Max sampling rate
DAC / ADC Chip
Amplifier chip
Class
Power (W)
2 - 1000
Channel
Input
Output
Remote Control
Streaming services
Color
Terrific cable
Tomasz C.
arnaud m.
Exelent
Audio amplifiers
HiFi systems require audio amplifiers. Here you'll find all our high-fidelity amplifiers, which will enhance your sound and bring out the best in your speakers. From power amplifiers to integrated amplifiers, all powers and all classes (A, D, T) are available to meet your needs.
Each amplifier is made up of an amplification module, an internal power supply, capacitors, printed circuits and a host of other components. You can be sure of the quality of these components in the amplifiers we offer.
  • Integrated amplifiers
    Here you'll find our selection of high-fidelity integrated amplifiers. Unlike power amplifiers, these have a pre-amplification section, notably via a volume knob and/or a source selector. Whether Mono or Stereo, you can plug your HiFi speakers directly into them and enjoy their impeccable sound.
  • Connected amplifiers
    Explore our selection of connected amplifiers. Connected amplifiers are mostly stand-alone devices, meaning they often combine the functions of network players and amplifiers. One of the most evocative terms for this category of Hi-Fi devices is the famous Just Add Speakers, which explicitly defines the concept. Simply add speakers to a connected amplifier and enjoy your favorite music sources.
  • Power amplifiers
    Power amplifiers
    In this category you'll find our selection of Power Amplifiers. Unlike integrated amplifiers, these only add power to the signal received, so they don't have built-in pre-amplification to concentrate on the very essence of amplification. Whether it's a Mono Power Amplifier or a Stereo Power Amplifier, find the ideal solution to perfect your HiFi installation.
  • Audiophonics Workshop Amplifiers
    All the amplifier models in this catalog are directly assembled in our Workshop located in Bordeaux. We selected the highest performing amplification circuit (Hypex NCORE, Purifi) to make the most from the best amplification technologies while maintaining an unrivaled budget on the high-end amplifier market. Available as mono blocks or stereo combined to meet all your integration constraints.
    Discover our full range of amplifiers made in France on our blog : Discover our range of Audiophonics Workshop amplifiers.
  • Ref : 20208
    In Stock
    SMSL's PA40 is an integrated amplifier based on Infineon's MA5332MS Class D amplifier chip, delivering 2x160W of power at 4Ω with a harmonic distortion of just 0.004%, for crystal-clear sound reproduction with low power consumption and very little heat generation. Furthermore, SMSL has selected a NJU7391 volume control chip with very low distortion,...
    159,00 € 132,50 €Ex.
    In Stock
  • Ref : 19918
    In Stock
    With the SMSL RAW-HA1, the brand unveils a versatile, high-performance integrated amplifier/headphone amplifier. At the cutting edge of technology, this device is based on audiophile components. In fact, it uses an Infineon chip to develop an output power of up to 2x 165W @ 4 ohm and a JRC NJW1194 volume control.
    249,00 € 207,50 €Ex.
    In Stock
  • Ref : 14233
    In Stock
    Although it has a compact format, this SMSL SA300 amplifier is able to deliver a comfortable 2x80W power at 4 ohm with high efficiency.  The SA300 is a digital amplifier, which has a Micro USB input and Bluetooth transmission.
    139,00 € 115,83 €Ex.
    In Stock
  • Ref : 20714
    In Stock
    The SMSL VMV A1 Pro is an innovative amplifier that uses Gallium Nitride (GaN) transistors to deliver 2x160W of amplification at 4Ω. Its versatility also allows it to operate in pure mono mode, delivering an impressive 400W into 4Ω. Every component of the VMV A1 Pro has been meticulously selected to achieve exceptional audio performance, with...
    529,00 € 440,83 €Ex.
    In Stock
  • Ref : 15391
    This affordable Class D amplifier is based on a TOPA3251D2 amplifier chip, ensuring a power of 2x140W under 4Ω and this with high efficiency. It will therefore have no trouble accompanying most speaker models. Moreover, it takes advantage of the PurePath Ultra HD technology, allows to maintain a very low level of distortion on the whole frequency...
    64,90 € 54,08 €Ex.
    In Stock
  • Ref : 17701
    Reduced price!
    In Stock
    The SVS Prime wireless pro SoundBase is a robust 300w stereo amplifier (150 watt per channel) with a 192 KHz/24-bit DAC housed in a compact and high-tech box. It is able to drive any loudspeaker to its full potential with plenty of dynamics, powerful bass and crystal clear sound. Its internal components are of audiophile quality. This integrated audio...
    719,10 € 599,25 €Ex.
    799,00 € In Stock
  • Ref : 19962
    In Stock
    Thinkya unveils a singular device with its DVR-102, a Class AB integrated amplifier based on the use of ECC83/ECC82 tubes for its preamplification stage and Toshiba PNP A1941 and NPN C5198 transistors for its power stage. One of its key features is that it features RCA input and output jumpers, enabling it to be used as a preamplifier or only as a...
    479,00 € 399,17 €Ex.
    In Stock
  • Ref : 19127
    In Stock
    Tinyside introduces one of their first ready-to-use devices. The TSA3610 is a Class D based on a TPA3116D2 amplifier chip, amplifier with 2x50W output power at 4 Ohm, featuring a CSR8635 Bluetooth 4.1 chip. This amplifier can be powered by any 12V-24V DC supply, and can be used to drive a 4Ω or 8Ω passive speaker while taking...
    54,90 € 45,75 €Ex.
    In Stock
  • Ref : 18657
    Powerful Class A stereo power amplifier, the Tonewinner AD-1PA+ benefits from a high quality balanced architecture that allows it to develop significant power while ensuring a dynamic and precise sound reproduction. Its careful and intelligent integration, proof of the attention paid by the brand to their product, results in a powerful and musical device,...
    3 590,00 € 2 991,67 €Ex.
    In Stock
  • Ref : 17768
    Reduced price!
    In Stock
    2 979,70 € 2 483,08 €Ex.
    3 590,00 € In Stock
  • Ref : 17769
    With the AD-2500 Pro, Tonewinner offers a particularly powerful stereo Class AB power amplifier. This one is indeed able to develop a power of 2x950W under 4Ω while offering a great dynamic range and ensuring a low noise level for a sound reproduction as precise as musical.
    1 490,00 € 1 241,67 €Ex.
    In Stock
  • Ref : 20214
    With the AD-3PRO+, Tonewinner offers a Class A integrated stereo amplifier rated at 2x165W at 8Ω, and relying on Toshiba 1941/5198 transistors and OPA 1656 to deliver warm, precise sound reproduction. Its numerous analog and digital inputs enable this device to fit into any possible configuration. Its integrated ES9038 DAC chip enables the AD-3PRO+...
    2 390,00 € 1 991,67 €Ex.
    In Stock
  • Ref : 17346
    In Stock
    The Tonewinner AD-5100PA+ is a Class AB power amplifier featuring 5 channels capable of delivering 130W into 4Ω or 90W into 8Ω each. It is therefore an ideal model for integration into a home theater system. It uses 5 pairs of Toshiba TTC5200 and TTA1943 transistors, ensuring a musical and rich sound reproduction. The low-noise differential...
    629,00 € 524,17 €Ex.
    In Stock
  • Ref : 19419
    In Stock
    The Tonewinner AD-60 is an integrated power amplifier offering 2 x 80W power at 4Ω while maintaining very low distortion and response time thanks to its Class AB design. Furthermore, its wide range of connectors means it can easily be used in a wide range of configurations, from home cinema with its HDMI/ARC socket to remote use via a simple...
    449,00 € 374,17 €Ex.
    In Stock
  • Ref : 19416
    Reduced price!
    In Stock
    356,85 € 297,38 €Ex.
    549,00 € In Stock
  • Ref : 18762
    Reduced price!
    In Stock
    The Tonewinner AD-66D PRO is an efficient and versatile Class A amplifier with a proven technical foundation for musical and detailed sound. Its circuitry uses audiophile-grade components to ensure excellent performance, including low noise and distortion. It also provides a complete set of connectors to meet the vast majority of needs for home audio...
    500,84 € 417,37 €Ex.
    659,00 € In Stock
  • Ref : 17354
    In Stock
    The Tonewinner AD-7300PA+ is a 7-channel Class AB power amplifier, ideal for home theater integration. Capable of developing significant power, measured at 584W RMS for one channel powered at 4Ω or 7x190W for 7 channels powered at 8Ω, this amplifier offers great dynamics and ensures low noise.
    2 049,00 € 1 707,50 €Ex.
    In Stock
  • Ref : 17407
    Reduced price!
    In Stock
    Tonewinner presents its AD-8300PA, an 11-channel power amplifier, allowing a home cinema integration, including Dolby Atmos systems. It delivers a consistent power with low distortion for an immersive and dynamic sound reproduction. Coupled with an audio/video preamplifier (sold separately), the AD-8300PA is an excellent solution for entering the world of...
    1 485,70 € 1 238,08 €Ex.
    1 790,00 € In Stock
  • Ref : 20216
    In Stock
    With the AD-86D, Tonewinner offers a Class A integrated stereo amplifier rated at 2x120W into 8Ω, and relying on TTC-5200/TTA1943 transistors and 1678 OPA to deliver sound reproduction that's both precise and warm. Its extensive connectivity means this amplifier can be integrated into many different configurations, even benefiting from Bluetooth...
    1 090,00 € 908,33 €Ex.
    In Stock
  • Ref : 18655
    In Stock
    ToneWinner unveils an all-in-one device with its AD89D Class AB integrated amplifier. This 2.1-channel amplifier features a CD player, high-fidelity Bluetooth reception and an HDMI ARC port. Powerful and versatile, the Tonewinner AD-89D is capable of delivering up to 2x 130W at 8 ohm.
    1 099,00 € 915,83 €Ex.
    In Stock
  • Ref : 17347
    Reduced price!
    In Stock
    As imposing in appearance as it is in power, the Tonewinner AD-99D is a powerful, versatile and robust Class AB stereo integrated amplifier. It delivers a pure and delicate sound, with a beautiful dynamic and richness of sound. It uses two balanced modules equipped with Toshiba transistors. It is completed by an efficient and reliable power supply stage...
    1 181,50 € 984,58 €Ex.
    1 390,00 € In Stock
  • Ref : 19759
    In Stock
    The Topping B100 mono power amplifier, little brother of the B200, is a state-of-the-art amplifier in terms of performance. It uses Topping's proprietary amplifier module to deliver 100W of power at 4 ohms, while maintaining a THD+N < 1% and a DNR of 151dB.
    299,00 € 249,17 €Ex.
    In Stock
  • Ref : 19764
    In Stock
    In Stock
  • Ref : 19588
    In Stock
    The Topping B200 power amplifier is a mono amplifier based on a discrete-component NFCA amplifier circuit. This enables it to achieve a considerable power level while maintaining excellent performance metrics. Indeed, the B200 is capable of delivering up to 200W of power (THD=1%) at both 4 ohms and 8 ohms.
    599,00 € 499,17 €Ex.
    In Stock
  • Ref : 19586
    In Stock
    In Stock
  • Ref : 17500
    In Stock
    Topping now offers the excellent LA90 in a version using discrete circuits, the LA90 Discrete. The result is a powerful amplifier with incredible metering for a breathtaking listening experience. The new NFCA discrete amplifier circuitry ensures extremely clear and precise sound reproduction. The amplifier has the same features as the first LA90, with...
    899,00 € 749,17 €Ex.
    In Stock
  • Ref : 17503
    In Stock
    In Stock
  • Ref : 15658
    In Stock
    Topping offers with its PA3s a small balanced Class D amplifier, simple, powerful and affordable. It is based on two Infineon MA12070 amplifier chips and has two balanced and single-ended outputs.
    149,00 € 124,17 €Ex.
    In Stock
  • Ref : 15659
    In Stock
    In Stock
  • Ref : 18001
    In Stock
    Topping's PA5 II amplifier is a compact and powerful model, adopting a totally balanced structure and an innovative Class D amplifier circuit, enabling it to develop a significant power of 2x100W under 4Ω with a low level of distortion. The excellent parameterisation carried out by the brand's engineers ensures clear, clean and deep sound...
    199,00 € 165,83 €Ex.
    In Stock
  • Ref : 18003
    Out of stock
    Out of stock
  • Ref : 17642
    In Stock
    The Topping PA7 is a powerful amplifier, based on a Class D architecture and benefiting from an intelligent and particularly careful design. It is thus capable of developing a significant power while maintaining a very low level of distortion. The technologies used ensure a clear, precise and deep sound reproduction. In addition, the balanced structure of...
    349,00 € 290,83 €Ex.
    In Stock
  • Ref : 17644
    In Stock
  • Ref : 19340
    Reduced price!
    In Stock
    An evolution of the WiiM Amp connected amplifier, the WiiM Amp Pro retains the features and functions of its predecessor, but with a few notable improvements. The WiiM Amp Pro, a high-performance connected amplifier, now features an ES9038Q2M DAC chip supporting sampling rates up to PCM 32bit 384kHz. In addition, the Class D amplification circuit using a...
    436,05 € 363,38 €Ex.
    459,00 € In Stock
  • Ref : 18387
    In Stock
    The WiiM Amp is an amplifier and streamer that's as compact as it is versatile and high-performance! It lets you distribute your music extremely simply via DLNA, AirPlay 2, Bluetooth (bidirectional) or Chromecast. So you can easily access your music library, whether it's stored on a computer, NAS or smartphone. What's more, control of the device and...
    369,00 € 307,50 €Ex.
    In Stock
  • Ref : 18424
    In Stock
    In Stock
  • Ref : 20685
    In Stock
    The WiiM Vibelink Amp, marks the brand's first foray into non-connected integrated amplifiers, designed to pair with WiiM Mini, WiiM Pro, WiiM Pro+ and WiiM Ultra streamers. This audiophile amplifier integrates an ES9039Q2M DAC chip, a TI TPA3255 amplifier chip and six OPA1612 OPAs, all within a PFFB (Post-Filter Feedback) structure.
    In Stock
  • Ref : 20686
    In Stock
  • Ref : 11845
    In Stock
    Wondom proposes here a TA2024 Clas D amplifier delivering a power of 2x15W under 4Ω, ideal for any secondary or auxiliary HiFi installation. Thanks to its compact design, its elegant case and its great ease of use, this amplifier will allow you to listen to your favorite songs on your audio systems with extreme simplicity.
    29,90 € 24,92 €Ex.
    In Stock
  • Ref : 16546
    Reduced price!
    In Stock
    The xDuoo DA-100, although compact and affordable, is very versatile, taking on the functions of Class D amplifier, headphone amplifier and DAC. Its careful design embeds a TPA3116 amplifier allowing it to develop a 2x50W power, a MAX97220 headphone amplifier and a ES9018K2M DAC ensuring low distortion and high SNR. A 1.3" OLED screen displays information...
    127,20 € 106,00 €Ex.
    159,00 € In Stock
