This filtered power supply module kit has been designed by LHY Audio at Beatechnik's request, and is intended for use with the Bluesound Node N132. This filtered power supply improves the performance of the Bluesound Node N132 network player, as using a filtered power supply rather than a switch-mode power supply offers many advantages, not least a great improvement in the sound reproduction quality of your devices.
This power supply module features three C-L/C-L/C-L/C filter stages and is made up of numerous capacitors and inductors. The input is on a DC 5.5/2.1mm connector and accepts DC 5V. The wiring supplied is silver-plated.
Removing or changing the power supply of the Bluesound Node N132 invalidates the warranty.
| Specifications | |
| Product type | Filtered power supply module kit |
| Supply voltage/current | 5V DC |
| Connector | DC 5.5/2.1mm |
| Input | Jack DC 5.5/2.1mm |
| Output | PCB Connector |
| Output voltage (V) | NC |
| Output current (A) | NC |
| Input voltage (V) | 5.0 |
| Power Supply | Power supply filter |
