Efthymios X.
As per title really.
Efthymios X.
As good as it always was
Plus reliable. That's it :)
Patrick R.
Customers reviews - There are 21000 reviews.
Fabrizio R.
On Lenco Ptp6, dsp Xilica and Powersoft amplifiers for 4 subwoofers...very good cable.
I have this interconnect cable for connect my Preamplifier Audio Note M5 phono with this turnable, dsp and classD amplifiers and work very well in all conditions,highly recommended.
Matej J.
In my opinion, very clean sound, especially at high frequencies, of course, the other bands do not fall behind in any way.
I have tried many capacitors with identical capacity, this one seems to be the best, and the price is also OK.
I highly recommend.
Martin S.
Great Product
I am genuinely impressed with this amp.
Purchased to power some small bookshelf speakers in my office, I was impressed the first time I turned it on.
Okay, in my opinion, this is obviously not a contender for a main system. However, that said, for €220 it really does a lot right. Very surprising midrange, most of what is on the recording can be heard. What the amplifier lacks is control and refinement. But the system I generally listen to, cost rather a lot more than this. I am giving 5 stars as at this price point it is a lot better than I had expected.
If you are looking for a small low cost amp. Then I think this product will satisfy. The most important thing is to enjoy the music you are listening to. I am certainly enjoying the music in my office using this amp.
jean michel G.
Utilisé pour un câble DIY. Sertissage parfait.
jean michel G.
Très bonne pince, maniable, facile à utiliser.
SHANLING EC MINI Portable CD Player and DAP Sanyo 680 2x ES9219MQ Bluetooth 5.0 aptX LDAC 32bit 384kHz DSD256 MQA-CD Silver The Shanling EC Mini is a CD player and DAP combo that's as compact as it is versatile and high-performance. Its high-quality design allows you to enjoy your music in every...
MOYEN
J'ai acheté ce lecteur principalement pour le lecteur cd pour ma chaine secondaire . En lecture cd les timbres médium aigu ont une tendance simplifiés et synthétiques légèrement frustrant à l'écoute . L'équaliseur est de qualité moyenne et ne corrigera pas ce défaut . Dommage car les détails sont présent et le suivi mélodique est agréable . En Bluetooth ce phénomène disparait et le liaison LDAC est bonne .
François G.
Remplacement haut parleur
J'ai déjà utilisé ce haut parleur sur une enceinte que j'avais développée il y a une quinzaine d'années et j'en avais un bon souvenir.
Aujourd'hui c'est pour restaurer des enceintes JMlab dont les tweeters Focal T101 ont rendu l'âme, j'ai réalisé avec une imprimante 3D une plaque d'adaptation pour les DT28N et après simulations et contrôle, il s'adaptait parfaitement en réponse en fréquence, phase, impédance.
Après écoute, aucune modification sur le filtre n'a été nécessaire. Les enceintes ont retrouvé leur jeunesse.
HERVE H.
EVERSOLO DAC-Z6 DAC 2x ES9068 XMOS XU316 Bluetooth 5.0 32bit 768kHz DSD512 MQA The EverSolo DAC-Z6 is a powerful DAC based on a neat technical structure. It embeds high-end components with notably two ESS ES9068AS digital/analog conversion chips and a XMOS...
Popularité méritée
Dac Z6 reçu rapidement(comme toujours
Pierre E.
Suitable for Fosi Audio BT20A Pro
Installed in a Fosi Audio BT20A Pro. Works well, I did not compare with the original op amp as I changed them right away.
Fast & efficient delivery by Audiophonics
Sasha B.
perfectly made and correctly packaged
Sasha B.
Sasha B.
2 ème avis
Voici une quinzaine d'heure qu'il fonctionne... Quelle amélioration !
Superbe basse, détail , la separation des canaux se fait de plus en plus précise.
J' ai autant de plaisir qu' a écouter mon tube de 10 fois le prix.... Autrement recommandé.
Thierry V.
Dommage
Celà fait plusieurs mois que j'ai acquis ce petit syteamer. Pour ce qui ai du streaming, pas de soucis, il fait bien le job et son appli smartphone est cool (Qobuz intégré). Par contre une petite faiblesse au niveau du dac et de sa partie sortie analogique. En tout cas sur une chaîne hifi correcte. La restitution est vraiment très moyenne. J'ai dû acheter un petit Dac externe et via les connexions optiques on arrive à qque chose d'acceptable. Mais encore et toujours, à ce prix, faut pas attendre des performances de fou !
Brian C.
Banana Plugs Rhodium Plated Ø9mm (Pair) These banana plugs, although inexpensive, benefit from a nice design quality. The design of these plugs allows a very good contact between the connector and the terminal block,...
I like them...use them without the sleeve
I like them...use them without the sleeve...the set of two screwws are on same side so it makes an even pressure on the wire
RAMM AUDIO S8MC Interconnect Cables RCA OFC Copper 1m This RAMM Audio S8MC RCA-RCA modulation cable offers good quality at a very affordable price. The cable conductors are single-stranded OFC copper. The cable features an aluminum...
Rqp de folie !!!!
Ne cherchez pas ailleurs !!!
Si vous souhaitez un câble équilibré pour un prix dérisoire ce petit Ramm est une super affaire !!
Il est arrivé ce matin à la casa et alors qu'il n'est absolument pas rodé il affiche de très belles qualités.....notamment un bel équilibre entre toutes les parties du message....certes il n'est pour le moment pas aussi ouvert qu'un câble à 600 euros mais ce dernier propose une mise en avant du haut médium aigu....ce qui peut fausser l'écoute....
Brut de décoffrage le Ramm donne une fessée à un câble anglais à 250 euros....comme le disent nos amis anglophones for thé price it's a giant killer !!!!!
efficace
Utilisée sur le câble secteur de mon vinyle et l'alim de mon récepteur Bluetooth . Dans le deux cas la musique est plus incarnée ; une sensation de présence qui implique à l'écoute . Un gain très appréciable pour un coût faible . J'ai déjà remplacé des câbles secteur par des produits de marque onéreux avec des résultats moins concluants . Cependant j'ai essayé le modèle de diamètre supérieur pour les câbles de mes barrettes et j'ai était moins convaincu . Vu le prix à essayé en fonction des résultats .
Pascal C.
Amélioration notable
Utilisé en remplacement d'un câble générique pour relier mon lecteur réseau à mon hub audiophile ce câble Audiophonics contribue à ce que les extinctions de notes soient plus longues, les graves plus tendus et améliore la définition en allant chercher les micros détails.
Pas forcément le plus neutre car peut-être un soupçon chaleureux mais le rapport qualité prix est très bon et tient aisément la comparaison avec un câble Atl*s 3 fois plus cher.
Robert C.
Not noticeable SQ improvement on my laptop
The device didn't bring any noticeable difference in terms of sound quality in my existing laptop configuration. Sound quality using direct USB cable to DAC and using USB over SMSL PO100 to DAC gave almost the same SQ results.
Rather save the money and by something like Wiim Pro or Wiim Pro Plus for audio streaming purposes.
Robert C.
Valid improvement over laptop/PC as a streamer
I was surprised with the sound quality using Spotify connect over Wiim Pro Plus instead of my laptop. The difference in favor of Wiim is more then obvious.
Pros: Easy of use, Wiim app, SQ for the price, SQ can be further improved with better external power supply.
Cons: Only Coax and Optical outputs (USB would be ideal), no native support for DSDs (at least I couldn't get it working in my setup).
Stefano C.
Not a good experience for me
I’m sorry to give a negative review on what seems to be a very high quality and well thought out product, but I have to share my experience. I have used this cables to connect my Benz Micro Glider SL to an Ortofon LH9000 headshell. Compared to the wires that come with the shell (I guess the ortofon 6N headshell leads), the 1877phono ones led to a more sterile presentation, less precise imaging, less threedimensionality and body, bass less controlled, highs a bit fatiguing, less dynamic. The clips on the shell side were a bit too large, but they allowed a sufficient grip on the pins and I don’t think that is the problem leading to the lesser presentation. I think the problem is most likely the rhodium plating. in my experience rhodium plating on audio signal connectors lead to sterile and harsh sound, this is the third time I have bad experience with rhodium, the other two being Ramm spades and Neotech XLR connectors. In all cases I had to switch back to gold or silver plating even giving time to break in. I have all power connector furutech rhodium plated but for audio signal now I’m really done with rhodium, I’ll try no more. To give context I have a Garrard 401 TT with modified SME 3009 II improved, Mark Levinson 26 and 23.5, and Tuscanini planar magnetic speakers (very revealing of any insignificant defect along the audio chain as in this case).
F M.
WONDOM AA-AB32221 Stereo Amplifier Board Class D TAS5613 2x150W 4 Ohm The Wondom AA-AB32221 is a stereo amplifier module capable of delivering 2x140W of power at 4Ω. Featuring a Class D architecture based on a TAS5613 amplifier chip, it...
Impressionnant (suite)
Je reviens car mon avis a été tronqué...
Je confirme donc l'efficacité de ce module qui envoie du lourd. La puissance est bien là (sous 36 volts), certes diminuée dans du 8 ohms, avec un son percutant est clair.
Normunds Z.
Recommend
Great device!
Normunds Z.
HDMI 2.1 Cable 8K 60Hz 48Gbps HDR eARC ALLM Dolby 2m This high-performance HDMI 2.1 cable supports video transmissions in 8K 60Hz and 4K 120Hz with a bandwidth of 48Gbps. Its conductors ensure an excellent signal transmission and...
Recommend
Excellent cable, noticeably improved the picture from computer to TV.
Insulated Female Blade Terminal 4.8mm Ø3mm (x10) These lugs accept cables up to 3mm and will allow you to easily connect your speakers. In addition, they are made of a Copper alloy to ensure good electrical conductivity. Each...
Adhesive Cable Tie 20x20mm Black This adhesive cable tie simply attaches to a wall to allow you to group your cables together. The base of the cable tie is adhesive and can therefore be easily attached to any...
Pratique
Très pratique et colle bien aux parois.
Je me suis lancé sur la construction diy d' un ampli classe d a partir de ce module 3e audio.
Ayant déjà eu un ampli 3255 en remplacement de mon tube parti en Sav, celui est incomparable !
Beaucoup plus nuancé, musical, silencieux et précis. Il représente sans doute l' avenir de la classe d , bien conçu et incontournable.
A ce prix, pas d' hésitation a avoir.
Je recommande sans réserve.
MP-H250S48 SMPS Switching Mode Power Supply Module 250W 48V 5A PFC This SMPS MP-H250S48 switch-mode power supply module is capable of delivering 48V, 5A current and 250W of power. It is also equipped with a PFC (Power...
Bonne alim.
Simple et efficace pour une implantation réussie. Fonctionne parfaitement.
Pas ouf
Assez déçu par ce boitier dont le système de fixation des capot est mal conçu selon moi. De plus, les petites vis de fixation sont trop courtes pour atteindre l' écrou dans la rainuré. Y' a mieux.
Step Drill Steel HSS-4241 15 Steps Ø4-32mm This 15-step drill, from 4mm to 32mm, is made of HSS-4241 steel and can drill through materials such as iron, aluminum or plastic. It has a hexagonal shank for quick tightening.
Nickel !!
Fait des trous avec précision . Dans de l' alu 3mm, c' est comme dans du beurre..je recommande
IEC C14 Plug with ON-OFF Toggle Switch and Fuse Gold Plated Pure Copper 250V 10A This IEC C14 socket is ideal for integration into a DIY device as a power connector.  The socket incorporates an ON/OFF toggle switch for powering your device and a fuse to...
Oui, mais....
Adapté pour une épaisseur maxi de 1,5 mm. Sinon, bonne connections et qualitatif.
Cablage interne ampli
Utilisé en cablage interne d' un ampli classe d 3 E audio, c' est très bien.
Cablage interne
Utilisé pour un cablage interne d' un ampli 3e audio stéréo, très bon résultat.
DURATOOL D03048 Digital Multimeter 500V 5A 2MOhm This Duratool D03048 digital multimeter features all standard measurement functions and is suitable for any professional or DIY electronics project.
Fait très bien ce pour quoi il est conçu.
Speaker Terminals 24k Gold Plated Ø19mm x 50mm (Pair) These speaker terminal blocks offer excellent design quality at an affordable price. Their contacts are made of 24k gold-plated copper alloy, ensuring...
Parfaits
C' est lourds, solide, bien fabriqué et très sérieux, très bons borniers.
pascal P.
Déçu
Après avoir lu nombre d'avis élogieux sur ce câble, j'étais très bien disposé, mais je suis très déçu. Médium creux et froid, aigu métallique, le grave est très (trop ?) présent. Courbe en V physiologiqie. P
Gerard T.
Des les premières écoute le Gustard fait de la très belle musique
Mais avec un coté un peu glacé
Il faut être très patient.
Mais une fois rodé je confirme que ce Dac est vraiment fantastique la musique est libérée aucune coloration.
Et encore meilleur avec un drive extérieur 3Dlab.
Bravo..!
Edmond H.
LPSU25
Achetée pour améliorer mon Raspberry DAC PRO 2,
Je suis ravi du résultat obtenu. Graves mieux tenus, reproduction douce et puissante du spectre, possibilité de monter le volume sans distortion si je compare à l'alimentation de base. Un vrai et grand plus pour moi. Merci Audiophonics
FURUTECH CF-202 NCF (R) Banana Plugs Rhodium Plated Pure Copper NCF Alpha Treatment Ø5.5mm (Pair) With the CF-202 NCF (R), Furutech unveils high-end banana plugs offering excellent transmission performance with contacts made of rhodium-plated pure copper. This is the brand's...
Pas de Surprises
Après avoir acheté, monté avec bonheur les fiches RCA, de la même catégorie.(FURUTECH CF-102 NCF), je me suis décidé a changer les fiche bananes de mon câble d'enceinte( Crystal Cable Ultra) , qui avait de simples bananes Furutech cuivre rhodium visée , par ces magnifique Bananes, qui sont d'une fabrication incroyable, qui ont apporté , un gain de finesse, de micros-détails , et un recul du bruit de fond, un petit plus de véracité, mais cela ne fait qu'une semaine , quelles 'tournent' le rodage n'est pas terminé. J'avoue que la remise des soldes d'hiver, mon décidé , à effectuer cet achat qui et quand même conséquent, au vu de la multiplication des prises!!!
Eric J.
SBOOSTER BOTW P&P MKII Regulated Linear Power Supply 12V 3A / 13V 2.25A / 13.5V 2.1A With the SBooster BOTW P&P ECO MKII regulated linear power supply, purification of the electrical signal begins immediately where the polluted current enters the power supply....
Je l'emploie pour alimenter ma box internet THD Redbox by SFR. L'alimentation est bien fabriquée et inspire confiance. Elle chauffe peu; consommation: une petite trentaine de watts.
Jacky D.
Bon câble
Câble qualitatif. Souple et facile à dénuder. Rendu sonore très correct, à confirmer après rodage. Livraison ultra rapide, bravo Audiophonics !
Jacky D.
Top qualité
Belle qualité. (fiche et vis). Elles tiennent très bien dans la prise. Pourquoi dépenser plus..!
Amélioration : séparation visuelle du + et - (rouge et noir) trop faible. Il manque un cerclage de couleur (que j'ai fait avec ruban adhésir de 2mm de large). Livraison ultra rapide, bravo Audiophonics
HERVE H.
Livraison rapide.
Petit accessoire malin qui fait parfaitement le job.
Après, il y aura toujours le débat: Laisser ses électroniques sous tension afin d'éviter les chocs à l'allumage et garder la bonne température de fonctionnement pour une meilleure écoute...ou tout éteindre...
Mark M.
Great sounding connector at a great price!
I built a cable with Belden 4694R 12G video cable for ,
my. Merason Frerot DAC. Awesome sound; so life like and real. I am buying more!
bien mais...
Nette amélioration d'un point de vue sonore, le médium est bien plus ouvert, c'est plus précis aussi sur le reste du spectre.
Il y a bel et bien une différence avec une prise Legrand.
L'embase est qualitative et upgrade réellement mon système.
Je regrette juste que les produits Furutech aient autant augmenté...ça devient dissuasif en dépit de leur efficacité et de leur qualité.
Par ailleurs, l'installation n'est dans mon cas pas achevée puisqu'elle ne s'encastre pas dans un boitier mural standard (prise Legrand mozaic), et dépasse de 3 cm. Elle tient aux 2 vis latérales du boitier.
Les conducteurs sont positionnés en haut et en bas, à la verticale, et non à l'arrière de l'embase, ce qui va m'obliger à élargir l'emplacement plus tard. A prendre en considération si vous avez des murs en béton ou en pierre par exemple...
Eric J.
Inspire confiance
J'emploie cette alimentation pour mon box internet thd red by sfr. Elle semble bien fabriquée, les nombreux adaptateurs sont pratiques. Elle alimente bien la box en chauffant peu. Consommation une petite trentaine de watts.
D2R
The elegant, very musical DAC surprised me with its sound clarity, its range and space of sound delivery, fast and accurate high-resolution sound delivery, excellent setting options, only when switching the type of sound resolution, you can hear a slight banging, but that will definitely be solved by later controls, I extremely satisfied with this thing
LAURENT L.
Quel ampli
Moi, qui recherche toujours des test a gauche ou à droite avant de choisir.... Ce coup ci j'y suis allée un peu a l arrache, le son est formidable avec mon focal celestee, de plus le s.a.v répond très rapidement. Première commande et sans doute pas la dernière. Encore merci
Henry G.
HYPEX SMPS1200A400 Switching Power Supply Module 1200W 2x63V The Hypex SMPS1200A400 is a high-efficiency, Safety Class 2 switching power supply designed for use with UcD™, NCORE®, and NCOREx® amplifier modules. This unit is...
Acheté en remplacement d'une alim similaire cramée après 6 ans de bons et loyaux services suite à une mauvaise manipulation.
Excellente qualité de fabrication, composants de qualité, notice très détaillée. Bien sous tout rapport.
Jani R.
AUDIOPHONICS Trigger Cable Male USB-A to Mono Male Jack 3.5mm 1m Extremely practical, this USB-A to Jack 3.5mm mono trigger cable, assembled in France in our workshops, lets you control the automatic switching of your devices using the 5V...
Just works
I looked for a product like this for years and haven't seen anyone else sell one.
Affordable AVRs don't have trigger outs but they often have a USB port. Arendal Subwoofers need a trigger signal to wake up and stay on at low levels.
This cable is the solution and it works great. I just wish there were options for longer cables and 90-degree USB-connectors.
