Discover the WiiM streamers series: WiiM Mini, WiiM Pro, WiiM Pro +, WiiM Amp and WiiM Ultra
Posté le 2023-10-25 Tests & reviews, HiFI products comparaisons 10247
WiiM streamers and connected amplifiers
Over the years, WiiM has developed a range of compact streamers that are affordable for the number of features they offer. Today, in the world of Hi-Fi, network players play an essential role, especially with the development of streaming platforms (Spotify, Deezer, Tidal, Qobuz, Napster, amazon music and others). WiiM stands out from the crowd with a complete range of Bit-Perfect streamers offering advanced features and audiophile-level sound reproduction performance. If you're not sure which of the WiiM Mini, WiiM Pro, WiiM Pro +, WiiM Amp and WiiM Ultra audio streamers to choose, you've come to the right place to find out what makes them different.
WiiM Mini, the entry level device
The WiiM Mini is a small streamer with the essentials, but great versatility. It converts your conventional audio system into a connected one. In terms of wireless connectivity, you can stream your music via Wi-Fi, Airplay 2 or Bluetooth 5.0. This streamer is compatible with Amazon Alexa and Apple Siri voice assistants, and features multiroom functionality. One of its other advantages is that you can stream your music via Spotify Connect or Tidal Connect without going through the brand's WiiM Home app. In terms of connectivity, it features only a Jack 3.5mm AUX input, with a Jack 3.5mm AUX and a Toslink optical outputs port.
99,00€ TTC (82,50€ HT)
WIIM MINI Audio Streamer Bit-Perfect WiFi AirPlay 2 Multiroom Bluetooth 5.0 24bit 192kHz
WIIM PRO Lecteur Réseau Audio Bit-Perfect WiFi AirPlay 2 DLNA Chromecast Multiroom Bluetooth 5.1 24bit 192kHz
WiiM Pro, a high-performance streamer
An evolution of the WiiM Mini, the Wiim Pro retains its flagship functions and features, but with a number of improvements. This time, it supports Bluetooth 5.1 as well as the DLNA and Chromecast wireless transmission protocols, extending the possibilities of audio sources. Another significant improvement is the extended connectivity. Inputs include an RCA stereo line input, a Toslink optical input and an RJ45 Ethernet port, while outputs include an RCA line output, a Toslink optical output and a coaxial SPDIF output. Additional features such as a 12V trigger on a 2.5mm Jack, support for Google Voice, a 10-band equalizer with 24 profiles and gapless track playback functionality also enhance the user experience.
179,00€ TTC (149,17€ HT)
WiiM Pro +, the audiophile network player with boosted performance
A true audiophile product, the WiiM Pro + now incorporates high-fidelity components: a TI Burr-Brown PCM1861 ADC for line input, a clock and power supply ensuring very low noise levels, and an AKM AK4493SEQ DAC for very low distortion and wide dynamic range. Overall performance is greatly optimized. It incorporates the WiiM Pro's extensive connectivity, full wireless connectivity and additional features, plus a voice remote control for the best possible user experience.
249,00€ TTC (207,50€ HT)
WIIM PRO+ Audio Streamer Bit-Perfect DAC AK4493SEQ WiFi AirPlay 2 DLNA Chromecast Multiroom Bluetooth 5.1 24bit 192kH
WIIM PRO+ Audio Streamer Bit-Perfect DAC AK4493SEQ WiFi AirPlay 2 DLNA Chromecast Multiroom Bluetooth 5.1 24bit 192kHz<span id=
WiiM Amp, a versatile, high-performance connected amplifier with advanced features
The latest arrival on the market, the WiiM Amp is a connected amplifier with the full functionality of a true streamer (Wi-Fi, DLNA, AirPlay 2, Bluetooth, Chromecast with access to streaming services). It also directly amplifies the audio signal from your music sources thanks to a Class D TPA3255 amplifier chip and delivers up to 2x100W under 4Ω power. Bluetooth 5.0 functionality is now bidirectional for possible pairing with headphones or wireless speakers. An HDMI ARC port and a subwoofer output enable you to set up a 2.1-channel system and recover your TV's audio signal. Thanks to its amplifier function, the basic connectivity has also evolved, with an RCA line input, a Toslink optical input, a USB-A port (USB Host) and an RJ45 ethernet port. On the output side, it simply incorporates a speaker terminal in addition to the subwoofer output already mentioned above.
359,00€ TTC (299,17€ HT)
WiiM Ultra, a new standard in network players market
A new standard in the world of network players, the WiiM Ultra is the most advanced model in the WiiM range. It features an ESS ES9038Q2M DAC for streams up to 32bit 384kHz PCM, and a TPA6120A2 high-fidelity headphone amplifier. At the cutting edge of performance, there's also a WiFi 6E connection and Bluetooth 5.3 functionality. The device's interface also features a handsome 3.5" touchscreen displaying a wealth of information on the playback in progress. The package is completed by extensive connectivity: HDMI input, phono input, subwoofer output, etc. The WiiM Ultra is thus able to adapt to any situation, and can be easily integrated into any sound system.
399,00€ TTC (332,50€ HT)
WIIM ULTRA
Summary of the features of the WiiM range of network players and connected amplifier
WiiM MiniWiiM ProWiiM Pro +WiiM AmpWiiM Ultra
Product typeStreamerStreamerStreamerConnected amplifierStreamer
DACPCM5121PCM5121AKM AK4493SEQNCES9038Q2M
ADCFixed 16bit 48kHzFixed 16bit 48kHzUp to 24bit 192kHzNCUp to 24bit 192kHz
AmplificationClass D TPA3255
THD +N (Analog output)-92dB (0.0025%)-92dB (0.0025%)-113dB (0.00023%)NC-116 dB (0.00015%)
SNR (Analog output)106dB106dB121dBNC121dB
Ethernet
Wireless connectivityWi-Fi / Airplay 2 / Bluetooth 5.0Wi-Fi / Airplay 2 / Bluetooth 5.1 / DLNA / Chromecast AudioWi-Fi / Airplay 2 / Bluetooth 5.1 / DLNA / Chromecast AudioWi-Fi / Airplay 2 / Bluetooth 5.0 bidirectional / DLNA / Chromecast AudioWiFi 6E / Bluetooth 5.3 bidirectionel / DLNA / Chromecast Audio
Airplay CastNC
ROONNC
Spotify Connect & Tidal Connect
Voice assistant supportApple Siri / Amazon AlexaApple Siri / Amazon Alexa / Google AssistantApple Siri / Amazon Alexa / Google AssistantApple Siri / Amazon Alexa / Google AssistantApple Siri / Amazon Alexa / Google Assistant
Multiroom
10-band graphic equalizer
CPUDual core A7Quadcore A53Quadcore A53NCQuadcore A53
DRAM128MB512MB512MBNC512MB
Flash128MB512MB512MBNC512MB
InputsAUX 3.5mm jackStereo RCA / Optical ToslinkStereo RCA / Optical ToslinkStereo RCA / Optical / HDMI ARC / USB-AStereo RCA / Phono Input (RCA) / Toslink optical / HDMI ARC / USB-A
OutputsAUX 3.5mm jack / Optical ToslinkStereo RCA / Coaxial / Optical Toslink / Trigger 12V on 2.5mm jackStereo RCA / Coaxial / Optical Toslink / Trigger 12V on 2.5mm jackHP terminals / SubwooferStereo RCA / Coaxial SPDIF / Optical Toslink / Subwoofer output (RCA) / 3.5mm jack headphone output
Voice-controlled remote control
Laisser un commentaire Leave a Reply
Vous devez être connecté pour publier un commentaire.
Rechercher dans le blog
Blog categories
Latest Comments
Prev
Next
