DOUK AUDIO T9 Tube Phono Preamplifier
The DOUK Audio T9 is a tube MM/MC phono preamplifier. It features four tubes, including two 6E2 tubes and two 6A2 tubes, offering a colorful and dynamic sound reproduction that is most enjoyable. The phono input supports both MM and MC cartridges for a high level of compatibility with turntables. In addition, it has an independent headphone amplification circuit and a 3.5mm jack output.
Reference : 21112
164,00 €tax incl.
136,67 € tax excl.
Shipping date: 24-11-2026.
Douk Audio T9 Tube Phono Preamplifier MM/MC with 6A2 / 6E2 Tubes
DOUK AUDIO T9 photo
The Douk Audio T9 is a tube MM/MC phono preamplifier. It features four tubes, including two 6E2 tubes and two 6A2 tubes, offering a colorful and dynamic sound reproduction that is most enjoyable. The phono input supports both MM and MC cartridges for a high level of compatibility with turntables. In addition, it has an independent headphone amplification circuit and a 3.5mm jack output. Capable of driving headphones with an impedance of 32 to 300 ohms, the T9 is also compatible with a wide range of headphones and IEMs. Bass and treble tone controls also allow you to sculpt the sound to your preferences. On the aesthetic side, you can choose between green and orange tube backlight colors for a pleasing visual appearance.
DOUK AUDIO T9 photo
Douk Audio T9: High-quality features and components
6A2/6E2 tubes
6A2/6E2 tubes for a warm sound
These tubes deliver an authentic sound when listening to your favorite vinyl records.
MM/MC compatibility
MM/MC compatibility
A switch allows both types of phono cartridges to be made compatible with the T9.
Tone adjustment
Tone adjustment
The bass and treble controls allow you to adjust the sound to suit the source or the listener's preferences.
Douk Audio T9 overview
DOUK AUDIO T9 overview
1Power button
2Source selector
3Tube backlight color switch
43.5mm headphone jack output
5Bass adjustment
6Treble adjustment
7Volume control
8RCA line output
9RCA input
10MM/MC phono input
11MM/MC switch
1212V 1A power supply via DC jack
Product typePhono preamplifier
Tubes2x 6E2/6A2
Inputs1x MM/MC phono input
1x RCA AUX input
Outputs1x RCA output
1x 3.5mm headphone jack output
Headphone output power250mW @ 32Ω
100mW @ 64Ω
60mW @ 128Ω
THD≤ 0.1%
Bass/treble adjustment±10dB
Backlight adjustmentGreen/Orange/Off
Settings with phono input
Phono input level0.005V RMS (MM)
0.0005V RMS (MC)
Output level0.6Vrms
Input impedance47K ohm (MM)
330ohm (MC)
SNR≥ 80dB
Frequency responseCompliant with RIIA ±2dB
AUX RCA input setting
AUX RCA input level0.775V RMS
Output level1.5V RMS
Input impedance100 Kohm
SNR≥ 106dB
Frequency response20Hz-20KHz (±0.5dB)
Power supply12V DC 1A via jack DC
Dimensions154 x 87 x 47mm
Weight600g
Package1x Douk Audio T9
2x 6E2 tubes
2x 6E2 tubes
1x Ground cable (alligator clips)
1x 12V 2A DC jack power adapter
InputPhono
OutputJack 3.5mm
ClassTube amp
DOUK AUDIO T9 Tube Phono Preamplifier MM/MC with 6A2 / 6E2 Tubes
The DOUK Audio T9 is a tube MM/MC phono preamplifier. It features four tubes, including two 6E2 tubes and two 6A2 tubes, offering a colorful and...
