HYPEX SMPS1200A100 Switching Power Supply Module
The Hypex SMPS1200A100 is a high-efficiency, Safety Class 2 switching power supply designed for use with UcD™, NCORE®, and NCOREx® amplifier modules. This unit is intended for audio systems that require a stable power supply across a wide load range, all in a compact and lightweight form factor.
By buying this product you get 25 loyalty points
Reference : 14847
259,00 €tax incl.
215,84 € tax excl.
Hypex SMPS1200A100 Switching Power Supply Module 1200W 2x40V
Hypex SMPS1200A100
The power supply includes an overcurrent protection mechanism that limits the output current in the event of a temporary overload. It also features balanced auxiliary outputs and a control interface that allows it to be used with UcD™, NCORE®, and NCOREx® amplifier modules.
The SMPS1200 is designed to minimize electromagnetic interference. Its topology and design are optimized to meet the EMI requirements typically associated with professional and high-end audio applications.
The power supply supports a selectable input voltage range, allowing it to operate with different power grid specifications. It is therefore suitable for use in international applications where power grid standards vary.
The SMPS1200 is a two-quadrant full-bridge rectifier designed to power asymmetric Class D amplifiers.
The SMPS1200 complies with current safety and performance standards and is certified for use in professional audio equipment
Hypex SMPS1200A100 diagram
Product typeSwitching mode power supply
Input voltage230V / 115V (switchable via jumper)
Main output voltage2x 31V (Min)
2x 40V (Typ)
2x 46V (Max)
Aux output voltage2x 15V (Min)
2x 20V (Typ)
2x 22V (Max)
Aux output current500mA
Main output power1200W
Switching frequency100kHz
Dimensions165 x 105 x 52mm
Weight750g
ProtectionOvercurrent
Output voltage (V)40.0
Input voltage (V)115.0
Input voltage (V)230.0
Power SupplySMPS
HYPEX SMPS1200A100 Switching Power Supply Module 1200W 2x40V
The Hypex SMPS1200A100 is a high-efficiency, Safety Class 2 switching power supply designed for use with UcD™, NCORE®, and...
