SMSL VMV D2R MK2 DAC
The SMSL D2R MK2 is a balanced DAC designed to handle the digital-to-analogue conversion of high-resolution audio streams, utilising a ROHM BD34302EKV chip combined with an XMOS XU-316 interface to ensure precise signal processing. It supports PCM formats up to 32-bit/768 kHz as well as DSD512, whilst maintaining a measured distortion of 0.00013% (-117 dB), thereby preserving signal linearity across the entire audible spectrum.
By buying this product you get 119 loyalty points
Reference : 21927
1 190,00 €tax incl.
991,67 € tax excl.
SMSL VMV D2R MK2 DAC ROHM BD34302EKV Bluetooth 5.4 32bit 768kHz DSD512
SMSL D2R MK2 : Front view
It combines a segmented internal architecture, a linear power supply and advanced digital signal processing, ensuring stable and consistent conversion. This approach enables it to shape the output signal with precise timing control, whilst maintaining broad compatibility with modern digital sources.
SMSL D2R MK2: ROHM DAC and XMOS interface
The SMSL D2R MK2 utilises a ROHM BD34302EKV DAC chip combined with an XMOS XU-316 USB interface, designed to ensure digital-to-analogue conversion with extremely low distortion, measured at 0.00013% (-117 dB), thereby preserving signal integrity even at the lowest levels. This architecture supports PCM streams up to 32bit 768kHz as well as DSD512, whilst MQA and MQA-CD compatibility extends support to content encoded with hardware decoding, ensuring faithful reproduction in high-resolution playback scenarios.
SMSL D2R MK2 : ROHM DAC
SMSL D2R MK2: Digital/analogue separation
The internal circuitry is designed to separate the analogue and digital sections, thereby minimising cross-talk that could degrade low-amplitude signals, whilst maintaining electrical stability across all critical stages. This approach is further enhanced by the integration of a linear power supply based on a Noratel transformer, whose regulation limits the switching noise typically associated with switching power supplies.
SMSL D2R MK2 : Circuit
SMSL D2R MK2 : Internal clock
SMSL D2R MK2: Internal OCXO clock
The D2R MK2 features an internal OCXO (Oven-Controlled Crystal Oscillator), whose thermal stabilisation maintains a constant reference frequency, thereby significantly reducing digital signal jitter. This temporal precision minimises synchronisation errors during conversion, thereby preserving the subtle nuances of the audio signal.
By stabilising the entire digital processing chain, this approach ensures consistent playback over time, a benefit that is particularly noticeable with complex signals or high-resolution recordings, where the accuracy of the clock directly determines the fidelity of the output.
SMSL D2R MK2: Bluetooth connectivity
The integration of a latest-generation Qualcomm Bluetooth chip expands wireless connectivity options, whilst maintaining compatibility with LDAC, aptX-HD, SBC and AAC codecs, thereby enabling the transmission to be adapted to the source quality and bandwidth constraints. This codec management enables optimised audio streaming depending on the connected devices, whilst maintaining consistent sound reproduction.
SMSL D2R MK2 : Bluetooth chip
SMSL D2R MK2 : Pinout I2S
Product typeDAC
Inputs1x USB-C
1x Optical Toslink
1x Coaxial
1x HDMI I2S
1x AES/EBU
Bluetooth 5.4
Outputs1x Stereo RCA
1x Stereo XLR
DAC chipROHM BD34302EKV
Supported sampling ratesPCM 32bit 768kHz
DSD512
Supported Bluetooth codecsSBC, AAC, aptX, aptX HD, LDAC
Line output levelXLR : 5Vrms
RCA : 2.5Vrms
Total harmonic distortion more noise (THD+N)XLR : 0.00013% (-117dB)
RCA : 0.00017% (-115dB)
Dynamic rangeXLR : 123dB
RCA : 122dB
Signal-to-noise ratio (SNR)XLR : 123dB
RCA : 122dB
USB transfer mode2.0 asynchronous
USB compatibilityWindows 7 / 8 / 8.1 / 10 / 11 : Driver required
Mac OSX 10.6+, Android, iOS, Linux : Driverless
Power supply100-240V AC
Consumption30W
Dimensions279.8 x 50.8 x 255.1mm
Weight3.25kg
Package1x SMSL D2R MK2
1x Power cable
1x Antenna
1x Remote control
InputAES/EBU
InputI2S via HDMI
DAC / ADC ChipROHM BD34302EKV
Max sampling rate768kHz
Max sampling rateDSD512
Max sampling rateMQA
Remote ControlYes
The SMSL D2R MK2 is a balanced DAC designed to handle the digital-to-analogue conversion of high-resolution audio streams, utilising a ROHM...
