAS and the playback via Pi is not that stable as expected. The only stable App was Picoreplayer which obviously cannot drive the second display without sophisticated programming and Linux knowledge. Good hardware with bad software is not worth that amount of money!
Hi,
This is obviously indeed not the product for you and we understand your frustration.
This DIY kit is intended for people capable of ensuring manual assembly and having the computer bases necessary to modify the software solution at leisure and according to their needs.
The images we offer are only intended to serve as an example and we are not the developers.
Picore is indeed one of the most stable and lightweight solutions available on Base PI and is 100% compatible with this hardware solution (yes indeed the second screen does not display anything by default).
Do not hesitate to contact our after-sales service staff if you wish to return it for a refund.
Burkhardt P.
Great solution
The item is for me a great solution for hearing SACDs in stereo (mostly with headphones) directly from my Cambridge Audio 752 BD through the Holo Audio May without any conversion to PCM.
In the May you've to set the I2S to ALT2 and then it's working without any problems.
Jean claude C.
Pangea
Après réception de mon câble PANGEA AC-9SE MKII, j'ai pu le mettre en place tout de suite sur mon Ampli Audio Analogue , j'ai été surpris par autant de détail ainsi que l'espace autour des enceintes . Je pense avoir eu une nette amélioration qu'aucun câble de modulation sur mon système jusqu'à ce jour.
Il n'est même pas encore rodé ?
Une belle trouvaille à ce prix bravo Audiophonic.
George B.
Perfection
Product arrived in Australia within 7 days of ordering and performs exactly as expected. Subwoofers now turn on and off with the Amplifier. Will definitely recommend to my audiophile friends.
RENE R.
FURUTECH
SUPERBE CABLE QUE J'UTILISE AVEC UN CASQUE AKG702.
L'AMELIORATION APPORTEE EST IMPORTANTE ET TRANSFIGURE COMPLETEMENT CE CASQUE.
QUELLE TRISTESSE DE VOIR A QUEL POINT LES FABRICANTS METTENT DES CABLES DE "MERDE" SUR LEURS PRODUITS, QUELLE HONTE!
JE METS EVIDEMMENT 5 ETOILES POUR CE CABLE.
François M.
Remarquable
Ce câble monté en symétrique avec les connecteurs de la même marque a remplacé l'Epilogue pourtant très bon.
Il s'avère plus transparent et encore plus fin sans aucune fatigue auditive. L'Epilogue a sur les fréquences élevées cette petite insistance qui s'avère un peu fatigante à la longue sur des Klipsch Heresy 3.
Peut on encore faire mieux que ces Nemoi 1220 ?
Erreur de jeunesse. Attente de l'age adulte
Avant le DMP A6 je streamais avec un PC et l'éversolo Z8.
J'ai testé le A6 qui a un super son (le A6 est meilleur que PC+Z8) et son look superbe.
Avec l'ancienne configuration, un seul bouton de la télécommande me permettait de passer d'une source à l'autre.
Avec le A6 ... c'est pas possible.
Mais dès qu'un firmware corrigera tout ça, je re-achèterai le A6 qui repart chez Audiophonics pour l'instant.
Tout est ici :
https://www.homecinema-fr.com/forum/source-dematerialisee-haute-fidelite-et-dac/everso-dmp-a6-collecte-des-bugs-pour-la-team-zidoo-t30127125.html
Pierre P.
Cable USB LINDY
Très bien envoi rapide et article conforme.
Sinon pas grand chose à dire sur un câble qui fait son job
Olivier A.
ATOHM S500-MK2-X ICE POWER Class D Amplifier Module Subwoofer 500W 4Ω The Atohm S500-MK2-X Ice Power is a Class D amplifier module for subwoofers offering excellent technical performance and great musicality. It is capable of delivering a power of...
Déçu
En remplacement d'un module klipsch R115 400w. Prix très élevé au regard du rendu en deça de celui du module d'origine. Pauvre en connectiques et en fonctionnalités par rapport aux modules de marques concurrentes. Le comble, pour 550€, pas même une fonction veille !!! Avec 10w/heure de consommation résiduelle minimale, il ne faut pas manquer de jouer les contorsionnistes pour actionné à l'aveugle l'interrupteur entre le dos de l'appareil et le mur.
Je regrette mon choix.
La marque nous fait parvenir sa réponse et des suggestions suite à votre avis produit par email (que nous vous avons transmis via notre messagerie).
Dans l'attente de vous lire.
Erwin S.
Works, but has a design flaw that can be overcome
The description says that the DAC can be used for I2S or S/PDIF signals and that switching can be done with jumper J3. Since I wanted to connect both types of input, I connected J3 with a toggle switch on the front of my Amp. S/PDIF signal from my CD drive and I2S from a Raspberry Pi and a HifiBerry Digi-Pro hat. Roon installed on the RPI. CD playing, with J3 closed worked well. As soon as an I2S signal is also send to the DAC, it switches to I2S, regardless of the position of J3. Also after switching off the I2S signal, it remains locked on I2S. Service desk of Audiophonics waved me away, saying basically that this is the way this DAC works. To me this is a design flaw that needed a resolution, which I have found. When switching to S/PDIF (closing J3), the I2S / BCK connection between the RPi/HifiBerry to the DAC needs to be interrupted. I use a dual toggle switch to do that, works well now. So first 5 stars with just CD, then to 1 star for not working as expected and finally to 3 because of the design flaw. For the money though a good sounding DAC with the option to upgrade the OPA to a better one. Greetings.
Patrick D.
FIIO BTA30 PRO
Bonsoir a tous,
je confirme l"avis de José, un temps "d'adaptation pour la mise en phase sur l"ensemble du système" est nécessaire.
Sur mon système le tout numéric via un "Mac Bouque Aéré" couplé en acquisition à une carte son en externe toute simple, une Esi 22 usb, il confirme [en source directe] ce que j'attends du numéric pour une restitution analogique via des enceintes 4 voies pas forcement évidentes à driver... à mon humble avis, dans une gamme qui à coup d'AOP surmultipliées et de marketing d'assemblage promus en tête de gondole il a forcement sa place.
Allez pour une fois je me lache ;
Un Big Up!
Audiophonics, qui au fil du temps, sait m'accompagner au fil musical de ma passion. Merci à Vous!
FIIO FT3 Circumaural Open Dynamic Headphones Ø60mm 350Ω 102dB 7Hz-40kHz Fiio offers with the FT3 headphones an aesthetic and performing model, revealing a musical and dynamic sound reproduction with an ergonomic and very modern design. The frequency...
Tout d'abord le "packaging" est tout simplement impeccable.. Les accessoires fournis avec le casque sont de première qualité,
que se soit la connectique (XLR 4, Pentaconn 4, jack 6.5 mmm) ou les oreillettes supplémentaires, le sac en tissu et la petite valise de transport ainsi que le câble de 3 m, tout cela respire une excellente fabrication.
Venons en à l'écoute ! Et bien cela fait maintenant plusieurs heures que j'écoute diverses musiques, classique, jazz, blues etc...et pour l'instant je suis satisfait, la bande passante est très étendue, l'aigu est bien maitrisé, le médium parfaitement en place et le grave est vraiment bon avec une belle diversité. Les instruments comme la contrebasse ou le violoncelle ont du corps. La musique électro a du punch.. Bref le casque est bien équilibré. L'image stéréophonique est large mais sans excés. Maintenant le casque réagit bien aux divers enregistrements, si c'est mal enregistré le casque n'arrangera pas les choses par contre si l'enregistrement est de qualité le casque saura lui rendre grâce. Ceci est l'apanage des bons casques!!
Attention toutefois vu l'impédance de 350 ohms, il faut un ampli costaud pour tirer le maximum, ce casque n'est pas nomade, c'est un casque d'écoute pour la maison. Il a besoin de puissance pour s'exprimer au mieux. Après 3 heures d'écoute d'affilée, pour ma part je n'ai ressentie aucune fatigue, ni échauffement aux oreilles dûs aux coussins. Le port est agréable malgré un poids respectable.
Au regard du prix, de sa qualité de construction et des accessoires fournis est on peut dire un grand merci au constructeur qui a réussi à sortir un casque remarquable à la portée de nombreux mélomanes pas forcément fortunés.
J'ai une très longue expérience de l'écoute au casque, puisque j'ai commencé en 1966 avec un casque Sansui et ensuite j'ai possédé un casque électrostatique Micro Seiki en 1972 et ensuite des casque Stax, Grado, Sony audio techniqua etc... etc...
A l'heure ou les fabricants de casques partent dans délires coûteux et pas toujours à la hauteur (Je sais il en faut pour tous les goûts!!) je trouve cela rassurant de voir que pour une somme raisonnable on peut avoir du matériel de qualité qui offre grandement satisfaction.
Albert L.
Pas convainquant
Le son subit une nette dégradation en passant par ce montage, et cela sur les 4 entrées. Un son saturé comme une station radio FM pas tout à fait sur la bonne fréquence. Un léger mieux après avoir changé le circuit intégré amovible par un équivalent sous la main, mais sans plus.
Un casque au rapport qualité/prix remarquable
HUBERT L.
Très belle découverte
J'ai dû remplacer les 4 tubes JJ KT90 d'origine de mon ampli (plus d'offre en KT90), et après avoir hésité avec des Gold Lion Genalex KT88, j'ai finalement jeté mon dévolu sur ces KT120, et je ne regrette pas. Gain en puissance, bien sûr, mais surtout en détails, avec des aigus présents , mais jamais fatiguants (malgré mes HP KLIPSCH RF7 MKIII), des médiums très bien servis et un grave profond à souhait. Bref, je recommande vivement ces TUNG SOL KT120 !!
Robert D.
Very Happy
The DAC sounds great, with details I haven't heard with my previous DAC. The streamer interface is very nicely designed and following an automatic software update, the unit patched into my network and was playing music within 5 minutes. Thank you Audiophonics for exceeding expectations, for the low price and quick shipping.
Gianfranco P.
Wonderful
I purchased this board after watching some videos where DIY streaming projects were presented. I am an enthusiast with white hair now, but I still like to experiment especially with Raspberry units, which with in pi4 model have made a significant step forward also in terms of pure performance. What can I say: the board is wonderfully engineered and equally well assembled. When listening, I noticed an increase in sound definition and a greater stage with incredible separation between the various instruments, especially percussion (which I love). In short, a top product, which does not at all disfigure with my other products costing 10 times more such as the Rose Hi-Fi RS-250 or the Auralic Aries. Money definitely well spent, especially when paired with the Pure Pi and the Tranport PI (with AES/EBU connection that I use to connect with my m2Tech Young MKIII DAC.
A Thank You to my friends at Audiophile who had all the products delivered to my residence in Italy in just 48h.
ELECAUDIO DCT-2.5G Male Jack DC 5.5/2.5mm Connector Tellurium Copper Gold Plated 3µ This DC 5.5/2.5mm Elecaudio DCT-2.5G connector will allow you to design high quality power cables, ensuring a clean transmission of the electrical signal to your HiFi device....
Voix superbes
Des belles voix
Ça chante bien
Le plus cher et le meilleur
Ça chante bien très bien
Banana Plugs Gold Plated Lockable Ø9mm (The pair) These affordable banana plugs allow a quick and easy connection to the terminals of your speakers and amplifiers, while ensuring an optimized contact. The contacts are...
Big banana
On peut en mettre du câble !!! J'ai relié 2 *4mm y'a encore de la place. Système de blocage efficace. Belle qualité de fabrication.
Johnnie M.
Fantastic!
This power amp is just absolutely fantastic! The build quality is much nicer in real life than what the pictures can express! I picked this NCx500 based version over the Purifi 1ET400A, because the Hypex module is more or less exactly the same module, but improved on. The sound quality is amazing, the power and control is almost unimaginable! I can highly recommend!
Jean-Christophe H.
Problème de blindage ?
Fonctionne normalement, pas encore testé en Hi Res.
En revanche, très fort grésillement dans le train (TGV) ... un problème de blindage ?
Luc D.
Je ne recommande pas ce produit
Ce produit :
- Colle très mal
- Est fragile car il se perce facilement
- Est très cher pour 94X20 mm
Donc je ne le recommande pas, je pense qu'il vaut mieux, si possible, utiliser du Kapton.
Luc D.
HYPEX UCD400HG HxR Mono Power Amplifier Module 400W The UCD amplifiers in the HG range are high-end versions of the UCD180ST and UCD400ST amplifiers. They are available in 2 versions: UCD180HG and UCD400HG. They're perfect for...
J'ai utilisé 2 modules UCD400HG pour remplacer les 2 modules identiques de mon Micromega AS400 qui donnaient des signes de faiblesse après 12 ans d'utilisation.
Sans surprise je retrouve la sonorité originelle de mon AS400, c.a.d un son neutre, détaillé, transparent et dynamique. Ces modules permettent d'avoir de vraies basses sur des enceintes difficiles à driver et gourmandes en courant, telles mes Martin Logan Theos dont l'impédance peut tomber à 0,7 ohm.
Avec une bonne alim, un bon préampli et un bon refroidissement (c'est de la classe D mais 400 W cela chauffe !), ces modules peuvent donner beaucoup pour un prix très raisonnable. Seuls petits bémols : la diode bleue d'un des modules s'éteint lorsque l'ampli est chaud alors que le module semble parfaitement fonctionner, et puis je m'aperçois que j'ai payé chaque modules 6 € plus cher que leur prix actuel.
Cédric R.
Fait le job et bien.
Premier cable de cette marque. Il est branché sur une barette Viborg. Je reste sceptique quant à l'amélioration qu'il apporte, j'ai l'impression d'un mieux sur tout le spectre.
Jean Philippe L.
No country of origin
Just came back from Japan Osaka and brought a pair of these connector but a bit disappointed on the packaging nothing is written Made in Japan.
Not on the boxes, not on the connectors even not on instruction manual.
But the products look very nice, well you have to trust with whom you buy!!!!
Bryant D.
Very unsatisfied
The unit I received makes a high-pitched noise whenever the screen is on (40 seconds each time a button is pressed). Feedback from Audiophonics is that this is normal and they are unable to offer any sort of remedy. So overall, I cannot recommend such a low quality product.
Bruno S.
10 et lode
Produit superbe
Bruno S.
FOSI AUDIO BT30D PRO Class D 2.1 Amplifier 2xTPA3255 Bluetooth 5.0 2x125W+250W 4 Ohm The Fosi Audio DT30D Pro is a small, powerful and affordable Class D amplifier, ideal for the integration of a simple but powerful audio system. It embeds for that two TPA3255...
Pour le prix est vraiment un bon produit .
Bruno S.
Produit super et livraison impeccable
Suite commande
Envoi rapide, fiches de très bonne qualité
Michel V.
inversion de phase ?
bonjour, quelqu'un a t'il une experience de câblage sur ce cable avec le connecteur VIABLUE T6s Connecteur Secteur IEC C15 Plaquée Or 24K Ø16mm ?
j'ai entendu parlé d'inversion de phase ?
cela veut-il dire que je dois mettre le fil Neutre domicile sur la connection qui est repérée Phase sur le connecteur et idem pour le fil Phase du domicile sur la connection qui est repérée Neutre sur le connecteur ?
Ca me parait bizarre non ?
Merci pour ceux qui ont deja fait ce branchement
cordialement
Joan M.
HIFI2000 GX388 - 80x330x280 - Facade 10mm Noire The Galaxy models are small housings particularly suitable for mounting active filters, preamplifiers, etc.... The internal useful height is 80mm.
Solid product
When assembling this case I could feel it solid, sturdy and elegant
It makes you feel like you invested money in a very high quality product. 100% recommended
Joan M.
ABL SURSUM Power inlet with sutter 250V 16A IP54 Black This ABL SURSUM female PVC power supply unit is suitable for installation on mains, panel or even wall-mounted spool valves.
High quality
I used this plug in my DIY preamp to deliver voltage to active speakers. It feels very solid and connections are very safe. 100% recommended
Joan M.
High quality
I used this utility board to add a balanced output from preamp to active speakers with XLR inputs. This little beast works great at first glance and delivers clean balanced signal. 100% recommended
Olivier C.
TOPPING MX3S Class D Amplifier Infineon Headphone Amplifier DAC Bluetooth aptX Adaptive 2x50W 4 Ohm 24bit 192kHz Black The Topping MX3S is a true swiis army knife of audio, acting as both an amplifier and a headphone amplifier with integrated AK4377 DAC and Bluetooth receiver. An ideal model for...
Juste excellent à ce prix.
Plus de naturel et d'ouverture que le SMSL AD18 que j'avais dans cette pièce. Utilisé avec des colonnes Davis + caisson.
Très bon aussi en bluetooth.
Très agréable à l'écoute tout en restant très précis. Il n'est pas fatiguant comme peuvent l'être certains FDA en écoute longue.
Seul la sortie casque n'est pas terrible (casque AKG K701) mais je ne l'ai pas achet pour cela, c'était juste pour tester.
luc M.
Entrée coaxiale pas compatible avec toutes les sources
J'ai acheté 2 exemplaires pour remplacer mes FDA en sortie d'un MINIDSP nanodigi (coaxiale) malheureusement cela ne fonctionne pas correctement, nombreux crépitement (leur fréquence dépend du contenu musical) ; Les 2 exemplaires ont le même soucis; En dehors de ce problème la qualité du son est bien meilleure que mes FDA et bien meilleure que mon DAC1 Benchmark donc je suppose qu'en USB c'est un très bon DAC; Bravo à Audiophonics pour son service impeccable.
Matthieu V.
bof
Amplificateur parti en SAV au bout de 6 mois. Utilisé à 50% de sa puissance. Peinture de très mauvaise qualité (en comparaison de mes amplis Atoll).
Musicalité de folie
J’ai assemblé ce câble avec des prises Rca plaquées or à 10€ les 4.
Les deux câbles au point chaud et la tresse de masse des deux côtés, le tout soudé avec 10% d’argent de chez mundorff.
Le résultat est exceptionnel et je pèse mes mots.
De la pêche, de la douceur, de la fraîcheur, le tout dans un mélange subtil, que l’on appelle MUSIQUE.
Bref, ce câble est une vraie pépite, et je ne parle pas de son prix dérisoire, mais bien de sa musicalité a couper le souffle.
Je vais recommander 2 mètres et des prises Rca type EIZZ Tellurium pour apporter une meilleure liaison a ce câble, qui le mérite amplement.
Sommer câble restera pour moi LA référence pour ses qualités musicales, toutes gammes de prix confondus.
A écouter d’urgence
Patrick. S
André G.
Fer à souder efficace et réglable
Ce fera souder est très pratique et permet un réglage de température élevée 500 ° grâce à sa mollette ronde et un led rouge. Bon rapport qualité prix
Bruno l.
superbe câble en modulation ou en câblage interne d’ampli.
En gauge 20 sur la masse et en gauge 22 sur le point chaud, ce cable est une révolution. aucune tonique, une articulation redoutable et des timbres fantastiques. Le cuivre OCC mais surtout la géométrie du câble plat en fond un must.
Bruno l.
Bruno l.
Magique !
Sans aucun doute, l’un des accessoires le plus étonnant et le plus performant pour améliorer sa chaîne. Plutôt que de changer de convertisseur ou de câble, essayez cet appareil redoutable.
Tout est plus net, plus propre avec un rythme insoupçonné et des timbres plus réalistes. Avec deux appareils, un sur la prise murale et un sur la nourrisse entre les amplis et le DAC, c’est magique !
YARBO RCA-012BW Male RCA Connectors Gold 24k Copper Plated Ø8.5mm (Set x4) Yarbo propose avec les RCA-012BW de très bons connecteurs RCA mâles, acceptant des câbles d'un diamètre pouvant aller jusqu'à 8.5mm. Simple...
A souder
Contrairement à ce qui est annoncé la fiche doit être soudée puisque seul le point chaud (central) est équipé d’une vis permettant de solidariser un conducteur. L’autre vis ne sert qu’à maintenir le câble et ne peut en aucun cas assurer un contact électrique correct. Négligence ou tromperie ?
Laurent H.
Excellent tube el34
Je possède un ampli cayin cs-88a avec des lampes kt88. J'ai voulu tester une bonne lampe el34. Effectivement cette lampe est vraiment excellente. Par rapport au kt88 genalex gold. Plus de texture, une écoute plus émotionnel, des basses tendus et plus de nuances pour les voix. Par contre le kt88 est plus dynamique, une image beaucoup plus grande en largeur et en hauteur. Plus de basses et le son est plus tendu. A part le prix je ne regrette pas mon achat. Pour info le rodage n'est pas encore terminé.
Qobuz en wifi
Je reliais ma tablette à mon DAC via USB pour écouter Qobuz. J'ai acheté ce lecteur réseau relié avec un cable optique à mon DAC pour écouter ma tablette en wifi, cela fonctionne parfaitement jusqu'à 24/192, avec une excellente qualité sonore. A ce stade difficile de dire lequel est le meilleur, il me faudra un peu de temps. Un grand merci à Audiophonics pour leurs conseils.
Todor S.
IFI AUDIO IDEFENDER+ Anti Ground Loop Filter Male USB-A to Female USB-A The iFi Audio iDefender+ allows you to cancel noise originating from a ground loop in your audio system. Indeed, the inevitable use of several plugs and cables within your HiFi...
Great device!
I have a Chinese DAC that is powered by USB, but there is no noise filtering from the current, so I needed to feed it with clean electrical signal. Ifi Defender+ does a perfect job for this - I'm using a smartphone power supply now, but I'm thinking of buying an Allo Nirvana to further improve the sound quality.
Mark D.
Solid DAC
I have had this DAC for a few years now. I have the second AKM version. It have no other DAC to compare it too, but I have been impressed by its absolute reliability, great sound and useful features. The first of those is the perfect volume control that seems not to lose resolution as it is turned down. The second is the loudness button which is exactly what is needed for late night low level listening. I also use the basic bass and treble controls though not the parametric because frankly I have not been able to master it. The user interface is forbidding. Lastly, as far as filter go I set it NOS which sounds to me the most natural. There may be other DACs that are more impressive. I would like to get a good ladder DAC but at three times the price will it be three times better?
Andrii B.
Linear Power Supply circuit board 4 35mm Snap in gold plated This dedicated linear power supply circuit is ideal for designing stereo DIY amplifiers. It allows you to integrate 4 35 mm Snap-In capacitors of your choice (10 mm...
Good quality.
Used in DAC power supply unit.
Andrii B.
LHY AUDIO DIR9001Interface Module SPDIF to I2S 24bit 96kHz This SPDIF to I2S interface module allows to get a signal from a coaxial or optical Toslink input for output to I2S. It uses a Burr Brown DIR9001 receiver chip and supports PCM...
The product is as described.
Fast delivery from France to Germany.
