TinySine's TSA8498B modules are Class D amplifiers that deliver no less than 4x100W at 6Ω. They are also combined with an AudioB Plus module to offer Bluetooth reception supporting aptX, for more convenient use.
The TinySine TSA8800B amplifier module combines the functions of a 2.1-channel Class D amplifier, DAC / DSP and integrates an AudioB I2S Bluetooth receiver supporting the high-resolution aptX and aptX HD codecs. It can deliver up to 2x90W of power and features a 200W subwoofer output. To achieve this, it uses TPA3321 amplifier chips. DAC / DSP signal...
The TinySine TSA8802B amplifier module combines the functions of a stereo Class D amplifier, a DAC / DSP and incorporates an AudioB I2S Bluetooth receiver supporting high-resolution aptX and aptX Low Latency codecs. It is capable of delivering up to 2x88W of power at 4Ω. To achieve this, it uses TPA3221 amplifier chips. DAC / DSP signal processing...
The TinySine TSA8802D amplifier module combines Class D stereo amplifier and DAC/DSP functions. It can deliver power up to 2x 100W, thanks to a TPA3321 amplifier chip. DAC/DSP signal processing is carried out by an ADAU1701 chip, enabling it to support streams up to 24bit 96kHz via its Toslink optical input (TOSLINKBee receiver).
The TinySine TSA8804 is a 4x100W Class D amplifier module based on a TDA7498E chip. It can be powered over a wide voltage range of 14V to 39VDC and can be used to drive 4Ω or 8Ω speakers. It also integrates a Bluetooth 5.1 receiver. This makes it possible to stream music remotely from a smartphone or tablet, for example.
The TinySine TSA9840B is a small Class D amplifier module, based on a MAX98400A amplifier chip, allowing to deliver, in this mono version, a power of 20W. This module can then be used to power a passive speaker 8Ω.
The TinySine TSA9840B is a small Class D amplifier module, based on a MAX98400A amplifier chip, delivering 2x20W power. This module can then be used to power two 8Ω passive speakers.
This Wondom AA-AA11466 aluminum mounting bracket is L-shaped for quick and easy wall mounting. It is specially designed for amplifier or battery power PCBs measuring 6“ by 4.5” (15.24cm x 10.16cm).
The Wondom AA-AB31282 amplifier is capable of delivering 1x200W of mono power under 3 Ohm. This substantial power reserve allows this amplifier to be associated with demanding speakers or subwoofers, requiring a significant power input. In addition, the module supports BTL (Bridge-Tied Load) configurations and is therefore bridgeable to provide power boost.
This Class D amplifier module Wondom AA-AB31413 is capable of delivering no less than 1500W at 2Ω with a high efficiency of 90% as well as a high level of detail and beautiful dynamics.
The Wondom AA-AB31471 is a small, simple and efficient Class D mono amplifier module. It includes a TPA3110 TI chip to enable it to provide a power of 30W for an efficiency of 90%, as well as a precise sound reproduction.
Mono amplifier module capable of delivering continuous power up to 2500W at 2 Ohm. The module uses an IRS2092 chip to drive 6x MOSFETs (IRFB4227 HEXFET) to provide a large power reserve with high efficiency (up to 91%).
Wondom's AIPO2X8 amplifier module is a versatile and robust solution for anyone wishing to build an audio installation. Its Texas Instrument TPA3110 amplifier chip enables this module to offer 2x8W or 1x16W amplification, while guaranteeing a signal-to-noise ratio of 103dB for crystal-clear sound reproduction. Its robust construction makes it suitable for...
The Wondom AA-AB32192 is a Class D stereo amplifier module based on a TAS5630B amplifier chip and capable of delivering a power of 2x300W under 4 Ohm (THD+N 10%). This amplification chip also allows to reach a very high efficiency, up to 96%.
The Wondom AA-AB32221 is a stereo amplifier module capable of delivering 2x140W of power at 4Ω. Featuring a Class D architecture based on a TAS5613 amplifier chip, it achieves a very high efficiency of 96% and excellent sound quality with very low distortion and noise level. Its SNR is thus measured at 94dB and its THD+N at 0.019% (@ 4Ω, 1W, 1kHz).
This small Class D AB32231 amplifier module from Wondom is based on a TPA3110 amplifier chip. It is capable of operating in stereo mode by delivering 2x8W and in mono mode by delivering 1x16W.
The Class D Wondom AA-AB32255 amplifier module is based on a TAS5756 chip from Texas Instruments (TI). This allows it to deliver a power of 2x30W at 4 Ohm and this with a high efficiency of 90% and a precise sound reproduction.
The Wondom AA-AB32281 is a stereo amplifier module capable of delivering 2x128w of power at 3Ω. Featuring a Class D architecture based on Sure Electronics' T-Amp technology, it achieves a very high efficiency of 91% and excellent sound quality with very low distortion and noise level. Its SNR is measured at 94dB and its THD+N at 0.004% (@ 3Ω, 1W, 1kHz).
The Wondom AA-AB32361 is a stereo amplifier module capable of delivering 2x110w of power at 4Ω. Featuring a Class D architecture based on a TDA7498E amplification chip, it achieves a very high efficiency of 95% and excellent sound quality with very low distortion and noise level. Its SNR is measured at 87dB and its THD+N at 0.032% (@ 4 Ohm, 1W, 1kHz).
This Class D Wondom AA-AB32433 stereo amplifier is capable, thanks to the T-Amp technology, of developing a consistent power of 2x750W at 4Ω with an efficiency of 90%. This large energy reserve allows it to be combined with a large number of speakers, including the most demanding models.
With the AA-AB32472, Wondom offers a Class D amplifier module. Designed with a Texas Instruments TPA3118 amplifier chip, this module delivers 2x23W of power at 8Ω, ensuring high-fidelity sound with low noise and 92.6% efficiency.
This Class D Wondom AA-AB32516 stereo amplifier is capable, thanks to T-Amp technology, of developing a consistent power of 2x500W at 4Ω with an efficiency of 90%. This large energy reserve allows it to be combined with a large number of speakers, including the most demanding models.
