Maurizio A.
AUDIOPHONICS LPA-S450ET
Consegna nei tempi previsti,sono molto soddisfatto del mio acquisto,descrizione accurata e coerente con la realtà,qualità audio...
jean michel G.
jean michel G.
Très bon fil, isolant qui résiste à la chaleur... Facile à souder
List of products LHY Audio
LHY Audio designs and distributes high-performance and affordable DIY audio modules. The brand offers a wide range of products, from digital interfaces to linear power supplies, Bluetooth receivers and clocks.
  • Ref : 21728
    The LHY-Audio linear power supply is a low-noise power supply based on the use of a high quality custom toroidal transformer, high-performance LT3086 regulators, high-current, low-resistance Schottky rectifiers, and Vishay BC electrolytic capacitors, all mounted on a four-layer PCB with gold-plated copper circuits.
    299,00 € 249,17 €Ex.
    In Stock
  • Ref : 21729
    In Stock
  • Ref : 21731
    In Stock
  • Ref : 19049
    Here's a stable, regulated linear power supply for any high-quality audiophile DIY project. All the necessary technical refinements are incorporated in this power supply dedicated to audio, and it will work perfectly with your HiFi devices operating at 12V.
    329,00 € 274,17 €Ex.
    In Stock
  • Ref : 19056
    In Stock
    Here's a stable, regulated linear power supply for any high-quality audiophile DIY project. All the necessary technical refinements are incorporated in this power supply dedicated to audio, and it will work perfectly with your HiFi devices operating at 9V.
    In Stock
  • Ref : 15637
    In Stock
    This mains noise tester allows to measure the interference and therefore the noise on a power network and to compare filtered and unfiltered systems. It operates over a frequency range of 300kHz to 700kHz. Below or above these values, an LED lights up to indicate that the value is out of range.
    105,00 € 87,50 €Ex.
    In Stock
  • Ref : 19892
    The LHY Audio OCK-2S is a high-precision master clock with ultra-low phase noise, designed to minimize sampling errors on high-resolution streams. This clock features six independent 10MHz 50/75Ω outputs on BNC connectors, including three sine-wave and three square-wave outputs. Based on a high-performance OCXO oscillator, it significantly improves...
    1 099,00 € 915,83 €Ex.
    In Stock
  • Ref : 19894
    In Stock
    In Stock
  • Ref : 18797
    In Stock
    These LHY Audio speaker protection modules contain a relay with a nominal voltage of 24V DC, a resistance of 1100 Ohms and a switching current of 16A.
    169,00 € 140,83 €Ex.
    In Stock
  • Ref : 21812
    This Premium Series power cable from LHY Audio features two 5.5/2.1mm DC jack connector. This cable is made with high-quality imported wire featuring a high-purity copper core, ensuring efficient signal transmission. It features a low-impedance design that guarantees a more stable current. The effective impedance over a 1-meter length is 23.8 mΩ.
    54,90 € 45,75 €Ex.
    In Stock
  • Ref : 21810
    49,00 € 40,83 €Ex.
    In Stock
  • Ref : 21813
    This Premium Series power cable from LHY AUDIO features two 5.5/2.1mm DC jack connector. It is constructed using high-quality imported cable with a high-purity copper core, ensuring stable signal transmission. Its custom DC connectors offer broad compatibility and excellent flexibility, working with most audio and digital devices.
    62,90 € 52,42 €Ex.
    In Stock
  • Ref : 21815
    This Premium Series power cable from LHY Audio features two 5.5/2.5mm DC jack connector. This cable is made with high-quality imported wire featuring a high-purity copper core, ensuring efficient signal transmission. It features a low-impedance design that guarantees a more stable current. The effective impedance over a 1-meter length is 23.8 mΩ.
    54,90 € 45,75 €Ex.
    In Stock
  • Ref : 21814
    49,00 € 40,83 €Ex.
    In Stock
  • Ref : 21816
    62,90 € 52,42 €Ex.
    In Stock
  • Ref : 21821
    This Premium Series power cable from LHY Audio features a Aviation 2-Pin connector (GX16) on one end and a Jack DC 5.5/2.1mm connector on the other.This cable is made with high-quality imported wire featuring a high-purity copper core, ensuring efficient signal transmission. It features a low-impedance design that guarantees a more stable current. The...
    54,90 € 45,75 €Ex.
    In Stock
  • Ref : 21820
    49,00 € 40,83 €Ex.
    In Stock
  • Ref : 21822
    62,90 € 52,42 €Ex.
    In Stock
  • Ref : 21824
    This Premium Series power cable from LHY Audio features a Aviation 2-Pin connector (GX16) on one end and a Jack DC 5.5/2.5mm connector on the other. This cable is made with high-quality imported wire featuring a high-purity copper core, ensuring efficient signal transmission. It features a low-impedance design that guarantees a more stable current. The...
    54,90 € 45,75 €Ex.
    In Stock
  • Ref : 21823
    49,00 € 40,83 €Ex.
    In Stock
  • Ref : 21825
    62,90 € 52,42 €Ex.
    In Stock
  • Ref : 21808
    This Premium Series power cable from LHY Audio features a Aviation 2-Pin connector (GX16) on one end and a USB-C connector on the other. This cable is made with high-quality imported wire featuring a high-purity copper core, ensuring efficient signal transmission. It features a low-impedance design that guarantees a more stable current. The effective...
    54,90 € 45,75 €Ex.
    In Stock
  • Ref : 21742
    49,00 € 40,83 €Ex.
    In Stock
  • Ref : 21809
    62,90 € 52,42 €Ex.
    In Stock
  • Ref : 21818
    This Premium Series power cable from LHY Audio features a 5.5/2.1mm DC jack connector on one end and a 5.5/2.5mm DC jack connector on the other. This cable is made with high-quality imported wire featuring a high-purity copper core, ensuring efficient signal transmission. It features a low-impedance design that guarantees a more stable current. The...
    54,90 € 45,75 €Ex.
    In Stock
  • Ref : 21817
    49,00 € 40,83 €Ex.
    In Stock
  • Ref : 21819
    62,90 € 52,42 €Ex.
    In Stock
  • Ref : 21794
    This Premium Series power cable from LHY Audio features a 5.5/2.1mm DC jack connector on one end and a USB-C connector on the other. This cable is made with high-quality imported wire featuring a high-purity copper core, ensuring efficient signal transmission. It features a low-impedance design that guarantees a more stable current. The effective...
    54,90 € 45,75 €Ex.
    In Stock
  • Ref : 21733
    This Premium Series power cable from LHY AUDIO features a 5.5/2.1mm DC jack connector on one end and a USB-C connector on the other. It is constructed using high-quality imported cable with a high-purity copper core, ensuring stable signal transmission. Its custom DC connectors offer broad compatibility and excellent flexibility, working with most audio...
    49,00 € 40,83 €Ex.
    In Stock
  • Ref : 21795
    62,90 € 52,42 €Ex.
    In Stock
  • Ref : 21796
    This Premium Series power cable from LHY Audio features a 5.5/2.5mm DC jack connector on one end and a USB-C connector on the other. This cable is made with high-quality imported wire featuring a high-purity copper core, ensuring efficient signal transmission. It features a low-impedance design that guarantees a more stable current. The effective...
    54,90 € 45,75 €Ex.
    In Stock
  • Ref : 21739
    49,00 € 40,83 €Ex.
    In Stock
  • Ref : 21797
    62,90 € 52,42 €Ex.
    In Stock
  • Ref : 21801
    This Premium Series power cable from LHY Audio features a USB-A connector on one end and a USB-C connector on the other. This cable is made with high-quality imported wire featuring a high-purity copper core, ensuring efficient signal transmission. It features a low-impedance design that guarantees a more stable current. The effective impedance over a...
    54,90 € 45,75 €Ex.
    In Stock
  • Ref : 21744
    49,00 € 40,83 €Ex.
    In Stock
  • Ref : 21802
    This Premium Series power cable from LHY AUDIO features a USB-A connector on one end and a USB-C connector on the other. It is constructed using high-quality imported cable with a high-purity copper core, ensuring stable signal transmission. Its custom DC connectors offer broad compatibility and excellent flexibility, working with most audio and digital...
    62,90 € 52,42 €Ex.
    In Stock
  • Ref : 19755
    This LHY Audio Receiver interface module converts an HDMI LVDS signal into an I2S signal. It accepts PCM and DSD signals, enabling users to enjoy high-resolution files.
    18,90 € 15,75 €Ex.
    In Stock
  • Ref : 21623
    The LHY Audio RPI Pro is a streamer based on the well-known Raspberry Pi CM4 module, integrating the RoPieee operating system for support of numerous streaming protocols: Roon Bridge, Airplay, Spotify Connect, Tidal Connect, Squeezelite, UPnP, NAA. Moode OS is also available for the RPI Pro if desired.
    1 199,00 € 999,17 €Ex.
    In Stock
  • Ref : 21632
    In Stock
  • Ref : 17565
    In Stock
    The single AOP LHY AUDIO is a discrete class A operational amplifier. Mounted on a stand, it offers quick assembly thanks to its DIP8 format. Even once installed, the AOP is easily changed. Designed for professional audio applications, it offers great performance. Indeed, it has greatly reduced noise, distortion and achieved an output current of 65mA.
    29,90 € 24,92 €Ex.
    In Stock
