Back
Impedance (Ω)
Speaker Type
Diaphragm type
Loudspeaker diameter (mm)
0 - 534
Efficiency / Sensitivity (dB)
75 - 110
Xmax (mm)
0 - 34
Lowest frequency (Hz)
10 - 17010
Highest frequency (Hz)
0 - 57000
Speaker Power (W RMS)
0 W - 2005 W
Categories
Jean-Claude F.
Très bon câble HP
Jean-Claude F.
Yvain C.
J’ai hâte de la...
Search by criteria There are 487 products.
  • Ref : 21890
    In Stock
    The XCITE XT19 is a compact vibrating driver designed for space-saving installations; its ultra-slim 14 mm profile makes it easy to fit into confined spaces whilst retaining significant excursion capability. It features a dual N42 neodymium magnetic circuit combined with a 4-layer voice coil, increasing sensitivity by more than 3 dB whilst maintaining a...
    10,90 € 9,08 €Ex.
    In Stock
  • Ref : 21891
    In Stock
    The XCITE XT25 is a vibrating speaker designed to extend the frequency response into the high frequencies, optimised up to 19 kHz. It features a dual N42 neodymium magnetic circuit delivering high sensitivity, whilst its 3.0 mm Xmax, combined with a linear excursion of 1.4 mm, enables controlled movement, ensuring a balance between refined reproduction...
    14,91 € 12,42 €Ex.
    In Stock
  • Ref : 21894
    In Stock
    14,91 € 12,42 €Ex.
    In Stock
  • Ref : 18801
    In Stock
    The XCITE XT32-4 exciter features a unique combination of large travel and low inductance, guaranteeing vibrations with the lowest distortion across the entire frequency range. The XT32-4 is equipped with a double neodymium magnet motor, offering excellent power and precision. The XT32-4 is extremely reliable. It has been designed to avoid level drops,...
    29,91 € 24,92 €Ex.
    In Stock
  • Ref : 19461
    Reduced price!
    In Stock
    The XCITE XT32-8 is a exiter driver featuring a unique combination of long excursion and low inductance, guaranteeing vibrations with the lowest distortion across the entire frequency range. It is equipped with a dual neodymium magnet offering excellent power and precision. The XT32-8 is extremely reliable, designed to avoid level drops and equipped with...
    23,92 € 19,94 €Ex.
    29,91 € In Stock
  • Ref : 21896
    In Stock
    The XCITE XTB40 is a vibrating speaker designed for low-frequency reproduction, with an architecture that optimises bass extension down to 25 Hz. It features an extended excursion of 5.0 mm Xmax for 2.5 mm of linear displacement, enabling it to generate significant mechanical energy whilst maintaining distortion control, whilst the combination of a dual...
    49,90 € 41,58 €Ex.
    In Stock
  • Ref : 21902
    In Stock
    49,90 € 41,58 €Ex.
    In Stock
